Infinity Beta Owners - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
Old 10-06-2007, 04:26 AM
96redformula's Avatar
I receive my eD a2-300 within a week or two, but for music the beta 50's are so well balanced and clean. I am not sure I will use the sub for music listening yet.
96redformula is offline
Old 10-06-2007, 07:06 AM
ams123's Avatar
Quoted: 24 Post(s)
Originally Posted by ams123 View Post
Well I am looking for a little feedback. I have always owned loudspeakers, currently selling a pair of DCM KX 12's. I don't have room for them anymore so I am looking a buying a pair of Beta 20's and figure I need a sub to go with them? My main interest is music but I also use them for DVD's but obviously I am not setting up surround system at the present time.
Is my assumption correct about needing a sub?
The audio video source has the PS10 on sale, would that be a good match?
If not what should I look into?
Well I got my Beta 20's set up last night and they are a great bookshelf speaker and the bass is better than expected but they just cannot reproduce the driving beat of a bass drum. I miss that so I expect I will buy the PS 10 since The Audio Video Source has it for such a good price.
ams123 is offline
Old 10-06-2007, 11:05 AM
Their are much better choices for subwoofer's for the same price. You might want to consider other companies for a subwoofer as the brand is of relatively less importance for subs.
Old 10-06-2007, 11:31 AM
iolmaster's Avatar
I'm not sure how much better he can do for $169.00. I would agree that the PS 10 is not a great sub, but I would argue that it is a decent sub.
iolmaster is offline
Old 10-06-2007, 11:59 AM
ams123's Avatar
Quoted: 24 Post(s)
I am open to suggestions. I had read some positive comments on Dayton Audio sub from parts express.
http://www.partsexpress.com/pe/pshow...3&ctab=15#Tabs
I don't want to spend a lot but would consider up to $250 or $300. The PS-10 for $169 just looks like it would be a great deal.
ams123 is offline
Old 10-06-2007, 01:09 PM
jmps's Avatar
You can get a HSU STF-1 for $254 on sale.
jmps is offline
Old 10-06-2007, 02:40 PM
ams123's Avatar
Quoted: 24 Post(s)
Thanks, did some more reading and found a lot of people likes teh HSU STF-1 and BIC Acoustech H-100.
ams123 is offline
Old 10-06-2007, 04:07 PM
GLBright's Avatar
Quoted: 65 Post(s)
Liked: 85
Originally Posted by aboroth00 View Post
Subs aren't just about playing the lowest notes. Having a sub in your system for plain music listening also changes your soundstage even at times dramatically. The Beta 20's do have plenty of bass and might even be called bass heavy. Just, take a look around at other selectoins.
I agree with all you have said. But although the Beta 20s may be bass heavy, they certainly can't be called "Bass deep". And certainly not at higher volume levels. BTW I love my Alpha 20s.
HT: Onkyo TX-SR702,Infinity IL60s/IL36c,LG PF1500,Draper92"screen,SonyBDP-S570,Dish622
Stereo1 Denon PMA-630 amp,TechnicsSL-1300TT,ToshibaSD-4960 uni-player,Infinity Overture 3s
Stereo 2 OnkyoTX-8222,HitachiHT-61S TT,YamahaDV-S586 uni-player,Large Advents (1972)
GLBright is offline
Old 10-06-2007, 04:38 PM
Given that price range I would probably consider the Bic H-100 for $230 shipped @ ebay, for $300 eD A2-250, for $350 the eD A2-300. If you want a nicer finish than eD and willing to sacrafice a little bit of sound compared to the eD, then go with HSU as somebody already mentioned.
Old 10-06-2007, 05:49 PM
ams123's Avatar
Quoted: 24 Post(s)
Yea the sub will be in plain view and that eD is ugly. I am settling on the HSU.
ams123 is offline
Old 10-07-2007, 09:52 AM
imagine6's Avatar
I've got the csw-10 to go with the rest of my Beta setup and have never used the RABOS feature. My room is small and this little sub sounds fantastic already, but I'm going to run the RABOS and see if I can hear any difference.
My question is can I use my Radio Shack spl meter instead of the supplied meter and what would the equivilent levels be?
My second question is when setting the master volume from the RABOS test cd, do I turn the sub off or leave it on? I get different levels from each setting. I've got a Harman/Kardon AVR 340 with the cross over set at 60hz for the sub.
