Focal - JM Lab Owner's Thread - Page 246 - AVS Forum | Home Theater Discussions And Reviews
 150Likes
post #7351 of 7355 Old Yesterday, 01:42 AM
Francky's Avatar
Quoted: 45 Post(s)
Liked: 50
Originally Posted by Deckard71 View Post
Sidewalls are 4ft and 10ft respectively. I have the 948 placed exactly the same I had the 726
This evening I will try combinations of toe-in and tilt, this time tilting down, to put the tweeter (it is too high!!!) pointing more towards me
I've tried this with my 936s(they are taller than the 948) and it didnt work. It screwed up the sound in a very bad way. I do have them with a slight toe in. for the boomy bass if you can, try some bass traps.
Focal Aria 936, 807V, SVS PB2000, OPPO 103D, MRX 500, Simaudio Moon Neo 280D, BC Acoustique EX362.
Francky is offline
post #7352 of 7355 Old Yesterday, 04:30 AM
Deckard71's Avatar
Quoted: 23 Post(s)
Thanks for sharing, I am afraid tilting down will not work either. BTW the 948 are the same height as 936 (926 are shorter)
Not sure about bass traps. I tried a piece of foam behind and in the corner, and it sounded more muddled
I will keep experimenting. With the previous 726 I was able to tweak the bass, as I had connected to a subwoofer via High Level input, what allowed crossover setting, but with the 948 I have removed the subwoofer (now connected to the central to balance the more power fronts Inhave now, but that is a different story)
Deckard71 is online now
post #7353 of 7355 Old Yesterday, 03:25 PM
Deckard71's Avatar
Quoted: 23 Post(s)
Has anyone tried the 948 (or 936) without the plinth, directly on the floor? Does it reduce the bass or increase it?
I ask before trying myself, as it is not so easy for me to remove the plinths
post #7354 of 7355 Old Yesterday, 04:02 PM
torii's Avatar
Quoted: 1375 Post(s)
Liked: 712
check your port holes, i have read some have experienced the internal wadding/stuffing falling down/blocking holes somewhat. I havent experienced any of that. speakers may need to break in a bit, 40 hrs or so.
Deckard71 likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #7355 of 7355 Old Yesterday, 04:05 PM
torii's Avatar
Liked: 712
only other thing I might think of is a room peak resonance...would need something like rew and umik mic for that tho. or test cd and spl meter.
torii is offline
Reply Speakers
Focal , Focal 705v , Focal 706v Chorus Loudspeakers , Focal 716v Floor Standing Speakers , focal aria , focal aria 936 , Focal Chorus 726v Floorstanding Speaker Light Walnut , Focal Chorus 836 V , focal electra
