KEF Owners Thread - Page 236 - AVS | Home Theater Discussions And Reviews
post #7051 of 7072 Old 01-18-2015, 08:55 PM
nirvy111's Avatar
Quoted: 108 Post(s)
Liked: 38
Originally Posted by DS-21 View Post
I know from actual listening tests personally conducted that you would have lost nothing sonic using Q100's (or worse speakers - the "lesser" speakers in my particular comparison were mid-2000s KEF Q-Compacts, which are inferior in every material way to the Q100) for the four surround positions.
The only advantage of using the same speakers all around is aesthetic. If having speakers that all look the same make one feel better, absolutely do it. But sonically it does not matter, and the people who claim it does generally (1) sell stuff and/or (2) haven't actually done a direct comparison and/or (3) are bad at critical listening.
I haven't tried the Kef Q100's but upgrading my four surround speakers from the Q acoustic concept 20's I had to the Kef ls50's made a pretty big difference in my setup and the QA 20's are a capable budget speaker, just not as good as the more expensive Kef's.
nirvy111 is offline
post #7052 of 7072 Old 01-18-2015, 09:36 PM
coli's Avatar
Quoted: 139 Post(s)
Liked: 36
While my amps are in repair, I'm down to a mono channel. So been I've experimenting with different setups.
There really is nothing quite like listening to the LS50 then switch to floorstanders to make you appreciate the bass in music, lol.
coli is offline
post #7053 of 7072 Old 01-21-2015, 01:58 AM
zoey67's Avatar
Quoted: 92 Post(s)
Liked: 81
Gents,..any owners out there some vintage Kef THX series? Need a bit of advice on whether to go with 2 very similar Kef series...a pair of AV3 or TDM23f?
zoey67 is offline
post #7054 of 7072 Old 01-22-2015, 01:10 AM
BobearQSI's Avatar
Quoted: 21 Post(s)
Liked: 29
Thought I would share my review I posted in another thread of my recent KEF upgrade for all the KEF fans here:
I bought a brand new KEF 3005SE system (the 'eggs') from Circuit City when they were going out of business for $900, and picked up two more of the eggs off ebay for a 7.1 system. They have served me well for the past 6 1/2 years, until my center channel tweeter went out while watching The Hobbit. I contacted KEF and could get a replacement of the tweeter/mid Uni-Q, but I opted to upgrade instead I use my system for 99% movies and 1% music.
Old system: KEF 'eggs' KHT3005SE system in 7.1 (with HTB2 sub), crossover at 80Hz all around.
New system: I kept the eggs/sub for surround, and just replaced L/C/R: 2 KEF Q500 for L/R and the Q600c Center, new crossover at 60Hz.
Room treatment: I've got two DIY 4' x 8' absorption panels that are 12 inches thick on the left and right walls covering first reflections points from the front 3 speakers for all seating positions. Also, I removed the drywall for the ceiling for the front 8 feet of the room, and filled it with sound absorption material. And one more 4' x 8' x 1' absorption panel on the rear wall between the rear surrounds.
Also, I now have 2 extra eggs that were previously L/R. In the next couple of weeks, I plan to test these out for side surrounds for the 2 rows of seating as an array and also parallel to the wall facing away from each other for a bipole-like setup.
Here's my reviews of the upgrade:
So, my review here is really just comparing the KEF Egg center (HTC3001SE) to the Q600c, which is about twice the price. The KEF eggs served me well, and is the only real speaker system I've had.
At first listen, my very first impression was that the Q600c was really bright. But after listening more, I realized that what I was hearing was a huge increase in clarity over the whole frequency range. I was hearing clarity in the highs that I simply had not heard before. The detail this thing puts out is amazing. In addition, the added bass really made the sound warmer as well, especially on music, that had a large range of frequencies.
A definite and drastic improvement, and well worth the money spent. I spent so much time paying attention to the Q600c, I haven't had time to notice the Q500 front speakers yet I need to build a stand to elevate the Q600c up so it is right below my screen and angled up a little, but eventually I'll listen to some more action movies/full front stage material and report back on the Q500 as well.
