B&W Owner's Thread - Page 827 - AVS Forum | Home Theater Discussions And Reviews
 774Likes
post #24781 of 24806 Old 04-08-2017, 11:43 PM
Mike Butny's Avatar
Quoted: 361 Post(s)
Liked: 656
Has anyone compared B&W to PSA speakers?
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7009 Receiver, 3-Marantz Ma700 and 2-Ma6100 mono blocks, 9.2 set-up, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, Infinity ( soon to be replaced by B&W ) bookshelf Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, PSA S3600I & XS30SE subs, Richard Grey, Monster Power, and Panamax powerline conditioning/surge protection.
Mike Butny is online now
post #24782 of 24806 Old 04-09-2017, 05:07 AM
KenM10759's Avatar
Quoted: 1334 Post(s)
Liked: 718
That's an odd comparison. It would matter just which B&W speaker line you'd be comparing, and what application to use them.
The Powersound Audio offerings are fine theater speakers for a darkened room, and perhaps best if behind an acoustically transparent screen unless you actually like flat black rectangular boxes. From your signature list, it appears this is exactly what you have for a home theater environment so go right ahead. It's good stuff for that and well supported. The money in those is in the drivers, crossovers and box construction, not in the finish.
KEF R500, R200C, R100, SVS SB2000 sub, NAD T758 receiver, Pro-Ject RPM1 TT w/ Sumiko Pearl, Bluesound Vault2, Sony BDP-S480 BlueRay player, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer.
KenM10759 is online now
post #24783 of 24806 Old 04-09-2017, 10:15 AM
Mike Butny's Avatar
Quoted: 361 Post(s)
Liked: 656
I love my B&W Nautilus 805's and Htm2 center speakers but I was thinking of trying PSA and I was just curious if anyone has compared the 2. I would say I'm 50/50 movies and music.
post #24784 of 24806 Old 04-09-2017, 08:53 PM
Berland's Avatar
Quoted: 50 Post(s)
Liked: 32
Originally Posted by RyanLM View Post
This is 100% HT, no music listening.
Currently I run my setup most for movies/tv, and maybe 5% music. The quality of the setup is just as important for movies as for music (maybe even more).
My setup:
Front: 2 * 803 D2
Center: HTM2 D2
Surround: 2 * 804 D2
Surrund-back: 2 * SCMS
Front-wide: 2 * 805 D2
Sub: 2 * DB1
Still looking for something useful to put on (not in) my concrete ceiling for atmos. I have listened to in-wall setups; not the same - I would go for external speakers any day.
Considering to replace front and center speakers with D3 (800 D3 or 802 D3 for front). But actually not sure if I will, the quality of my setup is one of the best I've heard (even when comparing to a lot more expensive setups). I've spent a lot of time tuning the room and setup (with multiple sound absorbing plates and bass-traps; and thick curtains (in front of windows) and thick carpet to reduce floor-reflections). Also running digital room-calibration on top of this.
dschulz and Cle Manuel Vice like this.
HT: CLASSE CA-5300 DELTA - BRYSTON 4B SST2 - Marantz AV8802A - B&W 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2, SA Talent - NORDOST Heimdall2/Frey2 - ISOTEK EVO3 Titan,Sigmas - Samsung UE78JS9505 - GIK ACOUSTICS - AUDYSSEY Pro Kit
HP: 2*MOON Neo 430HA D - 2*Schiit Yggdrasil - 2*Audiobyte Hydra Z/ZPM - 2*iFi micro iUSB 3.0 - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, 2*LCD-XC - SHURE SE846
Berland is offline
post #24785 of 24806 Old 04-12-2017, 08:11 AM
FargateOne's Avatar
Quoted: 35 Post(s)
Liked: 3
A question for long time B&W owners.
if you take a look at my signature you will see my set up My HT is a small room and the fronts speakers are at the long wall. My MLP is at 2,35m from the speakers. I consider it as a small distance from the 804D2. I read somewhere that those speakers do not need toeing unless in large room if they are far from the MLP.
Would you suggest to fire them straight forward or with a to toe in angle. My room is reasonnably (not heavily) treated (DIY).?
