*** The Official APERION Thread *** - Page 246 - AVS Forum | Home Theater Discussions And Reviews
 300Likes
post #7351 of 7380 Old 11-11-2016, 07:09 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
Originally Posted by Newbie789 View Post
This is a short review of the Aperion Verus Grand II speakers and some info the on the Aperion Verus Grand
http://praveen-kailas.com/listen-up-...s-ii-speakers/
Thank you for posting this nice detail review
Is this yours or something you found?
I got the original Verus I series (2 towers, 1 center and 4 bookshelf).
It was a good read
Ray
Newbie789 likes this.
darthray is online now
post #7352 of 7380 Old 11-11-2016, 07:10 PM
Newbie789's Avatar
Quoted: 107 Post(s)
Liked: 45
It was a good read
Ray
Thanks Ray
This is mine. I haven't seen anything on these speakers so I figured I'd write something.
darthray and ManBarra like this.
Newbie789 is online now
post #7353 of 7380 Old 11-11-2016, 07:19 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
Thanks Ray
Very well done
Ray
post #7354 of 7380 Old 11-18-2016, 11:42 AM
ManBarra's Avatar
Quoted: 30 Post(s)
Awesome!
__________________________________________________ _________________________
Aperion Audio Allaire - Saving my pennies to get the Verus Grands!
ManBarra is offline
post #7355 of 7380 Old 11-21-2016, 08:09 PM
i'm currently using an old pair of jbl l100t3's for my main l/r towers. while i don't enjoy how lively they are, the bottom line is that they crank. i've read great things about the grand verus towers, but i fear they just don't turn up loud enough? can anyone attest to this? they are on the top of my short list.
serith is online now
post #7356 of 7380 Old 11-22-2016, 01:27 PM
ManBarra's Avatar
Quoted: 30 Post(s)
According to Praveen's review posted above, they get "uncomfortably loud without distortion". I would have to agree because even the little Allaire speakers that I have get pretty dang loud without distorting.
serith and Newbie789 like this.
ManBarra is offline
post #7357 of 7380 Old 11-22-2016, 08:01 PM
Newbie789's Avatar
Quoted: 107 Post(s)
Liked: 45
Check it out the video on my review. I posted a video of the driver in slow motion when turned up to about where it hurt my ears. You can see how well they move and there was no distortion at this volume.
Here's a direct link to the video too
ManBarra likes this.
post #7358 of 7380 Old 11-23-2016, 11:30 AM
ManBarra's Avatar
Quoted: 30 Post(s)
haha I love slow motion videos like that.
ManBarra is offline
post #7359 of 7380 Old 11-23-2016, 08:23 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
Does anyone here use some Aperion for ceiling speakers?
For Atmos duty!
I am thinking to get 4 more, Verus Grand Bookshelf for that duty.
Mounting them will be just a matter to find the proper mounting bracket.
I am thinking to mount them, almost horizontal to the ceiling, with a small angle for the rear and front facing the main listening position.
If so, pictures would be greatly appreciated
Ray
post #7360 of 7380 Old 11-24-2016, 02:51 PM
Newbie789's Avatar
Quoted: 107 Post(s)
Liked: 45
For Atmos duty!
Ray
Ray
Check out these brackets from monoprice.
Monoprice 106839 Adjustable Speaker Wall Mount Bracket, Black, Set of 2 https://www.amazon.com/dp/B004C4XN86..._Ub2nyb30A83BZ
darthray and gpzbc like this.
post #7361 of 7380 Old 11-24-2016, 08:05 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
Ray
Thanks for link
These look like it might be the ticket.
I would do two modification;
- Instead of using a hand tight screw, I would use a real bolt and nut, this way you can tight it a lot more secure.
- Also, the ends of the security cable look flimsy, so I would put some real small carabineer.
Other than that, they look perfect for multi angle.
Just have to figure on how to install these in my room on the ceiling
https://www.aperionaudio.com/speaker...kshelf-speaker
My room can be seen on my signature, open to all suggestions.
All I can find are pictures of speakers with built-in angle or in ceiling, unfortunately nothing so far or real Bookshelf.
Just want to have all the same speakers all around, for sound signature.
And will also buy another power amp (5 channels) from Outlaw Audio to match my current one (7 channels), yes I can be I little anal and way over board, but I believe to do-it once and to do-it right the first time
After all, it is my only Hobby
Again thanks for the link and the reply
Ray
post #7362 of 7380 Old 11-25-2016, 03:17 AM
Newbie789's Avatar
Quoted: 107 Post(s)
Liked: 45
Thanks for link
Ray
What about cutting out a section of sheet rock and mounting these between the ceiling joists, directly to the subfloor above? You'd have to install a trim on the cut sheet rock edge.
