B&W Owner's Thread - Page 361 - AVS Forum | Home Theater Discussions And Reviews
 754Likes
post #10801 of 24724 Old 03-31-2012, 08:38 AM
sofast1's Avatar
Originally Posted by millerrh View Post
Sweet! Let us know on the Rythmik forum how it goes. I'm particularly interested in what you discover by tweaking phase settings and how that changes interaction with your mains at the crossover. Especially compared to where your receiver set things.
I know it's the wrong forum,but it might help folks here too. I actually set the phase by ear. I put on some music that had strong bass that I knew was in my xover freq(60hz) range. Then I set the distance on my pre/pro higher than I knew I would use. I closed my eyes and slowly decreased the distance until the bass was the strongest(loudest). The distance setting was the exact same as Brian's subtuner's result! Using the LFE input on the sub allows you to adjust the phase with the distance setting in the bass management,much more accurate than using the phase control on the sub(much easier too,no reaching behind the sub,just sit in your LP and use the remote!). For you folks on this thread,I'm using two Rythmik F15HP subs with my B&W(see,it is relevant) speakers and I can't recommend this combination enough, a perfect match!!
sofast1 is offline
post #10802 of 24724 Old 03-31-2012, 09:01 AM
jackte50's Avatar
I am very interested in purchasing the new B&W M1s and have a couple of questions before I buy. The PV1 D subwoofer is a little steep on the price but is it worth the extra money? Would the ASW 608 or 610 suffice for a 16'x16' family room? I don't really need a HT system to shake the walls. Any other subwoofers that would match the M1s? I heard these speakers with both the Yamaha Aventage and Pioneer Elite VSX 52. The Yamaha produced a more natural sound than the Pioneer(much too bright treble). The Pioneer sounds much better with floor standing speakers IMO. Any other recommendations for
receivers?
jackte50 is offline
post #10803 of 24724 Old 03-31-2012, 09:14 AM
jjackkrash's Avatar
Quoted: 932 Post(s)
Liked: 805
Ask for options in the subwoofer forum. B&W makes decent subs but they cost too much for what you get. There is no need to match B&W speakers with B&W subs, I once swapped out a better sub for a B&W sub that was about the same price because I wanted all B&W in my system and it was the worst audio mistake I ever made. Again, my B&W sub is nice, but I regretted downgrading performance just to have the name match. Take a look at HSU, SVS, Rythmik, and Outlaw (an HSU designed sub) for a better value.
jjackkrash is offline
post #10804 of 24724 Old 03-31-2012, 09:55 AM
gene9p's Avatar
Quoted: 31 Post(s)
Liked: 31
added some panels from MYTHEATER..very cheap and work nice...really improves sound...very easy to install
only 124 for 4 at Sam's club..they are 199 for 4 at Audioadvisor.com.. they were delivered in 3 days from Sam's via Fed Ex..
I will adding the smaller 24x24's later on and will update
gene9p is offline
post #10805 of 24724 Old 03-31-2012, 11:20 AM
jackte50's Avatar
Good advice-Thanks!
jackte50 is offline
post #10806 of 24724 Old 03-31-2012, 04:48 PM
Justins123's Avatar
Just picked up a pair of CM1s. Beautiful looking speakers. I'm hoping to get some advice on an amplifier to pair them with.
I have an old Carver PM-175 laying around I was thinking of using. However, I'm a bit concerned that it has too much power - 175 watts at 8 ohms. The CM1 has recommended power of 30-100 watts.
Can anyone give me their thoughts?
