Acoustic Research ARXP62 Bookshelf Assessment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 50 Old 12-22-2006, 03:45 PM - Thread Starter
avr5700's Avatar
First, let me note that I consider myself a casual audio listener, not a rarified audiophile. What follows is only my opinion, but it is more than you will find elsewhere concerning this product's performance. It is my sincere hope that this write-up will be helpful to those whom are unable to audition this speaker before deciding on a purchase.
As of December '06, J&R seems to be the sole purchasing option. If you live near a brick and mortar store, I encourage you to go listen for yourself and add your thoughts to this thread. If you own or have otherwise heard these yourself, please do post an opinion, whatever it may be.
Attributes of the XP62:
  • 1" extended frequency tweeter - soft dome; unidentified material
  • 6.5" aluminum woofer - with true phase plug
  • Frequency response: 38Hz-50kHz +/-3dB *
  • Nominal impedance: 8 ohms
  • Sensitivity: 88dB ^
  • Recommended power: 15-125 Watts
  • Finish: Black Ash Vinyl with High-Gloss Black Accents
  • Dimensions: 13-3/4"h x 7-3/4"w x 12-5/8"d
  • Individual speaker weight: ~13.5 lbs
  • Video shielded
  • Made in China
  • Not bi-wireable
  • XP series manual: http://www.audiovox.com/manuals/owners/XP_Man_6_29.pdf
  • Currently available for $100/pair.
* see post 2; measured bass output does not support this claim at -3dB; I have not run across an official response chart; J&R web spec. doesn't match manual
^ SPL output vs other 88dB speakers suggests actual sensitivity of ~86dB
Speakers used for comparison: B&W DM601 S2
Test system configuration: -----
I spent several hours listening and A/B selector switching between the DM601s and XP62s. In that time I compared five selections; specifically, these:
  1. Sarah McLachlan / Afterglow - Train Wreck
  2. Seal / Seal 94 - Don't Cry
  3. Carpenters / The Singles '69-73 - Yesterday Once More
  4. Pink Floyd / Dark Side of the Moon - Money
  5. Norah Jones / Come Away with Me - Don't Know Why
My listening position was centered about 7.5' away, with the speakers on the same makeshift stands, side-by-side with the channels separated by about 6.5'. Most of the time the seating position level measured 80-90dB, peaking at 95dB. Both sets were auditioned without grilles.
One confounding issue is that the DM601s were louder at the same volume setting. It's odd since the B&W specs state 88dB, matching that of the XP62s. However, they clearly had a 2-3dB greater loudness as measured using a Radio Shack handheld digital meter on program material. Maybe the receiver B amps were hot compared to the As. [subsequent selective measurements did not reveal an amp offset] Whatever the cause, louder tends to sound better and in some of the testing I did try to adjust for this effect but could not be 100% accurate since the Technics does not read out volume digitally. It has only a motorized knob for level indication.
Performance observations:
I'm not comfortable calling something warm, transparent, bright, smooth, 3D, etc. It seems to me that such terms are too easily misconstrued, so I will avoid using them.
Bass: XP62 wins this one, with more of a tactile quality, but not by a lot. Do I need a sub? Not really, but perhaps at lower volumes.
Mids: Surprise; I preferred the XP62's performance here as well! This difference is much of what gives the sets different tonality. I sense that the XP62s have less bass emphasis in the mid which results in less nasal sounding voices. Lyrics are nice and clear. I noted the slightly more nasal sound of the DM601s when comparing Norah Jones' and Sara McLachlan's voices. I'm not saying the DM601s aren't pleasing in this respect; I like them still. Could someone send Sara over so I can compare the genuine article to these?
Highs: There is another small difference here. The XP62s are only slightly less intense. Maybe it is due to the greater degree of mid/bass emphasis. I should note that I'm 37, so according to sources, I no longer hear above ~16kHz, which begs the question of what the rated 50kHz response really could contribute. Micro-dynamic harmony? I suppose. If there is a winner here, it's not clear enough to me. [see also post 28]
If I were not privy to which set were selected but had heard the selection on both recently, these speakers are different enough that I'm reasonably sure I could identify which is in use. If an unfamiliar artist/selection were played on only one randomized set, I'm not so confident. I would try to pin it down using the difference in bass response in that case.
