Focal - JM Lab Owner's Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 142Likes
post #181 of 7284 Old 11-21-2006, 10:30 AM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
Their sensitivity is 91.5db. Their Nominal impendence is 8ohms. It is just that they have that dip. You should be fine with leaving it in the 8ohm mode. The Halo is a very good amp. The specs look pretty beefy on it. If they were 4ohm's nominal then you would need to make some changes. But you should be fine with that amp.
It ain't easy being green.
My System
MIkeDuke is offline
post #182 of 7284 Old 11-21-2006, 09:38 PM
HJJ
HJJ's Avatar
Well surprisingly my special ordered XLR cables came in today. So I kind of did some scrambling to find an XLR to RCA adapter from a local guitar shop. They had the perfect adapter with the male RCA and femal XLR. So I was all excited to finally have a reason to open up my amp and get it connected to get a taste of what these speakers really can do. Luckily for me I decided to plug in my adapters into the back of the receiver before I completely unpackaged the amp and set it in my entertainment center. Because as I was afraid of after loocking at a diagram of the RCA connectors, the adapters where too wide to fit side by side.
So.... I can either buy some RCA cables. Look into a different sort of adapter. Or bite the bullet now and order the Parasound C2. Luckily I am single and have no dependents so the decision is all mine. Because I think based on the fact that I am wanting to get this C2 eventually anyway, I might as well get my system completed from the start.
Oh yeah, I had Saving Private Ryan on today and my receiver was cutting out ever minute or so at one point. It definitely was not volume related. I ended up just turning it off. So I guess certain movies and shows are off limits until I get my situation resolved.
HJJ is offline
post #183 of 7284 Old 11-22-2006, 05:34 AM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
"Or bite the bullet now and order the Parasound C2. Luckily I am single and have no dependents so the decision is all mine. Because I think based on the fact that I am wanting to get this C2 eventually anyway, I might as well get my system completed from the start."
That is what I am talking about. Do it now so you will not be wondering. As I said I have the C2 and it sounds fantastic. It is so much better then my Showcase was. Also, the menus are very easy to use. For me, music is important. The C2 has a bypass mode that you have to select from the menu. It is really good on music that way. But it is good for music all around.
My System
MIkeDuke is offline
post #184 of 7284 Old 11-22-2006, 04:06 PM
Esox50's Avatar
Quoted: 117 Post(s)
Liked: 99
Are there any reviews of the center channel in the Electra Be line?
Thinking about 5 1027Be's, but might have to go with 4 1027Be's and the center channel instead.
Esox50 is offline
post #185 of 7284 Old 11-22-2006, 10:03 PM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
I haven't seen any, but I am sure it is a good center. I have the 901 and it works and sounds great. But 4 1027's will be quite a setup.
My System
MIkeDuke is offline
post #186 of 7284 Old 11-23-2006, 02:42 AM
cpu8088's Avatar
the cc1000be is as smooth as baby's bottom. the unbelievable tweeter do smooth out the edges and integrate well with the mid and bass units. it can handle dynamics very well too.
what can you say!!!
suggest mike to trade 901 for this just as he traded up the 927be for the existing 1027be
cpu8088 - OLD and SLOW !!!
cpu8088 is offline
post #187 of 7284 Old 11-23-2006, 08:49 AM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
CPU, I probably will, just a bit down the line. I have money commited else where for a different upgrade.
My System
MIkeDuke is offline
post #188 of 7284 Old 11-24-2006, 10:11 AM
Vampyro's Avatar
I am loving my 826V's I get a nagging feeling they are underpriced, they just sound & look real purdy. Anybody see any reviews yet? I know they are brand spanking new but I eager to see what someone might say about these amazing speakers...IMHO they are perhaps one of the best looking speakers in ANY price class!
Vampyro is offline
post #189 of 7284 Old 11-24-2006, 02:45 PM
wgerman's Avatar
Quoted: 62 Post(s)
AudioArchitect,how do the new Chorus speakers stack up against Dynaudios? Compared with the Focus and Contour series.
You sell both lines,can you give us your opinion on pros and cons of each.
Vampryo, I too am surprised at the cost of these speakers. Focal makes their own drivers and cabinets like Dynaudio and do not contract out. Amazing.
wgerman is offline
post #190 of 7284 Old 11-24-2006, 03:07 PM
Vampyro's Avatar
I just picked up the CC800v center and I heard the $8000 JMlabs and must say the 826V can really hold themselves proud compared to their more expensive siblings...I am convinced that nothing under $3000 can't stack up to the 826V
Vampyro is offline
post #191 of 7284 Old 11-24-2006, 03:35 PM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
That is really great to hear Vampyro. I am glad that JM has quality stuff at all levels. And if they are like other JM's with better equipment they can sound even better. Make sure to keep us posted on how everything progresses.