Alright, got a chance to do some more evaluation of the Q500s. Overall, pretty much the same thing as the center - all sounds are clearer, and my lower crossover (now at 60Hz for the L/C/R instead of 80Hz with the eggs) makes everything sound much 'fuller' too. I was particularly impressed with the opening music on Tron: Legacy. The music is very rich in the lower frequencies, and it immediately hit me like it never has before with the sheer amount of presence it had. The ability to fill out the front is just night and day compared to my old eggs. To put it another way, the sound is now big and full, rather than small and thin. Now, the eggs with a subwoofer and 80Hz crossover are pretty decent and I wouldn't call them 'thin' on their own, but when comparing the two, that is the impression I get when listening to the difference.
Very pleased with the upgrade.
BobearQSI is offline
post #7055 of 7072 Old 01-22-2015, 02:38 AM
fatbottom's Avatar
Quoted: 563 Post(s)
Liked: 223
yup it's good Kef produce large center speakers, I have Kef Reference 200. Last time I heard Kef Eggs- they're ok but thin sounding, just because of the 3/4" driver can only do so much. I recommend standmounts as a minimum now, and I prefer large center speakers as some seem to make them as an afterthought rather than integrated to your L/R floorstanders
How about this monster lol
Pivetta Opera
Bose Jewel speakers.
fatbottom is online now
post #7056 of 7072 Old 01-22-2015, 12:24 PM
sdg4vfx's Avatar
Quoted: 25 Post(s)
Liked: 103
Set the crossover for the KEF eggs at 100hz and you'll likely notice a better sound. (Most avr's will let you set the surround crossover separately from the center and mains.)
sdg4vfx is online now
post #7057 of 7072 Old 01-28-2015, 08:47 AM
exm
exm's Avatar
Quoted: 20 Post(s)
Liked: 62
I started with the 100C, then I owned the 200C for a while and now I have the 204/2C (with Ref 4s). Love their center speakers!
exm is offline
post #7058 of 7072 Old 01-28-2015, 12:18 PM
ambesolman's Avatar
Quoted: 519 Post(s)
Liked: 505
Congrats on the upgrades! Mind posting pics of your room? Curious what 1' thick panel looks like on the side walls[emoji16]
Sent using Tapatalk since the mobile version is still [emoji107]
ambesolman is offline
post #7059 of 7072 Old 01-29-2015, 02:16 AM
BobearQSI's Avatar
Quoted: 21 Post(s)
Liked: 29
My room is normally very dark, as the only lights are recessed lights above the seating. So normally, the panels aren't very noticeable. The whole room is pretty ugly when well lit - it's amazing how much better things look in low light. But you're in luck! I've been playing around with surround speaker placement, so I've got work lights in there right now. The panels are suspended from the ceiling so they sit a couple inches out from the wall for even more bass absorption.
Here's the view of the new front end (you can see the edge of one panel on the far right):
Here's the panel on the right of the room by the door:
And here's the left side:
ambesolman likes this.
post #7060 of 7072 Old 01-29-2015, 10:50 AM
ambesolman's Avatar
Quoted: 519 Post(s)
Liked: 505
Great space bobear, thanks for the pics. Those panels are huge! What are they stuffed with? Do they pull double duty for sleep overs?
post #7061 of 7072 Old 01-29-2015, 12:34 PM
BobearQSI's Avatar
Quoted: 21 Post(s)
Liked: 29
Hmmm, now you're making me think back to when I built them 7 years ago . . . I'm remembering now that they are actually 10 inches thick. But I stuffed them with 12" fiberglass insulation compressed down to 10 inches, covered with fabric batting to contain the fiberglass, and covered with black burlap.
