Official Anthony Gallo Owners Thread - Page 116 - AVS Forum | Home Theater Discussions And Reviews
 32Likes
post #3451 of 3462 Old 10-10-2017, 08:01 AM
simon wagstaff2's Avatar
Quoted: 23 Post(s)
Liked: 27
Originally Posted by RDD337 View Post
Thanks. Few months ago I tried Denon 4300 AVR and was not happy with the sound. My Pioneer AVR sounds a lot better. So I return the Denon. I'll try Marantz AVR next.
I believe it is the power amp that will make the most difference in sound when using an AVR, despite what other posters may say.
simon wagstaff2 is offline
post #3452 of 3462 Old 10-10-2017, 08:45 AM
jilgiljongiljing's Avatar
Quoted: 16 Post(s)
Originally Posted by Kodak805 View Post
Incidentally, I find the Ref 3.5's work best aimed straight ahead due to the very wide dispersion of the CDT. Towed in they are too bright. I also orient the woofers facing inward for a solid soundstage. This would also help with a close wall placement. However, I augment the bass with a pair of Wilson Benesch Infrasonic Generators and their amplifier/crossover units.
This is quite true, after much experiementation, I found the 3.5's to sound best with barely any toe in at all, firing straight out and the woofers facing in.
3.5's LOVE juice, get a good dedicated power amp and they will absolutely sing. straight out of the AVR they sounded a bit flat when I initially bought them, but switching to Rotel separates just took them to a new level.
jilgiljongiljing is offline
post #3453 of 3462 Old 10-10-2017, 11:20 AM
Quoted: 70 Post(s)
It has too many factors. Nothing is guaranteed to make your sounds better. I guess this what makes this hobby fun. You just have to try and see for yourself. Just hope you don't waste a lot of money finding the right combination In my case I hope Marantz 7011 will give me satisfying sound as I don't have the budget for separates nor space in the house. My use is 50/50 Music & Movies.
RDD337 is offline
post #3454 of 3462 Old 10-10-2017, 11:24 AM
Quoted: 70 Post(s)
Which Rotel amp are you using? Same here my Refs are firing straight and woofers facing each other.
RDD337 is offline
post #3455 of 3462 Old 10-10-2017, 11:30 AM
Quoted: 16 Post(s)
Rotel RB-1590 (2x350W)
post #3456 of 3462 Old 10-10-2017, 11:41 AM
Quoted: 70 Post(s)
You got a really nice amps there. I have a long way to go to reach to your level Someday... What preamp are you using? Did you also add stand to your Refs? Thanks.
RDD337 is offline
post #3457 of 3462 Old 10-10-2017, 11:57 AM
Quoted: 16 Post(s)
I matched it with a Rotel pre.
Regarding stands YES, they really helped because my listening room isn't big and I have the speakers closer to the rear walls. I use concrete blocks as the stand
The best bang for buck upgrade I've done in audio IMO.
post #3458 of 3462 Old 10-10-2017, 01:50 PM
Quoted: 70 Post(s)
How tall is your stand? Most people here suggested 8" high. I don't understand why AG did not make this Ref 3.5 taller if it really makes it sound better. I will raise my speakers to 4" high using the rubber ballistic block that somebody here recommended.
RDD337 is offline
post #3459 of 3462 Old 10-10-2017, 02:25 PM
Quoted: 16 Post(s)
Mine are 6 inch high (standard concrete blocks). I've tried 4 inch (haven't tried 8 since I was happy with the blocks)
My theory is that it is VERY scenario/room specific and hence AG left it at what would work for "most" folks. For me since my rear walls and side walls are close, the sound tightened up significantly and focussed much better. There is absolute control shown across the range now and the response is more even. I've tried it in larger rooms with different heights for varying results.
In my experience, here is my guideline
- If you have less than 2 feet go 6-8 inches depending on your seating position
- If you have more than 2 feet but still have closer walls on the side, 4 will work
- If you have several feet to the walls on both sides, leave them on the floor unless you have bass issues with your flooring
Use the factors below to fine tune
- If you like your bass a bit fuller and louder than the other responses (escpecially for electronic, hip hop, where you want to FEEL the bass) then lower the stand
- If you like tighter imaging, focussed sound, more even response, a bit more sparkle, raise it higher
As always, it helps to experiment with your setup as there are many other factors that will affect the sound. Its quite easy to grab a bunch of hardware of varying heights and do some A/B tests There is no need to spend big bucks on them fancy wooden stands
post #3460 of 3462 Old 10-10-2017, 06:52 PM
Quoted: 70 Post(s)
Yup no plans on buying $800+ wood stand. Ballistic blocks are only $20/ea and looks decent enough in our living room. My speakers are only 1ft away from the front wall and the right speaker is about 4ft away from the side wall. Left speaker has no side wall since it is open to dining area.
RDD337 is offline
post #3461 of 3462 Old 10-18-2017, 03:45 AM
Liked: 0
Unhappy
Hello, I have the problem with my Anthony Gallo 3.5, but dealer in USA said, that they have not any bass driver for repairing my gallo. Is there any other solution? Thank you.
Thanks for your email.
The Reference 3.5 is an extremely capable loudspeaker. I’m sure you will be very happy with them.
Unfortunately, I don’t currently have any stock of new drivers available. The bass driver is unique to this speaker, and although the driver in our subwoofers is very similar, it’s not compatible.
Stephen Pitt
Manager - Product Operations
Gallo Acoustics
Manufacturer of the world’s finest compact high-end loudspeakers
T. +44 (0) 1555 666883
M. +44 (0) 773 6279461
Skype mrstephenpitt
Gallo Acoustics is a trading name of Anthony Gallo Acoustics Ltd
Registered in Scotland SC 538472
Isaac_AG is offline
post #3462 of 3462 Old 10-18-2017, 06:29 AM
Quoted: 70 Post(s)
Stephen Pitt
Gallo Acoustics
Skype mrstephenpitt
Check ebay. Few months ago somebody selling oem bass drivers for Ref3.5. I almost bought a pair to upgrade the bass drivers of my Ref3. Good luck!
RDD337 is offline
Reply Speakers
Anthony Gallo Acoustics , Anthony Gallo Acoustics Tr 3d , Anthony Gallo Acoustics Nucleus Reference 3 5 , Yamaha , Sony , Pioneer Elite , Pioneer Elite 49 Txi Receiver