Thanks in advance
imagine6 is offline
Old 10-07-2007, 12:07 PM
iolmaster's Avatar
I have a CSW-10 and you should use the supplied meter. It is specific for the frequencies you will be testing. Infinity's statement, not mine. I would also go up to 80 for the cross over. Keep the sub on to set levels.
Old 10-07-2007, 01:38 PM
GLBright's Avatar
Quoted: 65 Post(s)
Liked: 85
Agreed. Leave the sub on. I use RABOS with my Interlude IL60s and can't shut the sub off unless I run it through the LFE outputs on the receiver which I don't do. Oh, and have a spare battery for the meter. It's notorious for chewing up 9 volts and spitting them out drained in no time at all. And follow the RABOS instructions carefully. It is a neat tool for taming a major peak. I have one at 30Hz and another at 60Hz. The manual said go for the higher peak as it is usually more audible. Cutting the 60Hz peak made a for a big improvement in overall sound quality.
GLBright is offline
Old 10-07-2007, 05:58 PM
Megalith's Avatar
Quoted: 20 Post(s)
Are you guys crossing over your Beta 50s at 80hz?
I feel that they don't perform too great at lower crossovers.
Megalith is offline
Old 10-07-2007, 06:50 PM
Mine are crossed at 80hz .
Old 10-07-2007, 08:08 PM
imagine6's Avatar
Thanks for the replies. I adjusted my crossover to 80hz and the sub does sound a little better. My beta 20's and c250 still sound the same, which is a good thing!
I ran the RABOS on the CSW-10 and found that I'm already at a pretty flat response. My room is only 10x13 so the small size must help out. I absolutely love the Beta series. IMO the best bang for the buck out there although I would have never paid retail for the CSW-10. I think when it was new it went for about a grand. I put in a pic for eveyone to view as I love to see them from other people.
imagine6 is offline
Old 10-08-2007, 11:49 AM
Cocahoe's Avatar
My system currently is made up of the following-- Mains- Cerwin-Vega V-10s, Center- Beta 360, Surrounds and Back Speaker- Beta 20s and Sub- Infinity PS-12. The room is approx. 20x18 and all this is driven by an Onkyo 504. I am on the fence about whether to go with the Beta 50s or 40s to replace the Cerwin-Vegas. Any thoughts out there? I would also make someone a great deal on the Cerwin-Vegas. Jim
Cocahoe is offline
Old 10-08-2007, 12:34 PM
Zardnok's Avatar
If you have the space and budget for the Beta 50s, I would definitely go for them. If you go with the Beta 40s, you are going to always wonder, "What if?".
Zardnok is offline
Old 10-08-2007, 05:23 PM
lamot's Avatar
Hello,
I'd like to place 7.1 BETA (50's for fronts, C360 for center, SW12 for subwoofer) in my home cinema room.
I'm not sure what combination is best for 4 rears (2 surrounds for side mounting & 2 surround for back mounting):
(a) are 4 x ES-250 OK or
(b) are 4 x 20's better or
(c) is it better to use for surround 2 x 20's and for surrund back 2 x ES250's or
(d) some other combination.
Any reccomendation or do I miss something if I just buy 4 ES250's what is currently my idea?
Thank you, marco
lamot is offline
Old 10-08-2007, 05:39 PM
Ambrosia's Avatar
Originally Posted by lamot View Post
Hello,
Thank you, marco
best suggestion would be, 2x 50, 2x 20s surrounds, and 2x es250s rear surrounds.
Here's what they look like, everyone can have a nice glimpse of the BETA series.
Really wonderful pictures.
http://www.minhembio.com/produktbilder/12304
Ambrosia is offline
Old 10-08-2007, 05:49 PM
Megalith's Avatar
Quoted: 20 Post(s)
Some of those placements are...well, odd.
Megalith is offline
Old 10-15-2007, 02:00 PM
RandallC's Avatar
Hey folks, great thread.
I've been on the fence about getting new fronts for my system for a while. I picked up a pair of Primus P362's, and while they sound pretty good, I think I want something that has a little more kick to it.
I have a crappy KLH sub from my student days. I almost prefer to just turn it off unless I'm watching an action movie. If I were to return the P362's and pick up a pair of Beta 50's, would I expect to get better bass response?
My setup:
Yamaha RX-V657 (7.1/95W)
8 or 10" KLH sub, I can't remember
Polk Audio CSi3 center
Polk Monitor 40's (I think) for rears
I went on a Polk spree for a while there, but I am very impressed with the Infinity's. I auditioned the P362's right beside a set of RTi10's, the the 362's sounded so clean compared to the bassy (muddy?) sounding RTi10's.
