B&W Owner's Thread - Page 634 - AVS Forum | Home Theater Discussions And Reviews
 845Likes
post #18991 of 25098 Old 08-10-2014, 07:59 AM
HarrisonS's Avatar
Quoted: 35 Post(s)
Liked: 32
Originally Posted by rpr View Post
Good advice, but this doesn't really address the SQ issue. I don't just have a problem getting the dB I am looking for, I cannot get the SQ I am looking for.
While the best option may be to ditch the speakers, that could be a $3K to $4K option (I would likely look at the CM10's), whereas (I think) you can get a decent dedicated amp for less than $1K?
So, do you think I would be able to improve the SQ much along with the dB if I ran more power to them with a dedicated amp?
Its been a while since I actively followed these forums, what is the sweet spot for most bang for the buck amps these days, still Emotiva?
Never ran a separate dedicated amp before, as this is also my HT setup, wouldn't running more power to the left/right channels overwhelm my center and surrounds?
Ditching the speakers is clearly the best option, just want to consider the other alternatives before doing that.
Sorry for the rookie questions. Thanks.
It seems that you are used to running your speakers at levels that most people would consider to be unbearably loud, even with the moderate ~90 dB sensitivity of most B&W speakers.. At any reasonable lever you should never hear any obvious, audible distortion.
If you do, you risk damaging your speakers. If the distortion occurs in the woofers, you will likely overheat the voice coils, causing them to warp and unravel - and that will give you plenty of distortion, even at low levels. If the distortion occurs in the amp or receiver (i.e., clipping), the harmonics will likely overwhelm and damage the tweeters.
In any case, it seems you may have already done this kind of damage to the XT8's. Sure, I have had my speakers reaching extremely loud levels on a few occasions, but I have never driven them, or the amp to levels where they exhibit any obvious, audible distortion.
You really should avoid conducting destructive failure tests on your speakers!
HarrisonS is offline
post #18992 of 25098 Old 08-10-2014, 08:11 AM
wse
wse's Avatar
Quoted: 2201 Post(s)
Liked: 805
Originally Posted by advanced101101 View Post
The two biggest things that affect SQ are the speakers and the room. If you find the speakers harsh and unlistenable I would look at the room first and work to fix that if needed. If you are still unhappy then upgrade the speakers.
But remember, if you put class A speakers in a poor room, they will sound poor. It might not be worth it to spend big bux on speakers if you have a room that doesnt allow you to get the most out of them. Buying a new amp will give you more db but little SQ improvement.
There is no sense of trying to fix your sound with different equipment that will only offer minor improvements. Find the speakers you love first ....
Agreed 100% fixing the room will do alot more than buying cables, new amps and so on... Also don't forget to get you ears cleanned every year by an ENT
In addition, well recorded music is essential to good sound.
wse is offline
post #18993 of 25098 Old 08-10-2014, 09:28 AM
rpr
rpr's Avatar
Quoted: 42 Post(s)
Thanks for the feedback guys.
On the extremely loud perspective, I can see why you may suspect I have been pushing the speakers beyond their limits from my comments, but that really is not the case.
If I ever hear distortion, they immediately get turned down, but that's the issue, I have to play the at low to moderate volumes that just does not work well for my huge open room.
So the comments on the room are definitely a factor here, but there isn't much I can do to this room.
The comment on well recorded music is definitely relevant here; however, the $300 Klipsch 650AW's I mentioned plays the same music in an outdoor completely open setting immensely better than these $3K XT8's.
But since this excellent point was raised, let me ask a question, I listen to a lot of music on Spotify, and I use the "Extreme" quality setting, which is supposedly 328kb/s.
I'm not sure how real this specification is, but for those who use Spotify's Extreme setting, what are your thoughts on the quality of those streams?
rpr is offline
post #18994 of 25098 Old 08-10-2014, 10:18 PM
wse
wse's Avatar
Liked: 805
Nooo, i was thinking every other update. So that might be 8 years away.
