B&W Owner's Thread - Page 677 - AVS | Home Theater Discussions And Reviews
post #20281 of 20300 Old 01-23-2015, 05:20 PM
Quoted: 77 Post(s)
I currently have 3 pair's of 683s2s and a htm61 center I'm looking to upgrade to either 802d's or 803D's and a Htm2 Diamond tweeter center (the largest one) for my front Soundstage.....any ideas where to pick them up at a good/fair price in Southwest Florida?
JimSatala77 is offline
post #20282 of 20300 Old 01-23-2015, 10:19 PM
mlupia92's Avatar
Planning on getting a new Marantz sr-7008 and Emotiva UPA-200 for my current system.
Fronts: B&W 685 S2
Center: B&W 681 S2
Rears: Klipsch S-20 (soon to be swapped with the 685 S2's)
And I plan on getting a pair of 683 S2's down the road for my fronts. Any other receiver options I should be considering for my speakers? I pretty much plan on using the receiver just to power my center and rears and using the amp to run my fronts. I have a preference to Denon and Marantz and am in need of something that has at least 5.1 channel analog outputs (as I may run a 5 channel power amp at some point). Any suggestions would be appreciated.
mlupia92 is online now
post #20283 of 20300 Old 01-23-2015, 10:31 PM
Quoted: 92 Post(s)
Liked: 7
Depending on the size of your room and preference for playback volume etc something like a nr165o by marantz takes up a lot less space and had everything a sr7008 had except it's much less power s d processing. Minus xt32
pickering.tim is offline
post #20284 of 20300 Old 01-23-2015, 10:39 PM
mlupia92's Avatar
I thought about the 1605, but its missing the 5.1 analog outputs that I want. So that won't work.
post #20285 of 20300 Old 01-23-2015, 10:52 PM
Quoted: 92 Post(s)
Liked: 7
Makes sense. I have a an sr5009 and I would recommend it. It was not the receiver I was in search of due to the fact that I wanted xt32 and more processing and power than the sr5009. It is a good product tho and Pm if you are interested in basically mint condition used at a fair price
post #20286 of 20300 Old 01-24-2015, 01:10 AM
ironsurvivor's Avatar
I bought the sr7009 mainly because i got an incredible deal and im in love with it. Have not tried atmos yet, but i am toying with the idea
ironsurvivor is online now
post #20287 of 20300 Old 01-24-2015, 10:15 PM
turnne1's Avatar
Quoted: 797 Post(s)
Liked: 179
Fronts: B&W 685 S2
Center: B&W 681 S2
Denon 4520
good build quality and fully featured...except atmos of course
Can be bought now for well under a $1000...depending on the dealer and your timing
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 LG 47LE8500 Denon 4520 Celestion 305 speaker system
Rm 3 Samsung 51E8000 Pioneer SC37 Kef 2005.2 speaker system
Rm 4 Panasonic 50ST50 Pioneer SC77 Mirage Omni sat speaker system
turnne1 is online now
post #20288 of 20300 Old Yesterday, 11:26 AM
khollister's Avatar
Tried searching for something on this, but no joy ...
I am thinking of upgrading to CM9 s2 for the front and CM8 s2 or CM5 s2 for the surrounds. My concern about the CM8's is the tweeter height will be below ear level and the midrange driver will be below the back of the sofa (the surrounds will be about 3' away and 20 degrees behind. I can fabricate a short box stand (lead filled) to bring the tweeters to ear level but I'm somewhat concerned about changing the coupling of the woofers to the floor. Ironically, I am considering the CM8's instead of the CM5's due to aesthetics.
Also curious as to whether there is any real-world sonic advantage to the CM8 vs CM5 given they will be rolled out @ 60-80 Hz anyway?
khollister is online now
post #20289 of 20300 Old Yesterday, 05:36 PM
postrokfan's Avatar
Quoted: 143 Post(s)
Liked: 626
There are probably no advantages of using the CM8 instead of the CM5 for surrounds except that you won't need stands. The one possible exception is if you listen to a lot of multi-channel music. Having the midrange driver behind the couch would be a major problem.
postrokfan is offline
post #20290 of 20300 Old Yesterday, 06:52 PM
Liked: 0
Receiver to go with 685 S2
I came into a pair of 685 S2 fronts and wanted your opinion on a receiver. Any suggestions? Thanks!
gupster is online now
post #20291 of 20300 Old Today, 05:07 PM
postrokfan's Avatar
Quoted: 143 Post(s)
Liked: 626
What's your budget? My first inclination would be to go with Marantz if it is within your budget.
post #20292 of 20300 Old Today, 07:27 PM
Liked: 0
My budget is rather flexible. I would like to get the most out of the speakers but I live in a condo and have to be respectful of the neighbors. I was looking at the Marantz SR 5009 and the Yamaha RX-A840. I like to stream so blue tooth and wifi are preferred.
post #20293 of 20300 Old Today, 09:01 PM
mlupia92's Avatar
The SR-5009 would be the better option of the two you listed. If you could push you budget a little you could get the 6009 Marantz which has better amps and more power. I've also seen it drop to $999.99 occasionally so depending on when you buy one, you may get a deal.
post #20294 of 20300 Old Today, 09:04 PM
mlupia92's Avatar
Originally Posted by turnne1 View Post
Denon 4520
Warren
Thanks for the suggestion, I actually work at a Magnolia store and I think we have a Denon 4520 that used to be a display that's for sale now, just never heard it running a set of B&W speakers so wasn't sure what to think. I'll have to look into it now, thanks!!
post #20295 of 20300 Old Today, 09:05 PM
JimSatala777's Avatar
Quoted: 22 Post(s)
Liked: 4
They just dropped the 8801 to 1999 that's an awesome prepro for less than 50% original msrp and then you just grab a nice balanced Class "A" amp
JimSatala777 is online now
post #20296 of 20300 Old Today, 09:23 PM
turnne1's Avatar
Quoted: 797 Post(s)
Liked: 179
unless you worked at an Magnolia Design Center
the 4520...and SC77 were the nicest receivers I had seen in the Magnolia Home theater location
a few had the Marantz 7701/7055 combo as well
Warren
post #20297 of 20300 Old Today, 09:25 PM
turnne1's Avatar
Quoted: 797 Post(s)
Liked: 179
you can get the 8801 for a lot less than that
its a serious closeout piece now as they implement the 8802
Warren
post #20298 of 20300 Old Today, 09:27 PM
Quoted: 22 Post(s)
Liked: 4
I'm pretty sure that magnolia has a primitive listening room with 7008 or 7009 and 7702 and 8801 and sc79 sc89
it's not the Walmart
post #20299 of 20300 Old Today, 09:35 PM
turnne1's Avatar
Quoted: 797 Post(s)
Liked: 179
interesting
I would say the Yamaha would be the better option
In fact I would snag the Yamaha refurb A1030 from A4L for $549
or troll Magnolia Home theater for their clearance deals
Warren
post #20300 of 20300 Old Today, 09:42 PM
Quoted: 22 Post(s)
Liked: 4
you can get a new Krell kav 300 receiver for a song right now
Reply Speakers
B W , Bowers And Wilkings 685 Speakers , carver cm-1090
Gear in this thread - cm-1090 by PriceGrabber.com
