Official MK - Miller & Kreisel Thread?!? - Page 146 - AVS Forum | Home Theater Discussions And Reviews
 204Likes
Old 04-05-2017, 08:49 PM
KC-Technerd's Avatar
Quoted: 96 Post(s)
Liked: 147
Originally Posted by richmagnus View Post
Get rid of the Sony. Drop in an Anthem. Your MK's deserve far better.
www.seriouslycinema.co.uk
Who has a Sony?
KC-Technerd is offline
Old 04-05-2017, 09:27 PM
richmagnus's Avatar
Quoted: 264 Post(s)
Liked: 172
Originally Posted by KC-Technerd View Post
Who has a Sony?
My mistake. Pioneer.
Authorised re-sellers for: Steinway Lyngdorf, Lyngdorf Audio, Acurus, Trinnov, Anthem, Arcam, Denon, Marantz, M&K Sound, Procella Audio, Phase Tech dART speaker systems, KEF, Paradigm, Origin Acoustics ,Paradigm, Bose PROFESSIONAL,Sonace, TruAudio, Moovia, Front Row, Pallado, DT Screens, Draper, Projecta, Screen Innovations, Grandview JVC, Sony, Barco, Sim2, Innuos, Zappati, Artnovion, Starscape and more......
richmagnus is offline
Old 04-05-2017, 10:13 PM
Quoted: 96 Post(s)
Liked: 147
^ Well, I got the Pioneer Elite SC-77 because it was the best THX controller/receiver I could find at the time (the SC-79 didn't warrant the extra cost). It is rated for 240W continuous per channel at 1 kHz, 4 ohm, 1.0 % THD (also THX Ultra 2) which I think is greater than the Anthem MRX 1120 (I can't find the 4 ohm specs for the Anthem, but the Pioneer beats it on the 6 and 8 ohm specs). Two years after got the SC-77 I purchased the S150/X12 system specifically to have a good THX Ultra 2 speaker system to go with it. It doesn't seem to break a sweat playing at reference level, which is louder than I can stand it. All the speaker level settings are attenuated (not boosted) to bring them to THX reference volume. I usually set the volume down 7.5 dB to 15 dB for what sounds like a normally loud theatrical presentation.
It seems like I've had this or a similar conversation before in this thread, back when I first bought the M&Ks.
As far as the struggle with bright and brittle sound, it is exactly the same thing I heard when I auditioned the S300 speaker system before buying the S150s. I've thought it was a room issue since I auditioned the S300s in living room more similar to my own, and the S150s in a wide room with no close side walls. Knocking the 8kHz band down a couple of dB seems to take care of it. It's just something I hadn't tried before.
richmagnus likes this.
Old 04-08-2017, 02:28 AM
richmagnus's Avatar
Quoted: 264 Post(s)
Liked: 172
The MK's are revealing speakers. Our experience with the Pioneers hasn't been the best.
We will often match Anthems with MK products and get great results every time. Try a Denon 7200wa as they are great value for money at the moment.
snpanago likes this.
Old 04-08-2017, 02:58 AM
Kelvin1965S's Avatar
Quoted: 276 Post(s)
Liked: 180
I have MP300 in a partly treated room (front wall 1' deep with Rockwool) and plenty of thick curtains and fabric furniture. I run an Arcam AVR390 (as a processor) into an Arcam P7 power amp. My speakers are anything but bright and brittle; very smooth sounding up to and beyond reference. I use Dirac, but for some listening I switch this off, so it's not because room eq is smoothering the treble either, so it makes me wonder if it's a room/amp issue in your case.
FWIW Richmagnus has heard my set up (the MP300 were his ex display speakers ), so can concur.
I previously used MP150 for my LCR (now recycled as my Atmos channels). These had a 'thinner' sound, but back then my room wasn't treated bar a large rug, though were driven by the same power amp and an older Arcam AV8 processor. They still didn't sound overly bright to me though.
