KEF Owners Thread - Page 251 - AVS Forum | Home Theater Discussions And Reviews
post #7501 of 7507 Old Yesterday, 07:59 AM
sfav's Avatar
interested to see how they look It is my understanding that the LS-50's sound unreal on the reference stands, a complete transformation and the absolute peak of their capabilities.
sfav is offline
post #7502 of 7507 Old Yesterday, 08:19 AM
CDLehner's Avatar
Quoted: 459 Post(s)
Liked: 672
They're likely, completely inert...that's for sure. My stands are nearly 80 lbs per side!
SYSTEMS-
#1: Aurender N100H>Ayre QB-9 DSD>Luxman L-505uX (Ayre AX-7 out for evolution upgrade)>PMC Twenty 26s/KEF Reference 1s
#2: C.A.P.S.>SOtM sDP-1000>Wyred4Sound mAMPS>Dynaudio X-14s
Founder-E.S.A.C. esac.club
CDLehner is online now
post #7503 of 7507 Old Yesterday, 12:38 PM
doublewing11's Avatar
Quoted: 205 Post(s)
Liked: 614
Have four KEF CI-200rr-thx arriving this Thursday. Will have CNC manufactured backer boxes fabricated with volume between 10-20 liters. Application is for Atmos heights.......will pass on info along with thoughts installing.
After exhaustive research, thought best available product for my room........hoping they sound good.
doublewing11 is offline
post #7504 of 7507 Old Yesterday, 12:53 PM
wse
wse's Avatar
Quoted: 1040 Post(s)
Liked: 523
I heard them they sound amazing!
Pictures after you install please
wse is offline
post #7505 of 7507 Old Today, 06:26 AM
TheBrandon's Avatar
Is your wall still under construction? Mounting depth from surface is 4.98 in, is your wall 2x4? I should have the Ci 200QL next week and will have to do some brainstorming if these don't fit the wall (Surface depth is 3.93 inches, my understanding is 3.5 is what you'd need for 2x4 so hoping that sheet rock buys the difference.) I am curious if you're in my boat having to possibly come up with a solution and if so I'd love to hear it.
TheBrandon is online now
post #7506 of 7507 Old Today, 07:07 AM
Quoted: 205 Post(s)
Liked: 614
No, this will be an on-ceiling application since it is inside soundproofed shell using clips/channel 5/8 th's OSB + GG+ 5/8th's drywall.......hence the reason for backer boxes. I have to have backer boxes CNC manufactured.......volume will be between 10-20 liters per manufacture spec.
Backer boxes will be attached directly to ceiling using four IB-3 clips.......
And will be hidden behind acoustic fabric in four corners of ceiling cloud here.........depth of ceiling cloud is 8-1/4" which determines depth of backer box for each speaker box.
In your case, speaker will not fit in standard 2x4 wall.........I suggest using another layer of 5/8 th's inch drywall and have edges with corner bead finished with plaster or use decorative wood spacer trimmed out...........would not feel comfortable with 0.07 inches clearance.......ie vibration.
post #7507 of 7507 Old Today, 07:13 AM
TheBrandon's Avatar
Can't wait to see your finished result!! You read my mind on my build. When I spoke to KEF they were adamant this would be fine but I'm with you on this. May need some slight modification and personally I think it can look pretty nice. Man, your room is amazing!
Reply Speakers
Kef , Kef Audio , Kef Bookshelf Speaker , Kef Center Channel Speaker , Kef C4 Subwoofer Black , Kef Q100bl Bookshelf Speaker , Kef Ls50 2 Way Speaker System , Kef Q700wa Floorstanding Speaker , Kef T Series Floor Stand Pair
