Infinity Primus Owner's Thread - Page 136 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #4051 of 4071 Old 05-12-2015, 05:26 PM
rx7racer's Avatar
So I am enjoying the P363's as my mains right now however I noticed my right speaker lacking in the high's dept. After some quick sophisticated testing using my ears it was painfully obvious i sent the tweeter packing home.
So I have read past posts about others who have blown the tweeter and called Harmon, tweeter is no longer around and the few links from goggling were from 2012 so they were no good anymore. Does anyone here now where or how I can find a replacement tweeter or a correct size that I could get to fit for the P363?
I'm grasping at straws I know but haven't even had these things a month yet so don't want to chalk them up as junk yet if I don't have to.
rx7racer is offline
post #4052 of 4071 Old 05-12-2015, 05:33 PM
toddman36's Avatar
Quoted: 286 Post(s)
Liked: 75
Try ebay....
toddman36 is offline
post #4053 of 4071 Old 05-12-2015, 05:59 PM
rx7racer's Avatar
Yeah, glanced at some, thinking best bet is to buy cheap bookshelf in the series used and just steal the tweeter and toss the bookshelf after haha. If I paid more than 100 I'd be pissed but let's face it I got what I paid for with the P363's. Can't really complain for their price.
From reading around that's one drawback these Primus series have is a cruddy tweeter essentially.
The smallest bookshelf is only 60 so only about 25 more than if I did find the tweeter to buy.
rx7racer is offline
post #4054 of 4071 Old 05-12-2015, 06:03 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 219
You can't just take any tweeter and pop it in. You'd have to get a new crossover and that won't be easy unless you know what you're doing.
Soulburner is online now
post #4055 of 4071 Old 05-12-2015, 06:09 PM
duc135's Avatar
Quoted: 117 Post(s)
Liked: 186
Since you've had them less than a month you should be able to take them back to where you bought them from. Both Fry's and Amazon have a 30 day return window. You can get an exchange at Fry's or return to Amazon then wait for the next sale to get a replacement. If you bought it somewhere else check with their return policy. They should have some type of warranty if you bought them new from an authorized reseller. Worst case scenario, if you bought them using a credit card, some have extended warranties. I know American Express will just refund you your money if the manufacturer can't/won't help you.
duc135 is offline
post #4056 of 4071 Old 05-12-2015, 06:15 PM
rx7racer's Avatar
Yuppers on the can't just put any tweeter in but all their primus series seem to use the same MMD 19mm tweeter, each crossover may be different but so far from my gathering tweeters are the same. I read a few posts with some replacing tweeters and adjusting crossover since Infinity has it crossed about 3.3khz.
Also yeah I could send it back to amazon but time is money and for me it's easier to drop 60 on a cheap bookshelf and do a swap myself within minutes than all those other time consuming options. The Speaker Exchange wants 45 to fix/recone and that's after me shipping it to them.
I knew I was grasping at straws but one never knows if someone might know or have one on hand.
rx7racer is offline
post #4057 of 4071 Old 05-12-2015, 06:47 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 219
Sorry, saw "cheap bookshelf" but missed that you were talking about the same series.
post #4058 of 4071 Old 05-13-2015, 12:55 AM
rx7racer's Avatar
No worries Soul, good and valid point
So I debated and went with one of the primus 4" 2-way bookshelf, it was only $50 so if all matches up the way I think it will/should I guess my fix will be a sinch. Honestly enjoying them and have to agree for when they are on sale it's hard to beat'em, although after this I'll have to be a bit more careful
rx7racer is offline
post #4059 of 4071 Old 05-13-2015, 11:35 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 219
I don't know if it would help, but I'm selling my PC351 center. Probably not as cheap as a bookshelf though
post #4060 of 4071 Old 05-13-2015, 05:09 PM
AverageJoeAudio's Avatar
Quoted: 16 Post(s)
Liked: 29
All the tweeters are the exact same in the current generation of the Primus (the older p140s do measure different a bit different than the p143s).
I've taking the p143's apart before, so as a word of advice, the terminals used on the ends of the wires can be VERY tightly pinched onto the terminals on the tweeter. So take your time and go slow with trying to pull them off, if you just tug on it, you may end up putting damaging the tweeter before you are able to switch them.
AverageJoeAudio is offline
post #4061 of 4071 Old 05-13-2015, 09:46 PM
rx7racer's Avatar
Thanks for the heads up. When I pulled the blown tweeter it was fairly easy to just slip off, not very tight at all. Got curious so pulled the other tweeter that is good as well and yeah those spades where darn tight indeed.
