Save me from a HTIB!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 04-07-2007, 06:35 PM - Thread Starter
dpak2005's Avatar
Ok so I'm going to throw this over to the experts. I have a main home theater room with the more expensive separate components, and I want to go much more minimalist for my living room. I have a 50" Panasonic plasma on the wall and I want either a small, inexpensive 5.1 system for the room.
Originally I thought I would go with a stylish 2.1 system like the Denon S101 or 301, but I really think I'd like 5.1. What I don't want is a home theater in a box.
Requirements:
$1000 budget max
No DVD player needed
5.1 (no 7.1) speakers
Speakers must be small and stylish
Need a receiver
So I'm essentially looking for something that would appear stylish and small like a HTIB without being one.
Any suggestions?
dpak2005 is offline
post #2 of 19 Old 04-07-2007, 06:43 PM
jostenmeat's Avatar
Hah! Too many to list. Might check out PSB Alpha sets. I've seen 5.1 PSB sets for $495 and up. People will drop names such as Ascend, BIC, Aperion, Monitor Audio, a whole bunch more. Gotta listen for yourself man. good luck!
Oh forgot to add, the PSB are not the sexiest. I think the money went towards sound. How stylish are we talking here? Ok, also Mission seems to be a "well-kept secret", will be near impossible to audition those without a US distributor. TSTO in Philly sells em. Also, not the sexiest, at least in that budget.
jostenmeat is offline
post #3 of 19 Old 04-07-2007, 06:43 PM
Captain Crunch's Avatar
http://www.svsound.com/products-sys-sbs_black.cfm
http://www.accessories4less.com/cgi-bin/item/ONKTXSR604
This is about the best I could come up with on your budget.
With the reviewer it puts you over your budget.
So you may want to get the front 3 speakers left, center, right and the sub, get the receiver and get the 2 surround sound speakers later.........
Captain Crunch is offline
post #4 of 19 Old 04-07-2007, 07:07 PM
ericgl's Avatar
Quoted: 25 Post(s)
Liked: 24
ericgl is offline
post #5 of 19 Old 04-07-2007, 07:59 PM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
Check out the Mission Cinema m70 Surround System for $240 from tsto.com
http://www.tsto.com/cgi-bin/TSTO.sto...duct/View/2229
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is offline
post #6 of 19 Old 04-07-2007, 08:25 PM - Thread Starter
dpak2005's Avatar
I think I might have found a winner guys. A little above my price range, but man these are stylish AND audiophile-grade. What do you think? Good choice?
http://www.amsound2.com/index.asp?Pa...ROD&ProdID=378
dpak2005 is offline
post #7 of 19 Old 04-07-2007, 08:28 PM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
I have not heard those, might be a good match for what you want. Maybe surf the web to see if you can get a better price. Good luck with your find.
post #8 of 19 Old 04-07-2007, 08:37 PM - Thread Starter
dpak2005's Avatar
Found some pictures of it in a room:
dpak2005 is offline
post #9 of 19 Old 04-07-2007, 08:40 PM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
Nice speakers and Ladies.
post #10 of 19 Old 04-07-2007, 08:47 PM
mazersteven's Avatar
mazersteven is offline
post #11 of 19 Old 04-07-2007, 08:47 PM - Thread Starter
dpak2005's Avatar
Ok guys, now that I've decided on speakers, I need to nag you about receivers for the speakers What I need is the cheapest possible receiver that will power this speaker set based on the following specs:
http://www.kef.com/kefamerica/ht3000/specifications.htm
There are specs for the surrounds, the center, and the sub.
I need absolutely no video options in the receiver, as I am connecting my HD-DVD player and all other components straight to my plasma. All I need is a cheap, good brand name receiver that can power this package sufficiently and can handle audio inputs from my HD-DVD player and cable box. Any suggestions?
Thank you so much for your help!!!
dpak2005 is offline
post #12 of 19 Old 04-07-2007, 08:51 PM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
Ok guys, now that I've decided on speakers, I need to nag you on receivers for the speakers What I need is, the cheapest possible receiver that will power this speaker set based on the following specs:
I need absolutely no video options in the receiver, as I am connecting my HD-DVD player and all other components straight to my plasma. All I need is a cheap, good brand name receiver that can power this package sufficiently. Any suggestions?
Check here: http://www.accessories4less.com/cgi-...ory/AVReceiver
or vanns.com, or one call.com,
post #13 of 19 Old 04-08-2007, 07:38 AM
one Call has some good prices on open box some times.
post #14 of 19 Old 04-08-2007, 10:13 AM
esaleris's Avatar
Try some Marantz products, especially older models. The newer ones started the x001 convention, where x = 4,5,6,7,8. The older ones had the xx00 convention, where xx = 53,54,55,56 etc.
esaleris is offline
post #15 of 19 Old 04-08-2007, 11:58 AM
ericgl's Avatar
Quoted: 25 Post(s)
Liked: 24
I can't speak to which KEF system is better, but have you seen this? http://www.vanns.com/shop/servlet/it...ures/544999293
I can second the Marantz recomendation, IIRC the receiver I linked earlier was tested and met specs.
ericgl is offline
post #16 of 19 Old 04-08-2007, 07:19 PM
blackacex2's Avatar
I'd just get the best stereo speakers you can buy, instead of going 5.1. I think you'll be more satisfied.
"If you put your mind to it, you can accomplish anything.."
blackacex2 is offline
post #17 of 19 Old 04-09-2007, 10:25 PM - Thread Starter
dpak2005's Avatar
Hey guys,
Well I wanted to give you an update. I decided to preorder an Onkyo 605 receiver for $399 to go along with the Kef 3005 speakers above I am also ordering. This is the new HDMI 1.3 receiver with Dolby TrueHD and DTS Master Audio all for $399!! I think this combination of speakers and receiver for a combined $1425 is going to blow people away! And its stylish too! I'm pretty excited. Thanks so much!!
dpak2005 is offline
post #18 of 19 Old 04-10-2007, 07:55 AM
unionmade's Avatar
A good friend has these, and it is a nice setup. once you are in this price range, I'd recommend you check out the orb People's choice. My opinion is subjective, but I much prefer my orbs for HT than my buddies KEFs. www.orbaudio.com
Plus, I think the orbs are far cooler looking.
Bryan
unionmade is offline
post #19 of 19 Old 04-10-2007, 07:58 AM
unionmade's Avatar
p.s. I got my receiver from American Theater, and recommend them highly.
Bryan
Reply Speakers