In conclusion, my B&W dealer is fortunate I didn't have the XP62s in an A/B setup at the showroom when I bought the DM601s. I would have confidently walked out that day with the XP62s! Factor in the price difference and it is no longer a serious contest.
Additional details of the XP62 per direct inspection:
  • Has 5-way binding posts with plastic nuts; even the DM601s use plastic nuts.
  • There are odd plastic top/bottom front retainers for the wire mesh grill. They remove easily, but do need to stay since the speaker directly sets on the bottom one and the top looks funny without it. The top cap is loose enough without the grill to make me wonder if it will eventually rattle, causing its removal.
  • Behind the grill is a surface covering shaped foam piece that is not intended for removal, but may have acoustic benefits and looks nice anyway.
  • Utilizes a single rear port, slightly above center, attached to a 1.5" diameter tube of about 7" length and flared on both ends.
  • Cabinet and finish seem solid with maybe a top/bottom that should be thicker. I passed that judgment after simply rapping a knuckle on each surface.
  • The rear wall is not a relatively solid plank like most speakers. Instead there is at least some side-to-side cross bracing and a large plastic housing. This housing is a 1.5" deep (at center) convex, semi circular, protrusion attached to the entire rear of the cabinet (axis running top to bottom). The shape echoes that of the cabinet's front grill.
  • Using a telescoping mirror to look around in the cabinet, I spotted yellow acoustic batting on one side and bottom with the top and opposite side being bare. The same batting is visible at the rear of the cabinet behind what appears to be the main rear brace/wall placing it in the aforementioned plastic housing.
  • Mid/bass surround material appears to be primarly composed of foam but may be a rubberized hybrid.
XP62 Photos:
Thanks to 'Groch' for the following photos from posts 21 & 22:
Deep Space - the free, all natural wire insulator, cabinet damper and transducer equalizer.
* Patented by Quietspeaker Industries, a division of Almighty Group.
avr5700 is offline
post #2 of 50 Old 12-22-2006, 03:45 PM - Thread Starter
avr5700's Avatar
Given that the manual specs for the ARXP62 bass extension are rather difficult to believe, I broke down and conducted a crude set of sine wave based frequency measurements.
I used the Radio Shack SPL meter to record the C weighted, slow response level of bass frequencies ranging from 31.5-104Hz. This was done with one speaker of each set at a distance of 2 feet from the test speaker.
While I was at it, I checked for a difference between the A and B amp set of the receiver. I found no difference when switching between them using the same speaker so the previously reported loudness difference of these two speaker sets does not seem to be due to a constant attenuation offset within the receiver's amps.
Measurements have not been corrected for the relatively well known Radio Shack meter offsets. They are also subject to unknown room effects so I don't expect others to be able to faithfully reproduce these specific results. I wanted only to get a less subjective feel for the lower response limits and bass signature deltas of these speakers. Measurements were spot checked by way of sub-sampled repetition after the full sweep on each speaker. They did prove to be repeatable.
I am surprised to find that the two speakers measured so similarly. Absolute standard deviation between readings is .95dB with only one instance of a >3dB delta at 54Hz among 74 samples. Despite my own expectations, the DM601 did not roll off any higher than the XP62. I did verify that the receiver's sub-woofer cut-off filter was disabled.
1/1/07 Update - Happy New Year!:
I spent a bunch of time today figuring out how to properly use HomeTheaterShack's free Room EQ Wizard. From that I obtained complete sweep graphs and posted them below. In the process I discovered that my PC's onboard C-Media sound device response drops precipitously above 7kHz, but it was measurable and the 'Wizard' applied correction factors for the sound card as well as the Radio Shack SPL meter.
Still, these metrics are really only useful for relative comparison of the two speakers in my write-up. Room effects remain undefined, as before. It's nice to see my original bass results are confirmed by these charts.
Apparently, the 4kHz DM601 crossover point is reflected in the graph. Judging from that, it seems the XP62 is using a similar frequency. In both cases, I would have hoped for a smoother transition.
