B&W Owner's Thread - Page 695 - AVS | Home Theater Discussions And Reviews
post #20821 of 20843 Old 05-13-2015, 11:54 PM
Liked: 0
Originally Posted by wadeh911 View Post
His advice was spot on. Listen to the 803D's. Such a difference from the 804's. They have the ability to give you amazing rock n roll and just as quickly change to Mahler or Miles Davis. The 804's are a step down from this ability. I have dual SVS SB13 ultras with my 803D's and you will not be disappointed. Jethro Tull or Grover Washington or ZZ Top. All worth the 803D's.
I have the TOTL 800 Di's but agree that the 803 Di's are great bang for buck and far more room friendly than the larger models, and I could easily live with them long term.
804 Di's are tuned slightly differently which gives them a slightly different mid-treble balance, which isn't a bad thing in some respects as it gives prospective buyers a choice of flavors. The 804's have a slight dip at 2kHz in the response - which is actually due to a slight variation in the crossover pcb. It's possible to remove the dip by installing the missing 'C2', a 10uF capacitor, but the overall balance might become a bit too forward in the upper mids without additional tuning so I suspect that's why it was omitted.
Kel Varnsen is offline
post #20822 of 20843 Old 05-16-2015, 12:46 PM
CHASLS2's Avatar
Quoted: 45 Post(s)
Liked: 29
Originally Posted by adrummingdude View Post
CM9's are indeed pretty easy to drive, but you still should see some performance gains in going to a stronger amp. Will it sound like a different speaker?...probably not, however the biggest difference will be at very high listening levels where the speaker otherwise would start to compress with the AVR. I have a Parasound Halo A21 driving my CM9's. The biggest difference sound quality wise between it and the amps in my Pioneer Elite receiver is that the Halo sounds a little flatter in the upper bass region, and a little softer way up top. These differences are very slight though, so to justify the $2500 retail price of that piece of gear can be a tough call for a lot people (like my wife, for instance).
From your initial post though, I suspect that your dissatisfaction has more to do with your room, or perhaps your speakers, than your receiver or your amp. Your room and speakers, in that order, are going to have about a 90% influence on how your sound is presented. Fancy electronics can smooth a little here, boost or cut a little there, but the room and speakers have to be right.
My CM9s2's sound great in my bedroom with a old Acurus 200 x3 amp.
Panny 60VT60 Acurus 200x3
Pioneer Elite 05FD &51FD
2 Oppo 83's Pioneer Elite DV 59AVI
Paradigm SIg2 v3's & 490cc
Pioneer Elite SC61 SVS SB12NSD
2 S-VHS VCR's B&W CM9 S2's
CHASLS2 is offline
post #20823 of 20843 Old 05-16-2015, 02:40 PM
adrummingdude's Avatar
Quoted: 142 Post(s)
Liked: 55
I enjoy mine very much as well.
My room sucks though, and since it is my family's main living area, there's only so much I can do about tuning it. Its 37.5 feet long, but only 12 feet wide, with mostly an 8 foot ceiling. The gear is oriented to fire towards the short width, so the speakers are too close to the back wall, and the ceiling reflections in particular as they bounce towards my 10 foot listening distance are nasty business. Good luck with that one.
B&W CM9 S2, B&W CMC2 S2, DefTech XTR-20BP, Dual SVS SB-2000, Parasound Halo A21, Pioneer Elite SC-65, Samsung UN55F8000, Apple Mac Mini, Iomega NAS
adrummingdude is offline
post #20824 of 20843 Old 05-17-2015, 12:49 AM
Liked: 0
Hey guys what are you opinions on the 684 vs the 684 s2? For music.
MattVivian is offline
post #20825 of 20843 Old 05-17-2015, 12:50 AM
Liked: 0
post #20826 of 20843 Old 05-17-2015, 03:46 PM
Liked: 4
I hope everyone is enjoying their Sunday!
I snapped a picture of my setup and wanted to share it.
I love my setup but unfortunately the room is far from ideal.