I see in eight years yes maybe it all depends, I am not getting any younger so it might not matter!
Presbyacusis is the medical term for hearing loss that occurs in older people as they age. It is the most common cause for hearing loss in people aged over 55.
wse is offline
post #18995 of 25098 Old 08-11-2014, 01:49 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
Looking to buy CM5 pair as book shelf
Can some one help me with placement.
I intend to use on the top shelf of my cabinet, 24 H, 32 W and approx 12 inch deep.
zoro is offline
post #18996 of 25098 Old 08-11-2014, 04:56 AM
advanced101101's Avatar
Quoted: 78 Post(s)
Liked: 26
I understand your room limitations, many of us have factors that we can't change due to WAF, Budget, Room Config, etc.
The next option would be to spend some time on placement. This involves changing the toe-in, distance from side and rear walls and the height. See if changing those variables cleans things up. When you say harsh and un-listenable I am equating that to the speaker being too bright. Changing toe-in might have the biggest effect outside of room treatments. Rather than having the tweeters directly pointed at your ears try decreasing the amount of toe-in, you might even prefer them shooting straight forward.
Your 650s might sound better due to them being outside. In an outside environment you don't have many reflection points.
For fun, try bringing in the 650s and place them in the same spot as the XTs and see what you think. If you think they are "harsh" then you most likely have room issues. If that is the case then I would demo speakers that are on the warmer side then ask for in-home auditions. If you think the XT8 is bright in your room I would predict that you won't be happy with the CM10s either.
But as I tell everyone your ears are whats important and I am only giving you advice based on my experience.
advanced101101 is offline
post #18997 of 25098 Old 08-11-2014, 05:28 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 133
What are trying to buy use or new ones.
Chise is offline
post #18998 of 25098 Old 08-11-2014, 05:28 AM
Quoted: 78 Post(s)
Liked: 26
The CM5s are rear ported so unless you intend to plug the rear port with the supplied foam plugs I would not recommend using it on a bookshelf against a wall. Plugging the port will cut off some of the lower end bass.
I would look for a speaker that is front ported unless bass isn't a concern of yours. The 6 Series Bookshelfs, PM1, 805s are front ported or you could try a different brand.
post #18999 of 25098 Old 08-11-2014, 08:02 AM
Berland's Avatar
Quoted: 50 Post(s)
Liked: 32
In the Dolby Atmos white-papers (http://www.avsforum.com/uploads/Dolb...me-Theater.pdf
they claim that you need ceiling-speakers with wide dispersion patterns (90 x 90 degrees).
Dolby recommends ceiling speakers with wide dispersion patterns. If you use ceiling
speakers with narrow dispersion (less than 90 degrees  90 degrees) or those with aimable
drivers, angle the drivers slightly toward your listening position.
Will we see any new speakers from B&W matching these specifications? Or are we left dry and would need to change to other brands?
HT: CLASSE CA-5300 DELTA - BRYSTON 4B SST2 - Marantz AV8802A - B&W 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2, SA Talent - NORDOST Heimdall2/Frey2 - ISOTEK EVO3 Titan,Sigmas - Samsung UE78JS9505 - GIK ACOUSTICS - AUDYSSEY Pro Kit
HP: 2*MOON Neo 430HA D - 2*Schiit Yggdrasil - 2*Audiobyte Hydra Z/ZPM - 2*iFi micro iUSB 3.0 - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, 2*LCD-XC - SHURE SE846
Berland is offline
post #19000 of 25098 Old 08-11-2014, 08:07 AM
Daniel Smith's Avatar
Quoted: 22 Post(s)
Liked: 27
I am looking for good LCR in wall. Any good options?
What are the dispersion patterns from the existing B&W speakers. I would have guessed that they would already be pretty close to that specification. I think they are almost all aim-able so dolby seems to think they could be used.
