Infinity Primus Owner's Thread - Page 133 - AVS | Home Theater Discussions And Reviews
 9Likes
post #3961 of 3990 Old 10-09-2014, 09:01 AM
Quoted: 13 Post(s)
Liked: 0
Yesterday my P363 came in! I am using a Denon X1000 with a Sony SA-W2500 Sub. I am a bit confused to what HZ to set the p363 to. Any recommendations?
beebee5 is offline
post #3962 of 3990 Old 10-09-2014, 10:34 AM
JChin's Avatar
Quoted: 129 Post(s)
Liked: 140
Hi beebee5, just run auto setup. The Denon may set the P363 to Large, if so you want to reset them to Small and raise the crossover point to 80hz so the lower frequencies are passed to the sub.
JChin is offline
post #3963 of 3990 Old 10-09-2014, 12:20 PM
Quoted: 13 Post(s)
Liked: 0
Thanks Jchin! I will try that when I get home.
beebee5 is offline
post #3964 of 3990 Old 11-15-2014, 07:50 PM
niggenz's Avatar
The binding posts on my P363's snapped off in a move. What is the best way to replace/repair them either with aftermarket or OEM parts?
HTPC: Intel NUC (DC53427HYE) running OpenELEC/Win7 Dual Boot
Projector: Optoma HD131Xe
Receiver: Onkyo TX-NR809
Screen: Elite Spectrum Electric 125"
Media Server: NAS4Free Core 2 Quad 2.40GHz
niggenz is offline
post #3965 of 3990 Old 11-15-2014, 09:44 PM
Digiti's Avatar
Exclamation
One source you could try is here:http://www.parts-express.com/Search....itesearch=true
Digiti is offline
post #3966 of 3990 Old 11-18-2014, 01:40 AM
niggenz's Avatar
Any decreased performance at all in using aftermarket parts? Opinions are nice.
Also, does anyone have the rubber feet that came with their P363's and don't need them? I installed the plastic feet when I had carpet. Now I have hardwood floor and could use the rubber. If you have them and are willing to donate them.....or sell them, please PM me.
niggenz is offline
post #3967 of 3990 Old 12-01-2014, 04:25 PM
Soulburner's Avatar
Quoted: 172 Post(s)
Liked: 35
I've been enjoying my Primus set for 5 years. They represent a truly great value in speakers and I've been very impressed by their sound.
But I am curious. If you were to say what speakers would be the "next level" up from these, what would they be?
Soulburner is online now
post #3968 of 3990 Old 12-01-2014, 07:07 PM
GLBright's Avatar
Quoted: 21 Post(s)
Liked: 72
Knowing how much you like the Primus line, you might consider Infinity's newer "Reference" series. Not in Revel territory but derived from them.
http://www.infinityspeakers.com/esto...Series/2500015
digimortal likes this.
HT: Onkyo TX-SR702,Infinity IL60s/IL36c,DefTech PF1500sub,PanasonicPT-AX100,Draper92"screen,SonyBDP-S570,Dish622
Stereo1 Denon PMA-630 amp,TechnicsPL-1300TT,ToshibaSD-4960 uni-player,Infinity Overture 3s
Stereo 2 OnkyoTX-8222 HitachiHT-61S TT,YamahaDV-S586 uni-player,Large Advents (1972)
GLBright is online now
post #3969 of 3990 Old 12-03-2014, 12:08 AM
Soulburner's Avatar
Quoted: 172 Post(s)
Liked: 35
Would you say there is a big difference between the Primus and the Reference?
post #3970 of 3990 Old 12-03-2014, 05:10 AM
GLBright's Avatar
Quoted: 21 Post(s)
Liked: 72
A review of the Reference is here http://hometheaterreview.com/measure...also-did-full/
I would say that they are probably more like the Beta and Interlude line than the Primus, substantially superior in every way.
post #3971 of 3990 Old 12-03-2014, 10:49 AM
Soulburner's Avatar
Quoted: 172 Post(s)
Liked: 35
I'm getting the upgrade bug. I knew I knew I shouldn't have come back here
post #3972 of 3990 Old 12-12-2014, 09:05 AM
Osirus23's Avatar
Quoted: 21 Post(s)
Liked: 198
P363s are on sale at Fry's for $99.