Equipment list:
Bowers & Wilkins 803d
Emotiva XSP-1 Gen 2
Emotiva XPA-2 Gen 2
Oppo 105
Project 2Xperience Classic
Panamax M5300-PM
Panasonic 60st60
Name:	IMG_8955 (1024x594).jpg
eorr23 is offline
post #20827 of 20843 Old 05-18-2015, 12:12 PM
baranowski's Avatar
Quoted: 34 Post(s)
Equipment list:
Emotiva XSP-1 Gen 2
Emotiva XPA-2 Gen 2
Oppo 105
Panamax M5300-PM
Panasonic 60st60
I don't think your room is all that bad. You have an area rug on the floor. It looks like you have a good amount of room for the front sound stage. Do a few diy acustic panels at the first reflective points and really enjoy. It is not that expensive at all.
Looks good
Bill
baranowski is offline
post #20828 of 20843 Old 05-18-2015, 05:19 PM
ap1
ap1's Avatar
Quoted: 17 Post(s)
My opinion is to get 683 for music.
ap1 is online now
post #20829 of 20843 Old 05-18-2015, 07:55 PM
Quoted: 142 Post(s)
Liked: 55
The 683 S2, that is.
post #20830 of 20843 Old 05-19-2015, 08:59 PM
kd-
Liked: 0
B&W - CCM682 For Overhead Atmos Speakers
Hello Everyone,
I am in the process of upgrading my system to an Atmos configuration and am considering the CCM682s for the four overhead speakers. I will be powering these with 4 of the 5 channels from a Parasound A51 amp. I would like to hear thoughts about these or if there are any other suggestions.
I currently have the 802s and the HTM2 and will power each of these with Parasound JC1 amps.
I am planning on buying 4 805s for the surrounds and rears. These will be powered with the remaining channel of the A51 and a 3 channel A31 I already own.
I have a DB1 sub and am going to add a 2nd one.
These will all connect to a Marantz AV8802A and I also have a Parasound JC2 BP.
Lastly, any recommendations for XLR cables to connect everything?
I am somewhat of a beginner so appreciate the help.
Other gear I have is an Oppo BD-105 and Marantz SA-1163 CD player.
KD
Denon AVR-4520CI Samsung PN59D8000 Parasound A-31
Oppo BDP-105 Marantz SA-11S3
B&W 802 Diamond
B&W HTM2 Center
B&W DB1 Sub
Klipsch KS-7800-THX Rear Klipsch KL-7800-THX Surround
kd- is offline
post #20831 of 20843 Old 05-19-2015, 09:11 PM
wse
wse's Avatar
Quoted: 911 Post(s)
Liked: 493
Originally Posted by kd- View Post
Hello Everyone, I am in the process of upgrading my system to an Atmos configuration and am considering the CCM682s for the four overhead speakers. I will be powering these with 4 of the 5 channels from a Parasound A51 amp. I would like to hear thoughts about these or if there are any other suggestions.
I currently have the 802s and the HTM2 and will power each of these with Parasound JC1 amps. I am planning on buying 4 805s for the surrounds and rears. These will be powered with the remaining channel of the A51 and a 3 channel A31 I already own. I have a DB1 sub and am going to add a 2nd one. These will all connect to a Marantz AV8802A and I also have a Parasound JC2 BP.
Lastly, any recommendations for XLR cables to connect everything? I am somewhat of a beginner so appreciate the help. Other gear I have is an Oppo BD-105 and Marantz SA-1163 CD player. Thanks! KD
KD Sounds fantastic you will have a great amount of equipment hope the room is also acoustically treated!
I would suggest XLR cables from Belden, Canaree or Mogami pro-studio cables good quality and reasonable prices
wse is online now
post #20832 of 20843 Old 05-19-2015, 09:23 PM
kd-
Liked: 0
Thanks for the quick reply! The CCM682 spec sheet says maximum amplifier power 150w but the Parasound A51 is 250w per channel. Any issue there? Again, still kind of a beginner so appreciate the assistance. BTW I checked out your system. Wow!
