B&W Owner's Thread - Page 692 - AVS | Home Theater Discussions And Reviews
post #20731 of 20760 Old 04-11-2015, 10:45 PM
Tank_PD's Avatar
Quoted: 34 Post(s)
Liked: 54
Originally Posted by Bugman1400 View Post
I tried to find a good deal for B&W 805s on Ebay from a seller that had good feedback. I paid $2K and got speakers that had marred cabinets and the diamond tweeters ripped out of them. I hope this post will let others learn from my stupidity and being a cheap-ass!
From the way the tweeters looked, it appears that they were after real diamonds!
I hope you paid with PayPal. There is a good chance you can still get your money back.
Tank_PD is offline
post #20732 of 20760 Old 04-12-2015, 02:27 PM
avsninja's Avatar
WTB a pair of PM1s
avsninja is offline
post #20733 of 20760 Old 04-13-2015, 10:32 AM
scanido's Avatar
Originally Posted by Patrick Butler View Post
The best choice for 800 Series owners would be the CCM8.5
Been late to the party with all the discussion on equivalent surround/height channel speakers for 800 series Diamond.
So it is recommended the CCM8.5 for in-ceiling, would saving a few bucks on the CWM8.5 still work for ceiling?
BTW, as far as installing anyone of these CI800 line speakers, does one need to do anything differently if they were installing double 5/8" drywall? The installation diagrams dont mention any setback allowance to keep the speakers front face flush with the drywall. Any advice is appreciated.
See Profile
scanido is offline
post #20734 of 20760 Old 04-13-2015, 03:26 PM
drewTT's Avatar
Quoted: 73 Post(s)
Liked: 108
File an "item not as described" case with Ebay immediately. You will get your money back 100%.
drewTT is online now
post #20735 of 20760 Old 04-14-2015, 05:48 AM
gene9p's Avatar
Liked: 24
wow....sorry to see that....definitely file a case for refund if seller doesn't offer to do so
gene9p is offline
post #20736 of 20760 Old 04-14-2015, 08:17 AM
scanido's Avatar
CI800 Installation Thickness
To keep this as general knowledge for anyone interested in installing any of the CI800 speakers, I received a response back from BW Support stating that installation will support double drywall thickness of 1.25".
Here's the reply i received:
"Both CI speakers sit over the top of the plasterboard, the thin shallow bezel provides a clean, tidy appearance.
The CI series of speakers have been designed to accommodate a wide range of thickness drywall installations, and can confirm that a wall approximately 1.25" thick would be within the installation travel of the fixtures of the speakers."
Great news, as I look at adding CCM8.5`s for ceiling heights into my new theatre.
See Profile
scanido is offline
post #20737 of 20760 Old 04-15-2015, 04:32 AM
beatboy77's Avatar
Another Like B&W?
Is there another speaker manufacturer like B&W who has a separated tweeter which sits on top, essentially outside of the main cabinet?
Kind Regards,
Josh
hidefpreview
beatboy77 is offline
post #20738 of 20760 Old 04-16-2015, 10:43 PM
Liked: 0
getting a center for my CM8s.
I just got a used pair of CM8 S1. I was wondering if the CMC S2 will work well with it? Will the timbre match. I dont have space for the CMC 2 S1. I didnt hear good things about the CMC S1 on this forum so was wondering if the CMC S2 will be a much better inprovement? Or should i just buy the CMC S1 to match it? My cabinet will only hold a 20" Centrr channel.
covers is offline
post #20739 of 20760 Old 04-16-2015, 10:49 PM
Liked: 0
btw. Im using a SVS PB-2000 with them CM8 S1 if that makes a difference. Im hoping the sub can Makeup for any midbass a CMC S1 is missing.
covers is offline
post #20740 of 20760 Old 04-17-2015, 07:57 PM
tractng's Avatar
Quoted: 44 Post(s)
Liked: 26
Hey there. I am in the process of building a family room. I bought a pair of ceiling speakers CCM663. Since this is a new construction, would you guys build a box to house them?
I have the tools and scraps to build.
TT
tractng is offline
post #20741 of 20760 Old 04-17-2015, 08:07 PM
postrokfan's Avatar
Quoted: 201 Post(s)
Liked: 912
The CMC S1 is a pretty mediocre center channel. I'm not sure the CMC S2 is a huge improvement although it is marginally more sensitive. I think timbre match would be decent with either one. It's too bad you can't make the CMC2 work.
