Revel Owners Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 1118Likes
post #271 of 10043 Old 10-20-2007, 08:54 AM
jostenmeat's Avatar
Though I know nothing of speaker finishes or Revel speakers, you might consider automotive "swirl remover" products. People use it on fine musical instruments, even those finished with the ultra-delicate "french polish". (Something that "auto polish" would ruin). In any case, make sure whatever you use is ok!
jostenmeat is offline
post #272 of 10043 Old 10-20-2007, 09:04 AM
syswei's Avatar
Originally Posted by Rinkledorf View Post
A little off topic but, I was hoping that some of the Studio/Salon owners would chime in. I own a pair of the Studios and was wondering if there's a polish that you can use on the speakers that would remove swirls.
I suggest calling Revel tech support. If they don't have a specific suggestion, they can at least find out for you what type of finish it is (for instance, polyester) so you can find a compatible product.
syswei is offline
post #273 of 10043 Old 10-20-2007, 09:59 AM
syswei's Avatar
Found a picture of Alywn's setup that he posted here:
http://cgim.audiogon.com/i/vs/i/f/1192109585.jpg
Nice setup, Alywn!
syswei is offline
post #274 of 10043 Old 10-20-2007, 11:38 AM
howaboutthat41's Avatar
Liked: 24
Nice setup, Alywn!
Wow -- that system must push a lot of sound in that room!
howaboutthat41 is offline
post #275 of 10043 Old 10-20-2007, 12:30 PM
Rinkledorf's Avatar
Thanks for the suggestions guys. First off, the swirls are super fine. I don't think a camera would pick it up. And whatever I use (even Revel recommended) I'll try it on area not seen. Maybe behind a side panel. Sometimes the panels need to be removed so that the inside of the grill can be vacuumed.
Rinkledorf is offline
post #276 of 10043 Old 10-23-2007, 05:23 PM
Need4spdnb's Avatar
Those of you with a Performa setup, what amplifier are you using to drive them? I am looking at a F52, C52, and S30 setup. I have a Lexicon NT512 right now but I don't think it will be enough power. Any recommendations?
Theater design at Audio Video Interiors of Chicago, Inc.
Right across from the Oakbrook Center Mall.
Noah B.
Need4spdnb is offline
post #277 of 10043 Old 10-24-2007, 10:39 AM
ssteel01's Avatar
The Lexicon is what, 100-125 WPC? How big of a room is it, is it open to adjoining rooms, etc.?
Scott
ssteel01 is offline
post #278 of 10043 Old 10-24-2007, 11:59 AM
Need4spdnb's Avatar
Scott,
The lexicon is 125 x 5. My paradigm signatures used up the juice in this amp and made it go into protection mode. They are more efficient than the F52's are, so I definetly need a new amp.
Room is 19x17 with a 15ft vaulted ceiling. It opens into a kitchen which is probably 25x15 ft.
I was looking at something 200w per channel. Lots of good ones in that category, just don't want anything that is bright (ie Anthem amps).
Noah B.
post #279 of 10043 Old 10-24-2007, 12:24 PM
ssteel01's Avatar
Scott,
Yeah...that's a pretty substantial room. I probably should have asked your price range, but, just to throw out a couple 200WPC amps that I have some sort of direct experience with and wouldn't consider bright (across a pretty wide price range):
Sunfire (I liked the old Cinema Grand, but don't really have any experience with the new models)
B&K Ref 200
If you like the old Lex/Bryston and price is no object maybe consider a combo of a Bryston 4B and 6B. That would make for a pretty sick setup...
Sherbourn (this is what I use to drive F32's. Definitely the "budget" amp of this crowd)
Scott
ssteel01 is offline
post #280 of 10043 Old 10-24-2007, 12:31 PM
marklnj's Avatar
What is your budget?
I have the Performa F32/C32/M22 system. I am using a Cinepro 6.4 (aka Verastarr 6.4SE), 6 channels/400 wpc bridgable to 3 channels/800wpc, which I got for much less than half of msrp. The amp is simply dynamite--dynamic, detailed and musical.
I am a precision instrument of speed and aromatics.
My system
marklnj is offline
post #281 of 10043 Old 10-24-2007, 04:39 PM
RMK!'s Avatar
Quoted: 1697 Post(s)
Liked: 1626
I have a F52,C52 and F32 5.1 system and I'm using a 4 year old, cool running Sunfire Sig. 400/5. This amp can drive the Revels much louder than I need/want.
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #282 of 10043 Old 10-24-2007, 07:32 PM
Zoubs's Avatar
I have been temporarily using the same amp to drive my ultimas (salons, voice, embrace)
Very surprising the capabilities of this amp. The amp pushes the salons at full levels effortlessly, no matter how demanding the sound track.
