KEF Owners Thread - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 640Likes
Old 11-17-2008, 06:44 PM
ec282's Avatar
thanks for your helpful responses
i'll probably test out 80hz and 100hz for the 3005 and see how it sounds.
ec282 is offline
Old 11-18-2008, 02:52 PM
bosco007's Avatar
anybody have any experience purchasing the cosmetic imperfection speakers from accessories 4 less ?
and also any reason to be concerned with B stock speakers?
im looking to get the iQ7s for similar price of new iQ5s
thanks in advance for the help
bosco007 is offline
Old 11-18-2008, 04:40 PM
Jurukk's Avatar
There's no reason to buy B stock because you can go to eBay and buy new with cashback.
Jurukk is offline
Old 11-19-2008, 08:36 PM
ATD1's Avatar
Originally Posted by pal1982 View Post
Just ordered them for a 5.1 system in my showroom... they are similar but not quite to the level or the old XQ line... much better higher frequency and a more well rounded out sound. The bottoms seems more tighter as well... Need to break in... i got iQ70, iQ60C, iQ30, and a PSW2500... VERY GORGEOUS SPEAKER!
P.S. I have a pair of IQ7's from the old line i wanna move at cost... if any one is interested!
Also... as far as the in ceiling yes i have used them alot! As well as the inwall take a look at http://www.premieracousticlifestyles.com/projects.html and notice Ken's system it's all based on ACE9000 in walls! For in ceiling i use the 160 and the 200's the 200's primarily.... I used the 160's with the IQ's and anything below (I.E. other custom product or KHT) i WOULD HIGHLY RECOMMEND NOT PAIRING THE 160's with the Ref series! I paired the 160's with XQ's and it sounded way off balance... Always was playing with tone controls in the back channels... no fun... by all means do the 200's worth their weight 10 times over!
-Brad
Can you tell me if the plinth on the new IQ70 will fit on the old IQ7?
ATD1 is offline
Old 11-20-2008, 01:51 PM
bosco007's Avatar
If I get the iQ5s as my fronts, would it better to use another iQ5 as the center or should i get the iQ6c?
thanks in advance
bosco007 is offline
Old 11-20-2008, 02:15 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Always better to have matching speakers across the front (L,C,R) if you can. So if you have room for a floorstanding center, get another iQ5.
Afro GT
afrogt is offline
Old 11-20-2008, 05:17 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
thanks in advance
No question. If you can accommodate it, a 3rd iQ5 is the way to go.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
Old 11-21-2008, 06:39 AM
kwilkins's Avatar
I just had a home install done and now have the Kef 3005 surround speakers. In reading some reviews it seems that a short while back Kef updated the line and the new model number is KHT3005SE. How can I tell if I have the new model or the old one?
On a couple of reviews they mention the speakers look almost identical apart from the new tweeter cover. The part of the tweeter I can see on the satellites looks like a small silver fan.
Can anyone help me figure out if I have the most up to date version of the 3005?
Ken
kwilkins is offline
Old 11-21-2008, 08:59 AM
afrogt's Avatar
Liked: 755
wouldn't the back of the speaker have a label that says 3005 or 3005se?
More importantly, how does it sound?
I believe the SE model has the star or fan cover over the tweeter. You can tell in the picture gallery.
http://www2.kef.com/US/SurroundSound/KHT/3000
The older model is here.
http://www.accessories4less.com/make...n-Black/1.html
Afro GT
afrogt is offline
Old 11-21-2008, 12:34 PM
kwilkins's Avatar
The speakers are mounted in a way that I can't see the back of them.
I haven't had a chance to listen to it yet.
kwilkins is offline
Old 11-21-2008, 01:59 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
There is some discussion of this somewhere in this thread. I 'think' that we determined that the "tangerine" waveguide didn't necessarily correlate with the "SE" moniker. I 'think' there are some "SE" 3005s without the waveguide. But if you have the waveguide, you have the "SE" model.
You may want to look back in this thread for the discussion.
Old 11-22-2008, 09:51 PM
kwilkins's Avatar
Thanks so much, I "feel" better now because I do have the waveguide.
I listened tonight for the first time and they sound great. My only complaint is it's a bit difficult to hear dialog at times. I'm wondering if I should replace the center channel with something different?
Ken
kwilkins is offline
Old 11-22-2008, 10:39 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
I assume you calibrated everything properly. There are some other posts in this thread regarding the same subject. It seems that some people have (or have contemplated) replacing the center with an iQ series center channel speaker. The good thing is that the iQ centers should match up pretty well timbre-wise. The tweeters are very similar, if not identical. Maybe an iQ2c would be a good choice.
Old 11-23-2008, 09:11 AM
kwilkins's Avatar
Thanks for the suggestion.
Has anyone paired up an iQ2c with a 3005 SE setup, and if so would you recommend it?
Are there any other recommendations for improving the center channel dialog, it's quite hard to hear in many cases. I have a decent budget to upgrade the center, I'm just not sure what the best way to go is. Also, I have the center mounted on the wall above a 60 inch plasma.
Thanks for any and all advice.
Ken
kwilkins is offline
Old 11-23-2008, 12:05 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
I assume you angled the speaker toward your ears. Is the plasma on the wall below the speaker or out front a bit. How high is the speaker? How close is it to the ceiling? How big is your room and how far do you sit from the TV?
