B&W Owner's Thread - Page 481 - AVS Forum | Home Theater Discussions And Reviews
 749Likes
Old 07-29-2013, 01:21 PM
petetherock's Avatar
Quoted: 1078 Post(s)
Liked: 516
Originally Posted by Kal Rubinson View Post
It's not toe-in, per se.  It is whether you are on axis or not.  On axis is usually brighter and toe-in or toe-out reduces that.
Thanks Kal, that's what I remember...
So I shoot the 804D down the hall, with just a hint of toe-in, such that the line of the tweeter goes slightly wider than my ears rather than directly at my ears.. the 804D was measured to have a exciting upswing in the treble by a UK rag not longer, and that has also been my experience..
petetherock is offline
Old 07-29-2013, 04:00 PM
wse
wse's Avatar
Quoted: 1977 Post(s)
Liked: 740
Originally Posted by danielo View Post
I ended up with about 50% toe-in between direct and aimed at ears. The signal now crosses behind th MLP ill probably fiddle a little more over the next few weeks. Daniel.
50% toe-in tat seams execive what for I thought 30% was max?
wse is online now
Old 07-29-2013, 04:38 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
There can never be an exact percentage as you don't know how far the speakers are apart and how far from the plane made by the speakers vertically to the listener, i.e. the distance from the speakers to the listener are. This is why I suggest listening and not abiding by any exact number.
B.
Brian B is offline
Old 07-29-2013, 04:56 PM
Kal Rubinson's Avatar
Quoted: 677 Post(s)
Liked: 460
Originally Posted by baranowski View Post
when you speak of " on axis" are speaking of the triangle formed from front left and right speaker to the main listening position?
my problem with the triangle is in a home theater environment.... because there is also a calculation for the seating distance dependent on the size of the screen you are using...
Bill
Nope.  On-axis means that the speaker axis (particularly, the tweeter) is aimed directly at the main listening position.  Has nothing to do with the actual angle which, as you say, is dependent on distance.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 07-29-2013, 06:13 PM
wse
wse's Avatar
Liked: 740
I am 8.75 feet away from the front and I toed in by ear :)
wse is online now
Old 07-30-2013, 01:05 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Again thanks for the many replies on this, got some interesting new hints esp. during ht/audyssey setup is something i didn't think about.
I guess i was unclear i mean 50% between no toe-in and directly aimed at MPL. In real numbers i would say about 15% maybe, The end result is that the 'laser beams' would cross about 1 - 2 meters behind the MPL instead of hitting the ears.
I agree that testing is best and ill continue to fiddle a little making markets on the floor to keep track of things. Like stated already its so easy with the 802D2's on the casters.
Also keep in mind i am happy with the sounds now i think the biggest problems where already solved i had mostly with the htm2d correct placement/angle solved that.
Daniel.
for men to evolve we have to upgrade
danielo is offline
Old 07-30-2013, 01:49 AM
akhter's Avatar
I follow below guide for positioning
http://audiophysic.de/aufstellung/beispiel_e.html
Geoff4RFC likes this.
akhter is offline
Old 07-30-2013, 04:41 AM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
You must have some dam strong ears! Lol ( sorry )
djnickuk is offline
Old 07-30-2013, 07:14 AM
Quoted: 677 Post(s)
Liked: 460
Daniel.
The more general way to describe toe-in is to use degrees with no toe-in (speakers aimed straight, perpendicular to their common plane) as 0deg.
Kal Rubinson
Old 07-30-2013, 12:22 PM
wse
wse's Avatar
Liked: 740
Originally Posted by djnickuk View PostYou must have some dam strong ears! Lol ( sorry )
Yes they are very big as well!
I don't get it Ah! Ah!
wse is online now
Old 07-30-2013, 02:23 PM
Scott_lb's Avatar
Liked: 45
Not a B&W owner, but for those who don't know and might be interested Genelec has a great iPhone app which will calculate the angle for toeing-in (sp?) speakers. I think it costs $0.99. I've used it and it works great! Don't know if it's available on Windows or Android...
bert170881 likes this.
Scott_lb is offline
Old 07-31-2013, 05:55 AM
bert170881's Avatar
Hi all
I'm currently looking to build my HT around Onkyo and B&W in a 7.1 setup.