You could use them for a sleepover, but it might be an itchy morning
Also, you can see in the first pic, the entire ceiling in the front of the room is also fiberglass -> batting -> burlap.
post #7062 of 7072 Old 01-29-2015, 02:49 PM
wulfcomp's Avatar
Finally got my theater finished. Trying out KEF C-series in a 7.2.2 config. Got C7 for mains, and C6LCR for center and surrounds and Ci160CR for ceiling speakers for Atmos
wulfcomp is online now
post #7063 of 7072 Old 01-29-2015, 09:30 PM
tomdac's Avatar
received my R400b and R600c today! yay! Love the white color. R300's haven't been shipped from KEF yet, so my setup is not complete... Grrr. The waiting continues.
ID:	511305   Click image for larger version
ID:	511313   Click image for larger version
ID:	511321   Click image for larger version
ID:	511329   Click image for larger version
EvilAlwaysWins and coli like this.
Tom
Hayward, CA
tomdac is offline
post #7064 of 7072 Old Today, 01:37 PM
tomdac's Avatar
hooked up the r400b sub today... turned off the room correction on my Anthem D2 and then messed with the settings... set both mains to small as well as the center.. set all levels to equal.
Once I get the r300s and get them all broken in, i'll play more with the room correction and settings..... I've not really ever had a sub before, other than the ones built into my ML Summits, so this is new for me.. I'm having fun, tho.
Tom
Hayward, CA
tomdac is offline
post #7065 of 7072 Old Today, 01:43 PM
fatbottom's Avatar
Quoted: 563 Post(s)
Liked: 223
£1000 sub for 2 x 9" and 26hz FR +/-6dB??? Overpriced.
I own Kef speakers but wouldn't buy Kef subwoofers
Pivetta Opera
post #7066 of 7072 Old Today, 02:04 PM
Mr.SoftDome's Avatar
Quoted: 51 Post(s)
Liked: 41
Tom,
Looks great. Love the white. Let us know how it goes after your all set- up.
Bet it will sound great as well.
Rick
Mr.SoftDome is online now
post #7067 of 7072 Old Today, 02:06 PM
Quoted: 51 Post(s)
Liked: 41
You may think so but looks great with the rest of his set-up. Let the man enjoy his his new rig!
Rick
sdg4vfx likes this.
post #7068 of 7072 Old Today, 02:22 PM
coli's Avatar
Quoted: 139 Post(s)
Liked: 36
Subwoofer from speaker companies sound significantly better than internet direct subwoofers.
coli is offline
post #7069 of 7072 Old Today, 02:24 PM
fatbottom's Avatar
Quoted: 563 Post(s)
Liked: 223
Here's a question for you, what is better, MJ Acoustics Pro 50, Rel Quake, or BK Gemini?
Fixed for ya.
Subwoofer from speaker companies are significantly more expensive than internet direct subwoofers.
Pivetta Opera
post #7070 of 7072 Old Today, 04:40 PM
beaveav's Avatar
Quoted: 150 Post(s)
Liked: 357
That's blasphemy on this forum. And a claim that is, well, questionable at best.
For every new thing I learn, I forget two things I used to know.
beaveav is offline
post #7071 of 7072 Old Today, 05:29 PM
fatbottom's Avatar
Quoted: 563 Post(s)
Liked: 223
I'm pretty sure that's the guy had heated exchange with.
I bet coli is a hifi shop owner or something..subs he stocks are brill, ID subs are rubbish that catch fire, electrocute you, give you cancer and AIDS, causes your willy to drop off etc.
Pivetta Opera
post #7072 of 7072 Unread Today, 07:52 PM
DS-21's Avatar
Quoted: 355 Post(s)
Liked: 275
That white looks sharp.
Um, subwoofers are speakers, so any firm that sells subwoofers is by definition a speaker company...
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
Multichannel music (and video) urban loft living room system
DS-21 is offline
Reply Speakers
Kef , Kef Audio , Kef Bookshelf Speaker , Kef Center Channel Speaker , Kef C4 Subwoofer Black , Kef Q100bl Bookshelf Speaker , Kef Ls50 2 Way Speaker System , Kef Q700wa Floorstanding Speaker , Kef T Series Floor Stand Pair