Old 11-23-2008, 12:57 PM
kwilkins's Avatar
The speaker is angled toward my ear.
The plasma is flat on the wall below the speaker, the front of the speaker sticks out a bit beyond the plasma.
The bottom of the speaker is 68 inches from the floor, and 4 inches from the top of the TV.
The top of the speaker is 32 inches from the ceiling.
The room is 12 x 14 and I sit 11 feet from the TV.
kwilkins is offline
Old 11-23-2008, 01:39 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
LOL.
What size shoes do you wear?
Old 11-23-2008, 02:29 PM
kwilkins's Avatar
LOL.
8-1/2,,,,,,,, but I tell my wife 9
kwilkins is offline
Old 11-23-2008, 06:44 PM
elee532's Avatar
Quoted: 78 Post(s)
Anyone know where I can get a wall mount bracket for iQ1 speakers? The only two places i have found one online indicate that it's not in stock. Thanks for any help!
elee532 is offline
Old 11-24-2008, 02:19 AM
SWORD_FISH's Avatar
http://www.independentaudiovideo.com...itemid=1000495
SF
SWORD_FISH is offline
Old 11-24-2008, 10:06 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Hey, SWORD_FISH. Is that a reliable retailer? Just curious. I'll add their addy to my collection of online retailers.
Old 11-24-2008, 01:04 PM
ajbuster's Avatar
I'm in a similar boat but cannot use a 3rd iq5 as my center. Is there no other center style speaker in the iq5 line?? I only saw the iq6 as well and figured that must be the center to pair with the iq5.
ajbuster is offline
Old 11-24-2008, 02:18 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
There is the iQ2c which only features a single 5.25" UniQ driver. With the additional low frequency drivers, the iQ6c is the better center to pair with the iQ5s and is a great match for them. Why are you searching for a different center speaker offering than the iQ6c?
The nice thing about KEF's coincidentally arrayed UniQ driver is that when used in a horizontal center channel speaker, it does not suffer from any of the detriments common to almost all conventional horizontal center channel speakers. It is the perfect driver configuration for a horizontal speaker. Rotate the UniQ driver 90° and it still absolutely identical.
Old 11-24-2008, 07:22 PM
ajbuster's Avatar
I guess I was figuring I needed a different center based off of your reply above. Glad to know these would match...the price seems pretty low on a few different sites for the IQ5's and IQ6 center right now. Thanks!
ajbuster is offline
Old 11-24-2008, 07:33 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
That reply was to someone who COULD accommodate a tower speaker in the center. Perfectly identical speakers across the front soundstage is the ideal situation. When you can do it.
With most manufacturer's horizontal center channel speaker offerings there are often serious compromises in performance relative to that which would be provided by a vertical speaker, especially one that is identical to the front L/R speakers. But, as I pointed out, the KEF's UniQ driver sidesteps many of these issues.
Old 11-25-2008, 06:35 AM
farrago's Avatar
Hello, I am building by first home theater and your opinion would be greatly appriciated. I bought Onkyo 606 and now trying to decide between 3005 or iQs
My room is 19 x 12 with 8 foot ceilings. System will be used for 50% music (hard rock or jazz) and 50% movies. What would you recommend to go with?
3005 or iQ5 and iQ6 as LCR, iQ1s back, PSW2500 sub.
By the way, salesperson in a store told me that KEF is no good for listening heavy music. It can not be true, is it?
farrago is offline
Old 11-25-2008, 02:16 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
If the money and space considerations are no object, why would you NOT buy the better speaker setup? If you can get a different sub, you may want to do that.
They are very revealing speakers. So loud and/or poor recordings can sound very harsh on them. So, no, I would not necessarily recommend them for heavy metal listening. Rocking out is NOT where they really shine.
Old 11-25-2008, 03:31 PM
farrago's Avatar
After posting my first post I went to a store again. I took Spawn soundtrack CD with me. Listened to it on 3005s and iQs setup: iQ7s and iQ2 LCR, iQ1 backs PW2500 sub. And I can tell you that I was not really impressed with iQs. In my opinion 3005 sounded better, fuller and produced more highs. Bass was the same. So I think I am going with 3005. And I got nice deal on them too. $1200.
If I would make 7.1 system out of 3005 what speakers could I use as LR? Which ones would integrate nicely with center and sub?
Thanks again
farrago is offline
Old 11-25-2008, 04:53 PM
afrogt's Avatar
Liked: 755
If you don't like any of the iQ speakers, why not get two more the 3005 satellites?
http://www.accessories4less.com/inde...arch_query=kef
Or get the smaller 1005 and use them as your surround back speakers.
Afro GT
afrogt is offline
Old 11-25-2008, 05:52 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
iQ1s, but I would get a center to go with them, too. Like the iQ2c.
Kef , Kef Audio , kef blade 2 , Kef Bookshelf Speaker , Kef C4 Subwoofer Black , Kef Center Channel Speaker , Kef Ls50 2 Way Speaker System , Kef Q100bl Bookshelf Speaker , Kef Q700wa Floorstanding Speaker , kef reference 3 , Kef T Series Floor Stand Pair
