The *OFFICIAL* Vienna Acoustics Owners Thread - Page 103 - AVS Forum
 1Likes
post #3061 of 3092 Old 10-12-2014, 07:06 PM
0425antgray's Avatar
Quoted: 21 Post(s)
I plan on buying some Vienna Acoustic Haydn Grands ,and I am not sure which integrated amp I should buy to go with them. My concern was having enough power to drive them, being that they are 4 ohm speakers. I do not want to spend more than $2000 dollars on an integrated amp. I also plan on also buying a laptop to use as my music source. So far I have considered:
1. Rotel RA 1570
2. Peachtree Audio Nova 220
3. Peachtree Audio Nova 125
0425antgray is offline
post #3062 of 3092 Old 10-12-2014, 10:07 PM
artur9's Avatar
Quoted: 103 Post(s)
Liked: 48
1. Rotel RA 1570
I think the Rotel is underpowered for the Haydns given my past experience.
artur9 is offline
post #3063 of 3092 Old 10-13-2014, 03:28 PM
Quoted: 21 Post(s)
Maybe I should get the Peachtree audio nova 220. I am willing to go a couple hundred over my budget If I need to. Any other recommendations for the haydns?
post #3064 of 3092 Old 10-13-2014, 07:19 PM
Quoted: 21 Post(s)
I noticed the total harmonic distortion on the Peachtree 220 se is ( .2 ) Not sure if that would make a significant difference in sound quality. It apparently has much more power than the rotel . 220 @8ohms and 350 @4ohms.
post #3065 of 3092 Old 10-13-2014, 07:41 PM
artur9's Avatar
Quoted: 103 Post(s)
Liked: 48
For an integrated, the Wyred4Sound specs look good but it's a little more than your limit. But I have no experience.
artur9 is offline
post #3066 of 3092 Old 10-13-2014, 08:14 PM
Quoted: 21 Post(s)
Thanks I will definitely check out that one.
post #3067 of 3092 Old 10-14-2014, 01:37 AM
Quoted: 21 Post(s)
Are you talking about the sti 500 or sti 1000? Do you think the sti 500 would be sufficient for the haydns? They look like amazing amps. I would be willing to drop $2,000 on the sti 500. I might be able to get the sti 1000 if you really think thats the one I need to make the haydns sound their best, but $2500 is really pushing it for the amp .
I wonder if I can hook up a laptop to either of these amps? Honestly, I have a ton of cds, so I dont really have to go the laptop mp3 route. I do have a dvd player that I could temporarily use as a cd transport until I get a decent player. But just looking at the connections on the back of the sti 500, I'm not even sure how I would hook up my dvd player to it in order to use the DAC in the integrated amp. It would have to be hooked up digitally right? In order to use the DAC in the amp.
Im still new to all of this. I currently have no equipment and I am trying to build a stereo around the Haydns. My budget for the entire system is anywhere between $4000 - $5000 max.
Ive picked the speakers I want. Now I just need to find the integrated amp and music source. Like I said , I do have a lot of cds. So I would be content just listening to cds, instead of hooking up a laptop.
Any other thoughts would be helpful, thanks.
post #3068 of 3092 Old 10-14-2014, 05:50 AM
artur9's Avatar
Quoted: 103 Post(s)
Liked: 48
Do you think the sti 500 would be sufficient for the haydns? ...
The 500 should be plenty for the Haydns. I'm currently using a 150W@8Ohms/300W@4Ohms amp and my Haydns sound fantastic. The best thing about the STI is that it goes down to 2Ohms which is important for most of the Vienna Acoustics.
The Haydns are very revealing of source material and components so if you really mean mp3 encoded CD vs flac or something you'd be making a big mistake.
Personally, I find using a computer as part of a stereo is a pain . If you're going to buy a laptop you may be better off moving towards a music server. The Bluesound Vault seems like a bargain, especially compared to some of these.
I don't think the Wyred4Sound has a digital input, you're right about that, so it has no DAC. But the DAC in your DVD player should be fine - connect the RCA out from the DVD/CD to the amp.