HT: CM9 S2 FR/FL, CMC2 S1, CM5 S1 surrounds, ASW610; Yamaha rx-a2030; Parasound 2100; Parasound 275; Oppo BDP-93; ATV
2 Channel: Ascend Acoustics Sierra-1 NrT FR/FL, ASW608; Parasound Halo P5; Parasound Halo A23; Rega RP1; Marantz CD5004
postrokfan is offline
post #20742 of 20760 Old 04-21-2015, 03:27 PM
spincut's Avatar
Quoted: 23 Post(s)
But just to be clear, the CMC2S2 is supposed to be pretty great, right?
spincut is offline
post #20743 of 20760 Old 04-21-2015, 08:41 PM
postrokfan's Avatar
Quoted: 201 Post(s)
Liked: 912
Both the CMC2 S1 and CMC2 S2 are great centers.
post #20744 of 20760 Old 04-21-2015, 08:49 PM
wse
wse's Avatar
Quoted: 750 Post(s)
Liked: 423
Originally Posted by vvuuren View Post
Anyone know when new 800 series will come out?
Maybe CEDIA 2015 or 2016 soon! Usually every 5 years
wse is online now
post #20745 of 20760 Old 04-21-2015, 10:44 PM
tanwn1's Avatar
Quoted: 31 Post(s)
Kind Regards,
Josh
You may find another manufacturer having separate tweeter which sits on top but most of them do not have the B&W expertise and technology , R&D to get accurate sound.
tanwn1 is offline
post #20746 of 20760 Old 04-22-2015, 02:18 AM
tshot07's Avatar
Hope to get some helps diagnosing a clipping bw htm3s.
-I purchased a bw htm3s from ebay, supposed to be fully functional.
-Found out that one of the jumper cable banana plug was broken when the speaker arrived.
-Made a new set of jumper cable with 9 G with banana plug and all.
-Ran the speaker with denon 4311. The sound was "soft", barely audible even at -20db. The receiver shut off at -15db.
-I removed the jumper cable and ran woofer and midrange one at time. The sound is louder but the receiver shut off at -10db.
Normally, I ran a biamp 683s, htm61, 4 685 for surround. -25 to -20 is loud for me. The speaker cables are 14g.
-thinking that htm3s may need more juice, I unplugged all the 6 series, the main and surround speakers. I biamp the htm3s through the front channel. The result are the same, a little louder, but not to the level of the htm61 and the receiver clipped at -12 db.
- I set the crossover at 80 and 100hz with the same result.
-I ran the htm3s with a Yamaha receiver that a friend uses to run his cm9 set up, still the same.
My questions are:
1. Should I try to run it with an external amp? Will it be any different? Getting an external amp to test it out is a little challenged.
2. Does this sound like a receiver or speaker problem? The speaker wires integrity is good. I would imagine that the denon 4311 should be able to easily drive htm3s by itself.
3. Would the unknown force that broke the banana plug during shipping affect the internal component of the speaker? It doesn't appear to be so at the binding post.
Or just return the speaker.
I am trying to up grade to the 804s. The htm3s was the first step.
Any input would be appreciated.
tshot07 is offline
post #20747 of 20760 Old 04-22-2015, 05:20 AM
baranowski's Avatar
Quoted: 32 Post(s)
I would get the speaker tested. If you did not run into a clipping problem before installing the htm3s then I doubt it would be anything other than the speaker.
I had a cc6 center channel for years. One day at higher volume it clipped my amp. I ended up disconnecting the tweeter and the amp would not clip. The tweeter finally had an issue... but only at higher volume.
Hope this helps
Bill
baranowski is offline
post #20748 of 20760 Old 04-22-2015, 08:48 AM
Morfious's Avatar
Quoted: 30 Post(s)
I have a CMC2 S2 sitting between my CM10's and it sounds wonderful. Nice full sound, pans left and right seamlessly. I am quite pleased with the sound. I heard the CMC S2 in the store and it did not impress me at all.
Panasonic 65ZT60 Plasma Calibrated by Chad B
Emotiva XMC-1 (Dirac is awesome)
Emotiva XPA-5 (200w x 5)
B&W (CM10 S2, CMC2 S2, CM5 S1)
SVS SB13 Ultra Sub (Planned Upgrade)
Room Treatments (Planned Upgrade)
Morfious is offline
post #20749 of 20760 Old 04-22-2015, 07:54 PM
tractng's Avatar
Quoted: 44 Post(s)
Liked: 26
Nice. Ready to purchase. Counting the pennies
tractng is offline
post #20750 of 20760 Old 04-23-2015, 12:16 AM
spincut's Avatar
Quoted: 23 Post(s)
Yeah that's the impression I'm getting, the CMC2 s1 was good, and the CMC2S2 is even better. I think towers may be too much for my tiny conrete-y media room, but I figure with CM6S2's at least I get the neato separate tweeter look and the beefiest satellite. I just hope if I get the CMS2 S2 so I can can get the good center channel isn't overkill.
