Revel Owners Thread - Page 274 - AVS Forum | Home Theater Discussions And Reviews
 1155Likes
post #8191 of 10152 Old 04-25-2016, 06:16 PM
Quoted: 720 Post(s)
Liked: 380
Originally Posted by John Schuermann View Post
See my response directly above ^^^
Indeed, I am quite happy with my salons. I was just curious about Gooddocs statement of "having right tools for the job" and what it refers to.
Btw, I would definitely like to spend some quality time in room on that picture.
John Schuermann likes this.
donktard is offline
post #8192 of 10152 Old 04-26-2016, 03:22 AM
steady teddy's Avatar
Quoted: 112 Post(s)
Liked: 53
Originally Posted by triumph66 View Post
Are there any deals to be had out there on the F208's or is the $5K MSRP kind of set in stone?
I don't think pricing discussions are allowed but no, the MSRP is not set in stone. I didn't pay MSRP for my F208's.
steady teddy is offline
post #8193 of 10152 Old 04-26-2016, 04:32 AM
triumph66's Avatar
Quoted: 31 Post(s)
My bad. I haven't shopped for speakers for years and was unaware of the no price discussion. I'll scan the forum rules.
Thanks for the reply though and the heads up on your experience.
triumph66 is offline
post #8194 of 10152 Old 04-26-2016, 06:57 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1285 Post(s)
Liked: 1347
Yeah, the AVS forum rules are pretty much no price discussion anywhere on the board, except in places like the "great found deals" forum. Just as a hint, you're less likely to find good discounts at your local dealer as opposed to looking elsewhere (try contacting some of the dealers who post in the forums and carry the line you're interested in).
gsr is offline
post #8195 of 10152 Old 04-26-2016, 07:34 AM
Gooddoc's Avatar
Quoted: 3109 Post(s)
Liked: 2413
It refers to choosing a speaker that is designed to handle the task you want it to perform .
As to the Salon 2's, I am basing my opinions off the Stereophile measurements that clearly show compression starting at 95 dB sweeps. Based on that, I wouldn't recommend the Salon2's for a reference level HT application. Not the right tool for that job IMO.
Maybe those measurements aren't valid, underpowered amp, etc.? Don't know. But Stereophile seems like there measurements are well done.
Gooddoc is offline
post #8196 of 10152 Old 04-26-2016, 08:47 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1347
I like to listen to music and movies really loud at times. My 6 x Salon 2's and Voice 2 are capable of playing content FAR louder than I'm comfortable listening in my room (approx 16'x26' with a 14' vaulted ceiling) regardless of whether the content is music or movies before they show any signs of running out of steam. I'm pretty sure I would seriously damage my hearing before running into any limits with these speakers.
Rather than just looking at measurements, I'd suggest listening to any of these speakers before jumping to any conclusions. Unless you need to fill a huge auditorium or concert hall, I doubt many people are going to run into any limits of this sort with the Salon 2's.
I'm using a pair of ATI AT6007 7 channel amps to drive the speakers (currently biamping the front 3, the other 4 will be biamped later when I get around to upgrading the speaker cabling to handle that).
gsr is offline
post #8197 of 10152 Old 04-26-2016, 09:00 AM
Gooddoc's Avatar
Liked: 2413
Dynamic compression is insidious and typically not noticed until it is fairly extreme. Usually, it is noticed when it's removed.
My ears are not golden and I depend on measurements to keep them honest. That's why I look at measurements then I listen, not the other way around. There are some qualities of speakers we haven't figured out how to correlate with measurements, so listening to speakers is not unnecessary. But those we can correlate directly to accuracy or distortion can't just be conveniently ignored.
Gooddoc is offline
post #8198 of 10152 Old 04-26-2016, 11:42 AM
Quoted: 720 Post(s)
Liked: 380
Okay, I am a bit confused now. Compression is narrowing of dynamic range of an audio content. Clipping is inability of device (usually amp) to deliver content at requested level, therefore effectively chopping off waveforms and causing distortion.
So when you say compression kicks in, and I think you are referring to picture where curve shows difference from 70dB at 95dB, what am I looking at? Inability of tweeter to deliver louder sound regardless of capability of amp? Some protection kicking in in speaker circuit which causes soft clipping and effectively prevents damage? Or is it just amp clipping?