FWIW my P7 is rated 230 watts into 4ohms ALL channels driven, which is probably a difference between an AVR output (I expect it will drop considerably ALL channels driven). MKs seem to relish having plenty of power to drive them.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
Old 04-09-2017, 01:05 AM
Quoted: 96 Post(s)
Liked: 147
^ Thanks. I don't mean to imply any of the dryness and brittleness (for lack of knowing any better way to describe it) is the result of either the S150s or the S300s. There have been various differences in my auditions of speakers including different sources, amps, receivers, and listening rooms. The S300s were never a realistic proposition for me due to size and budget. However I traveled about 1500 miles from home to audition the S150s, and the dealer also had the S300s set up in his living room, so I thought I should take advantage of the rare opportunity to check them out. Most of the dealers in the United States are custom installers, and I found it very rare that anyone was set up to demo any of the speakers at all. There also happened to be a Best Buy/Magnolia store near the dealer I visited that had an older S150 setup in a theater room that I was able to demo. Neither of them had any of the tri-pole surround speakers set up.
At the Magnolia store I just listened to the movie they had playing, but I was using a CD I'm familiar with to demo at the dealer. It contains orchestral music that I've found to be very revealing when played 2 channel. The thin, brittle, dry sound becomes very evident on this and one other CD that I have. The 100+ piece orchestra with some unique instruments just sounds weak and dry. Low notes on the grand piano, bass trombone, tuba, bass cello, etc. seem weak and dry when they should be bold and rich. This is much less noticeable on other music and multi-channel movies. I've heard some of the music from the CD played through a theater speaker system and it doesn't sound this way. It also sounds rich with some headphones. Anyway, I was surprised to find that simply reducing a boost that my Pioneer's room correction system was setting at 8kHz apparently went a long way toward fixing this. I've also found that it makes movies sound closer to what I'd expect them to sound like in movie theaters with the best sound systems. The Pioneer's room correction system is apparently setting for a perfectly flat response including room reflections, and I'm learning that it may be best to exclude the room reflections at higher frequencies. Fortunately the Pioneer lets me adjust most of the room correction criteria myself. My purpose of posting about it here was in case it might help anyone else.
I'm not planning on replacing my receiver anytime soon, unless I discover it is a real problem. I tried to compare it with Yamaha, Onkyo, (and I believe Denon, 4 brands total) before purchasing. The demo setup at the two Best Buy/Magnolias were certainly not the best, but the Yamaha and the Pioneer sounded the best. In retrospect, knowing what I know now, I might have given more consideration to Denon. I'd probably give less consideration to Pioneer now since they've been purchased by Onkyo. Based on the questions I've seen come up in the Pioneer forums, I've found the new manuals to be rather lacking. I think Onkyo is the only option left for a THX receiver now. My next upgrade will probably be a video display.
The S150s are extremely clear and revealing. Dialog is as clear as I've heard it anywhere on any system or speakers, including theaters. However I often find myself listening to details of the orchestral music in movies. Maybe I've just learned to listen better, but it seems like the M&Ks have made it considerably easier to listen to specific subtle details and layers of movie soundtracks. I did have a few frustrations with the grills on the subwoofers for a while, but those have been fixed now and they sure integrate wonderfully with the S150s.
Kelvin1965S and richmagnus like this.
Old 04-09-2017, 01:29 PM
snpanago's Avatar
Quoted: 54 Post(s)
Liked: 46
I have legacy MK s150s x 3 and SURT200M2 surrounds and I have NEVER heard my speakers sound as great as when I hooked them up to the Denon x7200wa receiver. Quality amp power along with Audyssey XT32 room correction.
KC-Technerd and richmagnus like this.
snpanago is offline
Old 04-09-2017, 01:37 PM
asere's Avatar
Quoted: 1441 Post(s)
Liked: 286
Is Ken ever going to release the new subs?
