Best way to splice speaker wire? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-12-2007, 08:07 AM - Thread Starter
Chip718's Avatar
Hi. I was wondering if anyone can tell me which is the best way to splice to pieces of speaker wires together? I ask because I have a speaker wire running under my carpet and it was cut. There is about 12" left and I was hoping someone can tell me the best way to connect a new piece to it. The problem I am having is that my rear speaker wires a sandwiched between paneling and sheetrock so I can simply pull a new cable trough. I am assuming there is no way to aviod quality loss, but I really have no other choice. Any info would be appreciated. Thanks
Chip718 is offline
post #2 of 7 Old 04-12-2007, 08:21 AM
jkhome's Avatar
Quoted: 98 Post(s)
Liked: 65
I'd use butt splice connectors (preferred pure copper inline splices), crimped on each end. Then seal with heat shrink tube.
jkhome is offline
post #3 of 7 Old 04-12-2007, 08:22 AM
quadriverfalls's Avatar
I would try to use the exact same wire that's there, remove the insulation, twist it together and wrap it with electrical tape. As long as the splice isn't somewhere where it can get jostled around.... you should be just fine.
John W.
Indy
quadriverfalls is offline
post #4 of 7 Old 04-12-2007, 08:24 AM
Even BETTER advice than mine....
John W.
Indy
post #5 of 7 Old 04-12-2007, 08:26 AM
madpoet's Avatar
French twist them together, solder them, then seal with heat shrink.
Someday maybe I'll actually WATCH my projector...
madpoet is offline
post #6 of 7 Old 04-12-2007, 06:08 PM
vfrjim's Avatar
ditto
Support C-band, the only true satellite signal, More information HERE
vfrjim is offline
post #7 of 7 Old 04-13-2007, 01:01 PM - Thread Starter
Chip718's Avatar
Thanks for all the advice
Chip718 is offline
Reply Speakers