I suppose also its impossible or very inaccurate to try similar measurement in a common living room. I got quite a mighty amp so that part wouldn't be a problem.
donktard is offline
post #8199 of 10152 Old 04-26-2016, 11:49 AM
Quoted: 720 Post(s)
Liked: 380
True. Although reference levels are probably nice I often just neglect them and turn it up until dialogue is comfortably very loud and everything else just sits in place nicely. As for music, my reference is usually: "make that snare drum be in the room", but that's basically the limit and shouldn't be practiced for too long periods of time.
donktard is offline
post #8200 of 10152 Old 04-26-2016, 12:00 PM
Gooddoc's Avatar
Liked: 2413
Yes, what I was referring to is the dip in response that shows one of the drivers cannot keep up in that frequency range. The 70dB to 90dB is what no compression looks like. Something like that could be amp related too from a significant ohm dip, but given the amps used I think that's probably not the case. But I really don't know for sure.
Gooddoc is offline
post #8201 of 10152 Old 04-26-2016, 12:05 PM
Quoted: 720 Post(s)
Liked: 380
Yeah, interesting. I am still kinda living with assumption that woofers will struggle first because of weakness of amp.
donktard is offline
post #8202 of 10152 Old 04-28-2016, 10:54 AM
Quoted: 16 Post(s)
Liked: 3
New Revel Owner
Hi all,
Long time lurker and new owner of a pair of Revel Performa3 M106! Just finished installing them in the main room of my condo. They sound great whether TV/Movies or Music and I'm extremely satisfied overall. Powering them with an Anthem MRX-310.
cavallino is offline
post #8203 of 10152 Old 04-28-2016, 11:40 AM
Egan's Avatar
Quoted: 336 Post(s)
Liked: 282
Do you know of any dealers here who carry Revel? I'm in the market for 208's also. Thanks.
Egan is offline
post #8204 of 10152 Old 04-28-2016, 04:06 PM
Warlan's Avatar
Quoted: 60 Post(s)
Originally Posted by SyntheticShrimp View Post
That's a pretty big room. I'd be looking at the F208.
My room is 13.5x18x8
For that size room, if you like it loud, also consider the JBL pro LSR708is. The new master reference monitors are the only high output speakers worth comparing to the Revels IMO.
Looking at your measurements many pages back where you compared the whole range, I don't see the benefit for going with f208 when the m105 plus sub would be just as good, especially for HT. Why the necessity for f208 in a larger room? Can the m105 not play as loud as the f208 in the 80hz plus range?
I can understand if it was 2 channel.
Also, why did you not go with the.c208 and instead went with m105 for center?
Warlan is offline
post #8205 of 10152 Old 04-28-2016, 05:18 PM
SyntheticShrimp's Avatar
Quoted: 241 Post(s)
Liked: 210
The f208's mid driver doesn't have to play as low as the m105's mid-woofer (its crossed over at 270Hz). They can trade extension for efficiency in the driver design. The F208 both has higher power handling and is usefully more sensitive as a result.
I'm sure the c208 is a good speaker, but I have an acoustically transparent screen and exercise the option to take identical LCRs when I can.
SyntheticShrimp is offline
post #8206 of 10152 Old 04-28-2016, 05:45 PM
Warlan's Avatar
Quoted: 60 Post(s)
Ahh that makes sense. The f206 should perform fairly similarly to an f208 for HT if sending lfe at 60 or 80 hz, right? Their crossover is 270 vs 275.
Would a single m105 as a center channel work well with either of the floorstanders or is the c208 hands down better?
Warlan is offline
post #8207 of 10152 Old 04-28-2016, 06:05 PM
Quoted: 720 Post(s)
Liked: 380
C208 has much better sensitivity and can handle much more juice then M105 and I am fairly certain you want a mighty center channel since it handles most of movie audio anyway.
donktard is offline
post #8208 of 10152 Old 04-28-2016, 06:59 PM
Quoted: 241 Post(s)
Liked: 210
As the other poster said, If you're going for floorstanders for the extra output, you'll want the c208 for the output too.
post #8209 of 10152 Old 04-28-2016, 07:02 PM
torii's Avatar
Quoted: 1536 Post(s)
Liked: 837
i thought this thru with the focal brand. the smaller models sounded fine...until I cranked up the volume and decided the bigger model was for me. the big thing to be careful of is usually the tweeter in any brand/model....they blow the easiest or distort first.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #8210 of 10152 Old 04-29-2016, 06:35 AM
Quoted: 235 Post(s)
Liked: 85
Originally Posted by beear View Post
I agree! I auditioned a wide variety of speakers including B&W, ML, Sonus Faber, Golden Ear, PSB, among others. Once I heard the Revels, I knew I needed to get them. I ended up with the F208's over the F206's.
How are the F208s for you? I've heard they need a lot of power to play wide open. What has been your experience?
Legacy Audio Silhouette Pro L/C/R
DefTech ProCinema 1000 SL/SR
DefTech Supercube III
Denon AVR790
Oppo PM-3
GIK bass traps and absorption
sunPin is offline
post #8211 of 10152 Old 04-29-2016, 06:52 AM
Oppo Beta Group
RichB's Avatar
Quoted: 1272 Post(s)
Liked: 873
My brother-in-law bought the F206's and we heard them with a NAD integrated amp (150 watts) and they needed more to be driven hard.
