B&W Owner's Thread - Page 832 - AVS Forum | Home Theater Discussions And Reviews
 804Likes
post #24931 of 24944 Old 06-19-2017, 11:32 AM
DonH50's Avatar
Quoted: 2048 Post(s)
Liked: 1615
I'll just say in this instance I disagree with B&W. The largest signals are deep bass due primarily to the way we hear (we are much less sensitive to bass so need to turn it up for it to sound as loud as midrange signals -- Google Fletcher-Munson). That means a signal at say 50 Hz may need to be 100x or more louder than a signal at 1 kHz, and that means 100x the power. Setting the crossover lower means more power, more distortion, and all that jazz. I prefer to let the subwoofer do its thing and offload the mains (speakers and amplifiers). Other considerations are placement, since the best place for the mains in terms of imaging and such is rarely the best position for the sub(s) to reduce room modes/SBIR in the bass region, and for ported speakers (like the CM10) the drivers become "unloaded" and thus exhibit higher distortion below the tuning frequency. B&W's answer indicates a fairly low-Q system and/or port tune below their -3 dB spec (I do not know). Still, you have to dump more and more power into the speaker to get it to match volume as it rolls off; a 3 dB drop requires twice the power.
Given such a difference between B&W's opinion and that from an unknown internet poster (me), the temptation is to blow of the 'net guy, but I do encourage you to read about the subject a bit here and elsewhere before deciding. And you can always try both, though it is tricky since the added distortion in the bass often makes the speakers sound "fuller" even though it is distortion.
thyname likes this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #24932 of 24944 Old 06-19-2017, 11:46 AM
Quoted: 28 Post(s)
Liked: 1
Hey avs,
Any tips for an amp to drive a pair 683 s2s? Or any other pertinent info about playing them. Thanks.
RonnyBb is offline
post #24933 of 24944 Old 06-19-2017, 01:14 PM
thyname's Avatar
Quoted: 249 Post(s)
Liked: 80
You may be right on this and B&W wrong. I did quite a bit of reading.
Also, SVS tech support seems to agree with you, although they suggest 1/3 of an Octave higher than 45 Hz on CM10, not 1/2 or 1. So they suggested setting it at a minimum of 60 Hz, and then moving up (as in higher frequency crossover) from there.
Thanks again.
thyname is online now
post #24934 of 24944 Old 06-19-2017, 09:00 PM
postrokfan's Avatar
Quoted: 579 Post(s)
Liked: 3471
Thanks again.
80 Hz is a logical conservative starting point. When I had the CM10S2s I had the crossover set at 60 Hz and that seemed to work quite well (in my listening area).
Living Room: B&W 804D2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is online now
post #24935 of 24944 Old 06-21-2017, 12:58 AM
adrummingdude's Avatar
Quoted: 482 Post(s)
Liked: 319
Thanks again.
That was definitely an odd answer from B&W. Having said that, it really depends on how you use the speakers. If 90% of your consumption is movies, tv or video games, an 80hz crossover is likely best. But, if you are more heavily into non aggressive music, running them full range without the subs could make you very happy.
I agree with the ideal crossover point for the CM10 when using subs to be somewhere around 80hz. Crossing to a sub at 40hz is wasting a sub and tasking your low freq drivers on the CM10 to do too much of the deep stuff, which will have a negative effect on midbass. Drivers can only change direction so fast.
HT: B&W 802 D2 - DefTech Mythos Ten - DefTech XTR-20BP - Dual SVS SB16 Ultra - Parasound Halo A21- Anthem MRX 720 - Samsung UN65JS8500
2CH: Sonus Faber Cremona Auditor M - Parasound Halo A23 - Bluesound Node 2 - Iomega NAS
WAF is currently at DEFCON RED
adrummingdude is offline
post #24936 of 24944 Old 06-21-2017, 03:59 AM
thyname's Avatar
Quoted: 249 Post(s)
Liked: 80
Just to clarify, this is for my stereo setup only. 100% music.
post #24937 of 24944 Old 06-21-2017, 07:44 AM
Jon Middleton's Avatar
Quoted: 190 Post(s)
Liked: 140
Seems like you'd want the crossover set so that the bass response is flat, which means higher than the -3dB point for the CM10s.
Jon Middleton is offline
post #24938 of 24944 Old 06-21-2017, 09:32 AM
thyname's Avatar
Quoted: 249 Post(s)
Liked: 80
Higher than the 45 HZ? I set the crossover on the subs at 60 Hz yesterday. That's what the sVS people suggested, as well as one of the posters here. I will keep experimenting with the crossover, but I certainly believe that should be higher than the 45 Hz.
post #24939 of 24944 Old 06-21-2017, 10:22 AM
Quoted: 190 Post(s)
Liked: 140
That sounds about right. It may be even higher, say 80Hz. The difference may be subtle. Seems like you could plot the frequency responses on top of each other to see where the summation remains flat in the transition region.
post #24940 of 24944 Old 06-21-2017, 12:20 PM
auronihilist's Avatar
Quoted: 129 Post(s)
Liked: 78
Does anyone here own the old classic B&W 801 Matrix Series 2 or Series 3 speakers?
Audiophile fanboy beliefs are based on myth, superstition and ego.
auronihilist is offline
post #24941 of 24944 Old 06-21-2017, 08:33 PM
Newbie789's Avatar
Quoted: 149 Post(s)
Liked: 54
Ceiling mounted rears
Which B&W speakers can I ceiling mount that will perform well as surrounds with 804d3 towers and the HTM2D3 center? 80% movies / 20% music.
I have been looking for any information on ceiling mounting CM6S2 but I can't find anything.
I am trying to avoid in-ceiling speakers.
Newbie789 is online now
post #24942 of 24944 Old 06-22-2017, 12:01 PM
bose301s's Avatar
Quoted: 73 Post(s)
Liked: 31
I have been looking for the same for Atmos speakers, do not want to do in ceiling.
bose301s is offline
post #24943 of 24944 Old Yesterday, 09:32 AM
Patrick Butler's Avatar
Quoted: 361 Post(s)
Liked: 128
Regarding the integration of a subwoofer into a system with CM10S2, the answer to the question about where to cross them over depends on their response in your particular room.
I've done systems where I've run them full range, and others where I've had them crossed over at 50Hz. In the later instance there was a large response null at 40Hz (due to the room), and in the former the CM10s bass response was solid and reasonably linear into the low 30s, and the amplifier driving them was competent.
Patrick Butler
B&W Group North America
brireeves629 likes this.
Patrick Butler is offline
post #24944 of 24944 Old Today, 05:47 PM
Newbie789's Avatar
Quoted: 149 Post(s)
Liked: 54
Question Matching ceiling mounted rears for B&W 804D3 and HTM2D3
I am about to purchase a set of B&W 804D3 towers, B&W HTM2D3 center, and a rotel amp.
I am looking for a matching bookshelf to pair with these that I can mount to the ceiling.
I am considering the CM6S2 but I can't find anything online on how to mount them to the ceiling.
Does anyone have any suggestions or advice on how I could do this or what other speaker would match the D3 fronts?
I have listened to the 685, 686, and multiple in-ceiling models and they can't come close to the D3 fronts.
Reply Speakers
802D , atmos , B W , b&w dm1400 , Bowers And Wilkings 685 Speakers , carver cm-1090