But I'd suggest a separate DAC since that's such key part of the experience and there are so many very good ones out there. There's a huge list of DACs here and many of them are not so expensive. I use a Bifrost and I'm pretty happy with the sound out of it.
And IMO USB shouldn't be in an audio chain. There's just too many ways to implement it poorly. On the other hand, there's a lot of USB stuff out there.
I find sorting through all the choices in audio fun and I hope you do as well. And the system you build should reflect your priorities.
If you don't mind my asking, what did you compare the Haydns to?
artur9 is offline
post #3069 of 3092 Old 10-14-2014, 08:11 AM
Quoted: 21 Post(s)
Wow thanks for the response. I will definitely check out some seperate DAC's and see whats out there. I think A cd player connected to a DAC connected to the sti 500 might be the way to go for me!
In my speaker auditions I have listened to :
1. Bowers and Wilkins cm6
2. Sonus Faber Venere 2.0
3. Dali Ikon 2 Mk2
4. Monitor Audio GX50
5. Monitor Audio GX100
6. Martin Logan Motion 15
To my ears the Haydns blew me away. They had exactly what I was looking for. They were detailed without being too harsh. They imaged well and had a decent soundstage. And they look great. The other speakers I auditioned to me made their flaws apparent much quicker than the vienna acoustics. The haydns are not perfect , but they are in my price range and compared to the others they do almost everything right for me. I am pretty sure I could listen to them for hours without ear fatigue, given that I provide good components, amp, good music source, etc..
I was also interested in the Monitor audio and Bowers and wilkins speakers. They both were very realistic in sound quality, but too harsh on the high end. The bowers and wilkins had a huge soundstage and were very loud. I listened to them with the rotel ra 1570. At one point in my audition with them I had to tell the dealer to please lower the volume because it was actually annoying. Thats the first time I have ever had to do that. To me that was where the b&w cm6's failed. I understand that room acoustics play a role. But In my auditioning I was really just looking to find out what the character of each speaker was. What makes each one special or gives the music some magic.
The Dali's had a nice 3d or holographic sound stage and actually almost won me over. But after a while I just felt like the speakers sound was just not my cup of tea. They had the ribbon tweeter and did sound bigger than their cabinet would suggest, but they did not captivate me like the Haydns.
Sonus faber just seemed flat and too warm. Did not hear much detail or musical separation between sounds. I don't know, maybe it was the peachtree 220se that caused this too.
The monitor audio had amazing sparkling highs coming from their ribbon tweeter , but it was just slightly harsh, and to me the speakers seemed like they were holding back a little. I was disappointed in their midrange. To me the haydns had better detail in the midrange and lower range.
As of right now I am definitely leaning towards the haydns , but I want to give the Monitor audio gx 100's one more chance just to be sure. To me the haydns were very neutral and it seemed like what I was hearing was very lifelike, and natural. I actually did not know the store I went to even had them. I went to just hear the monitor audio speakers and just happened to see them and asked what they sounded like. As soon as I heard them I was pleasantly surprised. At first the volume was played low, and when he turned up the volume their was no distortion or harshness. The monitors were there as well on the same amp and when they were turned up I could hear them get slightly harsh and color the music.
I found it interesting how some speakers add their own sound to music. To me the haydns just made the music sound real.
Yep so far I am really enjoying this! It is fun doing the research and auditions.
post #3070 of 3092 Old 10-14-2014, 07:32 PM
artur9's Avatar
Quoted: 103 Post(s)
Liked: 48
That's how I feel as well. The Sonus Faber were really good as well, I thought. but when I heard the Haydn's sounding better than the Sonus Faber that was multiples of its price I was sold.
