Gallo Adiva vs Orb Mod1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-31-2006, 01:19 AM - Thread Starter
DS
DS's Avatar
I have a pretty small room (11 x 13) that I will use for HT and also live in a condo, so can't disturb neighbors too much TV is Panasonic 50" 9UK.
I've read all the posts on Gallo and Orbs but still not sure which one is a better choice. 50% movies / sports , 30% just watching TV, and 20% music.
I am down to the following choices:
Orb: 4 mod1 and 1 mod2 for center + super 8 sub
Gallo: 5 Adivas + TR-1 sub
Value: Gallo system is about 1/3 more expensive than Orb including 5 wall mounts and shipping
Orb has a better sub (although I can't play my system that loud, so may not be a big advantage). I did install base shakers in my couch to compensate. Orb is also a few hundred cheaper
But for Orb, need to do a crossover at 150, worried that may be an issue especially for music and not all receivers support that. Thought about getting mod2s instead of mod1s but they don't really improve the crossover frequency.
With Gallo Adiva, can do crossover at 100 and feel better about it (80 may be pushing it).
Based on specs, Gallo Adivas should give me better overall sound since they go down to at least 100. In practical terms, don't know if the Orb sub can compensate enough to hide the high crossover.
Am I missing anything?
DS is offline
post #2 of 6 Old 12-31-2006, 02:47 AM
tonygeno's Avatar
Quoted: 134 Post(s)
Liked: 37
Yeah, listening to them for yourself.
Tony
In search of the Holy Grail.
tonygeno is offline
post #3 of 6 Old 12-31-2006, 06:46 AM
ericgl's Avatar
Quoted: 25 Post(s)
Liked: 24
I can't see any reason to expect the Gallo sats to reproduce any lower than the Orbs.
ericgl is offline
post #4 of 6 Old 12-31-2006, 09:23 AM - Thread Starter
DS
DS's Avatar
Gallo Adivas are larger (5") than the Orbs and rated to about 85 hz with wall installation (but probably closer to 100 hz). They theoretically should sound fuller than the Orbs.
Gallo Micros (4") are the ones that are about the same size as Orbs, going down to around 150 hz
DS is offline
post #5 of 6 Old 12-31-2006, 09:40 AM
Russdawg's Avatar
I have listened to both for a long, long time. I wound up buying a couple complete sets of the Orbs. This is my opinion only but the Gallo's defintely do not sound better and especially at the price they charge for them...Good Luck.
Oh one other thing, the Orb Sub absolutely smoked that thing I was listening to with the Gallo's.
Russ
Russdawg is offline
post #6 of 6 Old 01-02-2007, 12:43 AM
bigbaldguy's Avatar
http://www.cabasse-usa.com/english/eole/
The Eole builds on the previous Xo2 -- which was a world class point-souce speaker similar in form factor to the ones mentioned so far in this thread.
Good listening,
John
John Caldwell
President
Grace Motif, Inc
Scottsdale, AZ
www.gracemotif.com
tel: 480-463-4248
fax: 805-856-2212
bigbaldguy is offline
Reply Speakers
