Official AV123/Onix Owners Thread: TECHNICAL TALK ONLY - Page 58 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1711 of 1738 Old 12-31-2012, 03:30 AM
AVS Club Gold
Mike_WI's Avatar
Originally Posted by T.Wells View Post
Hi,
I have a quick question about my RS150s. I am looking to move them into my theater to use as height speakers as I would like to move to an 11.2 setup. Is there any problem with laying this speakers on their side to help keep them as high as possible? I know they may be a bit unstable but I can "prop" them up with something as they will be located behind the screen and won't be visible.
Also, while I am posting, I am looking to add a pair of Rockets to complete my 11 channel setup. I would prefer a floor standing set (rosewood preferred but not required) to use a my L/R speakers. So, if anyone has a pair they would like to sell, I am interested. Just drop me a PM.
T.Wells
For used AV123 speakers you might check the for sale parts of the following forums -- AVS, Chase Home Theater, and Emotiva. You can still see some occasional AV123 activity there.
Mike
Mike_WI is offline
post #1712 of 1738 Old 12-31-2012, 07:02 AM
T.Wells's Avatar
Mike
Thanks. I was not familiar with Chase and Emotiva.
T.Wells
T.Wells is offline
post #1713 of 1738 Old 02-15-2013, 06:43 PM
1qaz2wsx's Avatar
I'm trying to locate an owners manual for the Onix Reference One MKII speakers; lost mine a couple years back. Can anyone help?
Thanks Allan
1qaz2wsx is offline
post #1714 of 1738 Old 05-21-2013, 11:23 AM
xo151's Avatar
Sorry to bring up an old question. I have a pair of RS850 sigs and a RSC200 center. Unfortunately, the RSS300 are too large (to mount) in the room I have now. Did you ever get a response on sides and rears that match with the rockets? I'm looking from something that is relatively small to mount on my walls.
xo151 is offline
post #1715 of 1738 Old 08-01-2013, 06:02 PM
mmereos's Avatar
I've been trying to find replacement 5.25 Atohm drivers for my Onix Ref 2's that were blown a couple of years ago (pressing on the cone makes a scraping noise).
Skiingninja emailed me the name of the importer for the Atohm speakers and I'm hoping I can get replacements.
If I can't get the speakers fixed, should I try and sell them or throw them away and just get new speakers?
Kind regards.
mmereos is offline
post #1716 of 1738 Old 08-02-2013, 04:13 AM
trekker's Avatar
Try Kevin @ Motor City Custom Audio.
trekker is offline
post #1717 of 1738 Old 08-02-2013, 07:28 AM
sandbagger's Avatar
Quoted: 13 Post(s)
Liked: 30
unforunantly I dont have a source for any of the Ref drivers, although I can get tweeters. I also have most drivers for the rocket line
You can try Hugh at Angel City Audio as he might have connections
Kevin
Bringing you Custom subwoofer kits, with flames if you want
Onix and Melody Valve Hi Fi Audio Dealer serving the Midwest and Canada
sandbagger is online now
post #1718 of 1738 Old 12-31-2013, 02:05 PM
slides_316's Avatar
Hello all,
I have been searching the web and this thread for the power handling capabilities of the RS850's and RSC 200. I have consistently found the general specs (FR, sensitivity, ohms, etc) but have no idea how much power these speakers can handle. I ask because I am venturing into purchasing a separate amplifier to drive these speakers but do not want to short-change myself or blow a tweeter/woofer when turning up the volume during movie/music playback.
If anyone has the knowledge as to the RMS watts and peak watts handling or a link to find that information, I would greatly appreciate it! Thanks in advance and have a Happy New Year's!
Isaac
slides_316 is offline
post #1719 of 1738 Old 12-31-2013, 02:45 PM
sandbagger's Avatar
Quoted: 13 Post(s)
Liked: 30
I would not worry about to much power. clean power almost never hurts speakers, its when you clip an amp or plug something like an ipod in hot and you send a spike to it.
anything from 100 to 400+ will be fine
Originally Posted by slides_316 View Post
Hello all,
Isaac
Kevin
post #1720 of 1738 Old 12-31-2013, 02:46 PM
jephdood's Avatar
Liked: 50
I don't pay any attention to wattage ratings for speakers. Generally, the greater harm to speakers comes from UNDERpowering them so that they clip during loud peaks.
jephdood is offline
post #1721 of 1738 Old 01-02-2014, 06:05 AM
slides_316's Avatar
Thanks so much for the reassurance. I had an inkling that I could power them with a quality 300-400 watt amplifier but just wanted to be sure. I read about damage from under powering any speaker leading to clipping, etc. In my research I noticed that many (but not all) speaker companies have been listing a minimum and maximum power handling capability so I developed a case of the doubts.
Thanks again!
Isaac
post #1722 of 1738 Old 03-23-2014, 08:54 PM
ajax-jp's Avatar
Anyone know where to get a crossover for an RS850 Signature? One of my 850's is playing no audio whatsoever, so my guess is that the crossover is dead.
Also, anyone know how to disassemble these things to get to the crossover so I can check it (and check the drivers/tweeter while I'm in there)?
Thanks for any help.
ajax-jp is offline
post #1723 of 1738 Old 03-24-2014, 06:47 AM
tdogroeder's Avatar
Liked: 26
Remove the drivers and you will be able to reach inside of speaker cabinet, I would think it would be on the bottom but not for sure about the location of crossover.
Jesus Christ is the Way, The Truth, and The Life, He is the only Way to God!
