B&W Owner's Thread - Page 630 - AVS Forum | Home Theater Discussions And Reviews
 521Likes
Old 07-21-2014, 02:39 PM
mantikos's Avatar
Quoted: 16 Post(s)
Originally Posted by ZachF88 View Post
The HTM61 is not timber-matched to the CM1's. I even think the CM1's shouldn't be matched with the rest of the CM-series. I feel that CM1's are great for 2 channel set up (or 4, but all CM1's). I would consider maybe the CM5 and CMC2 if you can pull it off. I listened to the CM1, CM5, CMC, and HTM61 3 times for over an hour each at BB/Magnolia. I love the CM1's but I don't like them paired with the other CM-series. The CM5 worked well with the CM centers and the floor standing CM's.
As for my set-up (if anyone cares), I ended up getting 2 more XT8's for sides. Hoping to get some FPM2's for the rears. But blew the budget by double......
Let me follow up with this:
I can get the CMC for 399 or the CMC2 for 980
Which one would you get?
I think I am committed to my CM1 for L & R
Still confused about the rear speakers, should I go 6 series, wait to save for CMs or go in-wall B&Ws? I do plan on using the speakers for music using all channels to fill the huge space I have.
mantikos is offline
Old 07-21-2014, 02:43 PM
mantikos's Avatar
Quoted: 16 Post(s)
Originally Posted by Chise View Post
The receiver you have I would go with CMC for center 685S2 for towers and M-1 for surrounds, you can mount them.
Thank you Chise, would you be able to answer the question above ^
mantikos is offline
Old 07-21-2014, 02:46 PM
ZachF88's Avatar
Quoted: 22 Post(s)
I would definitely go with the CMC2 if you have the space. The majority of the dialog in movies is emitted via the center. The CMC2 is 3 way with that FST mid driver, so you'll get better dialog. As for the rears, save up for CM1's. I've never liked the in-wall speakers from b&w. Also look into FPM series. But the CM1's will be better, The CM1's are great little speakers!
PS. I'm running DM600 S3 (3rd generation, now they are on 5th) as rears. I can definitely tell the difference in the upper end (upper mids and highs). The 600-series just sound "muddy" to me. I really hate mixing different B&W speaker lines.
ZachF88 is offline
Old 07-21-2014, 02:53 PM
mantikos's Avatar
Quoted: 16 Post(s)
I agree on the 6 series sounding muddy - especially in the mid-range.
mantikos is offline
Old 07-21-2014, 04:00 PM
Chise's Avatar
Quoted: 338 Post(s)
Liked: 130
Now if you was using different receiver like SC-75,77,79 then I would use CMC2 for the center and CM9 towers CM5 for surrounds but you are on budget and finally do not under estimated 600 series S2's.
Chise is offline
Old 07-21-2014, 04:12 PM
mantikos's Avatar
Quoted: 16 Post(s)
what's wrong with the vsx 80? Not enough power to drive these speakers?
mantikos is offline
Old 07-21-2014, 04:30 PM
Gecko85's Avatar
Quoted: 157 Post(s)
Liked: 97
I am/was in your same shoes. I demoed (in house) the 683 S2's and CM1's, and decided on the CM1's. They'll be my fronts for a while, until I can spring for some CM5's, then I'll move the CM1's to the rear to replace my Athena's. I'll also eventually replace the Athena center with the CMC2. Which upgrade comes first (CMC2 or CM5) depends on what deals I can find down the road when I've saved up some more money.
For me, the CM1's sounded better than the 683 S2's.
Panasonic TC-P60ST60, Pioneer SC-1523-K, Oppo BDP-103D, Pioneer PL-550 + Cambridge Audio Azur 640P, B&W CM1 (fronts), B&W CM Centre, Athena Point 5 Mk II (rears), Hsu VTF-2
Sony 34XBR960, Onkyo TX-NR414, Sony PS3, Athena Point 5 Mk II (center and fronts), Wharfedale WH-2 (rears), Polk PSW10
Gecko85 is offline
Old 07-22-2014, 12:51 AM
Berland's Avatar
Quoted: 32 Post(s)
If anyone got B&W SCMS speakers stashed away; please contact me. I'm looking for several pairs of B&W SCMS'
HT: CLASSE CA-5300 DELTA - BRYSTON 4B SST2 - Marantz AV8802A - B&W 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2, SA Talent - NORDOST Heimdal 2 (signal) - VAN DEN HUL (speaker) - Samsung UE78JS9505 - GIK ACOUSTICS - AUDYSSEY Pro Kit
HP: 2*MOON Neo 430HA D, Neo 380D DSD - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 (all cables) - AUDEZE LCD-3(Fazor), 2*LCD-XC - SHURE SE846 - SENNHEISER IE 800 - BEYERDYNAMIC T5p, T70
Berland is offline
Old 07-22-2014, 04:06 AM
mantikos's Avatar
Quoted: 16 Post(s)
Random question - would this work for wall mounting a CMC2 ?
