Where to find cheap speaker cables? - AVS Forum | Home Theater Discussions And Reviews
Old 01-08-2007, 09:40 PM - Thread Starter
Zurion's Avatar
Hi there,
I wanted to get some new speaker wire, and was looking at monoprice dot com since they have really good deals, but they are out of stock and have been out of stock for awhile. Are there any other comparable online shops with comparable prices to monoprice? I'm looking for either 10 or 12 gauge.
Zurion is offline
Old 01-08-2007, 09:43 PM
armystud0911's Avatar
Our home depot carries 12gauge speaker wire for 55cents per foot. That doesnt come close to monoprice though.
armystud0911 is offline
Old 01-08-2007, 09:46 PM
louthewiz's Avatar
louthewiz is offline
Old 01-09-2007, 09:57 AM
Tnilsson's Avatar
Liked: 25
Frys (I think they also have an internet site) sells 12-gauge wire for 40 cents per foot.
Tnilsson is offline
Old 01-09-2007, 10:41 AM
steve71's Avatar
Quoted: 72 Post(s)
Liked: 36
Home Depot "HD-14" cable works out at about 33c per foot. Incredible sound for the price IMHO.
[edit] BTW it's "only" 14 gauge if you must have 10 or 12. But then again you can always combine all three 14 gauge strands and run two lengths per channel. Of course that will double the price
steve71 is offline
Old 01-09-2007, 11:40 AM
oztech's Avatar
Liked: 101
blue jeans has belden very reasonable in 10 or 12 awg
or canare if you like to go big and round good quality
and snake oil free.
oztech is offline
Old 01-09-2007, 02:41 PM
dobyblue's Avatar
Monoprice has good prices on 12 gauge cable.
http://www.monoprice.com/products/su...d=10239&style=
$24.95 for 100 feet! You can't beat that.
They're currently out of all speaker wire though, so if you can't wait until the end of February, RamElectronics might be your next best bet.
http://www.ramelectronics.net/html/s...cable.html#zip
$46.15 for 100 feet of 12 gauge.
dobyblue is offline
Old 01-09-2007, 05:34 PM
homerj105's Avatar
I just picked up 100 ft of 12 guage for $36 plus shipping from pacific cables ###com
Someone else here recommended them...
homerj105 is offline
Old 01-11-2007, 03:48 PM
chappy16775's Avatar
I just picked up some 16 Gauge Monster THX. Yes I overpaid ($20 for 50') but will this cable be OK for my Onkyo 604 and Athena Micra setup?
Just want to make sure I'm not spoiling the system with cheap cable.
chappy16775 is offline
Old 01-11-2007, 04:16 PM
ericgl's Avatar
Quoted: 25 Post(s)
Liked: 24
I think you'll be fine.
ericgl is offline
Old 01-11-2007, 06:34 PM
davidpa's Avatar
davidpa is offline
Old 01-12-2007, 07:09 PM
MauneyM's Avatar
Quoted: 78 Post(s)
Liked: 38
12 gauge Home Depot cable (the stuff on the reel - made by Carol) is FAR better speaker cable than the 16 gauge Monster...and far less expensive.
MauneyM is offline
Old 01-12-2007, 11:32 PM
But can you really hear a difference in a 5.1 system in a 12x12 room?
Hope not...
Old 01-13-2007, 12:13 AM
Soransis's Avatar
Hope not...
I think the response was more about saving you money rather than getting you better quality. Can you tell the difference? Probably not, but you CAN feel the difference on your wallet.
Soransis is offline
Old 01-13-2007, 12:16 AM
louthewiz's Avatar