Justins123 is offline
post #10807 of 24724 Old 03-31-2012, 07:49 PM
postrokfan's Avatar
Quoted: 533 Post(s)
Liked: 3171
Actually, too little power is more dangerous as that is when clipping occurs. This will kill speakers. That amplifier should make them sing so no need to worry.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #10808 of 24724 Old 04-01-2012, 07:36 AM
gene9p's Avatar
Quoted: 31 Post(s)
Liked: 31
your Carver is fine.........I agree too little power is not a good thing
when you hear them in stores they are usually working with an AV with lots of power
gene9p is offline
post #10809 of 24724 Old 04-01-2012, 10:17 AM
tribestros's Avatar
I got some new Bowers & Wilkins M1 for cheap because they were my store's shelf display...wow. Can't believe how good these are. They were only on display for a few months.
tribestros is offline
post #10810 of 24724 Old 04-01-2012, 02:34 PM
gene9p's Avatar
Quoted: 31 Post(s)
Liked: 31
welcome to the club ....B&W's are the best at every level IMO
gene9p is offline
post #10811 of 24724 Old 04-01-2012, 06:05 PM
sofast1's Avatar
They're probably the just discontinued old M-1. The new ones were announced in Feb.;http://blog.bowers-wilkins.com/speak...heatre-series/
Here's the new ones;http://www.bowers-wilkins.com/Speake...eatre/M-1.html
There's usually a reason......but if the price was right,enjoy!
sofast1 is offline
post #10812 of 24724 Old 04-02-2012, 02:09 PM
sschwar2's Avatar
receivers?
jackte50,
I bought 5 of the new M1s from BestBuy which are hooked up to an Onkyo 709 receiver. I bought a Definitive Technology SuperCube 2000 to fit behind our couch. We live in a relatively small Brooklyn apartment so at first I wasn't even going to get a sub. I'm very happy I did end up getting it and sounds awesome. The system is amazing - I'm very happy.
I purchased the KEF wireless system for the rears and the Audioengine W1 to make SC2000 wireless. The KEF wireless works flawlessly and sounds great. I'm having issues with the W1 adapter killing my wireless network when it is plugged in. My speeds goes from 35mb up/down to 1.2 up/down and making my Airplay unusable. I'm going to try a few things this evening their tech recommended otherwise return them and look for a different wireless option.
Right now, internet issue aside, the W1 works very well. I couldn't believe how good The Game of Throne's sounded last night. Even my wife who was extremely skeptical of the whole system loved it - she is having a bit of issue figuring out the receiver but she'll get it eventually, I hope.
Let me know if you have any other questions.
sschwar2 is offline
post #10813 of 24724 Old 04-02-2012, 03:08 PM
dadlersberg's Avatar
Have the M1 on the stands .... Looks awesome !
dadlersberg is offline
post #10814 of 24724 Old 04-03-2012, 05:43 AM
sschwar2's Avatar
dadlersberg - can you post a pic? I'm trying to decide if I want stands or mount to the wall in the rear.
sschwar2 is offline
post #10815 of 24724 Old 04-03-2012, 12:09 PM
jackte50's Avatar
sschwar2 and dadlersberg
A couple of things: I have heard both the Onkyo 709 and Yamaha Aventage 1010 and both sound good with the M1s. The yamaha is maybe a touch more musical. I am somewhat interested in wireless systems but am unsure of the quality. Is your KEF wireless the new 2.0 model? I am also going to need the
stands which are ver stylish but expensive. There is a good picture on the B&W website.
jackte50 is offline
post #10816 of 24724 Old 04-03-2012, 12:39 PM
sofast1's Avatar
You could just click on the links in post#10813 above.
sofast1 is offline
post #10817 of 24724 Old 04-03-2012, 02:46 PM
sschwar2's Avatar
I bought this from Amazon: KEF UWIRELESS Wireless System
sschwar2 is offline
post #10818 of 24724 Old 04-03-2012, 08:18 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Did you think about placing panels behind speakers? I do not think that they will do much being behind TV.
ap1 is offline
post #10819 of 24724 Old 04-04-2012, 02:49 PM
gene9p's Avatar
Quoted: 31 Post(s)
Liked: 31
I followed the video instructions on audioadvisor.com...they show the set up with these panels not directly behind the speakers very much like my set up. I also used blu tac as they do to keep panels straight..just happen to still have some of that and it works great...smaller rear panels arriving tomorrow
I did move panels 8 inches apart now..can always move them back it is that easy..put up 4th panel on side wall and 24x24's being delivered today for back wall
gene9p is offline
post #10820 of 24724 Old 04-04-2012, 03:03 PM
Briandl's Avatar
I know a lot of you have the higher end stuff, but I got my hands on a pair of 685's and I'm loving them.
