B&W Owner's Thread - Page 696 - AVS | Home Theater Discussions And Reviews
post #20851 of 20869 Unread 05-25-2015, 09:22 AM
chef jer's Avatar
Originally Posted by agerson View Post
I am looking at setting up a 5.1 system in my 17 x 17 living room with 685 fronts. Is the natural pair for these the the 686 as rears and the HTM62 as a front? Or is it the HTM61 (which I have read mixed opinions on)?
I went with this same set up and have been very pleased with how the HTM62 S2 and 686 (rears) match with the 685's. I don't feel like the 62 gets lost in this set up.
Samsung 64F8500 - Marantz sr7008 - B&W 685 S2, 686 S2, HTM62 S2, KEF Cube (upgrading soon - TBD)
chef jer is offline
post #20852 of 20869 Unread 05-25-2015, 10:16 AM
pathogen's Avatar
Thanks. Yes. I am talking about the S2. I like the three way on that center. Why is that that a bunch of people say its performing poorly compared to the HTM62?
Please somebody correct me if I'm wrong but those criticisms were for the S1 HTM61. The S2 unit seems to be an excellent center. (full disclosure I have 683s2, htm61s2 and 686s2)
pathogen is offline
post #20853 of 20869 Unread 05-25-2015, 10:54 AM
postrokfan's Avatar
Quoted: 215 Post(s)
Liked: 965
As pathogen mentioned criticism is probably directed at the HTM61 S1 center not the S2. The HTM62 S2 is fine but as I said before the HTM61 S2 might be a better fit for your room dimensions.
HT: CM9 S2 FR/FL, CMC2 S1, CM5 S1 surrounds, ASW610; Yamaha rx-a2030; Parasound 2100; Parasound 275; Oppo BDP-93; ATV
2 Channel: Ascend Acoustics Sierra-1 NrT FR/FL, ASW608; Parasound Halo P5; Parasound Halo A23; Rega RP1; Marantz CD5004
postrokfan is offline
post #20854 of 20869 Unread 05-25-2015, 03:39 PM
Kal Rubinson's Avatar
Quoted: 234 Post(s)
Liked: 232
Right. The 2-way MTM HTM61 suffered from an uneven horizontal dispersion pattern while the 3-way HTM61 s2 corrects this arrangement. I reserve comment (since I have not heard the speaker) about the HTM62 which has a similar configuration to the original HTM61.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #20855 of 20869 Unread 05-25-2015, 05:39 PM
Quoted: 38 Post(s)
Liked: 1
Thats good to know they have fixed it. I have also heard it said that the best center for a pair of 685's is another 685. Does this imply you would mount it sideways or stright up normal like the L/Rs above the TV poitned down? Anyone try this setup?
agerson is online now
post #20856 of 20869 Unread 05-25-2015, 06:05 PM
Quoted: 234 Post(s)
Liked: 232
The horizontal array of drivers is what causes the irregular "venetian blind" horizontal dispersion, so putting a 685 on its side would create a similar effect. That is one reason why I prefer to use three identical (and identically oriented) speakers for L/C/R in both of my systems.
Gerardo2068 likes this.
Kal Rubinson
post #20857 of 20869 Unread 05-26-2015, 06:05 AM
Quoted: 38 Post(s)
Liked: 1
Where do you place it physically? I would be unable to have it lined up with the L/R's. Would it be ok to mount it above the TV?
post #20858 of 20869 Unread 05-26-2015, 06:07 AM
Gerardo2068's Avatar
Quoted: 237 Post(s)
Liked: 59
I'm pretty sure you put all 3 front towers on the floor and attach the TV to the wall high enough to clear the center speaker
Gerardo2068 is online now
post #20859 of 20869 Unread 05-26-2015, 08:48 AM
gonzalc3's Avatar
Quoted: 32 Post(s)
Liked: 34
Originally Posted by kd- View Post
scanido - Thank you for the recommendation to consider the CCM8.5s. I haven't looked at those but will definitely check them out. I really appreciate it.
