B&W Owner's Thread - Page 685 - AVS | Home Theater Discussions And Reviews
post #20521 of 20536 Old Yesterday, 04:03 AM
Morfious's Avatar
Quoted: 23 Post(s)
Bi-Amp - Low frequenies and high frequencies are sent from 2 different amplifier channels. They can be from the same amp or from 2 different amplifers. The main concept is that each speaker is driven by 2 different channels. The amp and each speaker would have 4 connections (Hi +, Hi -, Low +, Low-). Best use of this method is with and external crossover and can give better sounding results since the low frequencies can be driven with a more powerful amp.
Bi-Wire - Low and high frequencies are sent from the same amplifier channel. The connectors at the amplifier end has the positive wires connected together as well as the negative wires connected together. Those 4 leads then make the run to the speaker.
Bi-Amping can have the ability to improve the sound quality or change the sound of the speakers, if an external crossover is utilized. You also can emphasize or decrease the bass in the speakers by using a different wattage amp for the low end of things.
Bi-Wire should not dramatically change the sound. You are effectively increasing the gauge of the speaker wire by using 2 runs to the same speaker.
I forget where I read the reference, but in my case using a quad cable 12 gauge speaker wire in bi-wire application is equivalent to using a single run of 9 gauge speaker wire. The main reasons I did it were for aesthetics, and for the fun of making the cables myself.
Hope this clears things up if there was confusion.
Panasonic 65ZT60 Plasma Calibrated by Chad B
Emotiva XMC-1 (Dirac is awesome)
Emotiva XPA-5 (200w x 5)
B&W (CM10 S2, CMC2 S2, CM5 S1)
SVS SB13 Ultra Sub (Planned Upgrade)
Room Treatments (Planned Upgrade)
Morfious is offline
post #20522 of 20536 Old Yesterday, 11:13 AM
karlsaudio's Avatar
Quoted: 80 Post(s)
Just a question here. I was at a place last night that had the 802Ds hooked up to some McIntosh mono blocks and pre amp. What an amazing sound in the mids and highs!! However. Below say 3-400 Hz, What a mess! VERY muddy bass! The room was treated and the treatments seemed to be the right kind and placed well. I am going to assume this was not the speakers and there was still something wrong with the room. I can't imagine the 800 series are like that. Anyone else experience this? Was the McIntosh stuff messed up? I know its hard to tell without actually measuring the room but I just found it odd. How do you sell multi thousand dollar equipment when it sounds like sh*t? This was not Best Buy.
Sounds good!
karlsaudio is offline
post #20523 of 20536 Old Yesterday, 02:44 PM
Gerardo2068's Avatar
Quoted: 161 Post(s)
Liked: 40
B&W Owner's Thread
On the minority of on this of course but internal crossover vs external cross over.. Crossover is a crossover doesn't matter where you put it. Unless there are 4 crossovers so the signal don't run in to each other at all. Just me visualizing it for what I have read.
Gerardo2068 is online now
post #20524 of 20536 Old Yesterday, 03:29 PM
Rod#S's Avatar
Quoted: 116 Post(s)
Liked: 31
Was there subs in the room? If so perhaps the pre-amp or SSP was set for double bass, that would certainly F up the low end. It's also possible the speakers were placed poorly, incorrect taps on the amps were used, etc. A lot of different things could be contributing.
Rod#S is online now
post #20525 of 20536 Old Yesterday, 03:49 PM
JimSatala777's Avatar
Quoted: 114 Post(s)
802d's have very good Bass response. ..not as good as say 800d's or Wilson Maxx3s or Grand slam
JimSatala777 is online now
post #20526 of 20536 Old Yesterday, 03:53 PM
drewTT's Avatar
Quoted: 72 Post(s)
Liked: 108
I would have been pointing that out the whoever was doing the demo for you. I have heard the 802 and 800D. Nothing but sublime sound across the board. The 800D was spectacular.
drewTT is offline
post #20527 of 20536 Old Yesterday, 04:12 PM
Quoted: 114 Post(s)
802d's fed by a Krell 402e will rattle your teeth and make you feel like you part of the music. ....800d's fed by a pair of 900e will literally kill you
karlsaudio likes this.
post #20528 of 20536 Old Yesterday, 05:35 PM
karlsaudio's Avatar
Quoted: 80 Post(s)
This was the first time I have listened to the 800 series. I know they can do better. When I say the bass was bad, it was bad!!! It was just noise without any coherence. I am sending them a email regarding this. Oh well. There was no other sub on. I looked at the connections.
Sounds good!
post #20529 of 20536 Old Yesterday, 05:36 PM
karlsaudio's Avatar
Quoted: 80 Post(s)
Now I know what to get when I win Powerball!