Sadly I'm not very technically into audio and the whole setup 'thing', but I hope some of you can help me out.
The L/R speakers will be the B&W 684, the center a B&W HTM61 and the four surround speakers will be in-ceiling due to space and other issues and for these ones I'm looking at the CCM362.
Can anyone tell me if those four in ceiling speakers will be good for the job and will they be able to keep up with those L/C/R? I just need them to create a surroundbubble so I hope they're strong enough...
In addition, with this setup, what sub do you all recommend? Is the best choice a sub from B&W itself or is there a better alternative?
bert170881 is offline
Old 07-31-2013, 06:56 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Originally Posted by bert170881 View Post
Hi all
In celing for surround duty should be Ok for movies. If you are are serious about surround music, I would try to accomodate standalone speakers like 685 (yes, they can be mounted on walls).
I wouldn't even think about B&W when I choose subwoofer. Lok at SVS, HSU and alik - much better value for the money.
I strongly suggest to consider 683 as fronts. They are much better than 684, for not much more money and closer match for HTM61 center.
ap1 is offline
Old 07-31-2013, 11:51 AM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
Hi all
If you are looking to match the front in terms of drivers, then you need to be looking at the CCM663. If you are doing 5 channel then perhaps the CCM683 instead of two sets of CCM362. If you are planning on 7 channel then you should go in-wall or free standing as ap1 suggests. I second the choice to go to the 683 if you have room and budget. If you plan a B&W sub, then I would look at at least the ASW610XP or bigger depending on room size.
B.
Brian B is offline
Old 07-31-2013, 01:36 PM
bert170881's Avatar
Thank you all for the quick and good replies! I'll look into it guys.
Old 08-03-2013, 10:28 AM
dr_bling's Avatar
Quoted: 58 Post(s)
Not sure if this is the right tread for my issue and help needed but here it goes. I purchased 5 B&W speakers, 2 605 s2 and 2 601s2 and a cc6s2, after getting these home I realized the amp in one 605 does not turn on, I checked the fuse and its not blown. The subs in the other 605 sound blown, they rattle and don't hit low. I pulled the subs from the other 605 and swapped them and both of those sound blown too frown.gif. I have a half ass sub so I calibrated the speakers to run like a bookshelf and it seams the mid/woofers are not functioning properly. They sound like they are not going below 2000 hz, absolutely no bottom end. the only good news is the tweeters sound great.
The 601 book shelf's only one woofer works, the other woofer seams stuck. IT won't flex in our out but appears to look great, any suggestions ? good news is both of the tweeters sound great.
The center works and sounds great.
My equipment is a Marantz 1403 receiver at 50 watts. I know its a little low on power but I tested it against all the other Marantz at Magnolia and It held up fine with all the B&W speakers on demo. I double checked all connections and tried anouther speaker to verify that it was not the receiver.
Any suggestions would be greatly appreciated.
Sony XBR65-850B and KDL-55 HX800
Marantz 1403
B&W 601's fronts , B&W CC6 Center and Athena micra rears
SVS PC12-NDS & Mirage Omni S10
dr_bling is offline
Old 08-03-2013, 11:40 AM
gonzalc3's Avatar
Quoted: 173 Post(s)
Liked: 143
I am thinking on upgrading my MK S150 speaker system for a B&W 803 system. In this part of the world I am able to get a demo model for the LCRs at 20%.
The center channel is an HTM2. Is this a fair deal? I heard that for brand new you can normally get at 10 % discount. However, the demo units have only been used for about 3 weeks so they still haven't completely break in. What do you think?
Chris. My DVD UHD Blu Ray and Blu Ray collection
JVC DLA-X750R (calibrated with calman 5 and c6 hdr meter), ST 100 (100") screen, B&W 803D2s mains, B&W HTM2D2 center channel, B&W 805D2 surrounds, B&W CCMM682s in-ceiling speakers (4), B&W DB1 subwoofer, Marantz AV8802A preamp, Parasound Halo A51+(2xA21)+(2xA23) amps, Oppo UDP 203 player, Roku Ultra and Harmony Elite remote.
gonzalc3 is online now
Old 08-03-2013, 12:57 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
I would take them back. As is, they are 10 years old and if you check the parts (assuming they are still available), are probably way more expensive than fixing all those bad speakers is worth. It sounds like the speakers have been abused, so I would have concerns about the other speakers even if they appear "okay."
