B&W Owner's Thread - Page 766 - AVS Forum | Home Theater Discussions And Reviews
 397Likes
post #22951 of 22963 Old Yesterday, 01:59 PM
Nelsun's Avatar
Hi guys,
Wanted to chime in and possibly get some help.
I've had a pair 805 Nautilus since 2000. The original 800 series 805. I've been enjoying them all these years, but since I upgraded the pre-pro and upgraded speaker cables a few years ago, I could really take full advantage of use speakers capabilities. However I also was lusting after new speakers since the 805's were performing so well, I wondered how much better I could get. I was using them mainly for movies and about 20% music. Which I know is a waste. But in recent years, the pendulum has swung over and I'm listening a lot more music because the gear is making it so much more pleasurable.
So at the time I got the new pre-pro, (Rotel RSP-1572 and the matching amplifier which puts out 100 watts I believe) I wanted to see if going to 804D2's would be what I needed. The dealer discouraged me and said to really wring out the 805's. Or to really feel a difference, go for the 803D2.
Well a month or two ago I read that the new 800 series are out and I wondered about those. I went back to my dealer and a new guy was there who actually encouraged me to consider a 804D2 or 803D2 demo model because he was going to be getting the new D3 line.
So I auditioned the 804D2 and 803D2. My interest has always been the 804D2 because of it's smaller size. While I could hear a difference, I figured once I got the 804D2 home, it would sound great. So they were offering a terrific deal for the demo models. So it was quite. Savings and I'm glad I went for it. Now I have the 804D2 at home and they do sound great. A real upgrade from the older 805 because of several generations of improvements and it being full range.
So since they are demo's, I was willing to accept a certain level of damage. My 805's were demos but were perfect. The 804D2 are cherrywood and there is a slight scuff/scratch on the side of one and the tweeter grille is damaged a bit. I'll be getting new grilles, both fabric ones and the tweeter from the dealer at no cost. I think I can minimize and or fix the scratch/scuff.
But the last thing I noticed upon delivery was one binding post is bent. If I unscrew the knob, and expose the threaded section and the hole for the wire to pass through, I see the threaded post is slightly separated at the hole. If I screw the knob back down it will cover that. It's functioning now so it's not a mechanical or functional problem. But I would like to know how easy or difficult it is to replace the binding post, or maybe the threaded section? The post is slightly loose and wiggly when unscrewed, but seems tight like the remaining good ones once the knob is tight.
Any insights on the binding post is appreciated. As I said, I'm very happy to have gotten one of the last generations of the D2 series with the iconic Kevlar cones too. Not meant as a dis on the new 800D3 series. I'm sure those are even better! And I do like the new designs a lot. But I'm glad to have gotten an upgrade for less money and a design I still like a lot!
Nelsun is online now
post #22952 of 22963 Old Yesterday, 02:48 PM
advanced101101's Avatar
Quoted: 62 Post(s)
Originally Posted by Nelsun View Post
Hi guys,
Easy, here is the service manual:
http://bwgroupsupport.com/downloads/...w/804D2-TM.pdf
Here are the parts:
http://www.bwgroupusa.com/bwgroup-pa...ond/804d2.html
advanced101101 is online now
post #22953 of 22963 Old Yesterday, 03:23 PM
lego1's Avatar
Quoted: 21 Post(s)
Advanced,
Thanks for your reply. I see the nautilus htm2 and nautilus 800 series have polypropylene caps so I figure those don't need to be refreshed since they have a long life span. I will look into changing the ferrofluid in the tweeter though. Hopefully it's an easy task. Thanks again.
lego1 is online now
post #22954 of 22963 Old Yesterday, 03:35 PM
Nelsun's Avatar
Thanks Advanced! I didn't realize they had such a section on B&W's site. Thanks, that's great.
Looks like the post has to be accessed with the tray removed.
post #22955 of 22963 Old Yesterday, 06:33 PM
smoothsac's Avatar
Liked: 0
Hi Guys,
Just after your opinions on which front speakers I should go for.
I'll be moving into our new house later this year and it has a dedicated theatre room,size is around 3.6x3.5m(around 12ft x 11ft).