My System
MIkeDuke is offline
post #192 of 7284 Old 11-24-2006, 04:06 PM
Hastley's Avatar
What do you guys think of this 5.1 by focal?
http://www.tweeter.com/sm-focal-sibs...i-2138378.html
Its on sale for 999.99 dollars for this thanksgiving weekend. I heard it and liked it but i am a novice so let me know what you think please.
Hastley is offline
post #193 of 7284 Old 11-24-2006, 04:18 PM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
Focal seems to be having a sale on the Profile Series
http://www.audioplusservices.com/frame.html
They look like good deals to me
Profile 908 : $2,295
Profile 918 : $3,995-$500
Profile 928 : $5,500-$800
Profile CC908 : $1,695-$200
Profile SW908 : $2,995-$200
My System
MIkeDuke is offline
post #194 of 7284 Old 11-24-2006, 04:55 PM
cpu8088's Avatar
hastley
get the sib and cub and join as owner of focal
cpu8088 is offline
post #195 of 7284 Old 11-24-2006, 08:09 PM
Vampyro's Avatar
I am sure it sounds alot bigger than it looks, ,you simply cant go wrong!
Vampyro is offline
post #196 of 7284 Old 11-24-2006, 08:25 PM
Hastley's Avatar
I like the sound in fact i listened to alot of polks and such, and they dont even compare but alot of people on another thread are giving me doubts
Hastley is offline
post #197 of 7284 Old 11-24-2006, 11:07 PM
cpu8088's Avatar
of course they will give you doubts because they never ever lived with focal speakers
and their hearing preferences are different
cpu8088 is offline
post #198 of 7284 Old 11-25-2006, 10:36 AM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
Hastley, don't doubt what you hear. Everyone else wont have to live with them, you will. If they sound good to you then there really is only one choice. Get them and join the Focal family.
My System
MIkeDuke is offline
post #199 of 7284 Old 11-25-2006, 05:41 PM
Esox50's Avatar
Quoted: 117 Post(s)
Liked: 99
Thanks for the comments on the Electra center channel.
Looking over Focal's lineup, I wonder if they're working on a 1017Be? Seems to be a gap there as compared to the other Focal lines.
Esox50 is offline
post #200 of 7284 Old 11-25-2006, 09:25 PM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
Esox50, true that the other lines seem to have a few more options. Even more towers. Time will tell if they bring out a 1017Be. If they did, I wonder what it would be like?
My System
MIkeDuke is offline
post #201 of 7284 Old 11-26-2006, 07:46 PM
Esox50's Avatar
Quoted: 117 Post(s)
Liked: 99
I could see the 1027Be getting a price increase to $7,998 (or even $8,498), and them releasing a 1017Be at around $5,998-6,498 (especially now that Paradigm just announced the Signature S6 with a Beryllium tweeter for $5,500).
What would it be like? Hmmm.
1-1" Pure Be IAL tweeter
1-6.5" W cone Midrange, 32mm voice coil (same as the Profile 918)
1-6.5" W cone Woofer, 40mm voice coil (same as the Profile 918)
FR: 42Hz-40,000kHz
And it would be maybe 2-3" shorter.
Just a thought, not saying it's going to happen. There just seems to be a gap there in the Electra range. I guess in that price range ($5,500) you got the Profile 928 but it does not have the Be tweeter (BTW, I haven't heard the 928 but it looks very stupendous in that new Diamond Black). The "gap" I speak of though is that every other line has a model that could be considered a "small tower", except the Electra Be line.
To be honest, I only thought of this because I'm not sure for a home theater that I need the bass extension of the 1027Be, since I'll most likely be installing two 15 subwoofers. Figured I could save a little dough with a 1017Be, if there were such a thing. I bet it would sell really well though, don't you guys think?
Esox50 is offline
post #202 of 7284 Old 11-27-2006, 05:32 AM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
I can tell you that they will most likely have a newer model above the 1027's. But a lower model might be interesting. And I agree about HT. I am into music as well so I really like having the low bass that the 1027's give me. Maybe they will show something new at CES this year. But it does seem like a good idea.