B&W 802 Diamond
B&W HTM2 Center
B&W DB1 Sub
kd- is offline
post #20833 of 20843 Old 05-19-2015, 10:00 PM
wse
wse's Avatar
Quoted: 911 Post(s)
Liked: 493
It is never an issue to have more power the biggest issue is underpower
Mike Butny, darthray and kd- like this.
wse is online now
post #20834 of 20843 Old 05-19-2015, 10:42 PM
darthray's Avatar
Quoted: 328 Post(s)
Liked: 319
wse is %100 right.
Underpowered speakers is where most blown Tweeters come from since the Amp/AVR is no longer in control at a certain frequency due to a lack of power to make the driver to not come back after it was told (electronically for a specific frequency to go forward and past the point of no-return to come back).
When this happen, you get blown tweeters in speakers and sub that go out of it's excursion (bottom- out).
It is always better too have more power than you need, that not enough.
The movie "Aliens vs Predator" said it best "I rather have a condom and not need it, than need one and not have it".
Ray
vvuuren and kd- like this.
darthray is online now
post #20835 of 20843 Old 05-20-2015, 07:48 PM
Quoted: 23 Post(s)
Liked: 2
My CM10 S2
I love the Biamped B&W Cm10s ..
CM 10 S2
SVS SB13 Ultra
Bryston 4Bsst2
Anthem PVA 7
Emotiva 2200 monoblocks
Marantz AV7702
OPPO BDP 103D
dhanula6688 is offline
post #20836 of 20843 Old Yesterday, 03:35 AM
scanido's Avatar
I would venture off to even substitute those CCM682's to something equivalent in the CI700 range or even up it to the 800 series matching ones from the CI800 which are the CCM8.5. You seem to be having the amplifier power on hand. If budget permitting maybe start with two height channels and add the other ones later.
See Profile
scanido is online now
post #20837 of 20843 Old Yesterday, 05:17 PM
kd-
Liked: 0
scanido - Thank you for the recommendation to consider the CCM8.5s. I haven't looked at those but will definitely check them out. I really appreciate it.
-KD
B&W 802 Diamond
B&W HTM2 Center
B&W DB1 Sub
kd- is offline
post #20838 of 20843 Old Yesterday, 05:21 PM
Seegs108's Avatar
Quoted: 1499 Post(s)
Liked: 543
I have a question for you guys. I'm putting up my 804 Diamonds up for sale. I have the original packaging for them. Do you think it would be safe to ship these without paletizing them and shipped out via freight. I mean, do you think the original packing materials are strong enough to withstand a 3 or 4 day trip with FedEx?
Seegs108 is online now
post #20839 of 20843 Old Yesterday, 07:28 PM
ap1
ap1's Avatar
Quoted: 17 Post(s)
If you feel that packaging will allow to survive three 5' drops (common with FedEx/ups) then you can ship.
ap1 is online now
post #20840 of 20843 Old Yesterday, 07:47 PM
wse
wse's Avatar
Quoted: 911 Post(s)
Liked: 493
Exclamation
I would not try it!
wse is online now
post #20841 of 20843 Old Yesterday, 08:17 PM
wse
wse's Avatar
Quoted: 911 Post(s)
Liked: 493
If you ever think of buying some B&W speakers and want to know what is fair to pay send me a pm!
wse is online now
post #20842 of 20843 Old Today, 07:08 AM
wse
wse's Avatar
Quoted: 911 Post(s)
Liked: 493
I would love to replace my three 80 Diamond with three of these for the front stage in my room!
If I ever win the lottery or can get dealer cost
wse is online now
post #20843 of 20843 Unread Today, 06:17 PM
blazar's Avatar
Quoted: 564 Post(s)
Liked: 425
I have heard nautilus, but there wasn't anything there that makes it the "perfect loudspeaker" as their marketing page implies.
B&W's are great at what they do, but I have been impressed with so many types of speaker design that I would question the "value" in the nautilus pricing scheme. The current pricing, like other high end speakers, is priced like "art".
I actually think the 802 series is priced very well for how well they are crafted and the design statement they otherwise make in your home. Beyond that, I would wager my left nut that in a blinded trial that many folks would prefer the sound of many other types of speakers over the Nautilus in that price range and lower.
blazar is online now
Reply Speakers
B W , Bowers And Wilkings 685 Speakers , carver cm-1090
Gear in this thread - cm-1090 by PriceGrabber.com
