B&W Owner's Thread - Page 798 - AVS Forum | Home Theater Discussions And Reviews
 599Likes
post #23911 of 23919 Old Yesterday, 04:56 PM
jima4a's Avatar
Quoted: 251 Post(s)
Liked: 140
Originally Posted by wicked45 View Post
What hertz should i set my CM10's and CMC2 S2 to on my AVR? Some say 60hz and others say 80hz?
I would use 60 for the CM10s (or 50 if an option) and 80 for the CMC2.
postrokfan likes this.
jima4a is online now
post #23912 of 23919 Old Yesterday, 07:16 PM
blur510's Avatar
Originally Posted by advanced101101 View Post
Yes, unless you can/ want use another 805 D3 as your center.
Originally Posted by thrang View Post
Best option if possible....
I prefer the look of a real center channel, is there a downside to using an HTM2 D3 over a 805d3? thanks again .. how about a Nautilus HTM2
blur510 is online now
post #23913 of 23919 Old Today, 09:46 AM
dgfla's Avatar
Liked: 0
Originally Posted by jeahrens View Post
Well a lot of movies have pans that frequently go across all 3 speakers. So effects and dialogue are certainly noticeable to me when the speakers aren't well matched.
Front to rear matching is also important, but less so if you're viewing habits tend toward action films. Concerts and films where the score bleeds into the rears it's definitely important IMO.
thanks jeahrens...
I will be addressing the surrounds after i figure out what to do about center channel.. although I really done have space or funds to perfectly match surrounds with my 803 D2 fronts. Probably should have also asked what folks thought would be a good match in a bookshelf size speaker.
thanks again..
dgfla is online now
post #23914 of 23919 Old Today, 09:47 AM
Invictus87's Avatar
Quoted: 16 Post(s)
Any CM10S2 owners have any feelings about how they stack up to the Paradigm Prestige towers? I realize this is a B&W thread but just wondering if anyone who went with CM10s made this comparison. I haven't heard the Paradigm's yet but they have gotten pretty good reviews within the same price category. Just curious.
Invictus87 is offline
post #23915 of 23919 Old Today, 10:01 AM
citsur86's Avatar
Quoted: 250 Post(s)
Liked: 63
Wondering if someone could help with this question I have. I purchased the CM Center S2 for my system and it does sound good. With MCACC EQ it's slightly low during dialog parts. If I turn up the volume then the action scenes are too loud. I realize they're meant to be loud but they are even louder than they should be. I'm wondering if a CM Center 2 S2 would help with this given my room size? - and maybe that's the right center vs the smaller CM Center 2 without the mid bass. You can see pictures of my room in the signature link.
FS: Proficient GL6 Center Channel Speaker
My Current "Living Room" Home Theater!
citsur86 is offline
post #23916 of 23919 Old Today, 10:35 AM
Invictus87's Avatar
Quoted: 16 Post(s)
I've had this issue with the YPAO on my Yamaha leaving the center a bit low during some movies. Idk if this is the preferred method but I would try just adding a few db to the level of the center manually so that its volume is boosted in relation to the fronts. Play around with topping off that center level to see how it sounds in different scenes. See if that does anything for you before upgrading.
post #23917 of 23919 Old Today, 11:48 AM
citsur86's Avatar
Quoted: 250 Post(s)
Liked: 63
B&W Owner's Thread
Thanks for the response. This works, and it doesn't. It works in that the lower dialogue scenes are clearly audible if I boost center a few decibels. It doesn't work in that during the action scenes or left to right sweeps, it sound unbalanced as the center channel plays louder than it should. Additionally, I believe the MCACC did a good job calibrating the center channels volume compared to the speakers around it. My question is more in relation to whether the extra speaker within the CM Center 2 S2 or its pure size increase will balance out the dialogue volume while keeping the action scenes level with the fronts/front heights.
citsur86 is offline
post #23918 of 23919 Old Today, 01:32 PM
postrokfan's Avatar
Quoted: 429 Post(s)
Liked: 2324
A larger center might be better for that space but it probably won't fix what is likely a calibration issue.
postrokfan is offline
post #23919 of 23919 Unread Today, 10:13 PM
wicked45's Avatar
Quoted: 31 Post(s)
What are the plugs used for on the back of the CM10's? My speakers are placed about 1.5 feet from the wall.
wicked45 is online now
Reply Speakers
802D , atmos , B W , b&w dm1400 , Bowers And Wilkings 685 Speakers , carver cm-1090
