*** The Official APERION Thread *** - Page 174 - AVS Forum | Home Theater Discussions And Reviews
 308Likes
Old 05-08-2011, 03:03 PM
dcdivenut's Avatar
Originally Posted by Trepanator View Post
The ARC spec only allows (at most) 5.1 Dolby Digital or Dolby Pro Logic signals to be sent back to the receiver. None of the higher quality audio tracks present on the Blu-ray can be passed to the receiver.
I believe this is due to bandwidth limitations.
The OP has a Samsung TV-- unfortunately every TV Samsung ships has a minimal (gimped) ARC implementation, in that it will only return a stereo signal, regardless of the source-- including the on board tuner.
So for him, there is little difference between using ARC or the optical connection, in fact, the optical connection is preferable for OTA.
Interesting... so the optical would send 5.1 signal, then right? I was planning on using my BR player to stream Netflix anyway, but the Samsung looks like it had some cool menus (started the break in slides before messing around too much) and was thinking of using the TV instead... guess not.
dcdivenut is offline
Old 05-08-2011, 06:17 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
You can only get 5.1 from the on-board tuner--stereo only from all external sources.
htwaits is offline
Old 05-10-2011, 12:46 PM
Hicks's Avatar
Pretty sweet review of the Verus Forte system dropped today at Big Picture Big Sound:
http://www.bigpicturebigsound.com/Ap...m-Review.shtml
Hicks is offline
Old 05-10-2011, 01:26 PM
brandon_k_w's Avatar
currently own the 4Ts, 4C, 4Bs and 8A. I'm interested in upgrading my towers to 5Ts. What improvements are these 5Ts from 4Ts? I've noticed the frequency ranges are the same for both speakers.
I've started listening to music more often because these 4Ts sound nice, but how well do 5Ts handle music? Would Ialso need to upgrade my center to a 5C if went with 5Ts? And Jason, how much do you think the shipping would be? I've saved my shipping boxes.
brandon_k_w is offline
Old 05-10-2011, 04:15 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
Congrats to Aperion for another positive review.
Any chance of a review from someone who does measurements as well? ... maybe Soundstage, Sound & Vision, Home Theater Mag, Stereophile, Ultimate AV Mag, Audioholics?... just to mention a few possible options
I'd probably most interested in seeing a review in Ultimate AV Mag, Sound & Vision, or Stereophile, since they address off axis performance as well...
alphaiii is offline
Old 05-10-2011, 06:03 PM
Hicks's Avatar
The main difference between the 4T and the 5T is you get a nice bump in midrange fullness in the 5T and it's more sensitive by 1 dB so it doesn't require quite as much power to get the same output from it and it can fill a larger area, say up to a room around 20X20 or so. Having the fuller midrange is certainly a nice thing to have for music, so if you are going to continue to listen to more music then that may be an upgrade that is worth it for you.
You can use the 4C with the 5Ts, they are timbre matched, but the 5C is a pretty sizable bump in performance over the 4C since it's a three way as compared to the 4C which is a two way. You could always upgrade the towers now and then see if you want to do the center next after you've had them for a while.
Indeed! There is a Grand system out for review at Home Theater Mag now, as well as a Forte system at Sound + Vision. Of course Audioholics already did a review including measurements of the Grand speakers here:
http://www.audioholics.com/reviews/s...ng/verus-grand
Hicks is offline
Old 05-10-2011, 08:36 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
Nice! Looking forward to them both, but particularly the S&V review of the Forte line.
Yep I did check out that Audioholics review of the Grands.... definitely piqued my interested in the bookshelves...
alphaiii is offline
Old 05-10-2011, 08:50 PM
Ethereal19's Avatar
6C center in medium cherry on Ebay if anyone wants to upgrade their center... 4T's also...
Eyes: Samsung UN55C8000
Brain: Integra DHC-80.2
Heart: Emotiva XPA-5
Ears: Klipsch RF-7 II
Mouth: Klipsch RC-64 II
Ethereal19 is offline
Old 05-11-2011, 03:51 PM
wcmlutz's Avatar
I realize it would not be ideal, but I would only have 3" of room from the back of the VGB to the wall. Is this OK? It would be sitting in a shelf cubby.
wcmlutz is offline
Old 05-11-2011, 05:59 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
We've recently had Jeff Meier (UMR @ AVS) calibrate our new 5T fronts and 6C center. It turned out that the main board of our sub's amp died before he arrived. As a result, the 5Ts are temporarily set to large in our Denon 3806 AVR.
