Polk speaker? Good or bad - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-23-2007, 12:22 PM - Thread Starter
Xuivo's Avatar
Hi all,
After several month on the TV thread (it's now done), I'm looking to get a good sound. Budget not too high right now, so I would go more with a 2 front speaker setup and a sub with an amp for starters.
Here's some question though. I've read in a lot of post to use the same center as the front speakers to get same sound. Surrond are just for effect, so I'm not worrying about them. If I planned to buy to speaker, is it a bad choice to not get a matching center or I could get another with the same specs later.
And waht are your suggestion? Don't want to go too hogh on price. Futureshop seems to have a deal on Polk M300 (299$, 300$ off they say) and on some Yamaha, and then some athena.
I'm a real newbie on sound, so any good advice appreciated. I'm looking later to get a blueray or HD-DVD, so something that could make me enjoy the sound of uncromprss HD sound would be awesome.
Looking at the end for a 5.1, not a 6 or 7.1.
Xuivo is offline
post #2 of 15 Old 02-23-2007, 01:00 PM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
Your best bet is to go out and listen to those and see what your ears like best.
Is futureshop some local a/v store, or is it a internet store?
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is offline
post #3 of 15 Old 02-23-2007, 01:42 PM - Thread Starter
Xuivo's Avatar
No, it's a big store in Canada, close to Best Buy (Actually, it's own by BB). I could listen to them, but I'm just wandering about quality and experience from others.
It's the M300 or M20 for the Polk.
Xuivo is offline
post #4 of 15 Old 02-23-2007, 01:51 PM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
Polk Audio makes descent speakers, and they have high-end speaker LSi's.
How big is the room the speakers will be in?
post #5 of 15 Old 02-23-2007, 01:59 PM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
You should go in and hear them before you buy them. You should also look at the
Athena AS-F2.s's or AS-F2.1's, $50 cheaper might sound as good or better to you.
http://www.futureshop.ca/catalog/pro...gon=&langid=EN
post #6 of 15 Old 02-23-2007, 02:44 PM
mazersteven's Avatar
I'm not a fan of any other Polk speakers other then the LSi's. The LSi's are like no other Polk.
I know you don't want to spend a lot of cash right now. But I feel there are better speakers and deals out there then the Polk's.
You also might want to ask your question over here
www.polkaudio.com join the club
Here are some speakers I would recommend
http://www.**********/products_catego...akers&brand=55
http://www.**********/products_produc...s&product=23.1
www.ascendacoustics.com
http://www.svsound.com/products-sys-sbs_black.cfm
http://www.svsound.com/products-spks-sbs01.cfm
http://www.paradigm.com/Website/Site...e/systems.html
mazersteven is offline
post #7 of 15 Old 02-23-2007, 05:14 PM
rhunt's Avatar
I have the Polk LSI15's for my main theatre speakers and am driving them with a Hafler D500 amp. They are 4ohm speakers and the Hafler is high current so it gives the Polks the power that they need to really shine.
I Have them bi-wired so the bass is excellent for my room. They actually sound as good as my neighbors Focal 10 something speakers driven by Denon. I hardily reccoment the Polk LSI15's but NOT the LSI25.
rhunt is offline
post #8 of 15 Old 02-23-2007, 05:18 PM
rhunt's Avatar
P.S If you are on a tight budget you may want to look at the Fluance line of speakers. They are mfg. by Polk and I hear they sound pretty amazing for their cost. Only sold on line though. Keeps cost down.
rhunt is offline
post #9 of 15 Old 02-23-2007, 05:37 PM
roscoe1972's Avatar
I believe Polk's M series is their new entry level line. I listened to the similar monitor series, and it sounded OK until I switched over to a Boston Acoustics, then it sounded like mud in comparison.
I own the Polk RTi series and have all bookshelves (Rti6 & RTi4 plus the CSi30 center).
I'm sure the LSi's are great but I can't afford them. I don't even want to listen to them,cause they might make me think my system is crap.
My RTi's, including a subwoofer, make a great home theater. They suit me fine for music also.
Look online for the best deals!
roscoe1972 is offline
post #10 of 15 Old 02-23-2007, 10:22 PM
louthewiz's Avatar
Originally Posted by rhunt View Post
P.S If you are on a tight budget you may want to look at the Fluance line of speakers. They are mfg. by Polk and I hear they sound pretty amazing for their cost. .
That is totally false polk audio does not make fluance speakers ,
so whomever told you that is a liar.
Fluance is based in canada and polk makes their speakers here in the USA.
louthewiz is offline
post #11 of 15 Old 02-24-2007, 05:08 AM
mark russ's Avatar
That is also totally false.
mark russ is offline
post #12 of 15 Old 02-24-2007, 06:16 AM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
Have you went out and listened to any of those speakers?
If you have, what are your thoughts?
post #13 of 15 Old 02-24-2007, 07:12 AM
LuthierJr's Avatar
Go take a listen to them. You can find the lower end polk at any CC. I own a CSi5, RTi6', and I think they sound very clear and smooth. Not harsh at all, and still detailed. Are they the best out there? Of course not, but they are affordable, and much better than many other things out there. If you like them then that is all that matters.
LuthierJr is offline
post #14 of 15 Old 02-24-2007, 11:50 PM
soundlovr's Avatar
If you're Futureshopping, there's a good bet that there's an A&B Sound located in your area (you didn't say where you are). Go over there and have a listen. They carry much better speaker lines (Energy, Totem).
soundlovr is offline
post #15 of 15 Old 02-25-2007, 01:33 AM
wje
wje's Avatar
The RTi line is being replaced with new models, which features revised drivers and a new. The RTiA line will hit stores in May. Ironically, I found little information about these new models on the Polk site (including their forum), but did read the announcement in the new issues of The Absolute Sound. The new cabinets will still offer the real veneer choice, but they will be curved cabinets - sort of like the Onix Rockets. The MSRP prices that were posted did appear to be slightly more than the current RTi line, but not horribly expensive.
I think this should become interesting when they get released. The RTi line has taken some abuse from people who didn't like the sound - and, it will be interesting to see how these fare. BTW, I have owned the RTi8 speakers in the past. To me, I appreciated the detailed sound. When it comes to the LSi line, one would need to get sufficient amplification to get the speakers up and humming. To me, they just don't sound good unless they're getting lots of juice. Then again, I don't think I'd purchase them because I do enjoy lower level listening and I don't think they'd please me.
wje is offline
Reply Speakers