My System
MIkeDuke is offline
post #203 of 7284 Old 11-27-2006, 05:50 AM - Thread Starter
AudioArchitect's Avatar
FR: 42Hz-40,000kHz
Paradigm is probably using a substrate material and vapor depositing the Berrylium, hence the lower price point. Furthermore, Focal is 6 years ahead of anyone in Be tweeters and obviously has the inverted dome which no one else has.
As far as being a gap in the Electra product line, realistically the 1027 sells so well, from a manufacturing standpoint, a smaller floorstander wouldnt make sense. For many systems the 1007 with a sub just makes as much sense.
AudioArchitect is offline
post #204 of 7284 Old 11-27-2006, 01:31 PM
wgerman's Avatar
Quoted: 62 Post(s)
AudioArchitect, how do the Focal Chorus 816 and 826 V stack against Dynaudio products. Please give the pro and con since you sell both.
wgerman is offline
post #205 of 7284 Old 11-28-2006, 08:22 AM
HJJ
HJJ's Avatar
Well, I placed my order for the C2 last Wednesday so I should definitely have it today or tomorrow at the latest. I was wondering for your setup if you are utilizing the component video switching capability of the C2 or if you purchased that seperate HDMI switching unit that they sell seperately? That is one of the few disappointing things about the C2 is that it does not provide HDMI switching out of the box. But I understand the designs for it were created a few years ago when HDMI was not in widespread use at the time. I do anticipate the sonic quality of this unit to offset my HDMI disappointment.
One other thing I noticed about this unit is the lack of an FM tuner. This is obviously not a deal breaker but it would have been nice since I usually listen to morning radio before work. But normally for music I am listening to satellite radio through direct tv or CDs or DVDs. Do you use an FM tuner with your system? I am contemplating eventually adding a low cost FM tuner for this system but obviously it is not high on the priority list.
I am still anticipating what my new Focal 836V surround system will sound like after adding the C2. It is very hit and miss with the shutdowns of my Onkyo receiver. I purchased the new Gears of War Xbox game and played it through the system. The sound effects were amazing for the quick momement before my Onkyo shuts itself down. Pretty much anything in dolby digital will eventually shut it down. So hopefuly in a day or so I will be able to release my new speakers from their shackles.
HJJ is offline
post #206 of 7284 Old 11-28-2006, 08:37 AM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
I don't need HDMI right now. I only have my TV connected to my player through a DVI cable. I also don't listen the the radio on this system so the lack of a tuner is not an issue for me. Did you mention what amp you are getting? I am sure that once you have everything in place it will sound great. I noticed an immediate difference. Again, congrats and be prepared to have a kick butt setup. Of course I know you will keep us updated.
My System
MIkeDuke is offline
post #207 of 7284 Old 11-28-2006, 09:16 AM
HJJ
HJJ's Avatar
I have had the Parasound Halo A52 (125W x 5) amp for several weeks now but have been unable to use it due to my decision to go with XLR cables rather than RCAs. I was trying to go the the XLR to RCA adapter route but the connector configuration on the back of the Onkyo unit did not allow for enough space for the adapters.
I will initially go with the component switching as I still have some nice component cables. Honestly the video between component and DVI/HDMI is not that far apart. This whole HDMI thing really is all about copy protection. Although it would be great to eliminate the need for a seperate fiber or Coax digital audio cable.
HJJ is offline
post #208 of 7284 Old 11-28-2006, 09:22 AM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
With that amp you will have a very nice sounding setup. I am sure of it. Right now I only have a 34 in TV. The picture I can get with my player is simply fantastic. If I had a projector I might consider a high def player, but not with this TV. It looks really impressive as it is.
My System
MIkeDuke is offline
post #209 of 7284 Old 11-28-2006, 11:57 AM
Hastley's Avatar
Hi,
I am considering buying the 706 are these better than the focal sibs? I can get a pair of the 706s new for like 350/pair? Let me know
Hastley is offline
post #210 of 7284 Old 11-28-2006, 12:13 PM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
Hastely
It may depend on what sibs you are talking about. The floor standing models I think got at least one nice write up. The 706 is a fine monitor I am sure. If you are talking about the sib and not the sib xl or xxl, then I might say the 706 is the way to go. It looks like a very fine monitor speaker. So I would say yes, they are better then the sib.
My System
MIkeDuke is offline
Reply Speakers
Focal , Focal 705v , Focal 706v Chorus Loudspeakers , Focal 716v Floor Standing Speakers , focal aria , focal aria 936 , Focal Chorus 726v Floorstanding Speaker Light Walnut , Focal Chorus 836 V , focal electra
