*** The Official APERION Thread *** - Page 244 - AVS Forum | Home Theater Discussions And Reviews
 267Likes
post #7291 of 7306 Old 03-31-2016, 10:48 AM
ManBarra's Avatar
Quoted: 21 Post(s)
Originally Posted by mingus View Post
Can anyone give me and idea of basic sonic signature of the Allaire? I prefer a lot of sparkle in the highs usually. currently I have Emotiva Airmotiv 5 that I like a lot, except they will not work with 220V where I am moving. they are not real bright, but i like way the highs sound, and also the bass is nice for what it is.
I do like the idea of sub-out just in case i wanted to go that route in the future.
They definitely have great clarity and sparkle. Not overly bright to cause any harshness to the ears though. They cap out at 85dB without distorting. I also feel the bass response is really strong for the smaller size driver. In fact when I'm about 15 feet away from the speakers I feel like the bass response is even stronger.
ManBarra is offline
post #7292 of 7306 Old 04-04-2016, 07:56 PM
Newbie789's Avatar
Quoted: 82 Post(s)
Liked: 31
Any idea when the verus 2 grand towers are going to have a review?
Newbie789 is offline
post #7293 of 7306 Old 05-24-2016, 07:29 PM
Liked: 0
Verus Grand Bookshelf Bi Amping
I've got an Onkyo 809 and have always run them bi amped and feel I can hear a difference. Any opinions.
Aperion Verus Forte system with two Outlaw LFM1 subs, Onkyo 809 receiver & a Panasonic Gt50 65" plasma.
Noviceburd is offline
post #7294 of 7306 Old 05-24-2016, 07:48 PM
Liked: 0
Any Reviews on the Verus II s
New Tweeter design.
post #7295 of 7306 Old 05-26-2016, 01:13 PM
ManBarra's Avatar
Quoted: 21 Post(s)
Originally Posted by Noviceburd View Post
New Tweeter design.
There are also modifications to the crossover like upgraded capacitors as well as better gauge internal wiring.
ManBarra is offline
post #7296 of 7306 Old 06-15-2016, 12:32 PM
ManBarra's Avatar
Quoted: 21 Post(s)
Does anybody have the Verus II's yet? What do you think?
ManBarra is offline
post #7297 of 7306 Old 06-15-2016, 04:34 PM
Newbie789's Avatar
Quoted: 82 Post(s)
Liked: 31
I have them and they are clearly better than the verus 1. Voices are clearer and the highs are a little brighter. Same speaker feet, cabinet, etc but the tweeter looks like a new design and the crossovers are supposed to be better.
I sent my ones back to get the twos and I'm happy.
darthray, gpzbc and ManBarra like this.
post #7298 of 7306 Old 06-15-2016, 06:21 PM
darthray's Avatar
Quoted: 723 Post(s)
Liked: 642
First congrat on your new Verus 2
I went through lots of gear through my audio hobby, almost 40 years now
When you say "clearly better than the verus 1", how much % would you think it did?
From my experience very few products can achieve 50%, most time spending double the money equal to maybe 5%, ($2000 to $4000 AV processor was about 5-10%, more on the 5% side) still an improvement when desire.
And sometime it is just a different sound that we prefer, since no one have the exact taste.
Ray
yanks1 likes this.
darthray is offline
post #7299 of 7306 Old 06-15-2016, 09:28 PM
Newbie789's Avatar
Quoted: 82 Post(s)
Liked: 31
Ray
If I had to assign an overall percentage I would say 15%
post #7300 of 7306 Old 06-22-2016, 01:26 PM
ManBarra's Avatar
Quoted: 21 Post(s)
Does anybody have any particular songs they like to demo while auditioning speakers?
ManBarra is offline
post #7301 of 7306 Old 06-22-2016, 02:23 PM
Tom Ames's Avatar
Quoted: 23 Post(s)
Liked: 48
It is probably best to use material that you are very familiar with--and preferably of differing styles.
Tom Ames is online now
post #7302 of 7306 Old 06-27-2016, 01:52 PM
ManBarra's Avatar
Quoted: 21 Post(s)
For sure. Just looking for possible suggestions and tunes to try out.
Does anybody audition between vinyl and CD's? I have a vinyl player but it's not hooked up.
ManBarra is offline
post #7303 of 7306 Old 06-30-2016, 09:03 AM
Liked: 0
What kind of toe in are you guys using for the verus grand towers. I've got everything set up and I ran audyssey once and things sound pretty good but I think I want to make some tweaks and run it again. Just curious what some other people are using for speaker positions and toe in with them for some ideas.
dreadnaught16 is offline
post #7304 of 7306 Old 06-30-2016, 11:40 AM
ManBarra's Avatar
Quoted: 21 Post(s)
I've found that I like the tweeters aimed in a way that they will cross paths just behind your head/ears. If you want to get detailed, you can use a laser pointer. However different rooms reflect differently so it may take some trial and error to find the sweet spot for your room.
ManBarra is offline
post #7305 of 7306 Old 06-30-2016, 01:45 PM
Liked: 0
Would the easiest way be to just play some familiar music in 2 channel mode and keep adjusting till it sounds the best? it'll be used probably 80%tv/movies and 20% music.
post #7306 of 7306 Old 06-30-2016, 02:07 PM
ManBarra's Avatar
Quoted: 21 Post(s)
Yeah familiarity helps. Also it's usually easier to have a partner so one of you can nudge the speaker a pinch at a time and you can more easily tell when you're in line with the sweet spot.
Even if it's mostly going to be used for tv/movies, there is usually not enough constant sound so it's harder to tell the sound field. Probably best to find the angles using music.
ManBarra is offline
Reply Speakers
Aperion Audio , Aperion Audio Center Channel Speaker , Aperion Audio Verus Forte Tower Hd Black , Aperion Verus Grand Tower Speaker Gloss Piano Black , Aperion Audio Verus Forte Satellite Sd Black , Aperion Intimus 5b Fusion Sd , Marantz , Marantz Sr5007 Home Theater Av Receiver , Mcintosh Labs Mc 2100