Zoubs is offline
post #283 of 10043 Old 10-24-2007, 07:54 PM
Need4spdnb's Avatar
I would say under 5k new or used. I am not opposed to Audiogon. I was thinking along the lines of a Theta Dreadnaught II, Krell HTS, etc. I can get a good deal on an Anthem P5, I would have to see what that would sound like because I have an Anthem D2 pre right now and it is slightly bright. I know their amps are also semi bright. Maybe the Parasound Halo A51. Any other thoughts?
Noah B.
post #284 of 10043 Old 10-25-2007, 07:16 AM
marklnj's Avatar
You can't go wrong with any of the amps you mentioned and I see that they have some really good deals on A-gon. I'd also consider the Halco MC50 for its detail and neutrality, I like the Theta warmth, similar to my 6.4... but I chose the Cinepro b/c of the power reserves and the extra channel.
The Verastarr is definitely not bright, it probably leans to the darker side of neutral, if at all, in my system.
My system
marklnj is offline
post #285 of 10043 Old 10-25-2007, 02:04 PM
alwynwilliams's Avatar
Both the Salons and my Ayre amps MX-R are now fully run in,and they are sounding wonderful.I have just listened to a new sacd recording with the above listed artists playing Mozart concertone for two violins and orchestra in Eflat,K,364 And it was just as if I was at the concert hall listening to the music being played to me live,absolutley superb.These speakers must rank amongst the worlds best.The thing that strikes me is the power that this combo of amps/speakers can give without being a strain on the listener,many times in the past with other speakers,I have reduced the volume because it hurt my ears,but with these I can turn the music up to its full soundstage image and have no problems.I would just add a comment regarding the Ayre amps,they give sound that is both delicate and yet precise their musicality is breath taking,and their power astonishing.
alwynwilliams is offline
post #286 of 10043 Old 10-25-2007, 02:08 PM
Nice setup, Alywn!
Thank you for showing my system,and your kind remarks
alwyn
post #287 of 10043 Old 10-25-2007, 03:13 PM
Rinkledorf's Avatar
Alwyn, I had a question about your Ayre's. Are they the ones that are milled out of a solid piece of aluminum? If so, I heard a pair of these about 3 mo. ago. Beautiful sounding amps, and for their smallish size over 50 lbs apeice. Fantastic setup BTW.
post #288 of 10043 Old 10-25-2007, 03:41 PM
Yes they are the ones that you heard MX-R.
post #289 of 10043 Old 10-25-2007, 04:43 PM
syswei's Avatar
Alwyn,
What are the dimensions of your room, and how far do you sit from the speakers? Sounds like you are listening at live-concert volumes?
Glad you are enjoying your system!
If I get Ultima2s, it is likely to be the Studio2, partly because of cost, partly because of efficiency (3dB better), and partly because the drivers are a match for the Voice2 (I am still concerned that the Voice2 is relatively overpriced, though).
syswei is offline
post #290 of 10043 Old 10-26-2007, 02:31 AM
Alwyn,
The room is 20ft x12ft.I sit eight feet away from the speakers and they are spaced six feet between them,each speaker has two feet space from both rear and side walls.I use an out of phase recording to get max stereo effect from them,towing in inch by inch untill I get an all arround the room sound,this results in very precise stereo.
post #291 of 10043 Old 10-29-2007, 04:06 PM
TrebleVsBass's Avatar
Hello everyone,
1)How good is the f32 over the m22? Would you notice the difference with a subwoofer?
2)is it better to get a f32 and get a cheaper subwoofer(~$500)? or use m22 with more expensive subwoofer(~$1500)? assuming both combinations cost the same.
3) Can you guys recommend me a subwoofer to go with m22s? (budget around $1500) How does the revel b15a stack up against the subwoofers talked about frequently on the forums? (like svs 13 ultra, epik tower, hsu vtf3 etc..)
The living room is 19*12 but open to kitchen and dining area on half of one of the long sides. Kitchen and dining area together would add more or less the same area to the living room. The speakers face the other long side with one speaker's back facing the wall and the other one's back facing the high kitchen counter wall. , so the listening distance to the speakers is around 9 feet along the shorter sides.
Thank you.
TrebleVsBass is offline
post #292 of 10043 Old 10-29-2007, 10:08 PM
rich wu's Avatar
alwyn,
I am considering replacing my Revel Studio with either the Salon 2 or Studio2. I would prefer the Salon but I am concerned that my room (25 x 16 ) may be too small for the Salon. How is the bass response in your room?
Also, how well does the old Voice match with the Salon2? I have the Voice and two pairs of Embraces in my system.
Rich
rich wu is offline
post #293 of 10043 Old 10-29-2007, 11:40 PM
hifisponge's Avatar
Originally Posted by TrebleVsBass View Post
Hello everyone,
Thank you.