Briandl is offline
post #10821 of 24724 Old 04-04-2012, 06:19 PM
e84cooper's Avatar
I'm new to this speaker brand I plan on buying the following system for my man-cave that I'm starting in June!
Center m1mw
Fronts b&w 685
Rears m1mw
Sub epik legend (1)
Receiver txnr 809
Main System
Fronts RB 81 II BLK
Cener RC 52 II BLK
Rears RB 61 II CHERRY (going to be replaced with a black set)
Subwoofer SW112 BLK
SR 5006
MM7025
LG 55 LED 120HZ BDPS590 ipad 2 remote
Bedroom RB 41 II BLK/ TXSR 607 / TCL32X1 / BDPS370 / Apple TV 2 wife ipad3 remote
e84cooper is offline
post #10822 of 24724 Old 04-04-2012, 08:35 PM
Tweaked05's Avatar
Quoted: 42 Post(s)
Liked: 26
Imo, compared to a lot of other big box brands, even the 600 series is high end.
Tweaked05 is offline
post #10823 of 24724 Old 04-04-2012, 10:14 PM
Briandl's Avatar
Yeah I think it is, I'm just mentioning that because everyone is talking about the CM series or better.
It's funny to spend 1200.00 on a setup and basically have people tell you you have a low end system. It's true no doubt but it also sounds nothing like any of the other stuff I've ever heard before.
Briandl is offline
post #10824 of 24724 Old 04-05-2012, 06:31 AM
tmaschm's Avatar
Anyone who tells anyone they have a low end system is a jerk anyways.
tmaschm is offline
post #10825 of 24724 Old 04-05-2012, 07:09 AM
gene9p's Avatar
Quoted: 31 Post(s)
Liked: 31
Originally Posted by tmaschm View Post
anyone who tells anyone they have a low end system is a jerk anyways.
+1..................
gene9p is offline
post #10826 of 24724 Old 04-05-2012, 07:14 AM
sofast1's Avatar
Center m1mw
Fronts b&w 685
Rears m1mw
Sub epik legend (1)
Receiver txnr 809
Big mis-match with your fronts and center. Use the HTM62 as the center. From the B&W website;
"The HTM62 is the smaller of the two centre speakers in the 600 Series, and is tailor-made to partner either the 684 floorstander or 685 standmount loudspeaker at the front of a home theatre system." I've used the HTM62 in a system with 683s,sounds great!
It'll sound much better than a M1!
P.S. Take a look at the Rythmik FV12 sub.
sofast1 is offline
post #10827 of 24724 Old 04-05-2012, 07:23 AM
sofast1's Avatar
Add a good sub and you've got a first class system! The 600 series responds very well to electronics upgrades and they love high current. If you think they sound good with your AVR,add an external high current power amp,upgrade your sources and you'll be amazed! You can build a great affordable system around the 600 series.
sofast1 is offline
post #10828 of 24724 Old 04-05-2012, 08:04 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Center m1mw
Fronts b&w 685
Rears m1mw
Sub epik legend (1)
Receiver txnr 809
I suggest to use 685 all around. If you can't get 5 of them (they are usually sold in pairs), use 6th as back surround (for 6.1 setup).
ap1 is offline
post #10829 of 24724 Old 04-05-2012, 10:04 AM
e84cooper's Avatar
Thanks can I use the m1 for rears
Main System
Fronts RB 81 II BLK
Cener RC 52 II BLK
Subwoofer SW112 BLK
SR 5006
MM7025
post #10830 of 24724 Old 04-05-2012, 10:15 AM
sofast1's Avatar
If your rear speakers require wall mounting,the M1 is a good choice. If your rear speakers are going on a shelf or stands,another pair of 658s would be much better.
sofast1 is offline
Reply Speakers
802D , atmos , B W , b&w dm1400 , Bowers And Wilkings 685 Speakers , carver cm-1090