20Hz-24kHz sweeps with 1/3 octave smoothing:
20-250Hz, 0-250ms waterfalls:
avr5700 is offline
post #3 of 50 Old 12-22-2006, 03:57 PM
ericgl's Avatar
Quoted: 25 Post(s)
Liked: 24
Very good write-up avr... thanks.
ericgl is offline
post #4 of 50 Old 12-22-2006, 04:16 PM
prerunnerv6's Avatar
Great write-up. I just might pull the trigger on this.
prerunnerv6 is offline
post #5 of 50 Old 12-22-2006, 10:25 PM
louthewiz's Avatar
louthewiz is offline
post #6 of 50 Old 12-22-2006, 10:27 PM
Luis Gabriel Gerena's Avatar
Quoted: 97 Post(s)
Liked: 64
Goos job! I want to see pics :-)
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
post #7 of 50 Old 12-23-2006, 07:26 AM
openwheelracing's Avatar
Liked: 34
When I had the VP26, I took it apart and found the cabinet construction dissappointing. Virtualy no bracing and the side walls were way too thin. Knuckle test failed. The tweeter seems extremely well constructed. The woofer seems decent with fake phase plug. The front also has the foam material that covers the screws. They very easy to peel off and easly stick back on afterwards. The back of the speaker was made of plastic.
Sounds similar to the XP26. I took some pictures when I had them. They are in another thread a few months ack.
openwheelracing is offline
post #8 of 50 Old 12-23-2006, 08:31 AM
dknightd's Avatar
Nice job. I wonder how the 601s2 compares with the 601s3
edit: are you keeping one and selling the other, or keeping both. Which do you think you'll mostly?
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
post #9 of 50 Old 12-23-2006, 02:23 PM - Thread Starter
avr5700's Avatar
Photos have now been posted.
openwheelracing:
I wonder if the sides of the VP26 and those of the XP62 are the same thickness. The XP62 sounds thinner on the top/bottom, but it could be due to cross bracing for the sides. Did the VP26 also have this characteristic? Knuckle rapping on the DM601s sounds remarkably similar to that of the XP62s.
dknightd:
I'm an audio/electronics pack rat. I would sell a lot of my other junk long before punting one of these sets. I'll keep both sets in service and may demote a much older set of ARs in my bedroom. At least for the short term, I will be listening more to the XP62s. Who knows?; I might find material they hate...then revise my assessment, though I hope not.
avr5700 is offline
post #10 of 50 Old 12-24-2006, 09:32 AM
Liked: 34
From the pictures, I can see that VR26 and XP62 use the same woofers (look-wise at least), and the XP62 has a dfferent tweeter.
The VP26 has similar thickness all the way around I believe. Top and bottom sounded solid, but the sides failed the knuckle test. There is no bracing in the cabinent.
post #11 of 50 Old 12-28-2006, 10:45 PM - Thread Starter
avr5700's Avatar
Originally Posted by openwheelracing View Post
When I had the VP26, The woofer seems decent with fake phase plug.
Despite having owned the DM601s for years, I had to educate myself a bit about phase plugs.
The XP62 mid/bass driver also seems to be different than that of the VP26 (and presumably the entire VP series). The XP62s are definitely using a true phase plug. The close up mid/bass photo shows the gap between the cone and plug.
In fact even the DM601s are using a quasi plug attached to the Kevlar cone. I was expecting to find that the XP62 design was the lesser of the two, but that is not necessarily so per this quote from Audioholics (in the speaker gimmicks article):
"Be cautious with some loudspeaker manufacturers that use a quasi phase plug which looks like a phase plug for marketing purposes, but does not physically separate from the cone of the driver. These 'so called' phase plugs can sometimes do more harm than good as they can provide an inconsistent surface area and can also increase mass of the cone yielding poorer frequency response and linearity.
A real phase plug essentially eliminates the need for a dust cap, which in turn, reduces cone mass, permitting extended frequency response. It allows more airflow through the motor structure, which improves cooling and thus increases power handling. A Phase plug also helps to reduce on-axis beaming by dispersing higher frequencies that the cone is producing."
avr5700 is offline
post #12 of 50 Old 01-01-2007, 08:02 PM - Thread Starter
avr5700's Avatar
I have updated the second post in this thread to include some full range sweep comparison measurements.
Enjoy!