Yamaha RXV765
Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15
SVS PB12 plus
Panasonic S65
Sony S5100
PS4, PS3, XBOX 360
tdogroeder is offline
post #1724 of 1738 Old 03-27-2014, 05:52 PM
ON IN II's Avatar
I have a 5 channel system that I am forced to sell as I have moved into a townhouse and have to go to a smaller system and am wondering what you think is a fair price. This is what I have
Rocket RS750 MLS signature edition w/skiing ninja upgraded crossovers and the speaker platforms
RSC200 Bigfoot center
ELT 525 bookshelf speakers
All in Rosewood in very good to excellent contion.
They are in Chico, Ca now but will be at my pops in Sacramento.
They sound incredable especially the 750's as the upgraded crossovers made a huge difference.
Any help would be appreciated.
Ps- I have all the original boxes.
ON IN II is offline
post #1725 of 1738 Old 12-23-2014, 03:49 PM
Aiml3ss's Avatar
Sorry to ressurect an old thread. Question: I have a pair of Onix Reference mkii. I blew BOTH drivers.
Is it possible to order new drivers somewhere?
If not, what is a comparable if not a slight upgrade? Trying to stay under a grand.
Aiml3ss is offline
post #1726 of 1738 Old 12-25-2014, 09:13 AM
point1's Avatar
Quoted: 97 Post(s)
Liked: 30
hi all! Merry Christmas
I was wondering if I can get feedback, I saw this on Craigslist and I was curious if this is something that you guys would consider a good deal for the speakers?
COMES WITH PAIR TOWER ONIX ROCKET MODEL RS850, PAIR SORROUND ONIX ROCKET SPEAKERS MODEL RSS300 AND A CENTER ONIX ROCKET MODEL RSC200. EVERYTHING IS IN GREAT CONDITION NEW IN BOX NEVER USED ASKING $850 OBO
http://orangecounty.craigslist.org/ele/4811507217.html
point1 is offline
post #1727 of 1738 Old 12-25-2014, 09:25 AM
Luis Gabriel Gerena's Avatar
Quoted: 38 Post(s)
Liked: 24
Those are terrific speakers in my opinion (I used to work for AV123 before) and the 850s where probably the best of the rocket towers (I own the 760s and the RSC200 currently). If they are new then I dont see how you can do any better, or even close for $850.
Mike_WI likes this.
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
post #1728 of 1738 Old 12-25-2014, 09:35 AM
sandbagger's Avatar
Quoted: 13 Post(s)
Liked: 30
looks like a great deal to me.
replacement tweeters for the 850/200 is easy along with all the drivers for the 850's
I would say go for it, at that price you cant go wrong if everything works
Mike_WI likes this.
Kevin
post #1729 of 1738 Old 12-25-2014, 09:42 AM
point1's Avatar
Quoted: 97 Post(s)
Liked: 30
thanks for the quick reply sandbagger! Where can I find replacement tweeters and drivers for this?
point1 is offline
post #1730 of 1738 Old 12-25-2014, 10:18 AM
sandbagger's Avatar
Quoted: 13 Post(s)
Liked: 30
I still have a few original drivers for some of the av123 stuff, tweeters are off the shelf at PE
sticknstones likes this.
Kevin
post #1731 of 1738 Old 12-28-2014, 12:19 PM
cdmoen12's Avatar
About the replacement tweeters... I have an Onix Rocket ELT set with damaged tweeters in both the center channel and both front surrounds -- inquisitive toddlers in the house. Are these also off the shelf? Can you tell me what I'm looking for?
cdmoen12 is offline
post #1732 of 1738 Old 12-28-2014, 01:52 PM
sandbagger's Avatar
Quoted: 13 Post(s)
Liked: 30
the tweeters are for the ROCKET and REF series, they are the Vifa XT25TG30-04
I have no idea what the ELT series used.
Kevin
post #1733 of 1738 Old 12-28-2014, 07:46 PM
cdmoen12's Avatar
Thanks for the reply Sandbagger. Any idea how I could figure it out, short of visiting Mark Schifter in prison? I've searching online a bit and haven't found the answer.
cdmoen12 is offline
post #1734 of 1738 Old 01-03-2015, 05:19 PM
AVS Club Gold
Mike_WI's Avatar
I have similar speakers.
Purchased in the AV123 heyday.
They sound great and I frequently get positive comments on the audio in my home theater.
Mike
Mike_WI is offline
post #1735 of 1738 Old 04-08-2015, 02:09 AM
average_joe's Avatar
As stated earlier in this thread, the Ref 1 Tweeters are Vifa XT (now Tymphany) XT25TG30-04 available at parts-express.com.
http://www.parts-express.com/tymphan...eter--264-1016#
The mid/woofers in the Onix Ref 1 are 5.25" Atohm LD130 CR04.
Here is link to a supplier in France. http://www.audiophonics.fr/en/hifi-a...cm-p-2252.html
I don't know a US supplier.
average_joe is offline
post #1736 of 1738 Old 05-05-2015, 06:37 PM
ON IN II's Avatar
Anyone know where I can get a replacement tweeter for the AV123 ELT525M speakers?
Someone bought mine and in shipping one of the tweeters was busted in half.
Just trying to find a replacement.
ON IN II is offline
post #1737 of 1738 Old Today, 09:15 AM
jsjenkins's Avatar
Liked: 0
Can someone with Onix Rockets tell me what size and thread pitch the floor spikes are on these speakers? I've lost my original brass floor spikes and am trying to source a comparable replacement. The standard 1/4" floor spike is too small. I'm really hoping it isn't a proprietary size..
jsjenkins is offline
post #1738 of 1738 Old Today, 10:01 AM
sandbagger's Avatar
Quoted: 13 Post(s)
Liked: 30
I believe they are M6
I dont have any rockets anymore but you could run down to HD or Lowes, grab an M6 and a M8 bolt and see what threads in, but my guess its an M6 as Parts Express sells M6 spikes
Kevin
Reply Speakers
