Revel Owners Thread - Page 315 - AVS Forum | Home Theater Discussions And Reviews
 814Likes
post #9421 of 9434 Old 02-22-2017, 08:48 PM
Quoted: 42 Post(s)
Liked: 30
Yep, my first Bryston was a 4B NRB and it was a great amp for the price, giant killer as they say. I'm pretty sure between my personal amps and ones I bought for work at my job, I had every version through SST2. I balked at the pricing on those, but love the sound, the build quality, the 20 year warranty so I stayed brand loyal. When I saw the Cubed series pricing I was glad I got an SST2 for a good price.
Bryston amps may still be good deals compared to Mark Levinson prices. I'd have to A/B them to see if I can hear the difference. Is a ML amp worth twice the price of a Bryston 4B3?
Rex Anderson is offline
post #9422 of 9434 Old 02-22-2017, 10:30 PM
Milt99's Avatar
Quoted: 239 Post(s)
Liked: 247
Originally Posted by rsg_1 View Post
Basically, anything with a switching mode power supply and some sort of pulse width modulation is referred to as "digital" amplifier as it is over 90% efficient in operation. If you have feedback mechanisms to regulate the input pulse width modulation you can get some excellent performance. The downside is noise from switch mode power supplies, but newer designs put it over 20 KHz. The new Emotiva XPA Gen3 amps are Class H because of the improved switched power supply. With these switched power supplies, you get higher efficiency and less of the energy is lost as heat. A Class A amplifier will faithfully amplify the input signal as its transistor is always on. They are heavy because of the massive torroidal power supplies and heat sinks as they are always on. Mark Levinson Class A amps are a beast for good reason. It is a no compromise design as power, weight and price are not constraints in the design. Tube amps are often Class A in design, but they don't generate as much power, but the harmonics generated are wonderful if you are playing an electric guitar. I wouldn't use them for audio because they aren't a faithful reproduction of the recording. Opinions of course would vary.
Just to put a fine point on it, a Class D amp can have a linear power supply and many do like the AT5xNC series.
The main feature of a Class A amp is that each bank of transistors processes the entire sine wave. They don't really have to have a massive transformer but it good design as the transistors are always "on" and much of the power is lost via heat. In class A/B only half of the transistors are on at any one time. A/B can still have massive power supplies
rsg_1 likes this.
It ain't ignorance causes so much trouble; it's folks knowing so much that ain't so
Milt99 is offline
post #9423 of 9434 Old 02-22-2017, 10:56 PM
rsg_1's Avatar
Quoted: 25 Post(s)
Bryston is certainly a good amp, but prices have gone up. Though some people have complained it is bright, but I've never heard that when used with Revel speakers. ML amps are way over designed and sometimes you can get good deals on used and B-stock. Whenever there are Revel demos of the Ultima Salons or Studios, they use ML amps as these speakers are power hungry and the ML amps don't hesitate. You may want to look at Classe amps too.
rsg_1 is offline
post #9424 of 9434 Old Yesterday, 07:33 AM
Oppo Beta Group
RichB's Avatar
Quoted: 881 Post(s)
Liked: 577
Originally Posted by Milt99 View Post
So far this is my plan to drive my Studio2s.
AT542NC.
Try a simple bi-amp configuration with one speaker (single blind test, if possible). Stacking banana connectors make this very easy.
That may help you decide how many channels to buy
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
post #9425 of 9434 Old Yesterday, 08:07 AM
Milt99's Avatar
Quoted: 239 Post(s)
Liked: 247
- Rich
Yeah Rich, but 500 wpc seems pretty ample, no?
I do have a pair of Emotiva XPA-1L monoblocks that I have been using.
The gain difference between the Emos and the ATI is 1db.
Does that render bi-amping using these different amps moot?
Milt99 is offline
post #9426 of 9434 Old Yesterday, 08:35 AM
Oppo Beta Group
RichB's Avatar
Quoted: 881 Post(s)
Liked: 577
Only if you believe this is about power.
However, I have observered, SBT, and demonstated bi-amped improvements at relatively low levels (80 DB range) using the Salon1's, Salon2's, and Studio2's. There were differences in bass response but most of the improvement was in mid-range and high-end clarity.
I have heard improvements with using Parasound A21 and ATI AT6000 amps bi-amped.
In a very-quick test of the Benchmark AHB1, I heard no upper-end benefit bi-amped and preferred this amp bridged driving the Salon2's. Every review I have read about the AHB1 with the Salon2's recommends bridged for bass-response.
- Rich
bigguyca likes this.
RichB is online now
post #9427 of 9434 Old Yesterday, 09:31 AM
Milt99's Avatar
Quoted: 239 Post(s)
Liked: 247
- Rich
I believe it is about power and frequency response.
I'll probably catch a ton of flack but in my experience adding a more powerful\capable amp is not only about SPL.
I've noticed improvements in detail and consistency across the frequency range when playing at lower SPL levels.
I didn't have to compensate for thin, recessed sound by using volume to pump everything up.
I'm hoping that by adding the ATI I will hear better sound & control from the mid-mid range down but hoping that bi-amping would improve from that point up.
