2 Audio Outputs into 1 Audio Input - AVS Forum | Home Theater Discussions And Reviews
Old 12-31-2000, 10:18 PM - Thread Starter
Mark II's Avatar
Was wanting to know if I could put 2 different audio sources outputs on one audio input. Would it be damaging to try and if so is there a simple way to do it correctly?
The reason I need to do this is because I am using audio equipment which does not have the ability to switch remotely i.e. I have to manually do the switch. I would like to just combine the 2 audio sources on one input.
Any help would be appreciatted.
Mark II
Mark II
I am a nobody, and nobody is perfect; am I therefore perfect?
Mark II is offline
Old 01-01-2001, 10:35 AM
Buzz Goddard's Avatar
Do NOT connect two outputs together. IN order to have them both connected to a single input you would nbeed to have a mixer or an auto-switcher.
Buzz Goddard
TAG Mclaren Audio
Buzz Goddard
GoddardGroup
Buzz Goddard is offline
Old 01-01-2001, 01:02 PM - Thread Starter
Mark II's Avatar
peepsdontlistentome,
I am using a older model spectrum analyzer/equailizer before my ssrcv. The ssrcv does not have a tape or adaptor loop to enable use of outside EQ. I would like to connect my DVD player and TV Tuner into one input on the analyzer/equailizer so I do not have to get up and manually switch the audio input between the two sources.
I knew it would work but also knew it would really not be the best way to do it. Thought there might be a easy way to add something home made in one or two of the line inputs to make it possible without the degrdation of signal.
Mark II
<FONT COLOR="#ffff00" SIZE="1" FACE="Verdana, Arial">This message has been edited by Mark II on 01-01-2001 at 04:03 PM</font>
Mark II
Mark II is offline