artur9 is offline
post #3071 of 3092 Old 10-18-2014, 05:53 PM
klownshoes's Avatar
Originally Posted by EricPu View Post
<div class="quote-container"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>EricPu</strong> <a href="/forum/post/12073737"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif" style=""></a><br><br>
After just reading a review of the Haydn Grand in the latest copy of Absolute Sound I'm really wanting to listen to them. I am also wondering is they would pair up well with the Parasound P3/A23 combo, which I am also thinking of buying to power them. if not, what would you recommend to power them?<br><br>
I'm starting from a blank sheet so now is the time to buy the corrent components and speakers. In the same Absolute sound they ran a piece on what speakers each one of the editors would buy in the &lt;2K and &lt;2K price brackets. One of the editors chose the Haydn Grand in the &lt;2K bracket. So I'm thinking I should go listen to it at the very least.<br><br>
The other pre/amp combos I was looing at are the NAD and Rotel's.<br><br>
Any advice appricaited.<br><br>
Cheers,<br>
Eric</div>
</div>
<br>
wee little bump, thanks <img alt="" class="inlineimg" src="http://www.avsforum.com/avs-vb/images/smilies/smile.gif" style="border:0px solid;" title="Smilie">
the a23 and p3 would be an excellent match for the haydens. I use the a21 and p5 for my mozarts, and will be upgrading my speakers to the baby beethovens.
klownshoes is offline
post #3072 of 3092 Old 10-19-2014, 11:55 AM
klownshoes's Avatar
Check out Anthem for integrate, and I think Parasound makes an integrate as well.
post #3073 of 3092 Old 10-28-2014, 08:15 AM
Liked: 0
Hi,
What you think about electrocompaniet ec-4.5 & AW250R with VA Beethoven Baby Grand
thanks
gsekhar thompson is offline
post #3074 of 3092 Old 10-29-2014, 08:32 PM
Yamaki's Avatar
Long time VA owner here with two Mozarts, two Waltzs and a Theatro. Been listening to them since 2005 and still enjoy them very much!
Michael
McIntosh/Emotiva/SimAudio/Yulong/Aerial Acoustics/Panamax
Yamaki is offline
post #3075 of 3092 Old 10-30-2014, 09:05 AM
artur9's Avatar
Quoted: 103 Post(s)
Liked: 48
Been changing things up constantly.
I put in a Belles HotRod for the 2 fronts, which are Haydn Commemoratives. Made for a much more pleasing sound than the Parasound multi-channel I had been using.
I put in 2 centers because I could localize one whether it was above or below the screen. I have a Maestro above and another below the screen. Clarity is great and sound seems to come from the entire front wall.
Then I replaced the sides, which were B&W M-1s, with Waltzes. The sense of envelopment in multi-channel is quite a bit more seamless now.
The soundstage I get with Return of the Jazz Communicators isn't quite three dimensional but it is tall and wide with a hint of depth.
Vienna Acoustics are certainly special.
artur9 is offline
post #3076 of 3092 Old 10-30-2014, 10:04 PM
Liked: 0
Is there any folks who had Vienna Acoustics with Electrocompaniet amplification?
thanks
post #3077 of 3092 Old 10-31-2014, 01:39 AM
RoDa's Avatar
thanks
Yes. I've tried a ECI5MkII here at home, and it worked really well with my Mozarts.
Not the same control in the bass as with my Audionet SAM G2, but no problem at all. More power and control with the EC than with a Naim SuperNait.
Regards
RoDa
Rega RP6 w/Exact | Heed Questar MM
ReadyNAS | Logitech Squeezebox Touch | Rega DAC
Audionet SAM G2
Vienna Acoustic Mozart Grand SE
RoDa is offline
post #3078 of 3092 Old 11-13-2014, 08:51 PM
al210's Avatar
Quoted: 80 Post(s)
Liked: 62
Here's my dilemma
I auditioned a pair of Mozart Grand SE and a pair of Goldenear Triton 7 at my local dealer.
I thought the Tritons had a great imaging. Cost $1150 a pair.
Then the dealer had me hear a pair of Mozart SEs. $1800 a pair. At first they didn't sound as good as the Tritons but I gave them a little more juice and they really came to life.
I'm looking a replacing my B&W 602 S3 and will use the new speakers for 70% music 30% movies. I'm tring to decide if the cost difference is worth it. Also not sure if my Emotiva XPA-200 is a good fit for the Mozart's.
The Mozart's did sound better but seem power hungry. I would love to hear your thoughts and comments.