I want the same clarity as the 362's, but with more bass...so will those Beta 50's work?
Edit to say: I will eventually buy a better sub, but if I don't need to immediately my wallet (and neighbors) will appreciate that.
RandallC is offline
Old 10-15-2007, 09:51 PM
rubs's Avatar
Quoted: 63 Post(s)
I have beta 50 fronts, c360 center, athena s.5 rears and hsu vtf-3 sub,
When i use equalizer it set the crossover for front and center at 40 and size large and rears as small and crossover 100. Is this setting looks correct since i read on other posts recommending setting of small as size and crossover 80 for all speakers.
rubs is online now
Old 10-16-2007, 07:17 AM
gabner's Avatar
I've decided on the Infinity Beta series for upgrading my home theater.
I'll be using the the beta 50s for the fronts and the C360 for the center.
Any reason to use the ES250s versus two more 50s for the surround speakers?
I'd like to use the 50s to avoid stands, wall mounting etc. Price isn't too much different between the two. Is there an advantage to using the ES250s? I'm a novice, no idea about bipole, dipole (I thought that was a psychiatric diagnosis).
Thanks for your help guys.
Gary
This was posted originally under the general "speakers" section but thought it would get better attention to beta owners here.
Panasonic TH-50PH9UK
Expressvu 6200
gabner is offline
Old 10-16-2007, 06:46 PM
Ambrosia's Avatar
Gary
Not sure i'm new to this stuff as well, haven't been gotten any help at all from anyone about setting up a a/v reciever and 7.1 system.
Anyways i called a specialized audio shop recently and asked the price of the setup u mentioned which was my intial plan.
But the guy told me he never heard of such a setup.
Logically i think that the 20s would be better or the es250's for surrounds since that's what they specificially designed for.
I'm not sure but i think if you used the 50's they wouldn't come off as they should compared to the *real* surround speakers.
Having 6x 50s and 1x c360 would look alot better imo, but if you think about it it doesn't make much sense to use large speakers at the back.
Because you want the sound to be natural and hear it exactly to what youre seeing on the tv.
Hope that helps...
Ambrosia is offline
Old 10-17-2007, 02:55 AM
lamot's Avatar
It seems that we are three now (Ambrosio, gabner, me) who are relatively new in understanding these things ;-)
To me it seems that there is no clear advise which one is better to use for surrounds and back surrounds. ES250 or 50s or 20s ? I'm still not sure whether to buy ES250 or 20s for side surrounds.
For surround back I've already decided on ES250. And I think I'll buy ES250 also for surround side. However I'm a little bit nervouse because I've haven't found clear advice in the manner of "yes, 250 is better for surrounds" or "it doesn't really matter whether ES250 or 20's" ....
lamot is offline
Old 10-17-2007, 06:57 AM
iolmaster's Avatar
50s in the back is major overkill.
Old 10-17-2007, 10:06 AM - Thread Starter
rsalexan's Avatar
...However I'm a little bit nervouse because I've haven't found clear advice in the manner of "yes, 250 is better for surrounds" or "it doesn't really matter whether ES250 or 20's" ....
Im not an expert in this but here's what I've heard different times on AVS: Since the 20s are direct radiators, they would be better for multichannel music. The 250s are not designed to be direct radiators, more like diffusers (indirect radiators) and are therefore better with movie surround duty.
With music you'll want to localise sound, with movies...not so much.
If you plan on watching significantly more movies than listening to multichannel music then I would seriously consider the ES'.
One other thing, if you do go with the 20s keep in mind that they are rear ported and thus the rear cannot be placed directly against a wall. You need 4" clearance at minimum.
Though I watch movies I went with the 20s as rears in my 5.2 system, since the ES' don't come in cherry.
rsalexan is offline
Old 10-17-2007, 12:21 PM
Ambrosia's Avatar
All the reviews i checked used 50/40, c360, 20s and es250s in that order of setup.
Also after reading the description on infinity's website it becomes more clear to why.
I went with 50, c360, 20, 20 myself they could arrive on Friday.
Ambrosia is offline
Old 10-17-2007, 04:07 PM
mbaxter's Avatar
The C360 center seems to be well-designed for dealing with lobing & off-axis listening. Has anyone had a chance to compare the C360 with other similiarly priced center channels, such as the Polk Csi5, Klipsh Synergy III, JBL LC1, etc?
mbaxter is offline
Denon Avr 2807 A V Surround Receiver