I ordered a second pair of these now; they are that good for the price. I'll need to figure out how to run them together...maybe A+B with one set flipped on top and foam between...hmm.
avr5700 is offline
post #13 of 50 Old 01-01-2007, 08:54 PM
Liked: 34
These ARs are undoudebly great steals.
post #14 of 50 Old 01-03-2007, 07:53 PM
masteraleph's Avatar
You didn't by any chance order the center channel, did you? Looking at these myself (particularly since I'm in NYC, and can get a slight discount at A&R- not a lot, but enough to make them around $95 a pair, and if I pick them up, no shipping), and considering going five channels with them...but I'm somewhat worried that the ARXP242C is using 4" woofers rather than the 6.5" ones on XP62s. And yes, I'll take a listen there, but it can be a little hard to tell anything in the store.
masteraleph is offline
post #15 of 50 Old 01-03-2007, 08:22 PM
Options2000's Avatar
Well, after reading this post I bought a pair too. Replaced Polk RTi4 as the front bookshelf speakers to install these. The receiver is PE VSX-82TXS. I must have listened for about 30 min after an auto install. My initial impression is that these are a little bit on the bright side compared to Polks. However, the sound is very crisp and much clear....distinctly different. Probably, compare some more before deciding which ones to keep. As of now, I am leaning towards keeping ARs....just need to figure out which settings to change to decrease the "brightness" a bit.
Options.
Options2000 is offline
post #16 of 50 Old 01-03-2007, 09:01 PM - Thread Starter
avr5700's Avatar
You win the award for first independent opinion to post!
Of course you'll probably know that lots of people also describe bright as detailed, even crisp/clear. As a reference, I own Axiom M80s and the audio community albatross of that brand is that it is 'bright', an opinion too which I never subscribed.
Anyway, I count detail as a positive when it is not overweighted in comparison to the remaining frequencies. Do you consider the bass or mids to be recessed at the same time? If not, I would be reluctant to tag these with the 'bright' term...just my two cents.
I hope you do get them adjusted to your liking, but I would advocate listening to them without treble adjustment for a while to see if they break you in (which is actually what some say 99% of break-in really is...haha).
Nope, I'm using them in a stereo only setup. The driver difference in the center would also concern me a bit. Then again that size isn't uncommon in centers. It would be nice to know if the mid/bass drivers use true phase plugs though. I doubt they do but would you mind checking for that when you go to listen?
I received the second pair today. Running them A+B provides a 3dB gain at the same volume setting...a nice little boost plus the flipped stacked orientation creates a makeshift D'Appolito driver configuration which may provide associated advantages.
avr5700 is offline
post #17 of 50 Old 01-03-2007, 11:12 PM
Yes, it appeared that bass/mids were recessed as compared to Polk. However, Polks pack a lot of bass in their size so the ARs may be fine when compared to other speakers. Yes, I too consider detail as a positive which is a big plus for ARs (in addition to price).
This is one of the adjustments I will make. Additionally, will play with the equalizer as I had originally tested it right after the auto install. Polks also were auto installed.
Another observation I made. The (auto) level settings for these were a few dB higher than Polks. This is consistent to what you observed in your comparison with B&Ws.
Options.
post #18 of 50 Old 01-04-2007, 05:12 AM
I'll certainly take a look.
Just to make sure, based on your definition, the difference is that the plug should not be attatched to the cone, correct?
post #19 of 50 Old 01-04-2007, 03:16 PM - Thread Starter
avr5700's Avatar
Thanks, and yes, the plug should not be attached at all.
Edit - Looking at the J&R image, the center seems to have the same golden outline which matches the XP62's cone, making me think it is also a true plug design. Surprising if so. How many budget speakers offer this feature nowadays?
avr5700 is offline
post #20 of 50 Old 01-07-2007, 01:33 PM
Looked at it in person, and it seems to have the same design- gold ring, and it didn't seem attached.
The floorstander model from this line has the same midrange drivers as the center- 4" with plug. They're also quite thin, and the 10" driver is on the side.
post #21 of 50 Old 01-07-2007, 02:19 PM
Groch's Avatar
My ARs finally arrived between Denver snowstorms after having ordered them on the 16th. Had some time on my hands so I performed minor surgery on the X62s and posted the results below.