Jeff was impressed with the base output the 5Ts are able to produce. What he said was, "That's pretty good for small speakers. The sub's amp has just returned from it's repair, and I'll probably get it set up tomorrow. Jeff will return on his next trip to finish the calibration (no charge).
I'm very happy with our new Aperion speakers. Jeff had recommended the 5C because we were having problems understanding some dialog. When I placed the order, the 6C was on sale, so I followed the "more is better" principle and switched the center to the 6C.
The 5Ts are doing a great job with classical, jazz, and blues. My wife and I are doing the "What did she say?" routine less often. As an extra bonus, the piano finish works a lot better than the old speaker's scruffy flat black finish.
My first impression of the Aperion speakers was good enough, especially the mid range, that I didn't bother to A/B them with the old speakers. Jeff had calibrated the old ones too. He commented that the Aperion speakers wound up calibrating to our room in a very similar way.
Now I need to get the sub back on line.
htwaits is offline
Old 05-11-2011, 06:49 PM
WhereToStart's Avatar
Quoted: 14 Post(s)
I've ordered two Grand Towers and a Grand Center, and will soon be ordering 4 Grand Bookshelfs for a 7.1 setup (sub to be determined). My question is what would a good receiver be to pair them to? I'm currently debating Denon 3311 or 3312, Yamaha Rx-a2000, or maybe an Onkyo tx-Nr709 (I'm open to other ideas). The room size is about 12x16 so it's a smallish room but I want to be able to move the setup to a larger room eventually so I was thinking pre-outs make sense.
Edit: Also, I'd like to keep it under $1k.
WhereToStart is offline
Old 05-11-2011, 07:05 PM
wcmlutz's Avatar
You also could look at the Anthem MRX series. They sound pretty good.
wcmlutz is offline
Old 05-11-2011, 07:12 PM
Quoted: 14 Post(s)
I think they are a little out of my budget, which I forgot to include.
Old 05-11-2011, 07:14 PM
Snowmanick's Avatar
Quoted: 247 Post(s)
Liked: 349
The 3311Ci can be found at a great price, and has pretty much all the useful features that the 3312Ci has (plenty of power, connections, Audyssey MultEQ XT), if AirPlay isn't that big a deal, it makes more sense. If you want to stream iTunes, an ATV is pretty cheap and more powerful anyway (ATV2 adds Netflix streaming, iTunes store, the ability to search, which is priceless if you have a large music collection, over AirTunes)
That said, the Yamaha has been getting great reviews and allows a second sub to be integrated a little more effectively. The Unit is built like a tank, has a very slick GUI, and offers a bit different of a visual aesthetic (at least Yamaha tried to make the unit look like more than an average black box). The initial set up process is a little simpler than that on Denon's, but you only have to deal with that, at most, a handful of times anyway.
Both units have plenty of power, very good reliability, are from respected companies that know how to make good equipment, and have solid video and audio credentials. Both would also benefit from a good universal remote (a la Harmony). There, I think that covers most of the disclaimers.
So here's my 1/50th of a buck. If you are thinking of a adding a second sub in the future, or really enjoy slick GUI's, get the Yamaha. If you are thinking about features v. price, get the 3311CI.
~Nick
"Every loaf of bread is a tragic tale of grains that could've become beer.......but didn't...."
"If it works the first time, it's not high end." ~ Harry Pearson
Snowmanick is offline
Old 05-11-2011, 08:03 PM
Quoted: 14 Post(s)
Thanks for the breakdown!
Old 05-12-2011, 10:17 AM
spiritfox's Avatar
You should also consider something from the Marantz line. I have the 6005 with my 5.1 system in a 10x12 room and it sounds really nice--really fills the room--I usually watch movies around -8.
Also, Marantz is the line sold by Aperion.
A few pics of my room.
Bob
spiritfox is online now
Old 05-12-2011, 11:56 AM
wcmlutz's Avatar
The Anthems are similar in price to the others you listed. MRX300 has an MSRP of $1000. MRX is at $1500.
wcmlutz is offline
Old 05-12-2011, 12:06 PM
Hicks's Avatar
If you cross them over at 80 Hz you should be fine. If they still sound a little muddy you can always try plugging the ports.
