KEF Owners Thread - Page 243 - AVS | Home Theater Discussions And Reviews
post #7261 of 7266 Unread Yesterday, 07:08 AM
jima4a's Avatar
Quoted: 95 Post(s)
Liked: 75
Originally Posted by ambesolman View Post
Completely different. I also haven't liked anything I've heard in the cm line. Going to the 800 series isn't so much like "lifting a veil" as much as it's like removing a thick soggy blanket that's been covering the speaker. This is not because the diamond is magical, it's because (to me) it sounds like the cm has no tweeter at all. Just no highs. Ymmv of course.
Sent using Tapatalk since the mobile version is still [emoji107]
Was that the CMS1 or CMS2 you are referring to. To my understanding the series 2 was a big jump. The only CM I have heard was the CM7 which ended my desire to get CM9s.
jima4a is offline
post #7262 of 7266 Unread Yesterday, 09:46 AM
Quoted: 139 Post(s)
curious, is this impression based on a particular speaker in the CM line, or based on listening to all of them?
My Current 5.2 Setup - for now....
B&W CM10s (FLR), CMC2, CM5 x2 (SLR)
Dual SVS SB2000s
Rack and Display:
Marantz SR7009, Marantz UD7007, T-PC50st60
[/COLOR]
pickering.tim is offline
post #7263 of 7266 Unread Yesterday, 09:54 AM
Quoted: 139 Post(s)
[QUOTE=ultrahertz;32959017]I have nearly completed my rec room home theater system.
Speakers: Kef R900, R600c, R800ds
Sub: SVS SB 13 ultra
TV: Samsung 78HU9000
Receiver: Onkyo 838
Blu Ray: Oppo 103
Turntable: Onkyo CP1050
very nice looking setup - I think you may have posted some specs for the size of the room but I may have missed them/can't find them. I am wondering how far back the opening on the front left side goes and how large it is. are the speakers firing down the length of the room i assume?
I ask cause cause I dealt with a lot of speaker placement frustrations due to an L shaped room.
Dual SVS SB2000s
Rack and Display:
[/COLOR]
post #7264 of 7266 Unread Yesterday, 04:50 PM
ambesolman's Avatar
Quoted: 615 Post(s)
Liked: 544
It was 2 floorstanders and one bookshelf at two different shops on different equipment over the past 2-3yrs. Every time it was the same, very muted highs. Maybe that's what they were going for with the design, who knows, but I can't see what the advantage of such a design would be if it was intentional.
ambesolman is offline
post #7265 of 7266 Unread Today, 07:03 AM
steveting99's Avatar
Quoted: 607 Post(s)
Liked: 190
I've recently purchased some KEF T-series speakers to be mounted in the ceiling for an Atmos height setup.
These are the T101 models and according to KEF's website the lower -3dB limit is rated at 80Hz. Much to my surprise, when reading the owner's manual - it states a much higher recommended crossover frequency setting of 120Hz.
Can other T-sereis owers confirm the above?
I've also got the KEF E301 series of speakers and so far the owner's manual and website matches the recommended lower -3dB freqeuncy of 90Hz.
It kind of bothers me that a reputable manufacturer such as KEF would play this type of trick.
Maranatz SR-7009, Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
steveting99 is online now
post #7266 of 7266 Unread Today, 08:44 AM
DS-21's Avatar
Quoted: 411 Post(s)
Liked: 296
First, question for E305 owners: how do you remove the grill?
I don't see a trick. Sure, the speakers might have an F3 of whatever, but F3 is not how low they can play without strain.
For that matter, 90Hz is way too low for E305s's, unless they're in a corner. I actually recently bought a pair of them to test out for Atmos heights, and I think 150Hz is a better approximation of their clean bass limits. Unfortunately, I think the E305 may be a step back from the old HTS3005SE. I'll have to re-measure my HTS3005SE's when I get a chance. It may be that the E305 driver is better (albeit cruder - ceramic vs. neo magnet), but the new crossover is too minimalist for use in a high-fidelity system. The HTS3005SE had a surprisingly complex crossover for a tiny and relatively inexpensive speaker. The E305, I gather from measurements (I'll let this thread know when I've processed them and put up my writeup on my blog, below) has a much simpler crossover.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Reply Speakers
Kef , Kef Audio , Kef Bookshelf Speaker , Kef Center Channel Speaker , Kef C4 Subwoofer Black , Kef Q100bl Bookshelf Speaker , Kef Ls50 2 Way Speaker System , Kef Q700wa Floorstanding Speaker , Kef T Series Floor Stand Pair
