Official MK - Miller & Kreisel Thread?!? - Page 132 - AVS | Home Theater Discussions And Reviews
 75Likes
post #3931 of 3935 Old 05-17-2015, 05:47 PM
billqs's Avatar
Quoted: 102 Post(s)
Liked: 30
^ Thanks for confirming for me. I appreciate the knowledge as I don't have a lot about M&K.
billqs is online now
post #3932 of 3935 Old 05-18-2015, 03:09 PM
richmagnus's Avatar
Quoted: 96 Post(s)
Liked: 56
Originally Posted by billqs View Post
I have a Denon X7200W for my receiver. I'm currently using Def Techs and Tannoy for Atmos overhead speakers. I've just really gotten into M&K recently. I see that many of their speakers are 4Ohms. Would the Denon 7200 be able to drive those without overheating?
I use a 7200 to power my MK 300/150 Atmos system. No issues.
Have also used the 5200 to power an MK S150 7.2.4 system at reference all gas long.
Marantz AV7702, Anthem Statement A5,Lyngdorf TDAi 2170, MK Sound MPS 300 LCR,MK Sound S300T's, MK Sound V12 x 2,Oppo 103,Sonos ZP90,Qnap TS112 NAS,PanasonicTXP50GT60.
richmagnus is offline
post #3933 of 3935 Old 05-18-2015, 04:29 PM
Scottyb09's Avatar
Quoted: 33 Post(s)
I'm a 150 owner (with a 350 sub) and used to power my five speakers with a Denon AVR2809. The system played VERY loud (while around -5 on volume) with no overheating or clipping issues. I've since switched to Marantz separates also without issue. I think you'll be just fine with a 7200
Scottyb09 is offline
post #3934 of 3935 Old Today, 03:23 AM
jaddie's Avatar
Quoted: 133 Post(s)
Liked: 73
Denon seems to agree.
jaddie is online now
post #3935 of 3935 Unread Today, 12:54 PM
wbcooley's Avatar
Liked: 0
Thanks Bostown
Originally Posted by Bostown View Post
So you scored a great 2.1 system. The S-90s seem to be the hidden gem in the bigger scheme of M&K products over the years. It's a close Kin to the S-5000THX in fact as I've written in other posts , When space constraints doesn't allow the user to use an S-5000thx, the S-90 is recommended as a direct replacement to use in it's place. as a 2 Channel set up the S-90 / V 125 combo will certainly hold it's own against other models in the M&K Line up ( S-125 comes to mind) .
In any case if you're looking at 2 Channel amps for stereo functionality. An ADCOM 555 / 555 II , Carver A500x , are fairly priced on the used market. NAD 2200PE, 2400, 2600a are also very much up to the task. Other brands to keep watch for B&K, Rotel, Parasound. again if you're looking at "previously owned" units there are several options at all price levels.
I STRONGLY recommend getting a high pass filter ( placed between your pre-amp and amp) choke the sats at 80hz and let the sub handle the rest. M&K had a few variations . If you're using an AV pre-amp or receiver. you can sort out hi/low pass within that unit so no need for a separate passive unit , but if your pre-amp doesn't allow for filtering ( most don't , although Parasound's P5 does and is also a solid DAC) you should find a hi pass filter so that you can properly dial in the S-90's to mate with the V-125 sub.
There isn't much chatter out there on the web about the S-90's but it's a great sounding speaker system. Music, Movies the whole nine yards.
Thanks alot for your input. Just posted over on amp receiver forum for even more input. Thanks again.
wbcooley is online now
Reply Speakers
Speaker Systems
