Infinity Beta Owners - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #2431 of 2451 Old 01-05-2016, 01:21 PM
baisong's Avatar
Liked: 0
Hi,
Would it be possible you send it to me, how does $20 sound? I can pay through Paypal.
Please let me know if the price is okay with you, I will send you my address.
Baisong
baisong is offline
post #2432 of 2451 Old 01-15-2016, 05:29 PM
thebove's Avatar
Anyone have a pair of ES250's still kicking around that they are looking to part with? Black preferably, but for some reason the white ones seem to be more prevalent. They're all pretty hard to find these days though.
I currently run a 7.1 setup using a pair of cherry Beta 50 fronts, a cherry C360 center, and 4x black Beta 20's for surrounds and surround backs.
But, I'm doing some re-arranging, and will be going down to to a 5.1 system instead of 7.1. So, I'm looking for a pair of the ES250s to run in bipole mode. (the main seating area will be all the way at the back wall).
thebove is offline
post #2433 of 2451 Old 01-15-2016, 05:35 PM
toddman36's Avatar
Quoted: 445 Post(s)
Liked: 142
I saw a new pair on ebay this week... But, they were white.
(R&L: Infinity Beta 50) (Center: Infinity Beta C360) (Surround Side & Back: Infinity IW ERS 210 x 4) (TM: Infinity IC ERS 110 x 2) (Sub: Def Tech SC1)
(7.2.2 Config.) (AVR: Denon 4100) (Audiosource Amp 110 for TM's) (BRP: Pioneer 80FD) (Display: Panasonic TC-P65S1)
toddman36 is offline
post #2434 of 2451 Old 01-17-2016, 05:16 PM
Erighan's Avatar
Quoted: 14 Post(s)
Hello all. I currently have a 5.1 setup using Beta 40s, a 250, 10s and a Klipsch 12, all running off an older Denon received. I just bought a new 7.1 Atmos Denon received and was looking to make a 5.2.1 setup. My room is oddly shaped, so a 7.1 won't work well.
Any thoughts on adding some Atmos speakers? Or, do you think I should save my money and upgrade pieces of my current setup? I can spend around $300-400.
Erighan is offline
post #2435 of 2451 Old 02-28-2016, 11:12 PM
rlb4's Avatar
Liked: 27
I currently use 2 Beta 50's and a Beta 360 for my LRC and 2 Beta 10's for my surrounds. I have an Onkyo 818 receiver and Hsu sub. Room is 18' long x 11.5' wide. I use the Beta 10's on the side wall. I plan on getting 2 Beta ES250's to replace them on the side walls(in bipole mode). My question is should I use a 3rd Beta ES250(to provide both channels) on the back wall for 7.1 or my 2 Beta 10's? Which would sound better? System is for HT only.
rlb4 is offline
post #2436 of 2451 Old 02-29-2016, 05:19 AM
GLBright's Avatar
Quoted: 68 Post(s)
Liked: 87
I'd use two Beta 10s high in the rear corners. The newer uncompressed audio codecs have discrete rear channels that I believe benefit by being separated by the width of your viewing area. That's the way I do it, with bipole side surrounds and small Infinity Primus 142s in the rear corners (elevated 6.5 feet).
HT: Onkyo TX-SR702,Infinity IL60s/IL36c,LG PF1500,Draper92"screen,SonyBDP-S570,Dish622
Stereo1 Denon PMA-630 amp,Technics SL-1300TT,Toshiba SD-4960 player,Infinity Overture 3s
Stereo 2 Onkyo TX-8222 rcvr,Pioneer PL-3000 TT,YamahaDV-S586 player,Large Advents (1972)
GLBright is offline
post #2437 of 2451 Old 02-29-2016, 07:12 AM
rlb4's Avatar
Liked: 27
Most diagrams that I see have the back rears close together. Do you think it makes much of a difference whether the back rears are close or separated?
rlb4 is offline
post #2438 of 2451 Old 02-29-2016, 08:34 AM
GLBright's Avatar
Quoted: 68 Post(s)
Liked: 87
I have a feeling that most of those diagrams were made when the "7" channel was a matrix derived single channel as on DVDs, a la DDex or DTS Neo6. Now that the L and R rear channels are discrete in new BD formats I still opt for corner placement.
GLBright is offline
post #2439 of 2451 Old 06-28-2016, 01:55 PM
Liked: 1
I'm running a Denon E-300 receiver with Infinity beta 40's as towers and a c360 for a center. During movie playback, everything sounds fantastic. During music playback, if I leave the receiver set to 5.1, I get really clear music from the center channel, but when I switch it to stereo, things sound muddier/less-defined.
  • I experience this with multiple sources (all hooked up via HDMI)
  • When in stereo mode, this is apparent with any of the various Audysee settings or off
  • Speakers/receiver work great in a friend's house (in 2-channel)
  • Without adjusting for volume, 5.1 is louder than when I switch to 2-channel
  • Does this mean that fronts are more-affected by lack of room treatment than a center (bookshelf on first reflection points on the right and very lightly-covered window on left side)?
