KEF Owners Thread - Page 370 - AVS Forum | Home Theater Discussions And Reviews
 933Likes
post #11071 of 11089 Old 10-10-2017, 08:30 AM
Originally Posted by Nick V View Post
It should be oversized (it can't have that tiny bit of light that leaks through around the shade). Instead of a blind that mounts inside the window frame it should mount above and be the wider than the actual width of the window otherwise some light might leak through.
So you're saying a tiny bit of light leak will show through the projector screen? without doubt?
a bit of ambient room light during the day is fine, the bifolds have built in blinds and won't shut out light completly, just don't want light lines through the back of the screen
Daniel Cook is offline
post #11072 of 11089 Old 10-10-2017, 09:00 AM
KenM10759's Avatar
Quoted: 1600 Post(s)
Liked: 850
It all depends upon the type and quality of the projector screen. Some projector screens are engineered to be more opaque than others where that wasn't a big consideration. Very few installations are in front of a window.
Best of luck. I'm sure there will be easy solutions to any problems that arise!
Daniel Cook likes this.
KEF R500, R200C, R100, SVS SB2000 sub, NAD T758 receiver, Pro-Ject RPM1 TT w/ Ortofon 2M Red, Bluesound Vault2, Sony BDP-S480 BlueRay player, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer.
KenM10759 is online now
post #11073 of 11089 Old 10-10-2017, 09:03 AM
Snowmanick's Avatar
Quoted: 315 Post(s)
Liked: 441
Light will come through. You can add sidetracks to most pull downs though, or make your own. These will reduce or eliminate that light on the side.
This is one example, to show what I'm talking about.
https://rollertrol.com/images/blackout-roller-blinds/blackout-roller-blind-using-u-channel-guide-650x488.jpg
KenM10759 and Daniel Cook like this.
Snowmanick is online now
post #11074 of 11089 Old 10-10-2017, 09:47 AM
a better view of the room and I put the grilles on the surround speakers, still waiting for atmos x 4 to go in
Nick V, Botika and KenM10759 like this.
post #11075 of 11089 Old 10-10-2017, 10:06 AM
KenM10759's Avatar
Liked: 850
Looking great!
Where will you be placing subwoofers and which did you choose?
post #11076 of 11089 Old 10-10-2017, 10:10 AM
Originally Posted by KenM10759 View Post
Looking great!
Thanks! Just the one subwoofer, I kept my existing BK Electric 600DF+ (gloss piano black)
In the most recent two photos, the first one looking at the front of the room - on the right there's a couple of wall plates (power+sub plate), it will go there.
post #11077 of 11089 Old 10-10-2017, 10:38 AM
KenM10759's Avatar
Liked: 850
I can't find any specs nor reference to that model subwoofer using Google, perhaps I'm just not good at searching.
The reason I wanted to look is because you've got the very best in-wall speakers made, they would really shine if paired with a single (or better, a pair) of new subs that are commensurate with the quality of the speakers. A pair of 500w ported subs (or higher power) would give you a better chance at even distribution of low frequencies present in movies today. With a single sub of less power, you may be unable to get good bass response from all seats and/or not be able to reach reference levels or the true lowest frequencies.
Is the B&K 600DF+ still available? What amp does it have and is a sealed downfiring sub or ported front-firing sub?
I'm not trying to spend your money, just want to help assure that you get the very best results for the investment you've made to this point.
post #11078 of 11089 Old 10-10-2017, 10:59 AM
It's this, I had it in my head it was '600', but it's the plus I know that.
http://www.bkelec.com/hifi/sub_woofe...th-df_plus.htm
I haven't wired in a second sub, which is a bit of an oversight
KenM10759 likes this.
post #11079 of 11089 Old 10-10-2017, 11:10 AM
KenM10759's Avatar
Liked: 850
That's a good one! Yes, a second one may be needed but you won't know for sure until the room is setup and you have several seats from which to check response.
post #11080 of 11089 Old 10-10-2017, 11:15 AM
Hopefully I'll manage, Louise wouldn't be overly keen on another subwoofer
Seating is like this, ignore furniture models used - but I will be on that sofa 100% of the time
post #11081 of 11089 Old 10-10-2017, 11:22 AM
Sorry it's not KEF related, but those ceiling lights are for partying..
post #11082 of 11089 Old 10-17-2017, 02:08 PM
EPlay's Avatar
Quoted: 123 Post(s)
Liked: 55
They're here!
EPlay is online now
post #11083 of 11089 Old 10-17-2017, 04:25 PM
KenM10759's Avatar
Liked: 850
Originally Posted by EPlay View Post
They're here!
WooT! Congrats!
Here's to hoping they're everything you'd expect them to be!
Do report back, you're the first here to get them as far as I know.
post #11084 of 11089 Old 10-17-2017, 04:28 PM
noobtv's Avatar
Quoted: 86 Post(s)
Liked: 29
They're here!
Exciting stuff! I still have the massive boxes for my Q900s and sub in the living room pissing off the girlfriend.
noobtv is offline
post #11085 of 11089 Old Yesterday, 12:35 AM
Hifisound's Avatar
Quoted: 110 Post(s)
Liked: 27
The Q900 woofer rolls off above 120Hz (https://www.stereophile.com/content/...r-measurements)
Does anyone know the roll off frequency for Q500, Q700 ?
Hifisound is online now
post #11086 of 11089 Old Yesterday, 06:41 AM
KenM10759's Avatar
Liked: 850
Not sure, but why is this important? The roll-off is termed as "gentle" so not a light switch, solid wall type of thing. As long as the crossover network handles this with generous capacitors (and it clearly does), none of these speakers are abrupt.
Just curious why you're looking at this particular aspect.
post #11087 of 11089 Old Yesterday, 08:12 AM
Hifisound's Avatar
Quoted: 110 Post(s)
Liked: 27
I never said its abrubt
Just curious about the crossover design info of Q500 and Q700, thats all
post #11088 of 11089 Old Yesterday, 12:07 PM
sivadselim's Avatar
Quoted: 269 Post(s)
Liked: 226
They're here!
I miss days like this...................
Lp85253 likes this.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #11089 of 11089 Old Yesterday, 05:08 PM
KenM10759's Avatar
Liked: 850
You can still have a day like that now & then. Just open the wallet and they will come...
Lp85253 likes this.
Reply Speakers
Kef , Kef Audio , kef blade 2 , Kef Bookshelf Speaker , Kef C4 Subwoofer Black , Kef Center Channel Speaker , Kef Ls50 2 Way Speaker System , Kef Q100bl Bookshelf Speaker , Kef Q700wa Floorstanding Speaker , kef reference 3 , Kef T Series Floor Stand Pair