You will only really benefit from the F32 + sub over the M22 + sub if a)you really like to crank action flicks to reference levels; b)play music at live rock concert levels; c)if you have a relatively large room; or d)you want the option to listen to music in stereo with out a sub at times. It all comes down to this: the extra bass drivers and larger cabinet of the F32 results in two primary advantages over a bookshelf--more extended bass and the ability to play louder.
I run floorstanding speakers with a sub because I want the high-output capability for movies, and I find that even with music, the added drivers in the floorstander provide an effortless quality at medium to high volumes.
With that said, you really don't want to pair a cheap sub with a speaker the caliber of the F32. Cheap subs tend to be boomy and/or peaky and have high distortion levels which will muddy up the sound of the F32's.
Oh, and the Revel sub is great, though as with many high-end speakers you are paying for the nicer cabinet quality of the sub and you could probably get similar performance from a more value oriented brand like SVS and HSU. They just won't look as nice or match your main speakers, if that is important to you.
hifisponge is offline
post #294 of 10043 Old 10-30-2007, 06:44 AM
ssteel01's Avatar
I'd second that, but with a qualifier. If you're only using the sub for HT and NOT music, I think you can get away with a cheaper sub w/ the F32's. I defintely prefer to run them full range for music, but they go low enough that a sub is not needed for the stuff I generally listen to. If you're going with the M22's, I'd consider a higher quality/more musical sub than the big box du jour of the sub forum.
Just my 2c.
Scott
ssteel01 is offline
post #295 of 10043 Old 10-30-2007, 11:37 AM
Originally Posted by rich wu View Post
alwyn,
Rich
iN MY OPINION,YOU WILL NOT HAVE ANY PROBLEMS USING THE SALON2 IN YOUR ROOM,THE BASS IS STRONG BUT WELL CONTROLED,I USED A REVEL Q400 WITH MY PREVIOUS F52 BUT WITH THE SALONS THE SUB IS REDUNDENT.
AS FOR THE VOICE1 IT BLENDS IN WITH THE SALON2 NO PROBLEM,I WOULD ADD,THAT I NEVER USE SURROUND SOUND FOR MUSIC,ONLY THE TWO FRONT SPEAKERS,SO MY CENTRE SPEAKER IS ONLY EVER USED FOR A/V AND WITH THAT I FIND IT FIRST CLASS.
alwyn
post #296 of 10043 Old 10-31-2007, 11:59 AM
Has anyone seen a revue of the new Salon 2 yet,I would have thought that after five months of the Salon being available in the US that at least one Mag. would have revued them
post #297 of 10043 Old 10-31-2007, 02:47 PM
hifisponge's Avatar
This is the only Ultima2 review I have seen so far--it's for the Studio2 model.
http://ultimateavmag.com/speakersystems/1007rev/
post #298 of 10043 Old 11-01-2007, 03:32 AM
Thanks for that,the revue amazes me in suggesting that the speaker should be used with a sub operating below 80hz for two channel music,does this guy know what he is talking about,to me the speaker should be allowed its full range for music.I realize that he is using the Studio and that my experience is with the Salon,but even so I can see no justifercation in stifling the natural range of such a qaulity speaker when listening to music,with any sub.
post #299 of 10043 Old 11-01-2007, 10:14 AM
Kal Rubinson's Avatar
Quoted: 771 Post(s)
Liked: 542
I don't know about 80Hz but, frankly, 2 speaker stereo is subject to the complication that the best site for wide-range imaging is rarely the best site for bass accuracy and linearity, even with the best of full-range speakers. (It can be but compromise is usually involved.)
Adding the sub permits greater optimization.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #300 of 10043 Old 11-01-2007, 10:45 AM
hifisponge's Avatar
I completely agree, and if you have a sub like the Velodyne DD (or the SMS-1 connected to any quality sub), the issues with proper integration between sub and mains pretty much goes away.
Speaking of, I own a Velodyne DD15, and I recently changed to new tower L/R speakers (coming from stand-mounts). When I first set them up, I ran the L/R's full range, they sounded nice and tight in the upper-bass, but a little boomy down low. When I switched in the sub, I noticed that the punch that was present in the L/R's playing full-range was now missing. So I hooked up the mic to the DD15 and ran the frequency sweep. Based on the readout of the FR, it was clear that there was cancelation happening in the cross-over region. I flipped the polarity on the sub and checked the FR readout again. The large dip at the crossover point had diminished but not completely. So next I inverted the phase and what do ya know . . . there was now a perfect blend between the mains and the sub. To get rid of the "boom" at the bottom, I notched out an 8dB peak at 30Hz caused by the room using the parametric EQ built into the sub. The end result: all of the punch and clarity of running the L/R's full-range, added LF extension and none of the room boom.
Reply Speakers
Revel