My system 5.1 :
ROTEL RSX-1562 /Fronts: B & W 804 D2 bi-amplified; surround : B&W 704 and center B&W HTM4d2/sub SVS PC 2000 /TV Samsung UN55ES8000
/BD player Cambridge CXU/ set-top (cable box) rented from cable co.
Bis Audio cables and power bar from the wall to the receiver
My room:15'4" x 11' 6" x 7'6" tv near the center of the long side wall
FargateOne is offline
post #24786 of 24806 Old 04-12-2017, 10:12 AM
wse
wse's Avatar
Quoted: 2171 Post(s)
Liked: 788
Originally Posted by rachmat-d View Post
Thanks, I can not acces to used b&w in here. I see that you use 804d and CMC s2 , is the sound ok ?
I have 800D2 for sale
wse is online now
post #24787 of 24806 Old 04-12-2017, 10:15 AM
wse
wse's Avatar
Liked: 788
My setup:
Front: 2 * 803 D2
Center: HTM2 D2
Sub: 2 * DB1
Nice set-up! What pre-pro do you use for wide?
wse is online now
post #24788 of 24806 Old 04-12-2017, 10:15 AM
wse
wse's Avatar
Liked: 788
wse is online now
post #24789 of 24806 Old 04-19-2017, 04:46 PM
PSBMAN's Avatar
Quoted: 48 Post(s)
Liked: 36
804D tweeters
Hello Lads,
How robust are the 804D tweeters? I've read quite a few posts of guys having to replacing their tweeters at 1000 bucks plus a piece.
Are they really that fragile? I like to listen to music at around 85db when I get the chance
Jack Bauer can unscramble an egg.
PSBMAN is offline
post #24790 of 24806 Old 04-20-2017, 12:23 AM
leithm's Avatar
Quoted: 22 Post(s)
guys i need some help please!
CCM663 in-ceiling for 5.1 surround sound? Matched with CM9 S2 & CMC2 S2 or is there a better ceiling speaker?
Budget only allows for CCM663 max. House is being built is that matters (no retrofitting)
I keep reading comments of speakers with enclosures / back boxes being the only way to go such as Triad, PSB, Niles,
Speakercraft. B&W don't seem to do this unless it's their top end model. The negative being if it's not B&W is not timbre matched ..
many thanks
leithm is offline
post #24791 of 24806 Old 04-20-2017, 08:03 AM
Patrick Butler's Avatar
Quoted: 353 Post(s)
Liked: 125
Hi leithm,
CCM663 will work great with your CM system. Back boxes are available for CCM663, and they will result in better performance and a higher price. Our CI700 and CI800 Series products all come with their own backboxes, as befits their higher price points.
Patrick
B&W Group North America
many thanks
Patrick Butler is offline
post #24792 of 24806 Old 04-20-2017, 08:07 AM
Quoted: 353 Post(s)
Liked: 125
How robust are they? Robust for playback (you'll not break the diamond dome playing music), but fragile around fingers. Play them as hard as you like, but don't touch the tweeter!
Patrick
Originally Posted by PSBMAN View Post
Hello Lads,
Cle Manuel Vice likes this.
post #24793 of 24806 Old 04-20-2017, 08:15 AM
PSBMAN's Avatar
Quoted: 48 Post(s)
Liked: 36
Patrick
I appreciate the response !
So, since I'll be buying used, the only real risk of damage to the tweeter is on packing them up into their boxes and transporting I take it.
Also, the Speakers are only 2 years old and I'll have the receipt......but the Warranty won't apply will it?
PSBMAN is offline
post #24794 of 24806 Old 04-20-2017, 08:19 AM
Quoted: 353 Post(s)
Liked: 125
Yes, that is the only real risk. As for the warranty, think of it like a car. The warranty might cover your transmission, but it is not going to cover driving it into a concrete wall.
Cheers,
Patrick
post #24795 of 24806 Old 04-20-2017, 08:27 AM
PSBMAN's Avatar
Quoted: 48 Post(s)
Liked: 36
Cheers,
Patrick
LOL....Sorry, I didn't mean for tweeter damage. I meant in general. Would the Warranty continue on for the last 3 years if I have the orig bill of sale ?
