Official MK - Miller & Kreisel Thread?!? - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 193Likes
post #901 of 4337 Old 05-03-2008, 12:49 PM
Steve Zodiac's Avatar
A couple of Parasounds for me also - A21 (2 channel) and an A51 (5 channel)... 400w per channel into 4 ohms.
Steve Zodiac is offline
post #902 of 4337 Old 05-03-2008, 01:21 PM
Pajax's Avatar
I am using Nad Masters M25, M15 preamp
Thomas
Pajax is offline
post #903 of 4337 Old 05-03-2008, 01:33 PM
wjr858's Avatar
Originally Posted by thxman View Post
I know it was mentioned earlier in this thread by Chris H. that the exact paint used for M&K speakers is unknown, but has anyone had any luck finding a black paint that closely matches the factory finish? I have a pair of M&K LDM-125 stands in white, which I would love to try to paint black to match some S150s. Any recommendations would be greatly appreciated.
I can't help with the paint directly, but I disassembled a non-functioning M&K Bookshelf 75 and stamped on the inside of the speaker was "VIP Woodworks, Inc.". A google search shows there is a firm by that name in Hesperia, CA. Hesperia is located off the I-15 north of LA and just south of Victorville. If they built other M&K cabinets they might know the source or mix of the black paint. Hope this helps.
wjr858 is offline
post #904 of 4337 Old 05-03-2008, 02:17 PM
svphile's Avatar
Some nice seperates.
M&K was always pretty tight lipped in regards to the paint used on their cabinets. Multiple layers and a baking process. They always told me to use a black paint pen from local art supply stores for touch ups. I don't think anyone is going to stumble onto the magic formula. Might just have to match paint as close as you can or live with them the way they are.
Maybe it was a lack of paint and not cabinets that was the final nail. OOOPS! Did I say that out loud?
svphile is offline
post #905 of 4337 Old 05-03-2008, 06:34 PM
Video's Avatar
Originally Posted by svphile View Post
What amps are S-150 owners using?
I've got 3 s-150's and 2 ss-150's. I'm using an arcam avr350 to drive them. I'm considering selling my 350 and getting an arcam avp700 and emotiva xpa2. I'm not unhappy with the 350 but the upgrade would be a lateral move economically. Does anyone think I would really benefit from the extra juice? For a 4 ohmn speaker the s-150's are very effecient and don't seem to need a ton of juice to drive them because of the sub sat design.
I used to use Parasound amps but when I redid my theater, I switched to Crown Pro Amps. My S-150 mains are powered by 402D at 450 watts per channel and my SS-150 sides and backs are driven by 202Ds at 250 watts per channel. I sold my MX5000 and built two 320 liter TC sounds subwoofers tuned to 11.5 Hz driven by a Crown CE4000 at 3200 watts mono. Its all about headroom.
Video is offline
post #906 of 4337 Old 05-03-2008, 06:37 PM
adidino's Avatar
Quoted: 309 Post(s)
Liked: 238
I'm using a Theta Dreadnaught II for my S150's and SS150's. 450w @ 4ohms. Best amp I've had for these speakers to date.
adidino is offline
post #907 of 4337 Old 05-03-2008, 06:45 PM
lwien's Avatar
The M&K 150's can be driven up to THX reference level and left there all day without ANY sign of strain......................but, as Video has said, when something comes in that requires a lot of power to reproduce at that reference level, you better have the power there to be able to handle it and being that these speakers are nominally rated at 4 ohms, it means that they can dip to well below that, so a rugged power supply, as found in very few if any receivers as compared to separate amps, is a worthwhile investment when running these.
lwien is offline
post #908 of 4337 Old 05-04-2008, 01:35 AM
claydo's Avatar
as seen here http://www.avsforum.com/avs-vb/showthread.php?t=1025840
Eupitment
Currently I have an Pioneer Elite VSX-26TX (yeah it is about 10 years old )
I have hooked up:
computer (spdif-digital)
ps3 (optical)
xbox (optical)
attbox (stero)
ipod (stero, y cable)
to a Sharp Aquos 4664u
Speakers are the M&K THX 750 system.