spincut is offline
post #20751 of 20760 Old 04-23-2015, 02:44 AM
jima4a's Avatar
Quoted: 106 Post(s)
Liked: 79
It will be far from overkill, just the much better option. The CMCS1 was highly regarded so the CMCS2 should just be that much better and a match to the CM10s or CM6s. A good center is important for movies and a good matching center more so for multichannel music.
jima4a is offline
post #20752 of 20760 Old 04-23-2015, 08:23 AM
Morfious's Avatar
Quoted: 30 Post(s)
I find that the CMC2 S2 is very clear, even at low volumes. With my older gear I had to turn the volume up to understand what the actors were saying because the sound was muddy. With the CMC2 S2 the dialogue is very clear and precise.
Morfious is offline
post #20753 of 20760 Old Yesterday, 04:53 PM
rahivictory's Avatar
best amp for 802d2
I'm in the process of putting together a home theatre with 802d front and htm 2 centre and ceiling mounted surrounds. I've been advised to consider McIntosh amps, or Classe, but have only heard the speakers with the Mac. Sounded great, but just want to know about other pairings. In particular, the Mc 7 channel is not powerful enough for the 802's so I need a separate amp. And with Mc that gets expensive.
Interested in other suggestions, especially experience with Emotiva amps which I've heard some people have successfully paired with the 802s. Alternatively, anyone have any preferences between the classe vs mc amps?
thanks in advance!
rahivictory is offline
post #20754 of 20760 Old Yesterday, 05:07 PM
vvuuren's Avatar
Quoted: 76 Post(s)
Liked: 25
thanks in advance!
Krell all the way!
vvuuren is offline
post #20755 of 20760 Old Yesterday, 05:51 PM
krell
Krell all the way!
I'm a huge krell fan, but very disappointed after D'Agostino left. Haven't listened to anything recently, though I still have a KSP7b that I love. However, krell only makes a 200wpc 7 channel amp, and otherwise, it's even pricier than the Mc gear.
Do you have anything specific you've used with 802d2's?
post #20756 of 20760 Old Yesterday, 06:36 PM
vvuuren's Avatar
Quoted: 76 Post(s)
Liked: 25
I use Krell Evolution 600's with mine which sounds awesome but they're not available anymore and little more expensive. I haven't heard their new amps yet but the reviews are very good. I too were disappointed when Dan D was ousted! I have a Foundation that sounds very good.
vvuuren is offline
post #20757 of 20760 Old Today, 03:49 AM
Cal68's Avatar
Quoted: 46 Post(s)
Liked: 74
thanks in advance!
I'm using a 3-channel McIntosh MC303 amp to power my B&W 803D2's and the matching center channel. It sounds great. A huge improvement over using my Integra 9 channel amp to power them.
Cal68
Cal68 is offline
post #20758 of 20760 Old Today, 06:46 AM
thrang's Avatar
Quoted: 352 Post(s)
Liked: 327
Consider Parasound Halo's...
Listening: Constantinople from "Modern Cool" by Patricia Barber (Rating 8/10) • Watching: "Captain America: The First Avenger" (Blu Ray ISO) (Rating 9/10)
Thrang's Theater: Sony VPLVW-1100 - Bowers & Willkins 800/802/803/HTM2D D2 Diamond - JL Audio Fathom 113 - Lumagen 2143 - McIntosh MX-151 - Parasound Halo JC1/A51 - Oppo 103 - Dune Smart B1/Synology 20TB NAS - DirecTV Genie - TiVo Roamio - Apple TV - PS4 • Audio: Sennheiser HD800 - Oppo HA1 - Kef LS50 - iTunes/Pure Music - iMac 5k
thrang is online now
post #20759 of 20760 Old Today, 08:48 AM
Rod#S's Avatar
Quoted: 122 Post(s)
Liked: 32
If you like D'Agostino designs he has a new line of home theater amps coming out but obviously won't be cheap however they are relatively affordable compared to his Momentum's
I personally use Bryston, they sound great. If you are looking to save money then like you mentioned Emotiva would be an obvious choice and another decent bargin would be Anthem PVA and MCA amps but they might not have the wattage you are looking for. You could also check out ATI.
Rod#S is online now
post #20760 of 20760 Old Today, 09:14 AM
Iostream's Avatar
Agreed, Parasound makes some fantastic amplifiers that work well with the 800 series. In fact, the only reason I am considering replacing my parasound electronics with McIntosh is because I have always wanted those blue meters. I don't think it is really going to be much more than a vanity upgrade.
Iostream is online now
Reply Speakers
B W , Bowers And Wilkings 685 Speakers , carver cm-1090
Gear in this thread - cm-1090 by PriceGrabber.com