Word of caution was appreciated, new bookshelf will be in tomorrow so I'll expect an easy swap now. And yeah Soul I doubt the price would have been in range of my goal but thanks for tossing it as an option out there.
rx7racer is offline
post #4062 of 4071 Old 05-13-2015, 09:52 PM
zieglj01's Avatar
Quoted: 856 Post(s)
Liked: 774
When there is a tight connect on a tweeter or woofer - I take a small pick tool, and from the back
of the female disconnect, I pry it open some - then I begin to pull and work it off. However, as
always be careful when working with sharp like tools.
Hope things work out for you.
__________________________________________
Who AM I
Speakers > MB Quart VS05, Boston VS260, Snell K7, EOS 150SP
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PAR-200, Pioneer VSX-30
zieglj01 is online now
post #4063 of 4071 Old 05-15-2015, 01:01 PM
rx7racer's Avatar
Had a smooth swap for the tweeter, was worried at first due to top plate being different but they were easy to pull out thankfully. Hopefully I won't break it again
Thanks for the input all around as well, for future reference supposedly Harmon with have the tweeters back in stock after June 15th from an email I received by them.
zieglj01 likes this.
rx7racer is offline
post #4064 of 4071 Old 05-20-2015, 01:25 PM
MIX_MASTER_ICE's Avatar
Quoted: 251 Post(s)
Liked: 99
Frys has the P363 towers on sale for $99 each w/coupon code, today only. Great speakers for under 100 bones. If anybody is interested in purchasing these, a code is required for online and in store purchase at this price. PM me and I'll be happy to give you my code, as I won't need it.
MIX_MASTER_ICE is offline
post #4065 of 4071 Old Today, 03:44 AM
Liked: 0
Finally received my P363's! After listening to them I wish they had a bit more bass, but i really only have about 1hr into them... I really need to get my Sub running again (ps210 with blown amp )
I'm looking at getting a matching Center, do you guys recommend the PC251 or 351? and why?
hepha3stus is offline
post #4066 of 4071 Old Today, 06:15 AM
christoofar's Avatar
I'd say get the 351, since the drivers match what's in the 363's, unless you have budget or placement concerns due to it's slightly larger size. Since one of my P163's toppled over on it's stand & stopped working, I moved my original P360s back into action for L & R duties & am reminded how great they sound.
christoofar is offline
post #4067 of 4071 Old Today, 09:43 AM
duc135's Avatar
Quoted: 117 Post(s)
Liked: 186
In order of preference based on performance:
1. Another P363 vertically oriented if space/WAF allows.
2. P163 vertically oriented if space/WAF allows.
3. P153 vertically oriented if space/WAF allows.
4. PC351
5. PC251
6. Any other speaker that you like the sounds of that is fairly close in sound signature (if your AVR/Pre-pro has some type of room correction feature).
A center speaker that is identical to the L/R speakers is optimal for best timbre matching. That would mean a third P363 if possible. Center speakers were designed to fit a specific need. That is to fit above or below the display. Sound quality plays second fiddle to this primary function. Horizontal Mid-Tweeter-Mid (MTM) speaker designs suffer from what is known as lobing. That is why I always recommend 1 - 3 above over a center speaker specific design.
If you insist on or can only accommodate a horizontal center speaker then get the PC351. The PC351 moves the tweeter up allows for the mid drivers to be physically closer to each other which minimizes the lobing effect. Of course this is also dependent on the crossover design, but generally speaking this is preferred.
Last option, since the PC351 is relatively expensive, is to get another center speaker from any other manufacturer that has similar sound characteristics that you like if you have an AVR/Pre-pro with room correction built in. IMO, timbre matched speakers were more important in the days prior to automated, electronic room correction. With features provided by Audyssey, MCCAC, DIRAC, etc., timbre matched speakers are less important since these products do a pretty good job of making the speakers timbre matched via EQ. So close enough is good enough IMO.
duc135 is offline
post #4068 of 4071 Old Today, 09:55 AM
Liked: 0
Thanks for the input! I guess i'm not totally committed to the center being a "center" but from the sounds of things the 351 is much better than the 251
thanks!
post #4069 of 4071 Old Today, 05:09 PM
Got my bad P163 popped open today - turns out the impact when it fell over must have caused the voice coil to get tweaked, it now produces a healthy rubbing/scratchy sound when I move the cone up & down. It seems Harmon has abandoned parts support for the 10s of thousands that were sold, nice...
Searching Google doesn't produce any source for a replacement, not sure if I want to spend $90 for another one (got mine on sale for $60 @ Fry's) or just stick w/ the P360s and my wife's occasional evil stare...
post #4070 of 4071 Unread Today, 05:17 PM
duc135's Avatar
Quoted: 117 Post(s)
Liked: 186
The drivers in the P360 should be the same as in the P163 I think. You can always swap drivers if that's the case.
duc135 is offline
post #4071 of 4071 Unread Today, 05:27 PM
True, but have no plans to part out the classic P360s. So I guess I'm out of my bookshelf phase for a while..
Plus no current budget for any upgrading, guess I can live with them.
Reply Speakers