There is a single H brace glued to grooves on both sides of the cabinet. I was sorry to see the back of the cabinet is the rounded plastic you see in the other photos/ no mdf to back it up. I see some air core inductors in the crossover. Sides seemed to be 1/2" to 5/8" MDF...the front perhaps a bit thicker.
Woofer and tweeter had hefty magnets with large shielding plates...woofers frame is plastic. I will post additional photos and first sonic impressions in the next post, but I am not sure how the photos work yet so thats all for now.
Groch is offline
post #22 of 50 Old 01-07-2007, 02:37 PM
Groch's Avatar
Attached below are a shot of the AR 62 woofer, and another woofer that was constantly underfoot for comparison purposes.
Cabinet build quality was typical of what to expect in the $50-$150 each range. I think it was not too different from the last cheap Chinese speakers I opened up recently, the Best Buy Insignias.
The drivers and crossover seemed more substantial than the Insignia.
The speakers have not burned in yet so I will be very cautious in my analysis. Bass is very good for a speaker this size and price. Quick, well defined, deep, and pretty tight. Despite the rather cheap cabinet I do not hear any evidence of resonances....I think modern computer analysis of cabinet designs allow for lighter cabinets without significant ill effects than was true 10 years ago.
Crossover to midrange seems smooth and imaging is quite good. I like it.
Tweeters are quick and detailed with pretty even spread pattern, but I do not like the brightness...definitely a thinner mid base than my reference speakers in this room and the high range seems elevated 1.5 to 2 dB or so across the range. I am expecting that as the woofer flexes a bit this difference will become less.
My usual speakers are ACI Sapphire XLs...similar size driver complement but a much higher end design. They are on loan so I can not directly compare, but I do hear a significantly brighter tonal balance with the ARs, even through my SP3 Onix amp which is pretty mellow.
My guess is that if I had tone controls and could pad the high end down a notch I would be quite pleased...perhaps break in will do that.
Note on the woofer size- The cone area to the start of the surround measures 4 1/4", total visible area including the surround is 5.5" which looks to me to be the same size as the Revelator woofer on my Sapphires. ACI calls it a 5.5" woofer, AR calls it 6.5" so they are measuring to the edge of the plastic basket (under the foam). I'll measure the Sapphires when I see them again but I think this is accurate.
Groch is offline
post #23 of 50 Old 01-07-2007, 07:15 PM - Thread Starter
avr5700's Avatar
Groch:
Thanks for the interior pictures! They are very nice/informative. Interesting that the basket is plastic. At least it appears to be a rigid design.
I had measured the mid/bass driver as you did but when I then measured the DM601, M80ti, and older SVS 12" drivers, finding them to consistently leave off 1" from the spec, I figured it was an industry standard. If so, driver measurements often include the basket mounting flange, accounting for the observed deviation.
I'm also wondering too what degree a break in period alters frequency response. My second pair arrived four days ago and was immediately put in service while flipped and set atop the first pair. Soon after, I heard excessive peaks when listening to Keri Noble's 'Fearless' CD. Switching to just the first pair, things improved. Moving the new pair back to a normal orientation and playing them solo, the peaks again seemed to reduce somewhat, presumably due to external acoustics likely coupled with an axis response variation. It's not surprising that positioning would be influential.
I'm now running the second set in to see what happens as time passes. I wrote the OP assessment based on a pair that was run in for about thirty hours so after about a week I'll know more and plan to post an update.
masteraleph:
This comfirms that all the XP mid/bass drivers share a true phase plug design. Did you listen to them and/or buy anything for an in home demo? Adding comments of any type regarding the XP62 herein is appreciated!
avr5700 is offline
post #24 of 50 Old 01-07-2007, 11:31 PM
JohnR_IN_LA's Avatar
How well do the ARs handle power? when do the tweeters start sounding stressed, compared to whatever else you have to compare them too ?