Daniel Smith is offline
post #19001 of 25098 Old 08-11-2014, 11:55 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
either way shall work
zoro is offline
post #19002 of 25098 Old 08-11-2014, 11:57 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
thanks. i would like some that sound as good as CM5
zoro is offline
post #19003 of 25098 Old 08-11-2014, 11:57 AM
Gecko85's Avatar
Quoted: 157 Post(s)
Liked: 98
Any chance you can put the CM5's on stands? That would allow you to get them away from the wall, and they'll sound much better.
Panasonic TC-P60ST60, Pioneer SC-1523-K, Oppo BDP-103D, Pioneer PL-550 + Cambridge Audio Azur 640P, B&W CM1 (fronts), B&W CM Centre, Athena Point 5 Mk II (rears), Hsu VTF-2
Sony 34XBR960, Onkyo TX-NR414, Sony PS3, Athena Point 5 Mk II (center and fronts), Wharfedale WH-2 (rears), Polk PSW10
Gecko85 is offline
post #19004 of 25098 Old 08-11-2014, 12:01 PM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
I agree ! but family is not quite upto it.
other alternate is to drywall the alcove and install in wall speakers including centre
zoro is offline
post #19005 of 25098 Old 08-11-2014, 01:10 PM
Quoted: 78 Post(s)
Liked: 26
There are a few front ported speakers out there around $1500:
Sonus Faber Venere 1.5/ 2.0
Paradigm Reference Studio 20
Focal Profile 908
Just to name a few. Or you could get a custom ID manufacturer like Salk/ Selah to build you a set. If you really like the CM5s and you can extend your budget to $2500 I would go with the PM1
post #19006 of 25098 Old 08-11-2014, 01:28 PM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 133
BW's do have in-wall speakers, but they are expensive, the ones that sound good, most folks I talk too think they are HT speakers.
Chise is offline
post #19007 of 25098 Old 08-11-2014, 01:37 PM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
Focal Profile 908
How deep Are paradigm?
Any LCR? Like CM1
zoro is offline
post #19008 of 25098 Old 08-11-2014, 01:41 PM
kamouflage's Avatar
Quoted: 145 Post(s)
Liked: 92
Focal Profile 908
I'll vouch for the Studio 20's as being awesome speakers. I think the CM5's are incredible sounding speakers. They were my first choice during my last bout of upgradeitis but location ruled them out for me too with them being rear ported, good luck.
PSN ID: javant86
Xbox Live: PikturePerfekt
kamouflage is online now
post #19009 of 25098 Old 08-11-2014, 01:45 PM
Quoted: 78 Post(s)
Liked: 26
Any LCR? Like CM1
It seems that the Paradigm Center is rear ported. You might just be able to get three Studio 20s.
The Venere 1.5 is 12" in depth and they also have a matching front ported Center. Check out the Sonus Faber site for more info. Sonus Faber is sold at many locations so finding a pair to audition shouldn't be too hard.
post #19010 of 25098 Old 08-12-2014, 08:25 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
I don't have room for center, it has to be on wall or in wall too.
zoro is offline
post #19011 of 25098 Old 08-12-2014, 08:49 AM
Quoted: 78 Post(s)
Liked: 26
You can get three Studio 20s for LCR.
Are they going on top of your cabinet? If so, I'm going to assume that the top of the cabinet is above ear height. If that is true consider how you are going to tilt the speakers down towards the listening position. (Or if your bookshelf is above ear height)
Consider something like the Auralex Mopad Iso Pad:
http://www.sweetwater.com/store/deta...FZJr7AodsEQAWw
They are cheap, adjustable and will isolate the speaker from the bookshelf, cleaning up the sound.
post #19012 of 25098 Old 08-12-2014, 10:46 PM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Which do you consider good, i am pondering adding a few backspeakers to my 802/htm2 fronts. I am looking at CI700 line. want to get 4 or 6 CCM7.4's for the job because they have a good included backbox.