http://www.peerless-av.com/en-us/pro...products/PS200
I would obviously keep it off the wall and use foam plugs for the ports
mantikos is offline
Old 07-22-2014, 11:14 AM
Chise's Avatar
Quoted: 338 Post(s)
Liked: 130
No way my friend I just listen CM1's I compared 685S2 and 683S2 and also I tried SC-71 the Denon X-4000 Pioneer VSX-80 the CM1's sounded weak I would never use them for towers surrounds then yes, and finally the receiver you have, get better receiver before you buy new speakers.
Chise is offline
Old 07-22-2014, 12:37 PM
mantikos's Avatar
Quoted: 16 Post(s)
The CM1s aren't the most sensitive - agreed, the 6 series is def louder but at the same time the mid range is muddled as many have pointed out.
As far as the VSX 80, I am curious to know why you think its weak.
mantikos is offline
Old 07-22-2014, 01:01 PM
Gecko85's Avatar
Quoted: 157 Post(s)
Liked: 97
I had the 683 S2's and the CM1's in my home, with my system, for over 2 weeks...on loan/demo from my local audio shop. In my home, with my system, the CM1's were clearly better. The highs were less shrill, the mids were less muddy, and there was more than enough bass when used by themselves, and they were even better when using a sub.
Maybe in your home, with your system, the 683's sound better. Just not in mine.
And I don't count any in-store listening, particularly if it's someplace like Best Buy/Magnolia, who have no clue how to set up a listening room. No store is going to match the acoustics of your own space.
Gecko85 is offline
Old 07-22-2014, 04:15 PM
Chise's Avatar
Quoted: 338 Post(s)
Liked: 130
I guess it will sound muddled using entry level receiver, if you are going to buy BW's 683S2 CM9 or 10 CMC2, HTM61S2 don't use entry level receiver go high end Like Denon 4520ci Pioneer SC-75 thru 79 or seperates, right now its good time to buy they are getting rid old for the new.
Chise is offline
Old 07-22-2014, 04:18 PM
Gecko85's Avatar
Quoted: 157 Post(s)
Liked: 97
I'm using the Pioneer SC-1523-K, which is the same as the SC-75, and they sounded muddled to me compared to the CM1.
Gecko85 is offline
Old 07-22-2014, 04:19 PM
thrang's Avatar
Quoted: 1303 Post(s)
Liked: 1095
@ jonmiddleton
Great room! I will be trying Bryston as well.
Maybe I missed this, but where's your center?
thrang is offline
Old 07-22-2014, 04:22 PM
mantikos's Avatar
Quoted: 16 Post(s)
I heard em on SC 75 and a top of they line ROTEL
still muddled
mantikos is offline
Old 07-22-2014, 05:24 PM
Chise's Avatar
Quoted: 338 Post(s)
Liked: 130
still muddled
In your house or at design center.
Chise is offline
Old 07-22-2014, 05:51 PM
Chise's Avatar
Quoted: 338 Post(s)
Liked: 130
Well I have no more too say about it good luck with your gear.
Chise is offline
Old 07-22-2014, 08:27 PM
mantikos's Avatar
Quoted: 16 Post(s)
My friends professionally designed home theater and a specialty high end home theater design company's theater
mantikos is offline
Old 07-22-2014, 09:28 PM
RLBURNSIDE's Avatar
Quoted: 1069 Post(s)
Liked: 803
Yeah, the room it's auditioned in makes a huge difference apparently. I listened to some 683 series 1 and CM9s and I hated the CM9s but loved the 683. I couldn't pull the trigger because I just don't like horizontal centers, especially asymmetric ones. But the new series 2 has a symmetric center so even though I'd prefer my front 3 speakers to be identical for a proper front sound stage as per theater specs, I'm more than happy if I get back into the B&W line with a new speaker series that's affordable and sounds better for classical music at reasonable listening volumes than my old horn speakers. I really had to burst out the volume into the stratosphere with my Klipsch 650s on classical to get intelligible nuance from music and voice (explosions and Miles Davis tracks notwithstanding). I had a much better / cleaner listening experience at lower volume levels with my old DM602 s1s that I used for about ten years but now I can't even get repaired because there are no parts left to repair them with.
RLBURNSIDE is offline
Old 07-22-2014, 10:02 PM
Jon Middleton's Avatar
Quoted: 150 Post(s)
Liked: 120
Originally Posted by thrang View Post
@ jonmiddleton
You didn't miss anything, I run a phantom center. The speakers are 9' apart, and I don't feel like I need a center. As I said, the room serves multiple purposes, including high end listening room. Also, a center channel would take 80% of movie soundtracks away from two perfectly good 800D2's. That doesn't make sense to me. We watched Les Miserables a bit ago, it was very nice.