Hicks is offline
Old 05-12-2011, 12:37 PM
Browninggold's Avatar
Liked: 37
http://www.vanns.com/shop/servlet/it...ries/538921246
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
Old 05-12-2011, 05:26 PM
Hicks's Avatar
Just a reminder that our Outdoor Speaker promo ends this weekend, so now is a great time to outfit your deck, patio or yard with Aperions:
http://www.aperionaudio.com/product/...30,31,718.aspx
Hicks is offline
Old 05-13-2011, 11:04 AM
Failwhale314's Avatar
I've decided my next speakers will be the Grand Center and Grand Towers.....now to come up with $2500
Failwhale314 is offline
Old 05-13-2011, 12:40 PM
Hicks's Avatar
Excellent choice, maybe hold a bake sale?
Hicks is offline
Old 05-18-2011, 11:49 PM
When you use Aperion's SPL to calibrate the sound levels for all the speakers, does that include the sub also, or is sub volume personal preference? For music purposes, should the sub's db level be the same as the speakers? My SPL's needle jumps way to the right when my subwoofer emits my test sound. All the speakers are closely level though.
Old 05-19-2011, 04:55 AM
justinto's Avatar
Quoted: 22 Post(s)
I used mine for the sub too. I like my sub a little louder. I found the meter to be accurate. You may want to dial your sub down a bit for more balanced sound stage, but if you really like it overpowering, that would be a personal preference.
Justin
LG OLED 65B6P; LG OLED 55B6P
Denon x4200W; (2)
Aperion Verus Grand Speakers
justinto is offline
Old 05-19-2011, 01:02 PM
Hicks's Avatar
In my experience SPL meters aren't very accurate at low frequencies. I recommend dialing in the sub by ear.
Hicks is offline
Old 05-23-2011, 05:44 PM
bigtimelew's Avatar
at least that way you'll know Oprah will show up. Sorry couldn't resist.
My first Home Theater is coming along nicely, i have two 5T's arriving tomorrow (so excited) already have the 5b's, and 5c. Now i'm just waiting for my Denon 4311 to ship and i can start installing. I do have one hangup however, I don't really have the budget to spend 800 dollars on a sub, I was wondering if it is an option to buy an off brand sub that will safice, but i'm worried about it meshing with the aperion speakers. Would this create a problem ? and i'm not an expert by any means, if 800 dollars or so is reasonable for something comaparable to the 10D 2 then i'll be more than happy to hold off until i can afford it. Any advice would be greatly appreciated
bigtimelew is offline
Old 05-23-2011, 06:48 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Originally Posted by bigtimelew View Post
I do have one hangup however, I don't really have the budget to spend 800 dollars on a sub, I was wondering if it is an option to buy an off brand sub that will safice ...
When UMR calibrated our home theater a short while ago, he thought the 5Ts had good base for their size. Our sub is now repaired and it does make a difference. You could just go with a 5.0 system until you can afford the right sub. Sloppy bass can be irritating.
htwaits is offline
Old 05-23-2011, 08:04 PM
RCase7's Avatar
Just got my Grand Verus towers, and they sound great, but my ears were very fatigued in less than half an hour of listening (70-85 dbs). I am sitting about 14 feet away, in a large room. I have them crossed over at 80 running through a Denon 989 and powered by Emotiva UPA-1's. Previously using Axiom M-80's with zero listener fatigue. Any suggestions?
RCase7 is offline
Old 05-23-2011, 08:28 PM
Lilmase1153's Avatar
Its very possible they just need to be broken in, I know when I got my PSB Image T65s I also got listening fatigue for the first 2 weeks or so. I came from a very warm set of speakers, in fact I almost sent them back, but am glad I waited as I love them now.
Hopefully thats just whats going on with you. Best of luck!
Lilmase1153 is offline
Old 05-23-2011, 08:37 PM
RCase7's Avatar
Yea, but I bought them used, they are at least three months old.
RCase7 is offline
Aperion Audio , Aperion Audio Center Channel Speaker , Aperion Audio Verus Forte Tower Hd Black , Aperion Verus Grand Tower Speaker Gloss Piano Black , Aperion Audio Verus Forte Satellite Sd Black , Aperion Intimus 5b Fusion Sd , Marantz , Marantz Sr5007 Home Theater Av Receiver , Mcintosh Labs Mc 2100