Milt99 is offline
post #9428 of 9434 Old Yesterday, 09:51 AM
bigguyca's Avatar
Quoted: 304 Post(s)
Liked: 209
Switching and digital are not the same thing
(1) Basically, anything with a switching mode power supply and some sort of pulse width modulation is referred to as "digital" amplifier as it is over 90% efficient in operation. If you have feedback mechanisms to regulate the input pulse width modulation you can get some excellent performance. The downside is noise from switch mode power supplies, but newer designs put it over 20 KHz. (2)The new Emotiva XPA Gen3 amps are Class H because of the improved switched power supply. With these switched power supplies, you get higher efficiency and less of the energy is lost as heat. A Class A amplifier will faithfully amplify the input signal as its transistor is always on. They are heavy because of the massive torroidal power supplies and heat sinks as they are always on. Mark Levinson Class A amps are a beast for good reason. It is a no compromise design as power, weight and price are not constraints in the design. Tube amps are often Class A in design, but they don't generate as much power, but the harmonics generated are wonderful if you are playing an electric guitar. I wouldn't use them for audio because they aren't a faithful reproduction of the recording. Opinions of course would vary.
(1) First here is a definition of digital from Google:
Digital: (of signals or data) expressed as series of the digits 0 and 1, typically represented by values of a physical quantity such as voltage or magnetic polarization.
You are confusing switching with digital. They are two different concepts. You are also arbitrarily linking types of power supplies with output sections.
Here is a link to the Wikipedia entry on class-D amplifiers. Note the section on Terminology:
https://en.wikipedia.org/wiki/Class-D_amplifier
While a class-D amplifier is more efficient than a Class A/B amplifier the 90% efficiency measurement is at, or close to, full output which is not typical of use in the home. At typical outputs of a few watts the efficiency is much less than 90%, but still far better than a class A/B.
(2) The new Emotiva Gen 3 amplifier is a class-H amplifier. The output section of each amplifier module switches between two voltage rails depending on the load. Switching rails is why Emotiva has labeled the design as Class H, not the switching power supply. The Gen 3 uses a switched power supply which supplies these two different voltage rails. The previous generation of Emotiva amplifiers was also class-H, but used a linear power supply to provide these two rail voltages. The Emotiva units are called class-H due to the switching between two power supply rails. The nature of the power supply that provides these two power supplies is an independent question. Digital doesn't enter in to any of this. The output stage is not driven or controlled by binary numbers.
rsg_1 likes this.
bigguyca is offline
post #9429 of 9434 Old Yesterday, 10:45 AM
rsg_1's Avatar
Quoted: 25 Post(s)
^^^Thanks.
So my confusion comes from the fact that digital amplifiers are Class D, but - "While some class-D amps may indeed be controlled by digital circuits or include digital signal processing devices, the power stage deals with voltage and current as a function of non-quantized time. The smallest amount of noise, timing uncertainty, voltage ripple or any other non-ideality immediately results in an irreversible change of the output signal. The same errors in a digital system will only lead to incorrect results when they become so large that a signal representing a digit is distorted beyond recognition. Up to that point, non-idealities have no impact on the transmitted signal. Generally, digital signals are quantized in both amplitude and wavelength, while analog signals are quantized in one (e.g. PWM) or (usually) neither quantity."
Could you suggest what are true digital amplifiers that are quantized in amplitude and wavelength? I'm not aware of any that are common for driving speakers like the Revel. I do know that some powered speakers do have a digital amplifier. Or at least advertised as such.
rsg_1 is offline
post #9430 of 9434 Old Yesterday, 06:36 PM
frenchmr's Avatar
Concerta2
I'm in the middle of trying to figure out what speakers to go with for my upgrade. I have B&W speakers currently and was going to go with their CM series line, but they felt too bright for my main purpose of watching movies. After trying out a couple of other brands, I listened to the Revel Concerta2 M16 speakers and really liked them.
The problem is the audio shop didn't have the CM25 center channel to listen to, so the question is should I go ahead and place an order for the M16 pair and a CM25 center without having listened to the CM25 yet? Will the CM25 sound be similar enough to the M16 that it should provide a very similar sound experience?
Thanks for the help!
frenchmr is offline
post #9431 of 9434 Old Yesterday, 07:16 PM
Quoted: 655 Post(s)
Liked: 328
I can tell you the M16s are excellent; bought them last month for rear surrounds for my Revel F206s at our 2nd residence ; running them now as fronts at main residence breaking them in
yanks1 is online now
post #9432 of 9434 Old Yesterday, 08:27 PM
danthony1's Avatar
Quoted: 118 Post(s)
Liked: 40
Since you like the M16 theres no risk. The speakers are a match.
I purchased my m106 first then bought my f206 and c205 without testing. Mo regrets at all.
danthony1 is online now
post #9433 of 9434 Old Yesterday, 08:46 PM
frenchmr's Avatar
Thanks, guys! Since I'm using the speakers for purely watching movies, I really like the full sound of the M16. My budget was $3,000 for this upgrade, and the M16's and CM25 will be about half the price, but they just had the best sound for my ears.
danthony1 and yanks1 like this.
frenchmr is offline
post #9434 of 9434 Old Today, 05:07 PM
danthony1's Avatar
Quoted: 118 Post(s)
Liked: 40
Then you did well. When I bought my f206, i was prepared to get the 208's so i hear you on that. Same for me, wasn't budget I just felt they were too big for the room.
Reply Speakers
Revel