Sounds good!
post #20530 of 20536 Old Yesterday, 10:14 PM
ap1
ap1's Avatar
Originally Posted by fokakis1 View Post
The CM10 is an excellent speaker representing great value. You will not be disappointed.
That being said, if you can afford a pair of 80XD2 I would encourage you to do so. They are the next level. The D2s are world class speakers.
Good luck with your search.
I would say - go with 802D. Price looks reasonable. They are way better than anything in CM line. Di is an improvement over older D, but not too big. Keep in mind that you will need decent amp for 802D too, so allocate $1500-2000 for that (search for used Classe, Krell or Bryston of similar age with speakers).
ap1 is online now
post #20531 of 20536 Old Today, 05:36 AM
Patrick Butler's Avatar
Quoted: 87 Post(s)
Liked: 34
Hi karlsaudio,
Any time you hear bass in a room, you are hearing loudspeakers+the room. Rooms can cancel or amplify bass at certain frequencies. They can also sing. Play a bass note at the right frequency, and you'll hear how the room continues to play that note long after it should have disappeared. On top of what I've just pointed out about rooms, if you don't have your speakers properly setup you can create further issues in the bass (and elsewhere.) The big one is smearing, where a note should be distinct but is instead too soft (or loud) and simultaneously indistinct. There is perhaps no bigger problem for small room acoustics than dealing with bass issues below 500Hz.
What you experienced was likely a combination of a misbehaving room a a compromised speaker setup. Most acoustical treatments that you see in stores are ineffectual at bass frequencies, but quite effective in the midrange and treble. This explains why you can have great mids and highs, but poor bass.
Rest assured that all of the equipment that you listened to is capable of fantastic sound if used properly under favorable conditions.
Patrick Butler
B&W Group North America
Patrick Butler is offline
post #20532 of 20536 Old Today, 06:31 AM
Alsof1's Avatar
Thought I would attach a few good pics of the system - just got to have the 802's spiked now ........major mission as they sound so good as is , but guess this has to be done .
ID:	571721   Click image for larger version
ID:	571729   Click image for larger version
Alsof1 is offline
post #20533 of 20536 Old Today, 06:50 AM
karlsaudio's Avatar
Quoted: 80 Post(s)
Originally Posted by Patrick Butler View Post
Hi karlsaudio,
Patrick Butler
Hi Patrick,
I realized after posting this as it sounded like I was bashing the speakers. Far from it. I am a fan of the whole B&W line. What gets me is that someone trying to sell speakers. Especially expensive ones. would not want to try a little harder to make sure there were no flaws in the room they were in. I hope they make some changes!
Karl
Sounds good!
post #20534 of 20536 Old Today, 07:38 AM
KaliKid2013's Avatar
Quoted: 40 Post(s)
I have 802 Diamonds in a small 10'X12' treated room and recently borrowed a Mac 452 amp and 2500 pre-amp from a dealer, the sound was awesome. I also heard the Mac 600w monos with the C500 ss/tube amps at a dealers location, in a treated room, and was there for like...hours...it sounded so good I didn't want to leave...LOL. In both listening environments, the bass was accurate, precise, enjoyable and in no way "muddy". So as others here have already done... I too can attest to the fact that the Mac/802 combination is incredible in the right room with the proper set-up, toe-in, etc...
B&W 802 Diamonds | ASWCM12 sub | Rotel RSP-1572 pre-amp | Rotel RMB-1585 amp (bi-amping the 802 Diamonds) | Oppo BDP-105 | Samsung UN60H7150 | SurgeX QX515 Surge Suppressor/Power Conditioner | Audioquest Cinnamon HMDI, Ethernet, & USB A/B cables | Tributaries Type 6 Speaker Cables | Tributaries Series 6 Analog Interconnects | Acoustimac DMD-422 acoustic panels.
KaliKid2013 is offline
post #20535 of 20536 Old Today, 09:19 AM
Quoted: 87 Post(s)
Liked: 34
Hi Karl,
I took your post in the light in which it was written, which was merely relating an experience you had. Not a hint of bashing to be found! In any event, I like knowing when our accounts are not hitting the high standards I know them capable of achieving. I also like hearing the success stories as well.
Thanks for sharing!
Cheers,
Patrick
Hi Patrick,
Karl
post #20536 of 20536 Unread Today, 01:35 PM
Liked: 1
I bought a pair of DM580's over 20 years ago. I still have them and they still sound great.
KornDoggyDawg is online now
Reply Speakers
B W , Bowers And Wilkings 685 Speakers , carver cm-1090
Gear in this thread - cm-1090 by PriceGrabber.com