Sammy 4k UN65HU9000 CURVED - Calman5 Calibrated" ----------- Oppo 103D for Blu Ray & SACD & DVD-A
Marantz SR6009 AVR & Rogue Audio Atlas Tube Amplification
Vienna Acoustics Mozart Grand SE--B&W HTM62 Center with Axiom QS4 surrounds ---------- SVS PB-1000 SUBWOOFER
al210 is offline
post #3079 of 3092 Old 11-14-2014, 07:33 AM
artur9's Avatar
Quoted: 103 Post(s)
Liked: 48
Originally Posted by al210 View Post
Here's my dilemma
I had listened to some Goldenears before selecting my Haydns. I thought they were a little too fatiguing for me. I couldn't imagine listening to them for very log. Even the audition was too much for me.
I don't know about power hungry but the VA do like power. I was originally powering mine with a Parasound A52 @125 W. I think that's equivalent to the XPA200? They sounded great but a little lean. So I think your XPA should be fine.
Then I used a Belles 150 HotRod. Man! Did that sound good. Those were 150W@ and, I think, stable down to 1-2 ohms. A kind of liquid sound, much richer than the Parasound.
Now I'm using a Krell @200W, KAV-300IL, and the speakers have opened up a little more. Back to leaner but I'm enjoying the additional detail the Krell brings. The Krell integrated seems more neutral than the other 2 amps were with a Cary Cinema 11 as preamp.
artur9 is offline
post #3080 of 3092 Old 11-14-2014, 07:37 AM
artur9's Avatar
Quoted: 103 Post(s)
Liked: 48
One other thing with the VA. Positioning is everything! I think there's a guide in this thread somewhere.
When positioned properly the soundstage is incredible.
In a nutshell, toe them in and tilt them back a little and the soundscape snaps into focus.
artur9 is offline
post #3081 of 3092 Old 11-19-2014, 12:25 PM
al210's Avatar
Quoted: 80 Post(s)
Liked: 62
Well I'm happy to report that I have just purchased a pair of Vienna Acoustics Mozart Grand SE in piano black from my local rep. During my speaker auditioning tour there was just something about the Mozart's laid back sound that won me over.
Now I wonder if there is some good info out there on proper setup for these guys. I see Patrick is no longer with Vienna.
al210 is offline
post #3082 of 3092 Old 11-22-2014, 09:14 AM
Raulka's Avatar
Red face
Originally Posted by ebug View Post
From "blood, toil, tears and sweat" ...well not exactly =). Welcome to my humble home. =) (Rel T2 hidden behind the right front).
ebug, I love your room (in post #2285 )! What type of the Waltz's console? This is not the original one, and I want something similar, because with the original console can't able to set the Waltz in same position like yours.
I take Concert Grand - Maestro Grand - Waltz Grand 5.0 next week.. I'm so excited..
Raulka is offline
post #3083 of 3092 Old 11-25-2014, 09:47 AM
ebug's Avatar
Thanks. Those are heavyduty door tee hinges I bought in Homedepot. I mount the hinge to the wall first, then mount the speaker next. I placed a felt pad between the speaker and hinge to protect the finish. You may need someone to help you.
ebug is offline
post #3084 of 3092 Old 12-05-2014, 10:26 AM
Raulka's Avatar
Wink
I made it like you, perfect solution!
Raulka is offline
post #3085 of 3092 Old 12-07-2014, 08:43 AM
Saril's Avatar
Quoted: 17 Post(s)
Google Sumiko or try this link:
http://www.audiocircle.com/index.php?topic=60819.0
I bought the CD and tried but did not make much progress. Some say it's like tuning a piano and requires a lot of skill. I've talked to a couple of dealers and one mentioned item that stood out was both stated the BBGs will sound better close to a wall or about 2 to 3 feet away; anything in between, e.g., 1 foot from wall, will be the worst possible location. After trying several positions, I also agree with this statement. I'm getting ready to dive into the REW rabbit hole and determine what my room is doing to these speakers. I am convinced that my issues are mostly room related and not gear.