Problem:
Just recently, half the time I turn on the receiver, It looks fine, lights up and everything, but I get no sound. This really sucks. Then if i turn it off an turn it back on, it wont work. but If i let it sit for no specific time. It will work great and I am in love again. When it does work it flashes (-4db offset) twice before it all clicks on. This dosn't come up at all when its not working. And this is any type of input. Not really sure what any of the problem would be other than OLD and or HEAT.
Solution:
tell me what settings or blah could fix it. Or recommended me a good replacement with hdmi pass through and dts-hd audio, THX is perfered but unnecessary as it has proven to be an outdated, and money driven certification price range is around 600-1500 5.1 is all thats really needed.
claydo is offline
post #909 of 4337 Old 05-04-2008, 09:04 AM
wjr858's Avatar
It looks like your receiver is in a death spiral..... and you should be happy about it! A while back I replaced a VSX-43TX with an Outlaw pre/pro and an ATI 2005 amp. Both made a world of difference with my (at the time) M&K 851s. My ATI puts out 300w at 4 ohms and so has plenty of power for those times when it is needed. A similar amp upgrade will make your 750s shine. As far as the pre/pro it might be a good idea to wait for a few months. I hear most manufacturers are waiting or have just received the chip they are going to use for decoding the new audio formats and need some time before getting into production.
wjr858 is offline
post #910 of 4337 Old 05-05-2008, 09:26 AM
ckenisell's Avatar
Quoted: 110 Post(s)
Liked: 62
Steve,
How do those amps hold up with your 150's? At one point, I wanted to get the A21 and get the in-wall versions of the 150's for the rear speakers to go from 5.1 to 7.1. All of my 150's are powered, but I really wanted to get those in-wall 150's before M&K went out of business and run them with the A21.
Edit: The speakers I'm refering to are the SW-150s. Info can be found here and more pix can be found here.
Chet
ckenisell is offline
post #911 of 4337 Old 05-05-2008, 09:45 AM
Originally Posted by ckenisell View Post
Steve,
How do those amps hold up with your 150's?...
They run a little warm, but then again, that's to be expected being a class A/AB design. (They're even quite warm at idle)
I don't have a particularly large room (18' x 13' - opening through to another room), but at reference levels, there isn't the slightest hint of any strain on the amps whatsoever... and I suspect there's also plenty left in reserve.
I'm certainly no expert, but I'd say that they are very well-built amps, with plenty of power and produce an uncolored sound. They perform very well with the M&K's and I'd certainly recommend them.
post #912 of 4337 Old 05-05-2008, 09:54 AM
lwien's Avatar
Most speakers and many amps have a sonic signature, that is, they can have a tendency to sound "hard" or "soft". And if these sonic signatures are prominant, you don't want to create a situation that magnifies these signatures by mating equipment with the same tendencies.
The M&K's have had a reputation for being a bit "hard" and the Parasounds have a reputation for being a bit "soft". A pretty nice match, if you ask me.
lwien is offline
post #913 of 4337 Old 05-05-2008, 03:38 PM
MKtheater's Avatar
Quoted: 1589 Post(s)
Liked: 1116
I ran M&K's(the s-150, s-250, and S-5000THX, and their other s-series and 750 series) with many different types of amps. Too many too list. I will give it a go anyway.
Ada ptm-650, ada ptm-6150, cinepro 3k6, Behringer ep-2500, crown 402, cinenova grande, adcom 565 mono's, Mcintosh MC-7106, Sherbourn 7/2100, Gemstone blue diamond, Cinepro 2k(2 channel), ada ptm-1260, monarchy audio mono's(class a), krell kav-150(2 channel), ada MPA-501. I might have missed some.
M&K speakers get more neutral every step up you take. My experience anyway.