Then you could have the speakers not sticking down a foot off the ceiling. They'd be semi in ceiling speakers.
darthray likes this.
post #7363 of 7380 Old 11-25-2016, 07:55 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
Thanks for your thoughts
Sticking out is not a problem, the rear ones will be above the rear row, and the front will be away of any traffic area.
According to your post, it sound like you suggest to mount them horizontally to the ceiling (with no angle or a very little one), so I think, I may be overthinking the whole process.
So maybe these one will be a better solution for me;
https://www.amazon.ca/Mount-MI-4501L...glnk-ca-c18-20
Or something similar (just a little bit smaller)
Mounted with the tweeter closer, and the mid/woofer further away from the sweet spot.
Thanks to the PSA thread.
I may go that way when our CDN$ go back up, it will be a while
(And maybe not, it might be one of those side way step).
Ray
post #7364 of 7380 Old 11-27-2016, 12:50 PM
Newbie789's Avatar
Quoted: 107 Post(s)
Liked: 45
Ray
Do you think it's necessary to use the Aperion bookshelf speakers for atmos? Does that much sound come from atmos?
My house is pre-wired for 5.1...so it'll take a considerable amount of work to add more speakers with the reciever upstairs across the house.
post #7365 of 7380 Old 11-27-2016, 06:54 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
To be honest, No
It like surround speakers, a lot less important than your 3 fronts.
Some like the surrounds to have the same signature of sound as there front stage, I fall into this camp
Even if there is a lot less action into them, this is why the surrounds do not really need to be match.
For Atmos, I suspect the same.
For me since it is my only Hobby, I intend to have All speakers matching even if it is a lot more expensive.
To run those wires into the ceiling will require about a week of work for me.
The space to get in the in-between (ceiling of the theater and floor of the main floor), is very tight, even for me 128lb.
On the left of the equipment's and right side of the furnace (you have to go about 3 and 1/2 ft above, 10 inches of space available and go between 2 vertical studs [18 inches apart]), once there I got about 4 inches to work between the ceiling and floor.
Not to mention than since wires do get snag once in a while, and I will be doing-it by my self, I need to go through that crawled space a few time (pull the wire, snag then back down, unsnag, then back up, and so on
So I intend to do-it by stages;
-get the speakers and install them first
-then, another Outlaw Audio Amp (less powerful
than my current one)
-last, a new Audio/video Processor.
Since I do not like to get into owning money, to my credit card or bank, I figure it will take me about 2 years to complete.
Ray
post #7366 of 7380 Old 11-27-2016, 07:31 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
Newbie789
Forgot to mention.
I also intend to finish the wires and using the same wall plate (ceiling in this case), as my front 3
post #7367 of 7380 Old 11-27-2016, 07:56 PM
Newbie789's Avatar
Quoted: 107 Post(s)
Liked: 45
Newbie789
Forgot to mention.
The wire looks good. Nice wire pants. Check the out the escutcheon I'm using to feed the wire through...I didn't want another plate on the wall.
post #7368 of 7380 Old 11-27-2016, 08:11 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
Thanks for the compliment, and yes it is only a Look thing
Really dig those little plugs
Any link for where to get them?
I will sleep on-it (or the lack of-it now), since I will have to figure out a new way to fish my wires, not much space to work with in an already tight space
One word of advise;
I know you coil your wire speakers for look, Uncoil them, sometime they can act like an antenna and pick-up some ground noise.
Thanks for the pic and suggestion.
Ray
post #7369 of 7380 Old 11-27-2016, 08:18 PM
Newbie789's Avatar
Quoted: 107 Post(s)
Liked: 45
One word of advise;
Ray
Here's the link...black or white
Single Feed-Thru Bushings - White - package of 100 by CIMPLE CO (White) https://www.amazon.com/dp/B004JOJQEY..._Uf6oyb8NPMXGR
What else can I do with the the wire? No more will fit in the wall....I'm afraid to cut and shorten it in case it in the future.
post #7370 of 7380 Old 11-29-2016, 06:11 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
Thanks for the link
You do not have much left over, so I would just let-it hang loose and messy.
No need to make it shorter, just doesn't look as much cleaner
People should just admire the look of the speaker and the wires/pants and plug, not if the wire is set neatly.
Look like we are using the same Banana Plugs
Put your ears next to the speaker, with no source playing and volume about half.