Daniel.
for men to evolve we have to upgrade
danielo is offline
post #19013 of 25098 Old 08-13-2014, 06:04 PM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
advanced101101, did you get your 800's yet? If so how are you liking them? Care to comment on how you feel they compare to your 802's, what's the same, what's different, etc?
Rod#S is offline
post #19014 of 25098 Old 08-13-2014, 06:31 PM
wadeh911's Avatar
Quoted: 79 Post(s)
Liked: 72
Daniel.
I'm very happy with my two rear channel in ceiling speakers B&W CCM80's. They blend extremely well with my front 803D's and HTM2D2 center. Not using backboxes with mine.
South Florida is my Theater
Listen to live music and recreate it at home.
wadeh911 is offline
post #19015 of 25098 Old 08-14-2014, 04:30 AM
Quoted: 78 Post(s)
Liked: 26
You know I wrote an entire review yesterday and my damn browser froze and lost it all
post #19016 of 25098 Old 08-14-2014, 04:44 AM
jima4a's Avatar
Quoted: 281 Post(s)
Liked: 153
Sounds a bit like the Dog ate my homework. 😄 And yes the Dog has also eaten my homework in the past, it sucks.
jima4a is online now
post #19017 of 25098 Old 08-14-2014, 05:37 AM
Quoted: 78 Post(s)
Liked: 26
My Review of the 800 Diamond versus the 802 Diamond
My new speaker search started a couple months ago. I originally had a set of Salk HT2-TL, not a shabby speaker by any means. But, it would take something special to be clearly better. I had listened to a bunch of different brands and speakers but I kept coming back to B&W. There is something about the house sound that I find enjoyable for classic rock. Once you get into the 800 series you get all the music detail but little of the harshness involved with hyper accurate speakers. So I picked up a pair of 802 Diamonds. I had them for a week and loved them, but I knew there was more, and I wanted it. It has been 5+ years since I heard a set of 800s and from I remembered they were fantastic. So I created more money in the budget and exchanged the 802s for the 800s. I moved up to the 800s without hearing them, on a leap of faith that they would be everything that the 802s are and more.
I was more than glad I did.
The 800 Diamond is in a completely different league than the 802 Diamond.
The first thing I noticed is that this speaker seems much more efficient than the 802. This is strange considering both speakers are rated at 90db. I found myself not needing to turn the volume up nearly as much to excite the speaker. I imagine that some people would be happy running this speaker off of a 75 WPC tube amp, although I doubt it would be able to control the woofers like a quality solid-stage amp. The dynamics of the 800s are much closer to a much larger high efficiency speaker like a JTR than the 802/803.
Bass: The bass is much more impactful. Once broken in (4 Hours of Electronic Music) the 800s dig much deeper. The bass still retains the speed of the 802s two 8” drivers but now I can feel it. “Fast Bass” is a term many dismiss but I refer to it as the speaker’s ability to reproduce a high frequency of kick drums independently. When listening to Rush’s Tom Sawyer Drum Solo each kick was fierce but separate, no muddiness here. The rise and fall of each bass note was reproduced with amazing speed and clarity. The speed is faster than my JL F113, although the F113 is much more visceral. I preferred the 802s with my F113 for music. I prefer the 800s without the F113. Maybe I would need two F113s to compliment the 800s, one F113 just gets lost. The bass is so good that I am thinking about selling the F113, but for right now I only have it turned on to shore up the lowest of lows on movies.
Mid-Range: Same mid-range driver as the 802 I should expect the same result with the 800? Wrong. The lower mid-range is much more natural. Male vocals have an inviting sound that might make you want to put away your Norah Jones albums and put on some Bob Dylan and Eric Clapton. After listening to the 800s I realized that many of the speakers that I have listened to have been a tad boxy and bloated in this region. Don’t get me wrong the 802s are great I would never have noticed this unless I compared it to the 800. The mid-range also seems slightly more detailed, diving deeper into each recording. As a measure of detail I use Pink Floyd’s The Final Cut. This recording a ton of detail deep into the soundstage that is only re-produced by quality speakers. Each time I upgrade my speakers I hear more and more out of the recording, it is kind of amazing considering I have been listening to that recording for 15 years.