  • I did a sweep with REW and all the frequency response seems reasonable, so that combined with physically hearing sound from each of my speakers, makes me think they all work.
Can crossovers start to become poor with age?
Can the large window at my first reflection point REALLY make that much difference?
Does it make sense that the center channel is so much brighter than the towers when switching from 5.1 to 2.0?
thanks in advance guys
95whtgst is offline
post #2440 of 2451 Old 07-22-2016, 05:06 PM
Shock96's Avatar
Woot! Glad to see this thread is still active!
I am finally about to get started on my theater in a few weeks. I have new in the box:
2 x Beta 40
1 x C360
2 x ES250
2 x Beta 20
Brand new, never removed from the boxes!
Anyways, the room design has changed a bit and now the Beta 20's that were going to be on the back wall will be directly above the heads of the rear seating positions. I would like to get 2 in-wall speakers that will be a match for the Beta's.
ERS HV250's are still available as are some of the 210 and 110 models as well. Are these a good choice as far as anyone knows? Phil?
GLBright likes this.
Shock96 is offline
post #2441 of 2451 Old 07-29-2016, 04:40 PM
Shock96's Avatar
Bump
Shock96 is offline
post #2442 of 2451 Old 09-07-2016, 11:32 AM
daveshouse's Avatar
Hi all. Still running Infinity Beta 40's in the front, and an Infinity c360 center channel!
daveshouse is offline
post #2443 of 2451 Old 09-08-2016, 08:03 AM
hopeles117's Avatar
I've got a pair of black ES250's I recently picked up but not sure I plan to use them. Let me know if you're still in the market and we could figure something out.
hopeles117 is offline
post #2444 of 2451 Old 09-11-2016, 03:02 PM
financethis's Avatar
i am looking to buy a set of beta es250s if your selling them pm me
epson 3010 projector
marantz 1402 avr
infinity beta mains, center and surrounds
110" dalite screen
tc sounds pro 5100 subwoofers
financethis is offline
post #2445 of 2451 Old 09-29-2016, 10:11 AM
GLBright's Avatar
Quoted: 68 Post(s)
Liked: 87
Old review. Just found it today. From 2005.
http://hometheaterhifi.com/volume_12...05-part-1.html
GLBright is offline
post #2446 of 2451 Old 01-05-2017, 12:15 PM
emiller1181's Avatar
I've got a H/K AVR 235 (old, I know) with an Infinity Beta C360, a pair of 20's for the R/L, and a pair of 10's for the rear speakers. I've been in an apartment for around nine years, so never needed anything bigger. Shortly I'll be moving into a house with a larger area for the home theater. I plan on upgrading the receiver, but love the C360 and would like to keep using that.
I've looked around briefly for a used pair of 50's, but haven't really found anything promising. I was wondering if there are other speakers out there I could use as the R/L and still use the C360 for the center. I know the front three speakers should really be the same, but I'm not sure that'll be doable.
Thanks guys/gals, I may just use the current setup for another room or something, but I don't want to spend the money on a whole new setup.
emiller1181 is offline
post #2447 of 2451 Old 01-05-2017, 02:25 PM
drunkpenguin's Avatar
Quoted: 1351 Post(s)
Liked: 1369
Are you anywhere near new mexico? Ive got a pair of 50s sitting in a closet, but i dont know if i want to mess with shipping them.
drunkpenguin is offline
post #2448 of 2451 Old 03-27-2017, 06:46 AM
Liked: 0
Just curious if anyone still knows where to find a pair of the 362820-001 Tweeters? or has one lying around they would sell? I cant find one anywhere.
Im in Chicago.
Dale
nacdale is offline
post #2449 of 2451 Old 03-27-2017, 06:59 AM
zryder's Avatar
Quoted: 14 Post(s)
Im in Chicago.
Dale
When I needed to order some, I called Harman directly.
I found this info in my email.
The part is in stock
N362820-001
$30.90 each plus tax (based on your state) and shipping.
Please call us at 888-691-4171 to place your order
Thank you"
Don't quote me on the price, that was a year and a half ago, but hopefully that will be helpful.
"The satisfaction of a great price will be overshadowed by the bitterness of poor quality."
Originally Posted by KO Abear
You still measure your TV in "inches"? Thats so cute! :D
zryder is offline
post #2450 of 2451 Old 03-27-2017, 09:24 AM
it should still be right I got some in November that's what they were.
marantz 1402 avr
110" dalite screen
post #2451 of 2451 Old 07-11-2017, 07:48 AM
Getting ready to sell my Beta 50s, C360 and 2 ES250S if anyone might be interested. I'm in Kansas City
marantz 1402 avr
110" dalite screen
Reply Speakers
Denon Avr 2807 A V Surround Receiver