The Bryston is awesome. A much better value than offerings from Classe, Ayre, etc. It's no nonsense gear, 20 year warranty, nice, solid build quality and aesthetics. Really hard to beat, IMO. Oppo 103> Bryston 4B SST2> 800D2's, does it get better than that?
Jon Middleton is offline
Old 07-23-2014, 02:09 AM
tanwn1's Avatar
Quoted: 62 Post(s)
You are half correct, but there are certain movie soundtrack whereby if you switch to phantom channel, there's a cancellation of some frequency and phase issue and you might not hear certain bass. This is with respect to discreet 5.1 /7.1.
tanwn1 is online now
Old 07-23-2014, 07:47 AM
jima4a's Avatar
Quoted: 239 Post(s)
Liked: 131
Are you using the 103 as a pre?
jima4a is online now
Old 07-23-2014, 10:31 AM
Quoted: 150 Post(s)
Liked: 120
Opps! No, the Oppo is just the front end because I have the TT. The satellite is connected to the HDMI In-Back. Both the Oppo and TT go into my old Rotel RSP 1066, which predates HDMI. Analog out of the Oppo to the multi inputs on the Rotel, the TT goes into a Project phono preamp then to the Rotel. Essentially, the Rotel is just a switching device with gain. The Oppo does all A/V processing. HDMI Out on the Oppo goes directly to the PJ. I think this is a pretty clean approach, and utilizes the processing excellence of the Oppo.
Old 07-23-2014, 09:42 PM
RLBURNSIDE's Avatar
Liked: 803
Oppo's pre-outs seem like such a good bargain considering it's basically a high end home theater DAC minus an amp section. Any AVR with analog ins can then do what it's supposed to do and nothing else, plus you can mix and match with amps that way. I'm in a dilemma myself, I had to decide whether to pay $200 to get my old Marantz SR5004 repaired (busted HDMI board), but then be stuck with HDMI 1.3, or just let it stay dead and use my HTPC analog outs until such time as OPPO comes out with an HDMI 2.0 player with 4K passthrough (or even Darby). I'd much rather save that $200 and upgrade my electronics, with the minor hassle of using my emotiva directly from the analog outs of my HTPC for the time being. If I can score an OPPO with HDMI 2 then I can start looking at cheap options to power my rear speakers.
I wanted to get a new Atmos receiver but any of those with pre-outs are going to be ludicrously expensive for at least a year or so. It seems like most options out there only have at most 2.1 or 2.2 channels of pre-outs (fronts and 1/2 subs), and to get the full 7.1 you need to pay at least 1K if not 2 to get it. Totally absurd, considering I paid 300 for my Marantz refurb that has full pre outs and had all the codecs I could possibly need. I just find analog outs from my motherboard decent enough, am I crazy? Or has onboard sound gotten quite good.
Old 07-24-2014, 06:59 AM
gene9p's Avatar
Quoted: 18 Post(s)
Liked: 25
the dog has a great spot..........
nice pictures of Bryce and Arches
gene9p is offline
Old 07-24-2014, 08:17 AM
Quoted: 150 Post(s)
Liked: 120
Thanks. I took those with my Zone VI 4x5, along with the detail of Little Cottonwood creek over the mantle. Tack sharp and grainless throughout. The sunrise at Bryce has very nice lighting, it's far better in person.
Heidi's spoiled.
Old 07-24-2014, 11:57 AM
mlupia92's Avatar
Quoted: 18 Post(s)
Hello everyone, I'm new to this thread and also a new B&W owner. Just bought my first pair about 3 weeks ago. I've gotta say its nice to own a pair after demoing them for years.
I'm running the following in my setup:
Receiver- Pioneer SC-63 Elite
Fronts- B&W 685 S2
Center- B&W HTM62 S2
Rears- Klipsch S-20's
Sub- Energy Power 12
Using all Audioquest wiring with Sanus steel series speaker stands. Definitely need to upgrade my rears and sub at some point but being on a budget limits me a little right now.
mlupia92 is offline
Old 07-24-2014, 12:42 PM
Chise's Avatar
Quoted: 338 Post(s)
Liked: 130
Fronts- B&W 685 S2
Well you got to start somewhere, and which you have its better than nothing,
Chise is offline
Old 07-24-2014, 03:04 PM
jima4a's Avatar
Quoted: 239 Post(s)
Liked: 131
Fronts- B&W 685 S2
Congrats! The series 2 are quite good based on feedback from those who's input I value.
802D , atmos , B W , b&w dm1400 , Bowers And Wilkings 685 Speakers , carver cm-1090
taboola here