He had Outlaw M2200 mono-blocks and they sound good a modest level but got harsh when driven into the high 80 DB range.
He upgraded to a Parasound A21 and they really rock.
I recommend a solid amp for spirited listening.
- Rich
sunPin likes this.
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is online now
post #8212 of 10152 Old 04-29-2016, 06:59 AM
Esox50's Avatar
Quoted: 117 Post(s)
Liked: 99
Originally Posted by cavallino View Post
Hi all,
Nice install. What mounts are you using?
Esox50 is offline
post #8213 of 10152 Old 04-29-2016, 10:51 AM
jima4a's Avatar
Quoted: 298 Post(s)
Liked: 155
Where are you located?
jima4a is online now
post #8214 of 10152 Old 04-30-2016, 06:39 AM
Quoted: 16 Post(s)
Liked: 3
Hi all,
They're Pinpoint AM-41. I enlarged the hole at the rear of the mount plate and used a 1/4-20 3/4" coarse thread bolt to secure the speakers using the existing mount holes in the rear of the cabinets. The mounts also grip the sides of the cabinet and include adhesive-backed foam strips to prevent scratches.
post #8215 of 10152 Old 05-02-2016, 11:11 AM
Quoted: 16 Post(s)
Liked: 3
clarification
I couldn't find an "edit" button (maybe my post count is too low?), anyway - to clarify, I used the rear-most hole in the bottom of the cabinets, and the adhesive-backed foam strips attach to the mount, not to the cabinets.
post #8216 of 10152 Old 05-06-2016, 05:28 PM
shelly40's Avatar
Quoted: 156 Post(s)
Liked: 53
Well.... I finally will be joining the Revel club......
Will have a nice new pair of Salon 2 (Mahogany) in my room in 10 days.......
The waiting is the hard part......
Power will be from a Mcintosh MC452.... so hopefully, no problems there.....
Other speakers I listened to....
Focal 1038 be
Revel Studio 2
B&W 803 D3
B&W 802 D3
Dynaudio C2
Dynaudio C4
TAD Evolution 1
Monitor Audio PL300 II
Magico S3
Martin Logan Renaissance ESL 15A
The Revels may have had an unfair advantage, as my dealer is accepting a pair of speakers as trade in, and giving full value for them....
So my out of pocket cost is about 10k for the new pair......
With that kind of price advantage, it was a no brainer.....
2nd place would be the Evolution 1, which is a tremendous speaker..... but from a different dealer, so would have been a good amount more $$$... wouldn't have gotten the same trade in value.... and they are a more expensive speaker....
Any tips for when they arrive ?
Shelly
shelly40 is offline
post #8217 of 10152 Old 05-06-2016, 05:47 PM
Quoted: 720 Post(s)
Liked: 380
Make sure to set up boundary gain accordingly so you don't have bloated bass if they are too close to the wall(s).
And make sure you don't handle them alone.
donktard is offline
post #8218 of 10152 Old 05-06-2016, 05:57 PM
shelly40's Avatar
Quoted: 156 Post(s)
Liked: 53
I know about the adjustments on the back.....
They are being delivered, unboxed, and put in position.........so I am good there....
This is for a system where music is the higher priority....
But of course, the occasional movie will be watched.....
It is a big room.... 16 x 35 feet.....with 9 1/2 foot ceilings......
Also have 2 JL F112 subs....what do people use for a crossover freq....
I am thinking at first to try about 50hz... I can also adjust the slope of the crossover
at 6, 12 18 or 24 db.....
Lots of experimenting to do, and see what sounds best to me...
Shelly
shelly40 is offline
post #8219 of 10152 Old 05-07-2016, 01:36 AM
GRfire's Avatar
Liked: 2
Shelly, you're gonna love the Salon 2's. I purchased a pair last year. The funny part is it seems we went through the same journey. I demo'd speakers for months. I also started with an MC452. I'll spare you the details other than to say the Salon's will swallow every bit of power you send them. They are now comfortably enjoying an MC1.2 each - happily.
Keep us up to date!!
Sent from my Dumb Phone, please pardon any spelling errors - my phone is not very smart.
GRfire is offline
post #8220 of 10152 Old 05-07-2016, 09:51 AM
bennyjammin's Avatar
Looking at the associated equipment in the soundstage review, the most powerful amp they used was a 200W/channel Classe integrated amp, and the three others used were in the 150W range. I wouldn't draw any conclusions in that resonse curve given they shortchanged the Salon 2s in power.
bennyjammin is offline
Reply Speakers
Revel
