KEF Owners Thread - Page 158 - AVS Forum | Home Theater Discussions And Reviews
 656Likes
post #4711 of 9860 Old 02-24-2012, 12:40 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Originally Posted by drewTT View Post
Good call on the auto body shop. I haven't thought of that. I did talk to a furniture refinisher and he can do it but I think the auto body shop would be cheaper. Yes, I will remove all drivers and components and probably even sand and primer it myself. Just have the shop paint and clear it for a smooth finish.
Pics when you're done, please.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #4712 of 9860 Old 02-24-2012, 12:41 PM
Eternal Velocity's Avatar
Quoted: 30 Post(s)
Liked: 61
That probably doesn't make any sense but I don't have fancy technical terms to describe it.
"accurate" ;P
Originally Posted by arshishb View Post
It is after all a sealed enclosure.
No, it's a bass reflex enclosure, no different from vented, only with passive radiators instead of pipes. And by running it full range, you're asking for a lot more output / motion out of the K900's coaxial midrange, which means that at higher SPLs you're modulating the tweeter's response.
It might seem counterintuitive but I would cross these at 100hz to two to four QUALITY subwoofers.
Eternal Velocity is offline
post #4713 of 9860 Old 02-24-2012, 01:04 PM
arshishb's Avatar
Originally Posted by Eternal Velocity View Post
"accurate" ;P
OK i can understand that for HT. What about music? I actually like the sound a LOT better without the sub. Yes, I have a good sub, its a Rythmik E15.
I am not running them at any high volumes, -30 to -25 max. Being in an apartment I don't have the luxury of shaking walls & pets :P
arshishb is offline
post #4714 of 9860 Old 02-25-2012, 09:42 AM
exm
exm's Avatar
Quoted: 120 Post(s)
Liked: 80
Originally Posted by sivadselim View Post
What is this a picture of?
Ok, so it's small piece of rubber holding the grill in place. Behind it you can find normal philips screws. Mystery solved!
exm is offline
post #4715 of 9860 Old 02-25-2012, 11:02 AM
cream puff's Avatar
finally picked up my Q300s last week.. brings me to a full Q series 5.1 setup
cream puff is offline
post #4716 of 9860 Old 02-25-2012, 11:08 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Ah. Makes sense, I guess. How did you get that piece out? Just slip something underneath and pry it out?
post #4717 of 9860 Old 02-25-2012, 11:09 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Enjoy!
post #4718 of 9860 Old 02-25-2012, 05:57 PM
punman's Avatar
So what are all the speakers you are using?
punman is offline
post #4719 of 9860 Old 02-25-2012, 06:10 PM
cream puff's Avatar
Q900 (2)
Q600c
Q300 (2)
post #4720 of 9860 Old 02-25-2012, 06:29 PM
Quoted: 30 Post(s)
Liked: 61
That means your E15 is very poorly placed.
What you need is multiple subs for flatter frequency response.
post #4721 of 9860 Old 02-25-2012, 07:30 PM
Jive Turkey's Avatar
Quoted: 216 Post(s)
Liked: 138
I might tend to agree. I have Dunlavy SC-IVA's for stereo music and still prefer having dual SVS PC-2039+ subs judicially intergrated.
I use KEF Q900's and a Q200c across the front of my Home Theater system, just to stay somewhat on topic.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #4722 of 9860 Old 02-25-2012, 09:28 PM
toolskizm's Avatar
Q900 (2)
Q600c
Q300 (2)
Cream Puff, I think I'm going for your same setup eventually. After falling in love with my q300's, I'm picking up my 600c tonight or tomorrow. Then I think eventually get the q900 and move my q300 to the rear. How does it sound? Is a sub really needed since the 900s can get fairly low?
toolskizm is offline
post #4723 of 9860 Old 02-25-2012, 09:44 PM
cream puff's Avatar
for music i run pure direct mode (2.0 no sub), and prefer it that way.. although for movies a sub is still needed in my opinion.
post #4724 of 9860 Old 02-26-2012, 02:26 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
Got my IQ90s dialed in. Really good speaker for the money.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #4725 of 9860 Old 02-26-2012, 05:45 PM
exm
exm's Avatar
Quoted: 120 Post(s)
Liked: 80
Yep
exm is offline
post #4726 of 9860 Old 02-26-2012, 08:41 PM
benzjas's Avatar
Tool. I am glad to see that you are enjoying your 300s. I too am really enjoying listening to all my music over now. I no longer get a headache after listening to music like i used to with my old polk monitor system. .
Toool, creampuff What kind of source are you using for your listening? Ps3? dedicated CD/blu ray player? About to pull the trigger on a universal player, denon 1611.
LG 55LK520
Denon 3311
Denon bdp 1611
KEF Q200c
KEF Q300s L/R
Bic Pl200
benzjas is offline
post #4727 of 9860 Old 02-26-2012, 09:43 PM
cream puff's Avatar
I use a combination of things, samsung bluray player, Western Digital Live TV media center full of music/movies, and a PC connected via HDMI.