If you do not hear a difference, then I say you are Golden either way
Ray
post #7371 of 7380 Old 11-29-2016, 08:43 PM
abd1's Avatar
Quoted: 83 Post(s)
Liked: 64
I have a pair of used Intimus 6T's. When I got them I noticed one of the bass port sleeves was missing. I don't think it's a big deal but it's' probably a $5 part so I wouldn't mind getting one and putting it in. The opening is 3". Does anyone know where to get the part and what exact part it is. It looks like there are multiple 3" ports available.
abd1 is online now
post #7372 of 7380 Old 11-29-2016, 09:16 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
I would contact Aperion, and let the expert do what they do best.
Here's a link for customer service through e-mail;
customerservice@aperionaudio.com <customerservice@aperionaudio.com>;
If you just got those speaker, they should send-it free if missing from your order.
If it is an older order, like you said, a $5.00 or so part and a little bit of shipping involve
Ray
post #7373 of 7380 Old 11-29-2016, 09:23 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
Got to hate, those So nice finish
I just realize that you can see part of the person taking the picture with sandals.
And yours, are not even the black gloss, I did not realize the wood version was also so shinny.
Outstanding
I guess we both spend spend a lot of time for dusting and polishing
Ray
post #7374 of 7380 Old 11-29-2016, 10:57 PM
Newbie789's Avatar
Quoted: 107 Post(s)
Liked: 45
Outstanding
Ray
Little bit of pledge with orange oil will reflect my sandals. It makes the wood look wet and you can get it anywhere
post #7375 of 7380 Old 11-29-2016, 11:53 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
LOL
I use the Pledge Lemon, as instructed by Aperion for Gloss Black one
Anyhow, I got to make some serious decision and await answer from Aperion and Outlaw Audio, customer service.
The AVR forum convince me, that I do not need the AV7703, The 7702mkII will do just fine for my application.
But the 7702, just like the grand series I, I believe both are on there way out
With the money exchange at this point, I must buy one a the time
So, I must make a very educated decision.
Just to let you know, where I am standing now.
Ray
post #7376 of 7380 Old Yesterday, 10:22 PM
are there any known coupon codes that work when checking out on their website? looking to pull the trigger soon on a pair of grand verus II towers.
post #7377 of 7380 Old Today, 09:26 AM
ManBarra's Avatar
Quoted: 30 Post(s)
Ray
Which Outlaw amp are you looking at? Do they only have the Model 5000?
That's also interesting that they sell Marantz processors.
ManBarra is offline
post #7378 of 7380 Old Today, 03:56 PM
Brent A's Avatar
Quoted: 35 Post(s)
Liked: 50
What about letting it fall naturally to the floor and then route it underneath the speaker and back out again and then up to the terminals?
Basically hiding the excess underneath the speaker.
Brent A is offline
post #7379 of 7380 Unread Today, 07:17 PM
darthray's Avatar
Quoted: 866 Post(s)
Liked: 806
They have many products available
http://outlawaudio.com/products/
This is the one I got, it take care of the LCR, sides and back surrounds (7 speakers).
http://outlawaudio.com/products/7700.html
By going Atmos, I need four more channels, so looking to add this little fellow
http://outlawaudio.com/products/7140.html
A waist of 3 channels, but I want to keep all my connections with XLR cables, and there is no choice for a 5 channels with XLR connections.
Then again for $1100, it will do what I need it to do
It is going to be a long project
I figure around 18-30 months.
Yesterday, I order a Marantz AV7702mkII
Once paid for in full, I will order the wires and ceiling plates, then fish all the wires and get the plates ready.
Once done and paid for, order 4 Verus Grand Bookshelf series II (wanted the original ones, but no longer available in Black Gloss, [I was told they will have the sound signature]), and once paid for.
Order the 7140, do all the connections and calibration
Ray
post #7380 of 7380 Unread Today, 10:12 PM
Newbie789's Avatar
Quoted: 107 Post(s)
Liked: 45
Might have to try that, but it ends up being a dust catcher.
Right now with the volume at 60 and the source off, there's no sound.
Do ferrite rings prevent ground noise?
Reply Speakers
Aperion Audio , Aperion Audio Center Channel Speaker , Aperion Audio Verus Forte Tower Hd Black , Aperion Verus Grand Tower Speaker Gloss Piano Black , Aperion Audio Verus Forte Satellite Sd Black , Aperion Intimus 5b Fusion Sd , Marantz , Marantz Sr5007 Home Theater Av Receiver , Mcintosh Labs Mc 2100