I am driving them with Emotiva XPA-100 mono blocks and a Marantz AV8801. I have the Maestro for the CC and am also driving with the same mono block. I use the Emotiva XPA-200 for the surrounds.
The best thing I did to improve overall bass response was to add a second sub. I chose the SVS SB13 Ultra and it has absolutely blown me away. I use my setup for both music and movies. Both sound better with Audyssey multiEQ XT32 enabled.
I hope this helps and sorry for the long post.
Saril is offline
post #3086 of 3092 Old 12-21-2014, 05:17 AM
Shmalan's Avatar
Vienna Acoustics new website is finally up and running.
http://www.vienna-acoustics.com/
Arcam Fmj A38,Arcam Fmj CD17, Arcam rDac kw,Vienna Acoustics Mozart Grand Se,Rel R-328,Cardas Golden Presence and Crosslink ic's,Kimber 4tc,VH Audio power cords,Shunyata Venom PS8 & Defender & HC power cord, Furutech wall outlets.
Shmalan is offline
post #3087 of 3092 Old 12-21-2014, 04:09 PM
NV1
Liked: 0
***for sale***
I am selling my Vienna Accoustics 5 speaker system as well as some other audio goodies. It consists of 2 Beethoven Baby Grands, 1 Maestro Grand and 2 Waltz Grands. Also selling a Martin Logan Abyss subwoofer... All speakers come with original boxes, mounting brackets (waltz), grills and I am the original owner of everything. They were used for about 10 months then boxed up when I moved - kept in the house in a climate controlled closet and haven't been used since. They are all in excellent condition but unfortunately one of the Beethoven's has a very small chip in the finish. They sound fantastic and are excellent speakers. Piano Black. They were driven with an Anthem D2v and Anthem A5. (also selling the A5 if interested). Aside from the small chip in one of the Beethovens all speakers are in excellent condition. I am told the finish can be repaired by an experienced furniture repair specialist. Local pick up (Southern California).
BBG's: $1800
Waltz Grands (2): $700 for pair
Maestro Grand: $1000
Martin Logan Abyss: $500
Anthem A5: $2000
Also selling a one year old pair of Golden Ear Triton 2's excellent condition - sound amazing driven by an Anthem integrated 225 amp.
Golden Ear Triton 2's: $2000
Pure Power 1050: $1050
Thanks - feel free to pm me and ask any questions. Pictures coming soon.
NV1 is online now
post #3088 of 3092 Old 01-03-2015, 09:16 PM
artur9's Avatar
Quoted: 103 Post(s)
Liked: 48
The Liszt is on TAS' 2015 Buyer's Guide for floorstanders up to $20K.
Really makes me want a pair but I think they may be too large for my space. Do you think they'll come out with a Haydn-like member for the Imperial family?
artur9 is offline
post #3089 of 3092 Old 01-05-2015, 07:41 PM
justthinking's Avatar
How much difference is there between Haydn Grand and Haydn Grand SE??
Will you guys consider a mint condition Haydn Grand at $500 a good price or should I try to negotiate lower?
justthinking is offline
post #3090 of 3092 Old 01-06-2015, 06:29 AM
artur9's Avatar
Quoted: 103 Post(s)
Liked: 48
I found this detail at audioreview.
Some key differences between the "Haydn Grand" and "Haydn" model are:
a) bigger mid-woofer (6" vs 5.5")
b) front ported vs rear ported
c) bigger dimension all round
d) 4 ohm vs 6 ohm impedance
Then TAS said this about the Haydn Grand Commemorative Special Edition, which are the walnut ones.
At first glance the Special Edition seems fairly similar to the standard Haydn Grand, but closer inspection reveals the use of better mid-bass drivers, hot-rodded crossover components, a distinctive select walnut veneer finish, and one-of-a-kind rear panels featuring a silhouette of Joseph Haydn and a facsimile of his signature, plus hand-marked serial numbers.
To the best of my knowledge, the Grand Symphony Edition are the same as the Special Edition but without the special commemorative touches like the walnut and rear panels.
Love my Special Editions!
artur9 is offline
Reply Speakers
