Official MK - Miller & Kreisel Thread?!? - Page 131 - AVS | Home Theater Discussions And Reviews
 73Likes
post #3901 of 3926 Old 04-15-2015, 01:40 AM
jaddie's Avatar
Quoted: 99 Post(s)
Liked: 61
Originally Posted by wiffleball View Post
I just asked this question on the receiver forum. "What receiver for 4 ohm M&K speakers." I didn't realize there was an M&K thread here. I want something that can drive them and make them sound great without the receiver straining/dying. My old receiver a Yamaha rx-530 did alright but my HK AVR75 made them sound amazing. However the receiver keeps shutting down, sometimes randomly and now when I turn up the speakers for a movie. I don't know if it's a 4 ohm issue or just the usual HK suckiness. I'm looking for something new or used, hopefully under $1000.
Denon X4000 seems to handle them just fine.
jaddie is offline
post #3902 of 3926 Old 04-15-2015, 06:49 AM
oRIDDLERo's Avatar
Originally Posted by richmagnus View Post
I take it you mean the on wall MP150 that angles up/down. This can't be rotated 90 degrees. The tweeters must be in the vertical plane.
If you are talking about an angled S150 in room these are no longer made and again must not be rotated 90 degrees.
I would suggest a 950 as it will be a better much with your existing 150's.
Great info, thank you! I am not familiar with the 950 series (Google also came up with nothing) Do you have an exact model number or link to specs / pics? What do you think about running dual 750 THX? Could i splice them together and run them at 4 ohms? My amp is good with loads down to 2 ohms.
oRIDDLERo is offline
post #3903 of 3926 Old 04-15-2015, 07:18 AM
richmagnus's Avatar
Quoted: 96 Post(s)
Liked: 55
www.mksound.com/950-series
The 750 are nowhere near a good as the S150's.
The 950 are a much closer match. They feature the new Pro tweeter.
Marantz AV7702, Anthem Statement A5,Lyngdorf TDAi 2170, MK Sound MPS 300 LCR,MK Sound S300T's, MK Sound V12 x 2,Oppo 103,Sonos ZP90,Qnap TS112 NAS,PanasonicTXP50GT60.
richmagnus is online now
post #3904 of 3926 Old 04-15-2015, 08:43 AM
jaddie's Avatar
Quoted: 99 Post(s)
Liked: 61
+1.
The 750s can work quite well with adequate subs and good room cal. But then, that's true of lots of speakers. 950s are a different animal, much better. S150s are simply "the reference".
Caution to all original S150 (non mkII) owners...treat 'em nice, there are no more replacement drivers in the world. MKII drivers are not interchangeable. Blow the center tweet, you'll be buying a used S150 on eBay.
richmagnus likes this.
jaddie is offline
post #3905 of 3926 Old 04-16-2015, 02:59 AM
Bostown's Avatar
Originally Posted by wbcooley View Post
These s-90's are not black and all I know is what was said in the few reviews I could find online. The one I found on here said "do not let these pass you by" My sister has picked these up for me and I am waiting for her to deliver these to me when she returns from Florida. What have I bought ???. I want to treat them right and make them sound as good as possible without breaking the bank.
So you scored a great 2.1 system. The S-90s seem to be the hidden gem in the bigger scheme of M&K products over the years. It's a close Kin to the S-5000THX in fact as I've written in other posts , When space constraints doesn't allow the user to use an S-5000thx, the S-90 is recommended as a direct replacement to use in it's place. as a 2 Channel set up the S-90 / V 125 combo will certainly hold it's own against other models in the M&K Line up ( S-125 comes to mind) .
In any case if you're looking at 2 Channel amps for stereo functionality. An ADCOM 555 / 555 II , Carver A500x , are fairly priced on the used market. NAD 2200PE, 2400, 2600a are also very much up to the task. Other brands to keep watch for B&K, Rotel, Parasound. again if you're looking at "previously owned" units there are several options at all price levels.
I STRONGLY recommend getting a high pass filter ( placed between your pre-amp and amp) choke the sats at 80hz and let the sub handle the rest. M&K had a few variations . If you're using an AV pre-amp or receiver. you can sort out hi/low pass within that unit so no need for a separate passive unit , but if your pre-amp doesn't allow for filtering ( most don't , although Parasound's P5 does and is also a solid DAC) you should find a hi pass filter so that you can properly dial in the S-90's to mate with the V-125 sub.