Marantz 7702 Atmos
MKtheater is online now
post #914 of 4337 Old 05-05-2008, 05:03 PM
lwien's Avatar
Every step up, in what? Price? Is McIntosh a step up from Krell. Is Classe a step up from Krell. Or is Accuphase better than Levinson better than Conrad-Johnson?
You do reach a point of diminishing returns here. Many would say that at a particular price point, one cannot tell the difference between how different amplifiers sound, while there are still others who would say that many times, different amplifiers have different sonic signatures.
But I am a bit confused when you say that the M&K's sound more neutral with every step you take "up", "up" being the confusing word here. If what you are implying is that they become more neutral when you step up from an AVR with a limited power supply to good separates that are rated to drive 4 ohm loads, than yes, I would say that they would sound better. But from there, the step's "up" can become quite subjective and where one would think that one amp would be a step up, another would say that that same amp may be a step down.
My take? Again, many amplifiers and speakers have a reputation for sounding a certain way, and those opinions are shared by many others.
Two examples: Many are of the opinion that M&K can be a bit harsh. Many are of the opinion that Parasounds and McIntosh amps can sound a bit lush and mellow. When it comes to mating good separates with good speakers, I believe that it is the sonic signatures of each that needs to be considered. To me, a step "up" is a bit too ambiguous.
lwien is offline
post #915 of 4337 Old 05-05-2008, 05:15 PM
Chiapest's Avatar
I've been a long time fan of M&K and happy to finf this forum.
Planning to upgrade my current system.
So far I purchased the CTR750 THX Center Speaker.
Now I'm hoping for some advice on which speakers I should get for the front and back.
Was considering using my old Satellite-1's (still sound great) as part of the system.
One more question: Has anyone had experience buying M&K speakers from Dakmart?
Chiapest is offline
post #916 of 4337 Old 05-05-2008, 05:40 PM
EBinMD's Avatar
Chiapest -
I have not purchased M&K speakers from Dakmart, but purchased a Denon receiver off E-bay from Dakmart. It arrived damaged, and Dakmart was very slow at responding to me. I got the impression that they knew it was damaged, or did this often. Fortunately they are an authorized dealer so I was able to take it to get fixed for free, but it was a hassle. I certainly wouldn't purchase M&K in case it arrived damaged.
EBinMD is offline
post #917 of 4337 Old 05-05-2008, 06:58 PM
MKtheater's Avatar
Liked: 1116
I was stating that I have owned many amps and many M&K speakers. Steping up just with speakers using the same amp. Saying all M&K speakers sound a bit harsh is vague because all M&K speakers do not sound the same. If they did, why not buy their cheapest ones? Mcintosh and krell are different brands, all M&K speakers are M&K. Same brand.
Sorry if I confused you. I agree with you that different combo's of amps and speakers will create different sonic signatures.
Marantz 7702 Atmos
post #918 of 4337 Old 05-05-2008, 06:59 PM
MKtheater's Avatar
Liked: 1116
Oh, I do not think parasound and Mcintosh have similar signatures.
Marantz 7702 Atmos
post #919 of 4337 Old 05-05-2008, 07:17 PM
lwien's Avatar
Oh ok. I misunderstood. I thought that you meant stepping up in amplifiers, not speakers. Sorry.
Regarding Parasound and McIntosh, from everything that I have read in magazine reviews as well as owners reviews here and in other forums, it has been stated that both the Parasound and the McIntosh amplifiers tend to be a bit on the soft side as compared to say a Bryston, Krell or many other amps out there and that is the sonic signature that I am talking about. There are other things like stage depth, imaging, etc etc etc, that I have no doubt, differ quite a bit.
