B&W Owner's Thread - Page 679 - AVS | Home Theater Discussions And Reviews
post #20341 of 20346 Old Yesterday, 08:01 PM
Rod#S's Avatar
Quoted: 109 Post(s)
Liked: 30
Originally Posted by JimSatala777 View Post
I'm probably just going to go with the 802s d2 because I don't really think I want to be tempted to buy a pair of krell 900e's or ML 33/53 to power them to full potential. ..I would be deaf in a couple months...I have my eye on a pair of 403e's that are more in my price range and would power the 802's and 803's real nicely
The 800's definitely don't need huge capacity power amps How much they need will depend on your room plus and the decibel level you typically like to listen at plus whether you use bass management. If you don't ever run them full range then they would run just great on very minimal power actually.
I have never heard the 800D1's but the 802D2's are great speakers and perform wonderfully with 300 watts into 8 ohms.
Rod#S is offline
post #20342 of 20346 Old Yesterday, 08:11 PM
JimSatala777's Avatar
Quoted: 57 Post(s)
I'm 1 of those " i think it would sound better just a little louder" guys...just too get the most detail out of my music...sometimes right now I'm listening and I don't even realize that I have it at 90%,
what I do is try and take a break with the volume periodically to reaclimate my ears to the volume. ...when you are gradually turning it while listening it can get away from you without realizing it
JimSatala777 is offline
post #20343 of 20346 Old Yesterday, 08:12 PM
rpr
rpr's Avatar
I need some help guys. I have a pair of XT8 tower speakers. They are enjoyable, but very bright and harsh.
They cannot be bi-amped so my options are limited and will likely void any warranty I still have left on them, but I would like to attenuate the tweeters.
I've also heard these aluminum enclosures are a nightmare to disassemble.
So what can I do? Try to take them apart and install an L-Pad?
rpr is offline
post #20344 of 20346 Unread Yesterday, 10:26 PM
jav1's Avatar
685 s2 - Poor Bass
Hi Folks,
Have about 15 hours on a pair being driven by a Marantz nr1403 50watt receiver. I realize the Marantz may be a bit underpowered and I am planning on upgrading. But I primarily listen at low to moderate levels and only 2.1 so I feel I should get pretty good performance. The speakers are 10 inches from the wall and so far the bass is anemic. I've been setting the cross-over to the sub at 80 or 100 to get decent bass. Decided to run Audyssey, ran it 3 times and it choose to crossover at 120/150/120. When I auditioned them in-store compared to Martin Logan Motion 15 without sub, they definitely did not go as deep as the Motions but I don't recall them being this thin. Anyone have any thoughts on why I'm nowhere near how low they are rated for? Will another 85 hours of break-in really make that much of a difference? Any 685 S2 owners care to comment on your bass performance and amp/receiver you are using.
Many Thanks
jav1 is offline
post #20345 of 20346 Unread Today, 01:10 AM
John1788's Avatar
Originally Posted by jav1 View Post
Hi Folks,
Many Thanks
When listening to music are you using STEREO mode or PURE/DIRECT?
if on stereo -do you have dynamic volume on and on what level (light, medium, heavy)?
John1788 is online now
post #20346 of 20346 Unread Today, 03:32 AM
miliotov's Avatar
Quoted: 12 Post(s)
HT speakers
I finally took the decsicion to sell my Klipsch THX speakers and go for B&W speakers. The reason I'm selling my Klipsch speakers is that they sound to bright to harsh at reference levels. I had 805D's and I really loved the sound of those speakers.
Now I have a dedicated HT and would like to buy B&W speakers.
Because I don't want to start to do to much construction works I will be using the CWM7.3 as surround speakers, they will replace the Klipsch KL7800 and KS7800.
My problem is now the frontspeakers. Will I go with the CT7.3 or the CWM8.3??
Yesterday I went to audition the 8.3 and they have to sound I'm looking for. However they were underpowered with an Anthem MRX310. Propably I will go back to listen when they have a better amp connected to them. I personally have the denon POA-A1HD.
As for timbrematching I think you can use the CI800 and CI700 together, later I will go for Dolby Atmos so there are options in the 700 and 800 series for ceiling speakers.
I just would like have some advice on the frontspeakers CWM8.3 or CT7.3??
Any advice is welcome...
miliotov is online now
Reply Speakers
B W , Bowers And Wilkings 685 Speakers , carver cm-1090
Gear in this thread - cm-1090 by PriceGrabber.com