The parts website is: http://bwgroupsupport.com/parts/price-avail
B.
Brian B is offline
Old 08-03-2013, 12:59 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
Sounds fair assuming they are 803D2 and HTM2D.
B.
Brian B is offline
Old 08-03-2013, 01:20 PM
gonzalc3's Avatar
Quoted: 173 Post(s)
Liked: 143
B.
They told me and seem to be the latest model...
Old 08-03-2013, 01:35 PM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
My Question where did you buy these speakers,plus you need much better receiver to push BW's speakers.
Chise is offline
Old 08-03-2013, 02:21 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Did you check them before paying money? I suspect they were sold as-is, right? In that case you are screwed. It will be a lesson for you - next time never buy used gear without thorough testing of it by yourself.
ap1 is offline
Old 08-03-2013, 10:40 PM
dr_bling's Avatar
Quoted: 58 Post(s)
long story short version, I called the gentleman that sold me the speakers and explained that they did not work properly. I met him the next day and he refunded me all the money and then said keep the speakers. He did not have to do this as I f$*% up and did not demo them properly. I never heard the bookshelves and center and the 605 were not hooked up properly so I assumed they worked correctly. bottom line is I own all of them thanks to an honest man. biggrin.gif
The Marantz 1403 has 50 watts, this was more than enough to push the B&W towers at bestbuy. Im sure they can handle alot more but this is what I got to work with.
Does anyone have any suggestions on why the mid/woofers are all bad ? or am I possibly doing something wrong ? any help would be appreciated.
Marantz 1403
dr_bling is offline
Old 08-04-2013, 05:33 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
Dr.bling I work in BestBuy part time and 1403 Marantz receiver is a weak receiver,sure you hear something but no soundfield if you going to buy some bookshelves then go with the M-1 and if can't afford BW's speakers and put the right receiver or amp or processor you are wasting your time,if you are cheap then I wasting my time writing to you,when im working at BestBuy I don't sugar coat with costumers,so even if buy 600 series in the store with hold package you better have 5 grand to spend.
Chise is offline
Old 08-04-2013, 05:35 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
Originally Posted by Chise View Post
Dr.bling I work in BestBuy part time and 1403 Marantz receiver is a weak receiver,sure you hear something but no soundfield if you going to buy some bookshelves then go with the M-1 and if can't afford BW's speakers and put the right receiver or amp or processor you are wasting your time,if you are cheap then I wasting my time writing to you,when im working at BestBuy I don't sugar coat with costumers,so even if buy 600 series in the store with hole package you better have 5 grand to spend.
Chise is offline
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
Chise is offline
Old 08-04-2013, 07:45 AM
gonzalc3's Avatar
Quoted: 173 Post(s)
Liked: 143
Has anyone used their 803ds with a parasound halo A21? Does it have enough power to drive them?
Old 08-04-2013, 08:05 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
Yes sir
Chise is offline
Old 08-04-2013, 09:14 AM
dr_bling's Avatar
Quoted: 58 Post(s)
Well I have a onkyo 803 with a little more ass that i'm going to try today, but i still got a feeling its the speakers and not the receiver. Still hoping someone on here may have some experience with blown b&w or at least have some useful tips on how to get these speakers working. Chine, I dont think my wife would call me cheap but i do have 3 kids so im usualy broke. biggrin.gif
Marantz 1403
dr_bling is offline
Old 08-04-2013, 09:35 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
Doc its going to cost you more money to get them fixed those parts for BW"s are not cheap,so you better off buying one piece at a time don't matter if it takes 6 mouths to do it and buy last year model receivers they are much cheaper some are 30 or 40 perecent off just keep looking around it took me 2 years to get all I wanted for my hometheater in the basement.
Chise is offline
802D , atmos , B W , b&w dm1400 , Bowers And Wilkings 685 Speakers , carver cm-1090