There isn't much chatter out there on the web about the S-90's but it's a great sounding speaker system. Music, Movies the whole nine yards.
Bostown is offline
post #3906 of 3926 Old 04-24-2015, 11:51 AM
Speaking of the S-90s, anybody have any S-90 speakers they are looking to sell or know of any being sold? Same for the S-5000. I've got a S-5000 LCR set and I'd be damn happy if I could build a full Atmos/DTS:X setup with S-90/S-5000. I suppose I could settle for S-100B...
On the matching front, the S-80/85/90/100B/125/150 should all be timbre matched, correct?
I also have 3x S-80 speakers and a MX-100 sub for anybody interested in a buy/trade offer.
energizerfellow is offline
post #3907 of 3926 Old 04-24-2015, 12:01 PM
sfav's Avatar
Anyone know the exact tweeter used in the S-300?
sfav is online now
post #3908 of 3926 Old 04-24-2015, 06:24 PM
jaddie's Avatar
Quoted: 99 Post(s)
Liked: 61
Don't have a part #, but I suspect it's unique to the S-300, and there may actually be two part numbers involved, like the S150 (the middle is one part, the upper and lower is another). However, since a great deal of the voicing of the speaker is the tweeters and crossover, I wouldn't expect them to use the S150 tweeters. As you know, the S150 and S150 MKII use very different tweeters too.
jaddie is offline
post #3909 of 3926 Old 04-24-2015, 06:26 PM
jaddie's Avatar
Quoted: 99 Post(s)
Liked: 61
MK just announced today that product will (once again) be distributed by Magnolia. Depending on how you view Magnolia, this comes as either good or bad news.
IMHO, I'm going with "good for MK and Magnolia, bad fur everyone else".
jaddie is offline
post #3910 of 3926 Old 04-24-2015, 09:01 PM
Dave Vaughn's Avatar
Quoted: 234 Post(s)
Liked: 291
At least people will be able to listen to them now! I think it's overall good news.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is online now
post #3911 of 3926 Old 04-25-2015, 02:17 AM
richmagnus's Avatar
Quoted: 96 Post(s)
Liked: 55
I think it's a real shame that the U.S. market hasn't been able to access the new MK products. Even if it is Magnolia, as Dave says now you can.
If you liked the MK of old, then you will love the new MK even more so.
Dave Vaughn and jlcichocki like this.
post #3912 of 3926 Old 04-25-2015, 07:42 PM
Quoted: 50 Post(s)
I'm absolutely thrilled, thank you M&K!!
jlcichocki is offline
post #3913 of 3926 Old 04-26-2015, 08:22 AM
sfav's Avatar
Magnolia, no comment on their impact on premium product lines.
sfav is online now
post #3914 of 3926 Old 04-28-2015, 06:07 AM
jaddie's Avatar
Quoted: 99 Post(s)
Liked: 61
The one near me has a fair selection of premium lines in a horrible retail display and an auditioning room that is impossible to hear anything in. But there they are, everyone else has packed up and gone home.
jaddie is offline
post #3915 of 3926 Old 04-28-2015, 12:46 PM
Quoted: 50 Post(s)
Where did you see this?? I can't find any info about this anywhere.
post #3916 of 3926 Old 04-28-2015, 01:21 PM
jaddie's Avatar
Quoted: 99 Post(s)
Liked: 61
Sorry, where did I see what? The bad marketing of Magnolia? Pretty much any store, just walk in and try to audition anything.
jaddie is offline
post #3917 of 3926 Old 04-28-2015, 03:12 PM
Quoted: 234 Post(s)
Liked: 291
And watch the majority of the clerks scatter like cockroaches in the light?
post #3918 of 3926 Old 04-28-2015, 10:12 PM
jaddie's Avatar
Quoted: 99 Post(s)
Liked: 61
...after you ask them a technical question...any technical question.
Dave Vaughn likes this.
jaddie is offline
post #3919 of 3926 Old Yesterday, 09:10 AM
firefightingrob's Avatar
Quoted: 13 Post(s)
Liked: 24
[QUOTE=jaddie;33856298]...after you ask them a technical question...any technical question.[/QL
LOL, this just happened to me at my local Magnolia. 3 employees where sitting outside of the demo room. I walked right by them, and they did not even acknowledge my presence. I was in the room for 20 minutes trying to get music to play, with no luck. Peaked outside the room.... crickets.
