KEF Owners Thread - Page 352 - AVS Forum | Home Theater Discussions And Reviews
 796Likes
post #10531 of 10539 Old Yesterday, 06:34 PM
KenM10759's Avatar
Quoted: 1414 Post(s)
Liked: 751
I think they do dip below 70hz or so, but I have no measurement means. Try setting the crossover to 80hz and take the centers out of the plugs. You can always put them back in if it's not to your liking.
BTW, a good review:
KEF R100 Review
And the measurements:
KEF R100 Measurements
KEF R500, R200C, R100, SVS SB2000 sub, NAD T758 receiver, Pro-Ject RPM1 TT w/ Ortofon 2M Red, Bluesound Vault2, Sony BDP-S480 BlueRay player, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer.
KenM10759 is online now
post #10532 of 10539 Old Yesterday, 07:09 PM
stash64's Avatar
Quoted: 266 Post(s)
Liked: 92
Thanks for the links. The measurements do somewhat jive with my Audyssey results, though it does not indicate if the port was plugged... I assume not. Next time I need to run Audyssey, I will try the 1/2 plug. I would like to use 80 Hz as cross-over on all my speakers and perhaps the 1/2 plug will get me there.
Sean
stash64 is offline
post #10533 of 10539 Old Yesterday, 07:39 PM
KenM10759's Avatar
Liked: 751
I have an SVS SB2000 sub and crossover my R500's at 70hz, the R200 at the same and the R100's at 80. I think it sounds great in my 13.5' x 19' room and my guests seem amazed. Of course none are audiophile types so probably could be impressed by anything.
I do have a nullpoint listening position so know I really should add a second sub in the future.
post #10534 of 10539 Old Yesterday, 08:57 PM
adrummingdude's Avatar
Quoted: 482 Post(s)
Liked: 319
I was running a pair of SB2000's before I went to the 16 ultras. Honestly, I liked the SB2000's better. Those are sweet little subs.
KenM10759 likes this.
HT: B&W 802 D2 - DefTech Mythos Ten - DefTech XTR-20BP - Dual SVS SB16 Ultra - Parasound Halo A21- Anthem MRX 720 - Samsung UN65JS8500
2CH: Sonus Faber Cremona Auditor M - Parasound Halo A23 - Bluesound Node 2 - Iomega NAS
WAF is currently at DEFCON RED
adrummingdude is offline
post #10535 of 10539 Old Today, 05:17 AM
KenM10759's Avatar
Liked: 751
I'm very happy with the one I have for now. Since I'm really the only one listening 99% of the time, the null point doesn't affect me one bit so no hurry. I want to upgrade the suspension on my bike first as I'll get more joy out of that.
I do often wonder if the SB13 Ultra might be the best choice. In my space I really don't have room for anything larger, but someday I may turn the whole setup 90º and that could accommodate more/better subs. For now, where I have it located literally just to the left of and slightly behind the left front speaker it blends so perfectly seamless that you can't tell it's not full range speakers at work.
adrummingdude and pase22 like this.
post #10536 of 10539 Old Today, 04:47 PM
sworth's Avatar
Quoted: 289 Post(s)
Liked: 148
Attention KEF fans! The R100 are on sale for $799.99 a pair until July 7th. They've only done that price once before, in December of 2015 for just two or three weeks. It could be a while before you see it again. Just the Walnut or Piano Black though.
I just ordered a pair of these. Normally I don't buy speakers without auditioning them, but it seemed like a great deal on exactly what I need. I have a home theater setup that doubles as a music listening room. It's a pretty large room with a high ceiling. The fronts are 15 inch 6 way studio monitors from the 70s doubled with a pair of JBL towers. Klipsch Reference center and a 12 inch Sunfire True Sub. It is capable of putting out a LOT of very nice sound. I've been using a pair of mediocre Klipsch bookshelf speakers for rears and they do the job, but they can't keep up at higher volume levels. The HT installer told me the KEF R100s would be perfect for me because they're small, clean and capable of getting plenty loud to keep up with my front end. My rears are wall mounted a little above head height.
For those who own these speakers... Are you happy with how they sound?
sworth is online now
post #10537 of 10539 Old Today, 05:16 PM
stash64's Avatar
Quoted: 266 Post(s)
Liked: 92
I predict you may start changing out all your speakers to KEF eventually. The Uni-Q has exceptional clarity and the R-series is nicely balanced. I think you will find the sound more refined than your other speakers.
Sean
stash64 is offline
post #10538 of 10539 Old Today, 05:21 PM
KenM10759's Avatar
Liked: 751
+1!
What he said. You're in for a treat, but don't take my word for it. For kicks, try them in place of the front mains you're using now, with the subs. I'd be surprised if you weren't....surprised.
post #10539 of 10539 Old Today, 07:28 PM
sworth's Avatar
Quoted: 289 Post(s)
Liked: 148
That makes me feel a lot better about buying them without auditioning them first. Thanks! But I'm positive my mains aren't going anywhere. Back in the 70s my brother had a friend who designed and built speakers for JBL and Roger Sound Labs. He started his own company and my brother hired him to design and build the ultimate studio monitors for his McIntosh system. I ended up with them when my brother downsized a few years ago. They are the most incredible speakers I've ever heard, and I've heard some pretty fine speakers. I want to be buried with these mains!
Reply Speakers
Kef , Kef Audio , kef blade 2 , Kef Bookshelf Speaker , Kef C4 Subwoofer Black , Kef Center Channel Speaker , Kef Ls50 2 Way Speaker System , Kef Q100bl Bookshelf Speaker , Kef Q700wa Floorstanding Speaker , kef reference 3 , Kef T Series Floor Stand Pair
