SANUS SYSTEMS BF-31B Wood Speaker Stands - AVS Forum
post #1 of 6 Old 12-29-2006, 09:10 PM - Thread Starter
yida's Avatar
has anyone bought these stands from amazon?
http://www.amazon.com/gp/product/B00...outThisProduct
i was wondering if they come in a pair or just one? its very confusing, the title says STANDS but the picture shows one only
thanks
yida is offline
post #2 of 6 Old 12-30-2006, 03:15 AM
einsteinjb's Avatar
thanks
Yep, I got 'em. You're right, it is confusing. They're sold in pairs, so if you need two just buy one set. They're cheap, look fine (for the price), they're solid enough, easy to put together. My Ascend CBM-170SEs are quite happy on them. The reviews on the page list various complaints but they're being utterly nit-picky for $30 a pair!! You usuallly can't touch a decent set of stands for less than $100 a pair.
einsteinjb is offline
post #3 of 6 Old 01-07-2007, 12:47 PM
geezerebenezer's Avatar
How big is the platform for the speakers? I bought the insignias, and want to make sure that they fit.
geezerebenezer is offline
post #4 of 6 Old 01-07-2007, 04:45 PM
axs
axs's Avatar
Top plate is 5" x 5". You will be fine with these stands.
axs is offline
post #5 of 6 Old 01-07-2007, 07:00 PM
JohnR_IN_LA's Avatar
I couldnt use the spikes that came with them, on my carpet (lousy spikes).
They were shaky with my extra large bookshelf speakers (RS-150). but I used em anyway.
In 2 years, one stand has toppled once, and it did damage the speaker slightly.
I still use em, but just beware, that they can be tippy if they are one carpet. These stands are for either light speakers, or owners that are willing to accept a bit of risk ....
JohnR_IN_LA is offline
post #6 of 6 Old 01-07-2007, 08:14 PM
axs
axs's Avatar
Rockets are generally heavier than most other speakers. These stands are rated for 15lbs and Insignias are about 13lbs.
axs is offline
Reply Speakers
User Tag List