I would also like to get a turntable at some point, but not sure if that will end up happening or not.
post #4728 of 9860 Old 02-26-2012, 10:23 PM
dancel's Avatar
I got a question for Kef america or anyone who might know the answer to this,
but on the boxes for the Q series there are stickers for manufacture date and compliance, now I get the manufactured date part, but there is another one there which says complaint phase 1 or phase 2.
for the speakers I own it says:
Kef Q900: Built 10.2010 compliant with phase 1
Kef Q600C: Built 12.2011 compliant with phase 2.
now what does those phases mean?
dancel is offline
post #4729 of 9860 Old 02-27-2012, 05:59 AM
ranchdrsn's Avatar
It just has to do with the elimination of using certain chemicals such as formaldehyde in the manufacturing processes of the wood to comply with new standards of production...(CARB) nothing to do with the speaker itself. More of an environmental thing. Kinda like Rohs compliant products.
ranchdrsn is offline
post #4730 of 9860 Old 02-27-2012, 06:32 AM
dancel's Avatar
dancel is offline
post #4731 of 9860 Old 02-27-2012, 02:05 PM
remush's Avatar
Quoted: 174 Post(s)
Liked: 172
I listened to a Kef T205 system hooked up to a 2112, and I really liked what I heard so I got the set for my condo. I would have got the 2112 but I want a receiver with pre outs for future use, I guess if I want the Denon with this feature I would have to get the 3312.
The other receiver I am considering is the Onkyo 709, mainly because I found a good deal on it (about $250 cheaper than the 3312), and feature wise, it is comparable to the 3312. I know some of you said that the Kef's and Denon's work really well together, but I don't know if it is worth the extra money???
So my question is do you think I should get the 709 or spend a bit more and get the Denon? I tried to find a place that has both set ups but no luck.
I will be using the speakers and receiver for mostly music and watching TV, roughly in a 19' by 11' condo living room.
remush is online now
post #4732 of 9860 Old 02-27-2012, 02:10 PM
benzjas's Avatar
What about the denon 2310. It is two models older than the 2110. But it has preouts and i think it will sound very good. It is quite cheap on a4L
LG 55LK520
Denon 3311
Denon bdp 1611
KEF Q200c
KEF Q300s L/R
Bic Pl200
benzjas is offline
post #4733 of 9860 Old 02-27-2012, 03:51 PM
arshishb's Avatar
You could get the Pioneer VSX 1021 or VSX 1121, they both are good receivers & have pre-outs. The 1021 goes on sale often for $300 on Newegg & the 1121 for $449.
arshishb is offline
post #4734 of 9860 Old 02-27-2012, 04:12 PM
remush's Avatar
Quoted: 174 Post(s)
Liked: 172
Thanks for the suggestions, one thing i noticed was that these units have Audyssey MultEQ instead of XT like the newer 3312, which is something i would pay extra for.
But you're right, maybe i should look at discontinued models to save some money, I believe the 3311 would be almost identical to the 3312.
post #4735 of 9860 Old 02-27-2012, 04:19 PM
remush's Avatar
Quoted: 174 Post(s)
Liked: 172
I actually owned a Pioneer with a set of JBL speakers and they were great, I would definitely consider these.
One of the main reasons why I am leaning towards the Denon is because it was highly recommended as a pairing with KEF by a few members in this thread and on this forum.
post #4736 of 9860 Old 02-27-2012, 04:30 PM
arshishb's Avatar
I have paired Q900, Q300 & Q600C to the 1121 & it sounds good to me. I haven't heard anything else with the Kefs so not sure how good/bad they are compared to the Denon. I did have Marantz few years ago & I like Pioneer sound better than the Marantz which seemed more "muffled" to me.
I recently bought a used Emotiva UPA7 to see what the deal is with getting a seperate v. a receiver. But even without the Emo, I am quite pleased with the way they sound.
arshishb is offline
post #4737 of 9860 Old 02-27-2012, 04:49 PM
remush's Avatar
Quoted: 174 Post(s)
Liked: 172
I would like to audition these speakers with a Pioneer, but all the places I've been to that had the T205 in store, had it hooked up to a Denon.
I will look around some more, and I guess i can always audition the receiver at home from a place with a good return policy.
post #4738 of 9860 Old 02-27-2012, 05:13 PM
arshishb's Avatar
Where are you located?
arshishb is offline
post #4739 of 9860 Old 02-27-2012, 06:04 PM
remush's Avatar
Quoted: 174 Post(s)
Liked: 172
Toronto, I found a place through Pioneer's dealer list that has both the 1021 and the KEF T205 listed on the website. I will go see them and hopefully they will pair these up for me.
I also remember finding a good deal on a SC-25, but that might be overkill for a condo living room and small speakers.
post #4740 of 9860 Old 03-03-2012, 02:08 PM
galvs's Avatar
Amazing speakers...blow away the oldies XQ20, rich and tight bass, sounds like towers!
Congrats Kef!
galvs is offline
Reply Speakers
Kef , Kef Audio , kef blade 2 , Kef Bookshelf Speaker , Kef C4 Subwoofer Black , Kef Center Channel Speaker , Kef Ls50 2 Way Speaker System , Kef Q100bl Bookshelf Speaker , Kef Q700wa Floorstanding Speaker , kef reference 3 , Kef T Series Floor Stand Pair