Sent from my SM-G900P using Tapatalk
asere is offline
Old 04-17-2017, 12:28 PM
Quoted: 12 Post(s)
Liked: 0
Hello
What is the different between "Miller and Kreisel SS-150 THX" and "M&K MPS1525M2"
The saller says
"This a similar design to the SS150-THX but in the Professional line"
Is that correct. Is M&K MPS1525M2 better than SS-150 THX???
remains81 is offline
Old 04-17-2017, 07:56 PM
snpanago's Avatar
Quoted: 54 Post(s)
Liked: 46
Originally Posted by remains81 View Post
Hello
The saller says
Here is the product information on those speakers. http://web.archive.org/web/200706091...om/mps1525.htm
snpanago is offline
Old 04-21-2017, 09:50 AM
CaptKid's Avatar
I've been looking for a pair of S-5000's for a while and most I see listed have worn foam pieces critical to the design. I've seen replacements for the S-150 but that foam is quite different. Does anyone know where I can find a correct replacement?
CaptKid is online now
Old 05-25-2017, 06:57 PM
Bostown's Avatar
Sadly I've never been able to find the foam appliques for any of the speakers I've needed then for. I reached out to Ken Kreisel a couple of times over the past half decade. at one point he mentioned offering some of these long lost foam pieces for some models but that was ages ago. S-5000, S90, S-1c those are what I was looking for at the time. I've since parted ways with a many of the M&K speakers I had. I still own the Powered sats and I'm in the process of listing S-100b, S-90, S-85 etc.
I was willing to take on the project of sorting out an order from the vendor if there was enough of a call to action foi have a specific foam replicated. but there isn't enough of a community outside of this thread that I could tap to find out which model makes the most sense to have foams made for. It certainly wasn't going to be a "business venture" more of a community support project. The vendor if I'm not mistaken was SoundCoat. but that was a dead end when I contacted them there's the matter of a cutting die, a fairly sizeable quantity needed to be ordered, and frankly they had little to no recollection of what they made for M&K nor if the parts they used were still around.
Clearly the speakers will play without them but it seems that the situation is such that once they're gone,... they're gone
Bostown is offline
Old Yesterday, 10:48 AM
snpanago's Avatar
Quoted: 54 Post(s)
Liked: 46
In a related question as to the foam appliqués, does anyone understand why the new mksound in Denmark, which supposedly is in possession of the proprietary specs from the original co., excludes the foam altogether in their speakers?
snpanago is offline
Old Yesterday, 01:18 PM
Quoted: 276 Post(s)
Liked: 180
My MK Sound MP150 speakers have the foam on them (see attached picture of them recycled as Atmos speakers). I believe the other mid range models still use the foam too.
However my MP300 do not have them, but they have totally different drivers to the 150 series, so perhaps they aren't necessary?
Name:	Week 2 Atmos speaker.jpg
Old Yesterday, 01:31 PM
snpanago's Avatar
Quoted: 54 Post(s)
Liked: 46
Oh, ok. I was just looking at the online brochure http://www.mksound.com/home-theater/...-series/mp-150
and they are not present in the photos.
snpanago is offline
Old Yesterday, 01:42 PM
Quoted: 276 Post(s)
Liked: 180
Yes, that's odd because the black ones don't show them, only the white ones.
Old Yesterday, 10:21 PM
richmagnus's Avatar
Quoted: 264 Post(s)
Liked: 172
The foam is still used as Kelvin states in the 150 series. The 300 series use the new wave guide so the foam is not required. The 300's do come with thin foam strips in the box if the 300's are to be used as near field monitors i.e. 8 foot or less.
Kelvin1965S likes this.
Old Today, 05:27 AM
CaptKid's Avatar
I was lucky to find a pristine set of S-5000's locally but it would be nice to have some back up foam to handle the eventuality waiting in the wings. I've conversed with Ken recently and I do think he means to get to these appliques. I know he's working on a host of other projects which consume his time and he's pushing to get certain thing out the door by the end of 2017.
Speaker Systems