But I must qualify that this is all second hand information for me, as I have not had the opportunity to own as many different amplifiers as you have.
lwien is offline
post #920 of 4337 Old 05-05-2008, 07:27 PM
MKtheater's Avatar
Liked: 1116
I have owned Krell, mcintosh, and parasound. I would say with neutral M&K speakers they all sound a little different(S-250 and S-5000THX). These are all the entry level except the parasound(2205 5 channel). The krell had great treble but lacked a bit in the midrange(compared to the Mcintosh). The parasound was neutral, the Mcintosh had an awesome midrange. It just did sound more full(meaning it filled the air with more sound). None of them did sound bright, just different. The 750THX system with the krell would be harsh, and only harsh at high levels, reference levels. I do listen at reference levels. This is where I hear most differences. They are subtle, but there nonetheless.
Marantz 7702 Atmos
post #921 of 4337 Old 05-05-2008, 07:31 PM
MKtheater's Avatar
Liked: 1116
I would not know what amps would be considered a step up. I guess the ones that match best with the speaker would be the step up(no matter the price). My personal favorite with the M&K S-5000THX speaker would be the Ada MPA-501, then the Gemstone. BTW, that adcom monoblock was very nice and if rack mountable would be another top choice.
Marantz 7702 Atmos
post #922 of 4337 Old 05-05-2008, 08:19 PM
claydo's Avatar
given a more budgeted setup, what would you suggest out of this group for these speakers
Marantz sr7002, Pio vsx-92, and the Dennon 2808/998
claydo is offline
post #923 of 4337 Old 05-05-2008, 08:25 PM
MKtheater's Avatar
Liked: 1116
Which speakers?
Marantz 7702 Atmos
post #924 of 4337 Old 05-05-2008, 08:27 PM
cpetkus's Avatar
I'm in the same boat with you. I also have the 750's which I love. I am currently looking at the 7002 and NAD T775 (I have an Marantz SR-19 now). It seems like the 7002/8002's have some issues with Room Eq / occasional popping (very rare it seems tho), and the like... which is making me hesitate to pull the trigger... Other AVRs have their issues too... I like the NAD for their modular design... haven't auditioned one yet
Anyhow, see this thread if you haven't yet (for the 7002): http://www.avsforum.com/avs-vb/showthread.php?t=901489
Also have thought of replacing my 750's with something else, but they are sooooo good it is hard to let go!
cpetkus is offline
post #925 of 4337 Old 05-05-2008, 08:33 PM
claydo's Avatar
Which speakers?
750 setup..
Left, Right, Center
M&K LCR-750thx
Rear
M&K LCR-550thx
Sub:
VX1250SFX THX
I am going to keep them till they blow out or some one offers a good price. Such great quality, been strong for 10 years, Look amazing, and very scaleable room sizes. They will get really really loud but sound great turned down at 12ft or so. And they were given to me..
claydo is offline
post #926 of 4337 Old 05-05-2008, 09:00 PM
cpetkus's Avatar
750 setup..
I agree... they can get loud and sound great loud or low IMO.
Also I forgot to mention that I love the sound of my Marantz SR-19 too, so (in my opinion) Marantz is definitely worth auditioning, especially if you can get an in home demo unit from a dealer.
cpetkus is offline
post #927 of 4337 Old 05-05-2008, 09:08 PM
claydo's Avatar
I didn't even know you could do that..
the dennon is looking good price wise, the Martaz is looking good features wise.. 4 hdmi inputs 2 hdmi out?.. yes please
claydo is offline
post #928 of 4337 Old 05-05-2008, 09:11 PM
cpetkus's Avatar
I just saw you post in the Marantz 7002 thread, hehe.
Yeah, some dealers will to this with a deposit(credit card). Two smaller, private, high end dealers do this in my area that I know of, maybe more. It's really the only way to go if you want to know what the product will do in your room IMO.
cpetkus is offline
post #929 of 4337 Old 05-05-2008, 10:43 PM
MKtheater's Avatar
Liked: 1116
Marantz is very good. Integra matches well with the 750's as well.
Marantz 7702 Atmos
post #930 of 4337 Old 05-06-2008, 09:44 AM
ckenisell's Avatar
Quoted: 110 Post(s)
Liked: 62
Anybody know where I can get a good pair of SW-150's in the US?
Chet
Reply Speakers
Speaker Systems