PSBMAN is offline
post #24796 of 24806 Old 04-20-2017, 12:02 PM
leithm's Avatar
Quoted: 22 Post(s)
Hi leithm,
Patrick
Thanks, Patrick! Could you make an argument for the ccm684s as these are also within budget
Cheers
leithm is offline
post #24797 of 24806 Old 04-20-2017, 12:34 PM
Quoted: 353 Post(s)
Liked: 125
Unless you are buying a used product like a demonstration model from a dealer, the warranty is not transferrable. If you are buying from a private party, there is no warranty.
Patrick
post #24798 of 24806 Old 04-20-2017, 12:38 PM
Quoted: 353 Post(s)
Liked: 125
Hi leithm,
The CCM663 has better quality parts than the CCM684. The 8" driver equivalent to the CCM663 would be the CCM683. Both of those feature a better tweeter, kevlar instead of glass fiber, a cast basket, better x-over parts and a better motor. I would do the CCM663 if that is what you can afford.
Patrick
Cheers
post #24799 of 24806 Old 04-20-2017, 01:24 PM
Cle Manuel Vice's Avatar
Liked: 0
Red face
My setup:
Front: 2 * 803 D2
Center: HTM2 D2
Sub: 2 * DB1
Hello
What is the minimum price for the 803 D2?
Send to portugal
thank you
Cle Manuel Vice is online now
post #24800 of 24806 Old 04-22-2017, 08:28 AM
Liked: 2
I was wondering how much difference it would make either Bi-Wiring or Bi-Amping my B&W speakers. Is it worth the extra money for either new cables or another AMP (Macintosh)? My system is in the sig line. I was thinking about only the front.
Thank you in advance for your help.
Home Theater: B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- 18" Velodyn Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Oppo 203, XBox One
BondDonBond is offline
post #24801 of 24806 Old 04-22-2017, 09:24 AM
postrokfan's Avatar
Quoted: 552 Post(s)
Liked: 3316
Bi-wiring won't make any difference. Bi-amping might. What is it that you are dissatisfied with at the moment regarding SQ?
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #24802 of 24806 Old 04-22-2017, 12:30 PM
Liked: 2
I turned up the volume and the speakers provided a better sound stage, which got me thinking that maybe the needed more power and if I bi-wired it would make it sound even better. Never tried it and had these speaker over 10 years.
post #24803 of 24806 Old 04-22-2017, 01:36 PM
postrokfan's Avatar
Quoted: 552 Post(s)
Liked: 3316
From your signature it looks like you have some high quality gear. Bi-amping may improve low volume listening (like having a "loudness" control) but I wouldn't expect miracles. With the Marantz pre-amp you should be able to solve those low volume listening issues with EQ.
post #24804 of 24806 Old 04-22-2017, 03:09 PM
Kal Rubinson's Avatar
Quoted: 708 Post(s)
Liked: 485
Bi-amping may improve low volume listening (like having a "loudness" control) ..............
Doubt it.
postrokfan likes this.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #24805 of 24806 Unread 04-26-2017, 07:08 AM
FargateOne's Avatar
Quoted: 35 Post(s)
Liked: 3
any suggestions for my question post 24785? In fact, I would like to hear expert here about toe-in B&W 804D2 in a small room . Distance from MLP to fronts is 240cm (95 inches) I have tried many angles. Sometimes the SS&I changed but it is difficult to make a decision: 60degrees equilateral triangle, more or less 22-30 degrees , straight forward etc. What is your experience?
My system 5.1 :
post #24806 of 24806 Unread Today, 04:17 PM
mpauline's Avatar
Quoted: 21 Post(s)
Just bought some 803D3's. Absolutely love them. I am using them in a mixed home theater and two channel listening setting. Any recommendations on whether to set these as large or small when setting up the audio processor? If setting to large what should I set the sub crossover at? I have two subs but don't want to take anything away from the integration of these spectacular speakers.
Also thinking of adding more power. I have a Krell 250 A3 amp which is 250W at 8ohms and 500 at 4ohms. It sounds a little lean and I think I could go to 500w amp at 4ohms.
Attached a picture. I know the speakers are too close to the sidewalls but I cannot really do anything about that right now because of where my projector screen is mounted.
mpauline is online now
Reply Speakers
802D , atmos , B W , b&w dm1400 , Bowers And Wilkings 685 Speakers , carver cm-1090