Also, how would you rate the ARs aesthetically, compared to other speakers?
thanks
JohnR_IN_LA is offline
post #25 of 50 Old 01-09-2007, 09:36 PM - Thread Starter
avr5700's Avatar
Power handling is good by my estimate. Using highly compressed popular music, I've turned them up a bit past 100dB at my listing position for short periods. I don't want to push them too much more than that. Once they reach loud levels, I start looking for the invisible sub. Based only on the specs, it should be possible to reach peaks of 109dB at 1 meter anechoic. However, I do believe the sensitivity spec is higher than actual, as has been noted twice in this thread. I suspect it is closer to 86dB vs the claimed 88dB. That said, they should get plenty loud in all but large rooms which challenge all similarly sized speakers. Since I have not driven them to their physical limits, I have not noted any point at which there is audible distortion, much less a stressed tweeter. I'm not exactly sure what a stressed tweeter would sound like, short of a strong but short spike followed by the complete loss of high frequency reproduction...
The vinyl finish is consistent and of good quality. Under scrutiny, seams meet up with just good to average alignment. They look like most faux wood black boxes I've seen before without appearing to be cheap.
avr5700 is offline
post #26 of 50 Old 01-10-2007, 05:17 AM
Groch:
masteraleph:
I did end up getting a pair of XP62s plus the center channel (had a discount, so came to around $140 including tax, $130 before). Haven't hooked up the center yet, as I had less cabling than I thought I did/I had to move my receiver and it's now across the room. There's a set of ARVP25s on the way for surrounds, as well.
Overall, I have to confirm what people have said as well. The bass is pleasant, though there is a definite drop out point, and if you listen to a lot of stuff with bass you'll want a sub. I'm actually really a fan of the highs. They're probably a tad bright, which may work itself out, but they sound quite nice. Cymbals sound clear, which is always a big test for me. I'd definitely call this set a keeper.
Note that while they're not particularly heavy, they're also not particularly light. If anyone else picks them up from J&R and is getting something else (another set, center), and plans on schleping them on the subway, bring someone else with you to help.
post #27 of 50 Old 01-12-2007, 10:35 AM
avscienceforurm's Avatar
For some photos of the little brother/cousin of these speakers and an initial miniature review of the ARVP25s, check out my post (#40) in the following thread:http://www.avsforum.com/avs-vb/showt...25#post9326053
avscienceforurm is offline
post #28 of 50 Old 01-14-2007, 09:38 AM - Thread Starter
avr5700's Avatar
Ok, I've run in the second set long enough to conclude that the initial brightness does reduce somewhat. What could be ear flinching peaks, lost the flinch response. Both of my XP62 pairs now have the same characteristics given the same setup. However, I have not measured the second set with my meter and have no plans to do so at this time. In the process I ran the new pair on a second amplifier (Sony TA-F707ES) to see if this had an obvious impact compared to the Technics. It did not seem to change things in any way I could readily identify.
Selections tested in the initial post do not seem to push the highs as significantly as some recordings. A good example of more peaky material is the previously mentioned Keri Nobel 'Fearless' CD. Playing that CD on the B&W's also creates a heightened sense of high frequency response. So my conclusion is again that compared to the DM601 S2s, the XP62s are remarkably similar..yes, even bright, in the way the DM601s are bright. Call it detail if you don't mind the DM601 sound. I would say that compared to a set of Axiom M80s, the DM601s and XP62s are brighter. Of course my M80s are in another, larger room with some acoustic damping, so take that with a grain of salt.
The major amendment to my initial assessment is that this perception of brightness is the primary weakness of the XP62 so far as mass appeal is concerned. Even I will be tempted to use the treble adjustment on select material. For the time being, I choose to view this as the speaker's unforgiving nature versus a truly unbalanced tweeter response. I expect only a professional response analysis could effectively settle the issue.
avr5700 is offline
post #29 of 50 Old 01-19-2007, 05:00 PM
cyberized's Avatar
Quoted: 32 Post(s)
These appear to be strictly Bookshelve speakers - RIGHT? OR - is there a way to mount them on a wall? In the photos I see nothing that would indicate wall mounting is an option??
TKS Michael
cyberized is offline
post #30 of 50 Old 01-19-2007, 06:16 PM - Thread Starter
avr5700's Avatar
These would need a creative solution for any kind of wall mounting. The rear port would cause some extra stand-off needs. Only the top, bottom and sides seem like viable attachment/support points. It should be possible to drill into those, if need be. I wouldn't trust the plastic housing on the back to provide adequate support on its own. These really are most at home on stands. It's a shame AR didn't keep the nice VP bookshelf mounting features...that was a definite step backward.
avr5700 is offline
Reply Speakers