Highs: The 800 and the 802 are comparable in the HF region. Although I would classify the highs as being neutral I would have to say with my associated equipment it is one small notch on the bright side. This is something that I find enjoyable. My sound is comparable to an all Rotel setup as opposed to an all Mcintosh setup. My preferred toe-in with the 800s was similar to my preference of all the 800 series with the tweeters crossing 8’ beyond my listening position.
Other Notes: This is a large speaker. Pictures on the internet make it seem like the 802s are similar in size but this isn’t the case. My girlfriend and I unpacked the 802s, for the 800s I requested my dealer give me hand. Once upright and unpacked the speaker move freely on the stock wheels. The 800s create a physical presence in the room whereas the 802s would blend in with a nice stand. WAF might be a factor for some due to its size. I’m not sure how I feel about the look on the Aluminum base plate but I would probably prefer it being matte black. The 800 is also 1" taller than the 802. For most people this will put the tweeter above the listener's ears in the seated position. I currently have the speakers tilted a bit with the included spikes but I am going to fine tune the tilt this weekend. You have to be careful though, the drivers are physically time aligned and that isn't something you want to mess with much.
If I was a reviewer I would give the 802s a 4/5 and the 800s 5/5. I didn’t understand what a “reference” speaker is until now. My speaker search is over and I will probably hold on to them for 8-10 years.
Original Speaker Considerations: Revel Salon/Studio, Sonus Faber Olympica, Focal Utopia, Salk SS10, Martin Logan
Potential Questions:
Is the 800 $10,000 better than the 802? I would say definitely, if you can afford it. Let’s say you have a $30,000 budget for equipment and speakers. I would rather have the 800s running with $5000 in equipment than have the 802s running with $15,000 in equipment. Although you would have to be smart how you spend the $5000.
Would the 802s be better than the 800s running $10,000 in subs? Depends on what is more important to you. Obviously $10,000 in subs (Two F113s) would create a fierce front of sub 80Hz sound, which would benefit movies. But for music the 800s mid-range and upper bass would still be far superior. And hey, you could always add subs later.
Associated Equipment: Wyred 4 Sound DAC2, Wyred 4 Sound mAmps, Mac Mini running Pure Music and hi-res music, quality cabling. The new mAmps are something to consider. At $2300 for a pair they provide more than enough detail and current to give the 800s what they need. Their small form factor doesn’t hurt either. As I continue to upgrade my system I am exciting knowing that the 800s will reward me with even better sound. I’m not even close to achieving the speaker’s full potential.
Below is pic of the 800s in my setup. Not ideal, but temporary. I have a new stand coming in a few weeks that will afford me floor space to get the F113 in there. Next year I plan on moving into a new house with a dedicated room.
post #19018 of 25098 Old 08-14-2014, 06:40 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 133
Daniel.
I did check them out, I will go to the design center in listen to them.
Chise is offline
post #19019 of 25098 Old 08-14-2014, 09:56 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
B&W and most manufacturers are probably just waiting to see if ATMOS has enough sustained and consistent market interest or go down in flames like other market failures.
If ATMOS is a true success, then there is no doubt B&W, Revel, KEF and everyone else will produce "ATMOS - ready" speakers.
Still way too early.
AcuDefTechGuy is offline
post #19020 of 25098 Old 08-14-2014, 10:16 AM
drewTT's Avatar
Quoted: 719 Post(s)
Liked: 727
Awesome speakers but that looks like awful placement. You basically have them in a hallway in between two rooms?
LG OLED65E6 | NAD C368 | Dynaudio Special 40 + Stand 3x | Oppo UDP-205 | Maingear Drift Z170 GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+
drewTT is offline
Reply Speakers
802D , atmos , B W , b&w dm1400 , Bowers And Wilkings 685 Speakers , carver cm-1090