I already have a B&W Centre2s2 and I will be using 4 M-1's for surround duties plus my B&W PV1D sub.
I'm torn between the CM8s2 and the CM6s2?
Any thoughts?
smoothsac is offline
post #22956 of 22963 Old Yesterday, 06:33 PM
smoothsac's Avatar
Liked: 0
Which Fronts?
Hi Guys,
Any thoughts?
post #22957 of 22963 Old Today, 06:24 AM
Quoted: 62 Post(s)
Originally Posted by lego1 View Post
Advanced,
You are probably right. Capacitors degrade over time, at what point would you notice sound quality degradation? You probably wouldn't know that answer unless you compared them to a new set.
Also, If you have a version earlier than the Diamond series it could also be an opportunity to put in a set of Mundorf SGO caps. But now we are just being silly.
post #22958 of 22963 Old Today, 07:18 AM
Quoted: 62 Post(s)
Originally Posted by smoothsac View Post
Hi Guys,
Any thoughts?
In your situation I would go CM6S2 and put the extra money to pick up another PV1D.
Or sell the PV1D and pick up a pair of SVS ported subs.
Or put the money away for room treatments for your new theater.
Depends on your budget. CM8 is a better speaker but more bang for the buck putting money elsewhere. The best option is the CM8s, another sub and room treatments.
post #22959 of 22963 Old Today, 11:58 AM
NagysAudio's Avatar
Quoted: 141 Post(s)
Liked: 51
I've held off commenting on the new D3 line because I wanted to hear a fully broken-in set... Two months later, I'm now ready. I've heard fully broken-in (hundreds of hours) pair of 803D3 and 802D3, with various electronics, i.e. Classe, Rotel, Boulder, and Bryston.
Here it goes... These are overall the best speakers that I have ever heard!
NagysAudio is offline
post #22960 of 22963 Old Today, 12:02 PM
NagysAudio's Avatar
Quoted: 141 Post(s)
Liked: 51
Hi Guys,
Any thoughts?
I've owned the CM6S2s and now own the CM8S2s. IMO, CM8S2s are a better balanced speaker. Their midbass is so prominent yet extremely nimble, it's a pleasure to listen to. BTW, PV1D is a great sub.
post #22961 of 22963 Old Today, 12:36 PM
lego1's Avatar
Quoted: 21 Post(s)
Well I changed the ferrofluid in the natilius tweeter yesterday. Way easier than I though. Took me some time to get the old fluid out which was quite thicker but wasn't really bunked up. There were also metal shavings in there too that I was able to remove.
Plugged the speaker in for a quick listen and it sounds great but I haven't really had time to do any critical listening to see if the treble improved.
Advanced, those Mundorf caps are quite pricey. I bought this center for $400 so I doubt it's worth putting that much money into the capacitors. : )
lego1 is online now
post #22962 of 22963 Old Today, 01:29 PM
Nelsun's Avatar
Sounds like you guys have a lot of experience servicing these 800 series speakers.
Now that Advanced has given me the information on the bent terminal core I want to replace, I'd be interested in knowing what's behind the terminal tray. I've looked at the service information Advanced linked to. There isn't clear information if the terminal cores are soldered in, pressed fit or what. I'd imagine though that if the terminal tray is removable, the entire assembly can be pulled out after the screws are removed. And the terminal cores simply slide in and out of something inside the speaker on the crossover boards.
I'd appreciate any insight before I start trying to disassemble the terminal tray on the 804D. Thanks!
Edit: oh wait, I think I see mention that the wires are crimped to the terminal core. I'll have to learn more about this for the proper crimping tool as I'm guessing you crimp the copper on the terminal core itself to secure the wire.
post #22963 of 22963 Old Today, 01:49 PM
Quoted: 62 Post(s)
Nice work!
Yes, very expensive. You would also want to change the caps in the LR speakers to match. Wouldn't be cheap.
Reply Speakers
802D , atmos , B W , b&w dm1400 , Bowers And Wilkings 685 Speakers , carver cm-1090