Dave Vaughn and audiofan1 like this.
firefightingrob is online now
post #3920 of 3926 Old Yesterday, 09:19 AM
sfav's Avatar
[quote=firefightingrob;33915314]
Better than: "I see that speaker has three tweeters, why?" "You get more highs that way and if you blow one it keeps working"
sfav is online now
post #3921 of 3926 Old Yesterday, 10:01 AM
Kelvin1965S's Avatar
Quoted: 101 Post(s)
Liked: 81
I wondered why there wasn't much talk of MK speakers over on here. At least there will be a supplier now (though I've no idea who or what Magnolia is, but I get the impression it is a bit like the old 'Comet' chain in the UK).
I've had my MP150 for over a year now, used with a pair of white (thanks to Rich's input here) S150T as side surrounds and an old pair of K4 tripoles as surround backs. I also have a small set up in my conservatory using a 4.1 set up of K5 fronts and more K4 surrounds.
My plan early next year is for a bit of a rebuild of my living room and installing a pelmet all round the room (not sure what the US term for a pelmet is?). I will get a suitable Atmos/DTS:X AVR/processor so I can run 5.1.4 set up with MK speakers.
I will then be able to discretely install 4 x 'ceiling' speakers and move the S150T lower down nearer to ear level for the surround position. They will have to be further back than ideal due to a patio door on the right side of the room, but I think it will work well. I'm not 100% sure what speakers will be used in the 'ceiling' positions, but I have a spare pair of K15 and can recycle the K4 that are currently surround backs in my existing 7.2 set up. Since my 'pelmet' could be AT fabric then I could put any speakers up there, even scruffy second hand ones, so perhaps some 950s if any turn up.
I've added a couple of pictures of my MK set up now that I've found this thread. My TV is on an electric lift so that I can have my MP150 LCR all at the same height for critical projector viewing.
ID:	695722   Click image for larger version
Name:	TV raised.jpg
ID:	695730   Click image for larger version
ID:	695738   Click image for larger version
Name:	Screen down lift raised.jpg
Dave Vaughn and richmagnus like this.
Zooming: Been there, done that, bought the lens...now using e-shift.
Kelvin1965S is online now
post #3922 of 3926 Old Yesterday, 06:13 PM
jaddie's Avatar
Quoted: 99 Post(s)
Liked: 61
[quote=sfav;33915474]
OMG, is that for real? Where?
Reminds be of the old days when I sales guy told me, regarding a cassette deck, "You record with Dolby on, play with it off". I cringed visibly, then explained how Dolby B worked, that it was an encode/decode process and you had to leave it on, and to his credit, the guy humbly apologized.
jaddie is offline
post #3923 of 3926 Old Yesterday, 06:17 PM
jaddie's Avatar
Quoted: 99 Post(s)
Liked: 61
Magnolia is found within Best Buy stores, trying weakly to be a boutique audio store within a discount appliance store. No idea who thought that up, but it must sort of work, it's been going on for years. M&K announced this week they and re-partnered with Magnolia, so yes it's another supplier, and that will be good for M&K, but...well, you do become known by the company you keep.
jaddie is offline
post #3924 of 3926 Old Today, 03:55 AM
Quoted: 101 Post(s)
Liked: 81
That's kind of how I perceived Magnolia just going on the comments I've read on here.
It's really odd compared to the UK set up though; we have very few outlets, but those who do sell them have very well set up demo rooms, so you really get chance to properly hear what they can do. Basically it is a much more 'high end' product over here, with appropriate high end dealer support.
The UK distributor Gecko is near me, and is where I got mine from (picked my white S150T up the same day as Richmagnus as it happens). They have amazing rooms including a more living room type area and a proper all black dedicated room. Another dealer in the North UK IdealAV has a similar light and dark room set up. Both have regular forum days where we can go and demo without feeling under pressure to buy (though of course eventually I did ).
post #3925 of 3926 Old Today, 07:11 AM
ckenisell's Avatar
Quoted: 28 Post(s)
Liked: 26
We do have a Gecko over here too, but he sells car, boat and motorcycle insurance. He's Australian.
ckenisell is offline
post #3926 of 3926 Old Today, 02:36 PM
richmagnus's Avatar
Quoted: 96 Post(s)
Liked: 55
I've never heard anything good about Magnolia but at least there is a chance now that the U.S. can get to hear the new MK Sound Products as they are serious speakers, out performing the brilliant MK of old.
Good to see you here Kelvin.
Reply Speakers
Speaker Systems
