Revel Owners Thread - Page 340 - AVS Forum | Home Theater Discussions And Reviews
 1173Likes
post #10171 of 10176 Old Yesterday, 12:39 PM
laserjock II's Avatar
Quoted: 778 Post(s)
Liked: 442
@jeffreybehr did you pull your speaker apart for the crossover pic or is that a stock photo?
laserjock II is offline
post #10172 of 10176 Old Yesterday, 02:04 PM
jeffreybehr's Avatar
Quoted: 18 Post(s)
Originally Posted by bigguyca View Post
Do you have a schematic for the crossover? Do you have the specs for the parts? If you don't know where in the circuit the parts are used it's hard to make good judgments on if they are appropriate for their job.
This afternoon I do. .. .. A very good friend is my speaker-crossover-schematic genius. I'll add a scan of it to this note.
After seeing the schematic:
Tweeter; 3rd-order high-pass. Corrected the schematic after my audio guru didn't believe it. I'll replace the 10- and 18uF caps in series with the tweeter with something significantly better than the inexpensive Bennic 'propylenes; more later.
Midrange; simple 2nd-order bandpass. The electrolytic caps MUST go. Will use a SoniCap-1 for the 25 and a Mundorf MCap EVO Oil for the 45.
BTW the speaker has a tweeter-level control (from -1dB thru +1dB in half-dB steps) and a wall-proximity switch built into the input-terminals cup. Probably won't do anything with those.
Tin-eared audiofool, vidiot, Classical-music lover, and highly amateur fotografer.
http://jeffreybehr.zenfolio.com/p610729623
Last edited by jeffreybehr; Today at 11:22 AM. Reason: Corrected schematic; the 10uF caps was in the wrong place.
jeffreybehr is online now
post #10173 of 10176 Old Yesterday, 03:04 PM
Quoted: 18 Post(s)
Yes; no.
post #10174 of 10176 Old Yesterday, 07:26 PM
DonH50's Avatar
Quoted: 2222 Post(s)
Liked: 1828
The "tweak" on the tweeter filter, if you are referring to the series cap to ground, is to help compensate for the inductance of the driver.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #10175 of 10176 Old Yesterday, 07:33 PM
torii's Avatar
Quoted: 1558 Post(s)
Liked: 850
it wouldnt surprise me in models with same drivers all the difference is in the crossover....yea that 5k speaker and 100k speaker only diff is crossover...
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #10176 of 10176 Old Today, 11:23 AM
Quoted: 18 Post(s)
Don, I've corrected the schematic; no tuning circuits in the c-over.
Reply Speakers
Revel
