Speaker for prewired home. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-26-2007, 10:42 AM - Thread Starter
tomaszp's Avatar
I'm new to this topic so I would really appreciate if somebody could help.
My living room area is pre-wired for the speakers and now I would like to install the speakers. What would you guys suggest? Which speakers and from? I'm now really looking for the high end stuff. More on the average side. Which brand would you suggest and where to get them from? What about the installation? Also what would be a good receiver to get?
tomaszp is offline
post #2 of 15 Old 02-26-2007, 10:49 AM
Kal Rubinson's Avatar
Quoted: 771 Post(s)
Liked: 542
Stand alone? In wall? In ceiling? What is your budget? What will be driving them? How big is your room? Help us out.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 15 Old 02-26-2007, 11:10 AM - Thread Starter
tomaszp's Avatar
In the ceiling. I need to get everything, so I don't have anything that will drive them yet. The room size is approximately 20 x 25. The budget would be probably not more then 1000$.
tomaszp is offline
post #4 of 15 Old 02-26-2007, 11:13 AM
kblee's Avatar
Quoted: 65 Post(s)
Liked: 73
Are the in-ceilings just the rear surrounds, or all speakers?
PSN = ChitownJackalope
Blackhawk Down(stairs) Theater
kblee is offline
post #5 of 15 Old 02-26-2007, 11:19 AM - Thread Starter
tomaszp's Avatar
All of them. I have 5 spots where they can be installed (3 + 2).
tomaszp is offline
post #6 of 15 Old 02-26-2007, 12:16 PM
Quoted: 771 Post(s)
Liked: 542
I cannot help you much since I know very little about in-ceiling speakers (except that I dislike them). If you need to have them installed and you are including that as well as a receiver in the $1K total, you may have a tough squeeze. Try a local specialty audiio/HT shop and get a quote.
Kal Rubinson
post #7 of 15 Old 02-26-2007, 12:47 PM - Thread Starter
tomaszp's Avatar
Thanks. May I know why you dislike in-ceiling speakers?
tomaszp is offline
post #8 of 15 Old 02-26-2007, 12:54 PM
Quoted: 771 Post(s)
Liked: 542
Two reasons. They sound terrible and they are in the wrong place for a source of music/voices. You may not care as I do. I'm pretty picky about these things.
Kal Rubinson
post #9 of 15 Old 02-26-2007, 01:36 PM - Thread Starter
tomaszp's Avatar
So if I didn't go for the in-ceiling speakers, what would you suggest to get below 1000$ (500$ preferably)? I would need top go wireless for 2 speakers, but that's ok. I'm open for all possibilities.
tomaszp is offline
post #10 of 15 Old 02-26-2007, 02:09 PM
Quoted: 771 Post(s)
Liked: 542
Sorry, I know of no decent wireless speakers either. As I said, I cannot offer much help. I hope others with a more sympathetic interest might jump in for you.
Kal Rubinson
post #11 of 15 Old 02-27-2007, 07:58 PM
iornsman's Avatar
I am in the same situation as you with my living room prewired for ceiling speakers. However, I have decided to go with flat panels mounted on the wall for the front 3 speakers. Another option is to go with 4 in ceiling and have a front firing center channel. That way you don't get weird imaging with the voices coming from the ceiling. If you go with fronts in the ceiling you will want to get pivoting speakers. You can spend less on the rears if you choose. It may be difficult to stay within your budget and still get decent 5.1 surround.
Speakercraft Aim has a large selection of in-ceiling that pivot. They can get pricey, but check out the lower end of their selection such as the Aim5 one.
Also see the definitive in-ceiling. Maybe the UIW 64/A for the fronts ($349) and the UIW 63/A for the rears ($229).
iornsman is offline
post #12 of 15 Old 02-27-2007, 08:26 PM
mazersteven's Avatar
I have to disagree with the "sounding terrible" part. Like any other speaker there are good and there is bad sounding speakers. Same as in-ceilings. You just might not have auditioned or heard a decent set-up. The right speakers and set-up can make the sound come right out of the television, and not from the ceiling.
But for $1000 for everything I think your better off purchasing the front two and building from there. Or purchase a complete system of bookshelfs. You can get a decent system for right at, or under $1000.
www.speakercraft.com aim series
http://www.nilesaudio.com/product_de...kers&catcdID=1
mazersteven is offline
post #13 of 15 Old 02-27-2007, 09:43 PM
These get mentioned around here alot. I know nothing about them. You need to research yourself. But they are in your budget.
http://www.htd.com/HD-R80?sc=9&category=13
post #14 of 15 Old 02-28-2007, 09:15 AM - Thread Starter
tomaszp's Avatar
Thanks a lot mazersteven.
tomaszp is offline
post #15 of 15 Old 02-28-2007, 10:32 AM
Quoted: 771 Post(s)
Liked: 542
You are right. Every in-ceiling system I have heard, including the Sony corporate screening room at their NYC building, has been grossly disapointing. I will allow for the possibility that good ones might exist.
That is conceptually difficult to accept but, I suppose, it is possible.
In any case, the choice of ceiling mounting is not an accoustic one. It is an acoustic solution to an esthetic choice related to appearance.
Kal Rubinson
Reply Speakers