Osirus23 is online now
post #3973 of 3990 Old 01-07-2015, 11:25 AM
Liked: 0
Question P363 Replacement Part
Hello everyone. I am the new owner of a pair of P363 Primus Towers and a P351 Center. Love them so far. I purchased these off ebay and one of them came with a blown 6.5" woofer. I have tried calling Harmon and they say they are on back order. Does anyone know where to look for a replacement woofer? or does anyone have a 363 tower that is no longer working but may have a functioning woofer? Any help is greatly appreciated. Thanks
p.s. the part number is 16PR85BZQ-HW04-E
Thanks again
Chance
douglassc100 is offline
post #3974 of 3990 Old 01-07-2015, 11:26 AM
Liked: 0
When I do room correcting programs with various receivers I get a crossover set at 80Hz for the 363s. Both my onkyo and my yamaha have chosen this crossover for these speakers. Hope this helps.
post #3975 of 3990 Old 01-08-2015, 08:48 AM
Osirus23's Avatar
Quoted: 21 Post(s)
Liked: 198
Hmm, Audyssey in my TX-NR809 crossed my P363s over at 40 Hz. I changed it to 80 Hz.
post #3976 of 3990 Old 01-08-2015, 03:10 PM
duc135's Avatar
Quoted: 71 Post(s)
Liked: 174
Regardless of what my receiver set the crossover frequency at I generally change it to 80Hz as a starting point and adjust to preference. I will never lower it below what the receiver set it to initially though.
duc135 is online now
post #3977 of 3990 Old 01-13-2015, 08:12 AM
steve1106's Avatar
Quoted: 112 Post(s)
Liked: 46
P363s are $99 at Amazon today.
steve1106 is offline
post #3978 of 3990 Old 01-19-2015, 11:37 PM
Dennis0201's Avatar
Can I use banana plug with P363? It seems like it is not allowed to remove that plug......
Dennis0201 is offline
post #3979 of 3990 Old 01-20-2015, 02:48 AM
Soulburner's Avatar
Quoted: 172 Post(s)
Liked: 35
Reviewers say that you can, but it may take some work.
Dennis0201 likes this.
post #3980 of 3990 Old 01-20-2015, 08:16 AM
fookoo_2010's Avatar
Quoted: 71 Post(s)
Liked: 59
Either use the holes where the speaker wire would go into or remove the red and black plastic plugs and insert banana plugs there.
fookoo_2010 is offline
post #3981 of 3990 Old 01-20-2015, 10:40 AM
Soulburner's Avatar
Quoted: 172 Post(s)
Liked: 35
I think it was the Audioholics review (can't remember) where the guy said he had to drill them out. So if there is the will, there's a way
post #3982 of 3990 Old 01-20-2015, 04:30 PM
duc135's Avatar
Quoted: 71 Post(s)
Liked: 174
Drill? Really? Just slide a knife edge under the lip and they will pop right off. I've done this on all 15 of the Primus speakers I've setup and it takes about 5 seconds per speaker. Make sure you use a real knife and not a butter knife. It has to have a sharp edge to get underneath the flush mounted plug lip.
post #3983 of 3990 Old 01-23-2015, 11:51 AM
Quoted: 71 Post(s)
Liked: 59
Infinity P363's onsale at Fry's again @$99.95, unbelievably with free shipping from frys.com, limit 2.
http://www.frys.com/product/6878376?...H:MAIN_RSLT_PG
post #3984 of 3990 Old 01-23-2015, 04:08 PM
Soulburner's Avatar
Quoted: 172 Post(s)
Liked: 35
These things are a steal at that price. A bit trebly for me, but still a very detailed full range speaker.
post #3985 of 3990 Old 01-23-2015, 04:45 PM
Liked: 0
Fry's has the Infinity Primus p363 on for 99.95 with free shipping. Just ordered 2 more so will have 4 p363's and 2 of the p163's I don't currently have enough posts to link the site. Maybe someone else could do that. sku # items:
qty receive by (est) unit price ext price 6878376 Infinity Primus 363 6.5" Tower Speaker - Single 2 Friday, January 30 $199.95 $199.90
You Save $200.00
subtotal $199.90
tax $16.99
Estimated Shipping & Handling Ground
$51.99 Shipping Savings
-$51.99
total $216.89
Edzzed is offline
post #3986 of 3990 Old 01-23-2015, 04:47 PM
Liked: 0
I also have the pc351 and am going to be getting 2 dayton 1500 subs from part express.
Edzzed is offline
post #3987 of 3990 Old 01-23-2015, 04:48 PM
Liked: 0
And if I make one more post I should be able to post the link myself. Ed
Edzzed is offline
post #3988 of 3990 Old 01-23-2015, 04:49 PM
Liked: 0
you need to hit the SPECIAL PRICE link http://www.frys.com/product/6878376?...H:MAIN_RSLT_PG
Edzzed is offline
post #3989 of 3990 Old 01-25-2015, 06:55 AM
drunkpenguin's Avatar
Quoted: 39 Post(s)
Liked: 51
So if I have a single P363 I wanna get rid of would I be breaking rules to talk about it in here?
drunkpenguin is online now
post #3990 of 3990 Old Today, 05:46 PM
Soulburner's Avatar
Quoted: 172 Post(s)
Liked: 35
I find my P362s a bit trebly when compared a neutral speaker. Is there a better midrange driver or tweeter I could use?
Reply Speakers