-KD
I am actually going to purchase two pairs of ccm682s as overhead speakers for an atmos setup. I will consider the CCM8.5s if the budget and the room allows you to do so. In my case, the room itself is a limitation and the CCM8.5 will be an overkill.
Chris. My DVD and Blu Ray collection
Sony VPL HW55ES, ST 100, B&W 803D2s mains, B&W HTM2D2 center channel, B&W 805D2 surrounds, B&W DB1 subwoofer, B&W CCMM682s inceiling speakers, Marantz AV8802, Parasound Halo A51+A21,Oppo BDP 103D, PS Audio Power Plant Premier
HT-Being re-designed and re-built.
gonzalc3 is offline
post #20860 of 20869 Unread 05-26-2015, 03:26 PM
Quoted: 234 Post(s)
Liked: 232
Not unless you put all three up there.
Yup.
Kal Rubinson
post #20861 of 20869 Unread 05-26-2015, 04:00 PM
baranowski's Avatar
Quoted: 35 Post(s)
Once you start to move the TV up too high, you may not be happy.
We talk about correct/ most optimal placement for speakers.
When you add a TV remember
there is a correct/ optimal placement for that too.
Once you put them together you may run into a issue where the seating position for the TV viewing might be too close or too far for the speakers.
Or vis versa... correct seating may be too close or too far for the tv.
Make sure you don't mount the TV too high. The brightness of the TV will get dimmer at the minimum. Also too high and you will not feel "emerged" in the show/ movie. Also it may be uncomfortable to hold your neck up at that height.
Just my personal experience and 2 cents.
Even small changes (like with speakers) can have a very large effect for viewing a tv.
Bill
baranowski is offline
post #20862 of 20869 Unread 05-26-2015, 04:27 PM
Quoted: 237 Post(s)
Liked: 59
True. Personally I think is more critical the speaker placement for my priorities. I'm ok with rising the TV some, attaching it to the wall and incline the mount so the TV points directly at my sitting location. It works out because I usually lean back a little on my recliner
post #20863 of 20869 Unread 05-26-2015, 06:18 PM
Quoted: 234 Post(s)
Liked: 232
Yes. I suggested that with tongue in cheek.
Kal Rubinson
post #20864 of 20869 Unread Yesterday, 04:23 AM
baranowski's Avatar
Quoted: 35 Post(s)
At least we are not speaking about a projection screen and all of the conciderations that have to go with that set up.
Speaker placement placement, possible behind the screen.
Then acustic transparent screens..
ETC....
Just have a good balance between all of the systems that you use.
Most of the time the "optimal" placement for one will not allow for the "optimal" placement for the other.
I just finished rearanging my home theater. Even the smallest difference has helped alot.
My advise when building a theater, listening/ theater room.....
Get the big "bang for your buck" parts first,
Then you can tweek from there....
Bill
post #20865 of 20869 Unread Yesterday, 05:29 PM
Quoted: 234 Post(s)
Liked: 232
The video is definitely of lower priority for me.
Kal Rubinson
post #20866 of 20869 Unread Yesterday, 08:34 PM
wse
wse's Avatar
Quoted: 939 Post(s)
Liked: 506
Not unless you put all three up there. Yup.
Did you ever review the NAUTILUS?
wse is offline
post #20867 of 20869 Unread Today, 07:40 AM
Quoted: 234 Post(s)
Liked: 232
Nope. Too much trouble with the multi-amping.
Kal Rubinson
post #20868 of 20869 Unread Today, 08:10 PM
wse
wse's Avatar
Quoted: 939 Post(s)
Liked: 506
Three 800 Diamond in front and loving it
wse is offline
post #20869 of 20869 Unread Today, 10:31 PM
Quoted: 237 Post(s)
Liked: 59
Nice. I can only get the 683 s2 lol. One day though
Reply Speakers
B W , Bowers And Wilkings 685 Speakers , carver cm-1090
Gear in this thread - cm-1090 by PriceGrabber.com
